martinb244
AirVPN running slow. High latency from servers.
Hello.
My downloads are taking much longer than usual and the streams I'm watching are lagging. I don't think it's my internet connection, but can I'm no expert.
Please advise.  Thank you.
. 2022.03.01 13:10:30 - OpenVPN > VERIFY KU OK
. 2022.03.01 13:10:30 - OpenVPN > Validating certificate extended key usage
. 2022.03.01 13:10:30 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.01 13:10:30 - OpenVPN > VERIFY EKU OK
. 2022.03.01 13:10:30 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.01 13:10:30 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 13:10:30 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 13:10:30 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.01 13:34:49 - Collect information about AirVPN completed
. 2022.03.01 14:10:15 - Above log line repeated 1 times more
. 2022.03.01 14:10:15 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.01 14:10:15 - OpenVPN > VERIFY KU OK
. 2022.03.01 14:10:15 - OpenVPN > Validating certificate extended key usage
. 2022.03.01 14:10:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.01 14:10:15 - OpenVPN > VERIFY EKU OK
. 2022.03.01 14:10:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.01 14:10:15 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 14:10:15 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 14:10:15 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.01 14:34:22 - Collect information about AirVPN completed
. 2022.03.01 15:10:01 - Above log line repeated 1 times more
. 2022.03.01 15:10:01 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.01 15:10:01 - OpenVPN > VERIFY KU OK
. 2022.03.01 15:10:01 - OpenVPN > Validating certificate extended key usage
. 2022.03.01 15:10:01 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.01 15:10:01 - OpenVPN > VERIFY EKU OK
. 2022.03.01 15:10:01 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.01 15:10:01 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 15:10:01 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 15:10:01 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.01 15:15:31 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #109465 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2022.03.01 15:34:20 - Collect information about AirVPN completed
. 2022.03.01 16:09:46 - Above log line repeated 1 times more
. 2022.03.01 16:09:46 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.01 16:09:46 - OpenVPN > VERIFY KU OK
. 2022.03.01 16:09:46 - OpenVPN > Validating certificate extended key usage
. 2022.03.01 16:09:46 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.01 16:09:46 - OpenVPN > VERIFY EKU OK
. 2022.03.01 16:09:46 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.01 16:09:46 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 16:09:46 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 16:09:46 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.01 16:34:28 - Collect information about AirVPN completed
. 2022.03.01 16:37:49 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #330408 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2022.03.01 17:04:31 - Collect information about AirVPN completed
. 2022.03.01 17:09:33 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.01 17:09:33 - OpenVPN > VERIFY KU OK
. 2022.03.01 17:09:33 - OpenVPN > Validating certificate extended key usage
. 2022.03.01 17:09:33 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.01 17:09:33 - OpenVPN > VERIFY EKU OK
. 2022.03.01 17:09:33 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.01 17:09:33 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 17:09:33 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 17:09:33 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.01 17:34:28 - Collect information about AirVPN completed
. 2022.03.01 18:09:20 - Above log line repeated 1 times more
. 2022.03.01 18:09:20 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.01 18:09:20 - OpenVPN > VERIFY KU OK
. 2022.03.01 18:09:20 - OpenVPN > Validating certificate extended key usage
. 2022.03.01 18:09:20 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.01 18:09:20 - OpenVPN > VERIFY EKU OK
. 2022.03.01 18:09:20 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.01 18:09:20 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 18:09:20 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 18:09:20 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.01 18:34:36 - Collect information about AirVPN completed
. 2022.03.01 19:09:06 - Above log line repeated 1 times more
. 2022.03.01 19:09:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.01 19:09:06 - OpenVPN > VERIFY KU OK
. 2022.03.01 19:09:06 - OpenVPN > Validating certificate extended key usage
. 2022.03.01 19:09:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.01 19:09:06 - OpenVPN > VERIFY EKU OK
. 2022.03.01 19:09:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.01 19:09:06 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 19:09:06 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 19:09:06 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.01 19:34:45 - Collect information about AirVPN completed
. 2022.03.01 20:08:53 - Above log line repeated 1 times more
. 2022.03.01 20:08:53 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.01 20:08:53 - OpenVPN > VERIFY KU OK
. 2022.03.01 20:08:53 - OpenVPN > Validating certificate extended key usage
. 2022.03.01 20:08:53 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.01 20:08:53 - OpenVPN > VERIFY EKU OK
. 2022.03.01 20:08:53 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.01 20:08:53 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 20:08:53 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 20:08:53 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.01 20:34:49 - Collect information about AirVPN completed
. 2022.03.01 21:08:38 - Above log line repeated 1 times more
. 2022.03.01 21:08:38 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.01 21:08:38 - OpenVPN > VERIFY KU OK
. 2022.03.01 21:08:38 - OpenVPN > Validating certificate extended key usage
. 2022.03.01 21:08:38 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.01 21:08:38 - OpenVPN > VERIFY EKU OK
. 2022.03.01 21:08:38 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.01 21:08:38 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 21:08:38 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 21:08:38 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.01 21:34:52 - Collect information about AirVPN completed
. 2022.03.01 21:50:46 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #387926 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2022.03.01 22:04:58 - Collect information about AirVPN completed
. 2022.03.01 22:08:23 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.01 22:08:23 - OpenVPN > VERIFY KU OK
. 2022.03.01 22:08:23 - OpenVPN > Validating certificate extended key usage
. 2022.03.01 22:08:23 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.01 22:08:23 - OpenVPN > VERIFY EKU OK
. 2022.03.01 22:08:23 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.01 22:08:23 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 22:08:23 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 22:08:23 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.01 22:35:03 - Collect information about AirVPN completed
. 2022.03.01 23:08:09 - Above log line repeated 1 times more
. 2022.03.01 23:08:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.01 23:08:09 - OpenVPN > VERIFY KU OK
. 2022.03.01 23:08:09 - OpenVPN > Validating certificate extended key usage
. 2022.03.01 23:08:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.01 23:08:09 - OpenVPN > VERIFY EKU OK
. 2022.03.01 23:08:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.01 23:08:09 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 23:08:09 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.01 23:08:09 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.01 23:35:13 - Collect information about AirVPN completed
. 2022.03.02 00:07:54 - Above log line repeated 1 times more
. 2022.03.02 00:07:54 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 00:07:54 - OpenVPN > VERIFY KU OK
. 2022.03.02 00:07:54 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 00:07:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 00:07:54 - OpenVPN > VERIFY EKU OK
. 2022.03.02 00:07:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.02 00:07:54 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 00:07:54 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 00:07:54 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 00:35:17 - Collect information about AirVPN completed
. 2022.03.02 01:07:41 - Above log line repeated 1 times more
. 2022.03.02 01:07:41 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 01:07:41 - OpenVPN > VERIFY KU OK
. 2022.03.02 01:07:41 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 01:07:41 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 01:07:41 - OpenVPN > VERIFY EKU OK
. 2022.03.02 01:07:41 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.02 01:07:41 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 01:07:41 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 01:07:41 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 01:35:24 - Collect information about AirVPN completed
. 2022.03.02 02:07:25 - Above log line repeated 1 times more
. 2022.03.02 02:07:25 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 02:07:25 - OpenVPN > VERIFY KU OK
. 2022.03.02 02:07:25 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 02:07:25 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 02:07:25 - OpenVPN > VERIFY EKU OK
. 2022.03.02 02:07:25 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.02 02:07:25 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 02:07:25 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 02:07:25 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 02:35:30 - Collect information about AirVPN completed
. 2022.03.02 03:07:10 - Above log line repeated 1 times more
. 2022.03.02 03:07:10 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 03:07:10 - OpenVPN > VERIFY KU OK
. 2022.03.02 03:07:10 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 03:07:10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 03:07:10 - OpenVPN > VERIFY EKU OK
. 2022.03.02 03:07:10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.02 03:07:10 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 03:07:10 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 03:07:10 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 03:35:39 - Collect information about AirVPN completed
. 2022.03.02 04:06:56 - Above log line repeated 1 times more
. 2022.03.02 04:06:56 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 04:06:56 - OpenVPN > VERIFY KU OK
. 2022.03.02 04:06:56 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 04:06:56 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 04:06:56 - OpenVPN > VERIFY EKU OK
. 2022.03.02 04:06:56 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.02 04:06:56 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 04:06:56 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 04:06:56 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 04:35:53 - Collect information about AirVPN completed
. 2022.03.02 05:06:46 - Above log line repeated 1 times more
. 2022.03.02 05:06:46 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 05:06:46 - OpenVPN > VERIFY KU OK
. 2022.03.02 05:06:46 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 05:06:46 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 05:06:46 - OpenVPN > VERIFY EKU OK
. 2022.03.02 05:06:46 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.02 05:06:46 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 05:06:46 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 05:06:46 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 05:35:59 - Collect information about AirVPN completed
. 2022.03.02 06:06:37 - Above log line repeated 1 times more
. 2022.03.02 06:06:37 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 06:06:37 - OpenVPN > VERIFY KU OK
. 2022.03.02 06:06:37 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 06:06:37 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 06:06:37 - OpenVPN > VERIFY EKU OK
. 2022.03.02 06:06:37 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.02 06:06:37 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 06:06:37 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 06:06:37 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 06:36:05 - Collect information about AirVPN completed
. 2022.03.02 07:06:23 - Above log line repeated 1 times more
. 2022.03.02 07:06:23 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 07:06:23 - OpenVPN > VERIFY KU OK
. 2022.03.02 07:06:23 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 07:06:23 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 07:06:23 - OpenVPN > VERIFY EKU OK
. 2022.03.02 07:06:23 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.02 07:06:23 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 07:06:23 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 07:06:23 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 07:36:11 - Collect information about AirVPN completed
. 2022.03.02 08:06:10 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 08:06:10 - OpenVPN > VERIFY KU OK
. 2022.03.02 08:06:10 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 08:06:10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 08:06:10 - OpenVPN > VERIFY EKU OK
. 2022.03.02 08:06:10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.02 08:06:11 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 08:06:11 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 08:06:11 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 08:06:24 - Collect information about AirVPN completed
! 2022.03.02 08:10:34 - Disconnecting
. 2022.03.02 08:10:34 - Routes, removed an existing route, 64.42.179.67 for gateway 10.23.18.1
. 2022.03.02 08:10:34 - Routes, removed an existing route, 2605:9f80:6000:81:290c:19de:1964:88cd for gateway fde6:7a:7d20:1312::1
. 2022.03.02 08:10:34 - Sending soft termination signal
. 2022.03.02 08:10:38 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2022.03.02 08:10:39 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 64.42.179.69 MASK 255.255.255.255 192.168.1.1
. 2022.03.02 08:10:39 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2022.03.02 08:10:39 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.23.18.1
. 2022.03.02 08:10:39 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.23.18.1
. 2022.03.02 08:10:39 - OpenVPN > delete_route_ipv6(::/3)
. 2022.03.02 08:10:39 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 13 fe80::8 store=active
. 2022.03.02 08:10:39 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2022.03.02 08:10:40 - OpenVPN > delete_route_ipv6(2000::/4)
. 2022.03.02 08:10:40 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 13 fe80::8 store=active
. 2022.03.02 08:10:40 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2022.03.02 08:10:40 - OpenVPN > delete_route_ipv6(3000::/4)
. 2022.03.02 08:10:40 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 13 fe80::8 store=active
. 2022.03.02 08:10:40 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2022.03.02 08:10:40 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 13 fe80::8 store=active
. 2022.03.02 08:10:40 - OpenVPN > Closing TUN/TAP interface
. 2022.03.02 08:10:40 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 13 all
. 2022.03.02 08:10:40 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1312::/64)
. 2022.03.02 08:10:40 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1312::/64 13 fe80::8 store=active
. 2022.03.02 08:10:40 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 13 fde6:7a:7d20:1312::1005 store=active
. 2022.03.02 08:10:40 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete dns 13 all
. 2022.03.02 08:10:40 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 13 10.23.18.7 store=active
. 2022.03.02 08:10:41 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2022.03.02 08:10:41 - Connection terminated.
. 2022.03.02 08:10:41 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 3, to automatic)
. 2022.03.02 08:10:41 - DNS leak protection with packet filtering disabled.
. 2022.03.02 08:10:41 - Interface Local Area Connection 3 metric restored from 3 to Automatic, layer IPv4
. 2022.03.02 08:10:41 - Interface Local Area Connection 3 metric restored from 3 to Automatic, layer IPv6
I 2022.03.02 08:10:41 - Checking authorization ...
! 2022.03.02 08:10:43 - Connecting to Libra (United States of America, Atlanta, Georgia)
. 2022.03.02 08:10:43 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021
. 2022.03.02 08:10:43 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2022.03.02 08:10:43 - OpenVPN > library versions: OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10
. 2022.03.02 08:10:43 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.03.02 08:10:43 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.03.02 08:10:43 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.03.02 08:10:43 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.03.02 08:10:43 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]64.42.179.69:443
. 2022.03.02 08:10:43 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2022.03.02 08:10:43 - OpenVPN > UDP link local: (not bound)
. 2022.03.02 08:10:43 - OpenVPN > UDP link remote: [AF_INET]64.42.179.69:443
. 2022.03.02 08:10:43 - OpenVPN > TLS: Initial packet from [AF_INET]64.42.179.69:443, sid=bc13b078 7ebdf3f1
. 2022.03.02 08:10:44 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 08:10:44 - OpenVPN > VERIFY KU OK
. 2022.03.02 08:10:44 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 08:10:44 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 08:10:44 - OpenVPN > VERIFY EKU OK
. 2022.03.02 08:10:44 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.02 08:10:44 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 08:10:44 - OpenVPN > [Libra] Peer Connection Initiated with [AF_INET]64.42.179.69:443
. 2022.03.02 08:10:44 - OpenVPN > SENT CONTROL [Libra]: 'PUSH_REQUEST' (status=1)
. 2022.03.02 08:10:44 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.23.18.1,dhcp-option DNS6 fde6:7a:7d20:1312::1,tun-ipv6,route-gateway 10.23.18.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1312::1005/64 fde6:7a:7d20:1312::1,ifconfig 10.23.18.7 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2022.03.02 08:10:44 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2022.03.02 08:10:44 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.03.02 08:10:44 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2022.03.02 08:10:44 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.03.02 08:10:44 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.03.02 08:10:44 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.03.02 08:10:44 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.03.02 08:10:44 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2022.03.02 08:10:44 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2022.03.02 08:10:44 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2022.03.02 08:10:44 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 08:10:44 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 08:10:44 - OpenVPN > interactive service msg_channel=0
. 2022.03.02 08:10:44 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=21 HWADDR=e8:d0:fc:9b:f8:ff
. 2022.03.02 08:10:44 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2022.03.02 08:10:44 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found.   (code=1168)
. 2022.03.02 08:10:44 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2022.03.02 08:10:44 - OpenVPN > open_tun
. 2022.03.02 08:10:44 - OpenVPN > wintun device [Local Area Connection 3] opened
. 2022.03.02 08:10:44 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 13 static 10.23.18.7 255.255.255.0
. 2022.03.02 08:10:44 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 13 all
. 2022.03.02 08:10:45 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set dns 13 static 10.23.18.1 validate=no
. 2022.03.02 08:10:45 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 13 all
. 2022.03.02 08:10:45 - OpenVPN > IPv4 MTU set to 1500 on interface 13 using SetIpInterfaceEntry()
. 2022.03.02 08:10:45 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 13 fde6:7a:7d20:1312::1005/128 store=active
. 2022.03.02 08:10:46 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1312::/64 -> fde6:7a:7d20:1312::1005 metric 0) dev Local Area Connection 3
. 2022.03.02 08:10:46 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1312::/64 13 fe80::8 store=active
. 2022.03.02 08:10:46 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2022.03.02 08:10:46 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 13 all
. 2022.03.02 08:10:46 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 13 static fde6:7a:7d20:1312::1 validate=no
. 2022.03.02 08:10:46 - OpenVPN > IPv6 MTU set to 1500 on interface 13 using SetIpInterfaceEntry()
. 2022.03.02 08:10:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 64.42.179.69 MASK 255.255.255.255 192.168.1.1
. 2022.03.02 08:10:46 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2022.03.02 08:10:46 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2022.03.02 08:10:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.23.18.1
. 2022.03.02 08:10:46 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4
. 2022.03.02 08:10:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.23.18.1
. 2022.03.02 08:10:46 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1312::1 metric -1) dev Local Area Connection 3
. 2022.03.02 08:10:46 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 13 fe80::8 store=active
. 2022.03.02 08:10:46 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1312::1 metric -1) dev Local Area Connection 3
. 2022.03.02 08:10:46 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 13 fe80::8 store=active
. 2022.03.02 08:10:46 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1312::1 metric -1) dev Local Area Connection 3
. 2022.03.02 08:10:46 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 13 fe80::8 store=active
. 2022.03.02 08:10:46 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1312::1 metric -1) dev Local Area Connection 3
. 2022.03.02 08:10:46 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 13 fe80::8 store=active
. 2022.03.02 08:10:47 - Interface Local Area Connection 3 metric changed from Automatic to 3, layer IPv4
. 2022.03.02 08:10:47 - Interface Local Area Connection 3 metric changed from Automatic to 3, layer IPv6
. 2022.03.02 08:10:47 - DNS leak protection with packet filtering enabled.
. 2022.03.02 08:10:48 - DNS IPv6 of a network adapter forced (Local Area Connection 3, from automatic to fde6:7a:7d20:1312::1)
. 2022.03.02 08:10:48 - Routes, restored a previously deleted route, 64.42.179.67 for gateway 10.23.18.1
. 2022.03.02 08:10:49 - Routes, restored a previously deleted route, 2605:9f80:6000:81:290c:19de:1964:88cd for gateway fde6:7a:7d20:1312::1
. 2022.03.02 08:10:49 - Flushing DNS
I 2022.03.02 08:10:49 - Checking route IPv4
I 2022.03.02 08:10:52 - Checking route IPv6
I 2022.03.02 08:10:54 - Checking DNS
! 2022.03.02 08:10:56 - Connected.
. 2022.03.02 08:10:56 - OpenVPN > Initialization Sequence Completed
! 2022.03.02 08:28:53 - Disconnecting
. 2022.03.02 08:28:54 - Routes, removed an existing route, 64.42.179.67 for gateway 10.23.18.1
. 2022.03.02 08:28:54 - Routes, removed an existing route, 2605:9f80:6000:81:290c:19de:1964:88cd for gateway fde6:7a:7d20:1312::1
. 2022.03.02 08:28:54 - Sending soft termination signal
. 2022.03.02 08:28:57 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2022.03.02 08:28:59 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 64.42.179.69 MASK 255.255.255.255 192.168.1.1
. 2022.03.02 08:28:59 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2022.03.02 08:28:59 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.23.18.1
. 2022.03.02 08:28:59 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.23.18.1
. 2022.03.02 08:28:59 - OpenVPN > delete_route_ipv6(::/3)
. 2022.03.02 08:28:59 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 13 fe80::8 store=active
. 2022.03.02 08:28:59 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2022.03.02 08:28:59 - OpenVPN > delete_route_ipv6(2000::/4)
. 2022.03.02 08:28:59 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 13 fe80::8 store=active
. 2022.03.02 08:28:59 - OpenVPN > delete_route_ipv6(3000::/4)
. 2022.03.02 08:28:59 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 13 fe80::8 store=active
. 2022.03.02 08:28:59 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2022.03.02 08:28:59 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 13 fe80::8 store=active
. 2022.03.02 08:29:00 - OpenVPN > Closing TUN/TAP interface
. 2022.03.02 08:29:00 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 13 all
. 2022.03.02 08:29:00 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1312::/64)
. 2022.03.02 08:29:00 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1312::/64 13 fe80::8 store=active
. 2022.03.02 08:29:00 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 13 fde6:7a:7d20:1312::1005 store=active
. 2022.03.02 08:29:00 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete dns 13 all
. 2022.03.02 08:29:00 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 13 10.23.18.7 store=active
. 2022.03.02 08:29:00 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2022.03.02 08:29:00 - Connection terminated.
. 2022.03.02 08:29:00 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 3, to automatic)
. 2022.03.02 08:29:00 - DNS leak protection with packet filtering disabled.
. 2022.03.02 08:29:01 - Interface Local Area Connection 3 metric restored from 3 to Automatic, layer IPv4
. 2022.03.02 08:29:01 - Interface Local Area Connection 3 metric restored from 3 to Automatic, layer IPv6
. 2022.03.02 08:29:01 - Flushing DNS
! 2022.03.02 08:29:01 - Session terminated.
I 2022.03.02 08:29:18 - Session starting.
I 2022.03.02 08:29:19 - Checking authorization ...
! 2022.03.02 08:29:20 - Connecting to Libra (United States of America, Atlanta, Georgia)
. 2022.03.02 08:29:20 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021
. 2022.03.02 08:29:20 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2022.03.02 08:29:20 - OpenVPN > library versions: OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10
. 2022.03.02 08:29:20 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.03.02 08:29:20 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.03.02 08:29:20 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.03.02 08:29:20 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.03.02 08:29:20 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]64.42.179.69:443
. 2022.03.02 08:29:20 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2022.03.02 08:29:20 - OpenVPN > UDP link local: (not bound)
. 2022.03.02 08:29:20 - OpenVPN > UDP link remote: [AF_INET]64.42.179.69:443
. 2022.03.02 08:29:20 - OpenVPN > TLS: Initial packet from [AF_INET]64.42.179.69:443, sid=29870be4 c2cfd8eb
. 2022.03.02 08:29:21 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 08:29:21 - OpenVPN > VERIFY KU OK
. 2022.03.02 08:29:21 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 08:29:21 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 08:29:21 - OpenVPN > VERIFY EKU OK
. 2022.03.02 08:29:21 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2022.03.02 08:29:21 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 08:29:21 - OpenVPN > [Libra] Peer Connection Initiated with [AF_INET]64.42.179.69:443
. 2022.03.02 08:29:22 - OpenVPN > SENT CONTROL [Libra]: 'PUSH_REQUEST' (status=1)
. 2022.03.02 08:29:22 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.23.18.1,dhcp-option DNS6 fde6:7a:7d20:1312::1,tun-ipv6,route-gateway 10.23.18.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1312::1005/64 fde6:7a:7d20:1312::1,ifconfig 10.23.18.7 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2022.03.02 08:29:22 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2022.03.02 08:29:22 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.03.02 08:29:22 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2022.03.02 08:29:22 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.03.02 08:29:22 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.03.02 08:29:22 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.03.02 08:29:22 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.03.02 08:29:22 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2022.03.02 08:29:22 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2022.03.02 08:29:22 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2022.03.02 08:29:22 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 08:29:22 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 08:29:22 - OpenVPN > interactive service msg_channel=0
. 2022.03.02 08:29:22 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=21 HWADDR=e8:d0:fc:9b:f8:ff
. 2022.03.02 08:29:22 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2022.03.02 08:29:22 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found.   (code=1168)
. 2022.03.02 08:29:22 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2022.03.02 08:29:22 - OpenVPN > open_tun
. 2022.03.02 08:29:22 - OpenVPN > wintun device [Local Area Connection 3] opened
. 2022.03.02 08:29:22 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 13 static 10.23.18.7 255.255.255.0
. 2022.03.02 08:29:22 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 13 all
. 2022.03.02 08:29:22 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set dns 13 static 10.23.18.1 validate=no
. 2022.03.02 08:29:22 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 13 all
. 2022.03.02 08:29:23 - OpenVPN > IPv4 MTU set to 1500 on interface 13 using SetIpInterfaceEntry()
. 2022.03.02 08:29:23 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 13 fde6:7a:7d20:1312::1005/128 store=active
. 2022.03.02 08:29:23 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1312::/64 -> fde6:7a:7d20:1312::1005 metric 0) dev Local Area Connection 3
. 2022.03.02 08:29:23 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1312::/64 13 fe80::8 store=active
. 2022.03.02 08:29:23 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2022.03.02 08:29:23 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 13 all
. 2022.03.02 08:29:23 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 13 static fde6:7a:7d20:1312::1 validate=no
. 2022.03.02 08:29:23 - OpenVPN > IPv6 MTU set to 1500 on interface 13 using SetIpInterfaceEntry()
. 2022.03.02 08:29:23 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 64.42.179.69 MASK 255.255.255.255 192.168.1.1
. 2022.03.02 08:29:23 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2022.03.02 08:29:23 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2022.03.02 08:29:23 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.23.18.1
. 2022.03.02 08:29:23 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4
. 2022.03.02 08:29:23 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.23.18.1
. 2022.03.02 08:29:23 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1312::1 metric -1) dev Local Area Connection 3
. 2022.03.02 08:29:23 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 13 fe80::8 store=active
. 2022.03.02 08:29:23 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1312::1 metric -1) dev Local Area Connection 3
. 2022.03.02 08:29:23 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 13 fe80::8 store=active
. 2022.03.02 08:29:23 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1312::1 metric -1) dev Local Area Connection 3
. 2022.03.02 08:29:23 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 13 fe80::8 store=active
. 2022.03.02 08:29:23 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1312::1 metric -1) dev Local Area Connection 3
. 2022.03.02 08:29:23 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 13 fe80::8 store=active
. 2022.03.02 08:29:23 - Interface Local Area Connection 3 metric changed from Automatic to 3, layer IPv4
. 2022.03.02 08:29:23 - Interface Local Area Connection 3 metric changed from Automatic to 3, layer IPv6
. 2022.03.02 08:29:23 - DNS leak protection with packet filtering enabled.
. 2022.03.02 08:29:24 - DNS IPv6 of a network adapter forced (Local Area Connection 3, from automatic to fde6:7a:7d20:1312::1)
. 2022.03.02 08:29:24 - Routes, restored a previously deleted route, 64.42.179.67 for gateway 10.23.18.1
. 2022.03.02 08:29:24 - Routes, restored a previously deleted route, 2605:9f80:6000:81:290c:19de:1964:88cd for gateway fde6:7a:7d20:1312::1
. 2022.03.02 08:29:24 - Flushing DNS
I 2022.03.02 08:29:24 - Checking route IPv4
. 2022.03.02 08:29:25 - Fetch url error:Couldn't connect to server
. 2022.03.02 08:29:25 - Checking route (2° try)
I 2022.03.02 08:29:26 - Checking route IPv6
I 2022.03.02 08:29:27 - Checking DNS
! 2022.03.02 08:29:28 - Connected.
. 2022.03.02 08:29:28 - OpenVPN > Initialization Sequence Completed
! 2022.03.02 08:29:41 - Disconnecting
. 2022.03.02 08:29:41 - Routes, removed an existing route, 64.42.179.67 for gateway 10.23.18.1
. 2022.03.02 08:29:41 - Routes, removed an existing route, 2605:9f80:6000:81:290c:19de:1964:88cd for gateway fde6:7a:7d20:1312::1
. 2022.03.02 08:29:41 - Sending soft termination signal
. 2022.03.02 08:29:44 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2022.03.02 08:29:46 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 64.42.179.69 MASK 255.255.255.255 192.168.1.1
. 2022.03.02 08:29:46 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2022.03.02 08:29:46 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.23.18.1
. 2022.03.02 08:29:46 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.23.18.1
. 2022.03.02 08:29:46 - OpenVPN > delete_route_ipv6(::/3)
. 2022.03.02 08:29:46 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 13 fe80::8 store=active
. 2022.03.02 08:29:46 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2022.03.02 08:29:46 - OpenVPN > delete_route_ipv6(2000::/4)
. 2022.03.02 08:29:46 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 13 fe80::8 store=active
. 2022.03.02 08:29:47 - OpenVPN > delete_route_ipv6(3000::/4)
. 2022.03.02 08:29:47 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 13 fe80::8 store=active
. 2022.03.02 08:29:47 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2022.03.02 08:29:47 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2022.03.02 08:29:47 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 13 fe80::8 store=active
. 2022.03.02 08:29:47 - OpenVPN > Closing TUN/TAP interface
. 2022.03.02 08:29:47 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 13 all
. 2022.03.02 08:29:47 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1312::/64)
. 2022.03.02 08:29:47 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1312::/64 13 fe80::8 store=active
. 2022.03.02 08:29:47 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 13 fde6:7a:7d20:1312::1005 store=active
. 2022.03.02 08:29:47 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete dns 13 all
. 2022.03.02 08:29:47 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 13 10.23.18.7 store=active
. 2022.03.02 08:29:47 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2022.03.02 08:29:47 - Connection terminated.
. 2022.03.02 08:29:47 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 3, to automatic)
. 2022.03.02 08:29:47 - DNS leak protection with packet filtering disabled.
. 2022.03.02 08:29:48 - Interface Local Area Connection 3 metric restored from 3 to Automatic, layer IPv4
. 2022.03.02 08:29:48 - Interface Local Area Connection 3 metric restored from 3 to Automatic, layer IPv6
. 2022.03.02 08:29:48 - Flushing DNS
! 2022.03.02 08:29:48 - Session terminated.
! 2022.03.02 08:29:50 - Logged out.
I 2022.03.02 08:29:51 - Checking login ...
! 2022.03.02 08:29:52 - Logged in.
I 2022.03.02 08:30:28 - Session starting.
I 2022.03.02 08:30:28 - Checking authorization ...
! 2022.03.02 08:30:29 - Connecting to Avior (Canada, Toronto, Ontario)
. 2022.03.02 08:30:29 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021
. 2022.03.02 08:30:29 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2022.03.02 08:30:29 - OpenVPN > library versions: OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10
. 2022.03.02 08:30:29 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.03.02 08:30:29 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.03.02 08:30:29 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.03.02 08:30:29 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.03.02 08:30:29 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.237:443
. 2022.03.02 08:30:29 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2022.03.02 08:30:29 - OpenVPN > UDP link local: (not bound)
. 2022.03.02 08:30:29 - OpenVPN > UDP link remote: [AF_INET]184.75.223.237:443
. 2022.03.02 08:30:30 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.237:443, sid=ebf05db5 1c72e79d
. 2022.03.02 08:30:30 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 08:30:30 - OpenVPN > VERIFY KU OK
. 2022.03.02 08:30:30 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 08:30:30 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 08:30:30 - OpenVPN > VERIFY EKU OK
. 2022.03.02 08:30:30 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Avior, emailAddress=info@airvpn.org
. 2022.03.02 08:30:30 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 08:30:30 - OpenVPN > [Avior] Peer Connection Initiated with [AF_INET]184.75.223.237:443
. 2022.03.02 08:30:31 - OpenVPN > SENT CONTROL [Avior]: 'PUSH_REQUEST' (status=1)
. 2022.03.02 08:30:31 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.10.242.1,dhcp-option DNS6 fde6:7a:7d20:6f2::1,tun-ipv6,route-gateway 10.10.242.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:6f2::10c0/64 fde6:7a:7d20:6f2::1,ifconfig 10.10.242.194 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2022.03.02 08:30:31 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2022.03.02 08:30:31 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.03.02 08:30:31 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2022.03.02 08:30:31 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.03.02 08:30:31 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.03.02 08:30:31 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.03.02 08:30:31 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.03.02 08:30:31 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2022.03.02 08:30:31 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2022.03.02 08:30:31 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2022.03.02 08:30:31 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 08:30:31 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 08:30:31 - OpenVPN > interactive service msg_channel=0
. 2022.03.02 08:30:31 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=21 HWADDR=e8:d0:fc:9b:f8:ff
. 2022.03.02 08:30:31 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2022.03.02 08:30:31 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found.   (code=1168)
. 2022.03.02 08:30:31 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2022.03.02 08:30:31 - OpenVPN > open_tun
. 2022.03.02 08:30:32 - OpenVPN > wintun device [Local Area Connection 3] opened
. 2022.03.02 08:30:32 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 13 static 10.10.242.194 255.255.255.0
. 2022.03.02 08:30:32 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 13 all
. 2022.03.02 08:30:32 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set dns 13 static 10.10.242.1 validate=no
. 2022.03.02 08:30:32 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 13 all
. 2022.03.02 08:30:32 - OpenVPN > IPv4 MTU set to 1500 on interface 13 using SetIpInterfaceEntry()
. 2022.03.02 08:30:32 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 13 fde6:7a:7d20:6f2::10c0/128 store=active
. 2022.03.02 08:30:32 - OpenVPN > add_route_ipv6(fde6:7a:7d20:6f2::/64 -> fde6:7a:7d20:6f2::10c0 metric 0) dev Local Area Connection 3
. 2022.03.02 08:30:32 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:6f2::/64 13 fe80::8 store=active
. 2022.03.02 08:30:32 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2022.03.02 08:30:32 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 13 all
. 2022.03.02 08:30:32 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 13 static fde6:7a:7d20:6f2::1 validate=no
. 2022.03.02 08:30:32 - OpenVPN > IPv6 MTU set to 1500 on interface 13 using SetIpInterfaceEntry()
. 2022.03.02 08:30:32 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.223.237 MASK 255.255.255.255 192.168.1.1
. 2022.03.02 08:30:32 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2022.03.02 08:30:32 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2022.03.02 08:30:32 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.10.242.1
. 2022.03.02 08:30:32 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4
. 2022.03.02 08:30:32 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.10.242.1
. 2022.03.02 08:30:32 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:6f2::1 metric -1) dev Local Area Connection 3
. 2022.03.02 08:30:32 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 13 fe80::8 store=active
. 2022.03.02 08:30:32 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:6f2::1 metric -1) dev Local Area Connection 3
. 2022.03.02 08:30:32 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 13 fe80::8 store=active
. 2022.03.02 08:30:33 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:6f2::1 metric -1) dev Local Area Connection 3
. 2022.03.02 08:30:33 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 13 fe80::8 store=active
. 2022.03.02 08:30:33 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2022.03.02 08:30:33 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:6f2::1 metric -1) dev Local Area Connection 3
. 2022.03.02 08:30:33 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 13 fe80::8 store=active
. 2022.03.02 08:30:33 - Interface Local Area Connection 3 metric changed from Automatic to 3, layer IPv4
. 2022.03.02 08:30:33 - Interface Local Area Connection 3 metric changed from Automatic to 3, layer IPv6
. 2022.03.02 08:30:33 - DNS leak protection with packet filtering enabled.
. 2022.03.02 08:30:34 - DNS IPv6 of a network adapter forced (Local Area Connection 3, from automatic to fde6:7a:7d20:6f2::1)
. 2022.03.02 08:30:34 - Routes, added a new route, 184.75.223.235 for gateway 10.10.242.1
. 2022.03.02 08:30:34 - Routes, added a new route, 2606:6080:1002:9:ffc4:b9c1:20ad:82f9 for gateway fde6:7a:7d20:6f2::1
. 2022.03.02 08:30:34 - Flushing DNS
I 2022.03.02 08:30:34 - Checking route IPv4
. 2022.03.02 08:30:34 - Fetch url error:Couldn't connect to server
. 2022.03.02 08:30:34 - Checking route (2° try)
I 2022.03.02 08:30:36 - Checking route IPv6
I 2022.03.02 08:30:37 - Checking DNS
! 2022.03.02 08:30:39 - Connected.
. 2022.03.02 08:30:39 - OpenVPN > Initialization Sequence Completed
. 2022.03.02 08:36:24 - Collect information about AirVPN completed
. 2022.03.02 09:26:42 - Above log line repeated 1 times more
. 2022.03.02 09:26:42 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 09:26:42 - OpenVPN > VERIFY KU OK
. 2022.03.02 09:26:42 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 09:26:42 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 09:26:42 - OpenVPN > VERIFY EKU OK
. 2022.03.02 09:26:42 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Avior, emailAddress=info@airvpn.org
. 2022.03.02 09:26:49 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 09:26:49 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 09:26:49 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 09:36:35 - Collect information about AirVPN completed
. 2022.03.02 10:23:00 - Above log line repeated 1 times more
. 2022.03.02 10:23:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 10:23:00 - OpenVPN > VERIFY KU OK
. 2022.03.02 10:23:00 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 10:23:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 10:23:00 - OpenVPN > VERIFY EKU OK
. 2022.03.02 10:23:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Avior, emailAddress=info@airvpn.org
. 2022.03.02 10:23:00 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 10:23:00 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 10:23:00 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 10:36:51 - Collect information about AirVPN completed
. 2022.03.02 11:13:42 - Above log line repeated 1 times more
. 2022.03.02 11:13:42 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #5203957 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2022.03.02 11:13:42 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #5203958 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2022.03.02 11:19:13 - Above log line repeated 587 times more
. 2022.03.02 11:19:13 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 11:19:13 - OpenVPN > VERIFY KU OK
. 2022.03.02 11:19:13 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 11:19:13 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 11:19:13 - OpenVPN > VERIFY EKU OK
. 2022.03.02 11:19:13 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Avior, emailAddress=info@airvpn.org
. 2022.03.02 11:19:14 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 11:19:14 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 11:19:19 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 11:19:27 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #5667169 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2022.03.02 11:36:55 - Above log line repeated 211 times more
. 2022.03.02 11:36:55 - Collect information about AirVPN completed
. 2022.03.02 12:06:59 - Collect information about AirVPN completed
. 2022.03.02 12:07:27 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #4750492 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2022.03.02 12:15:25 - Above log line repeated 2275 times more
. 2022.03.02 12:15:25 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 12:15:25 - OpenVPN > VERIFY KU OK
. 2022.03.02 12:15:25 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 12:15:25 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 12:15:25 - OpenVPN > VERIFY EKU OK
. 2022.03.02 12:15:25 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Avior, emailAddress=info@airvpn.org
. 2022.03.02 12:15:25 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 12:15:25 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 12:15:25 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
! 2022.03.02 12:15:46 - Disconnecting
. 2022.03.02 12:15:47 - Routes, removed a route previously added, 184.75.223.235 for gateway 10.10.242.1
. 2022.03.02 12:15:47 - Routes, removed a route previously added, 2606:6080:1002:9:ffc4:b9c1:20ad:82f9 for gateway fde6:7a:7d20:6f2::1
. 2022.03.02 12:15:47 - Sending soft termination signal
. 2022.03.02 12:15:50 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2022.03.02 12:15:52 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 184.75.223.237 MASK 255.255.255.255 192.168.1.1
. 2022.03.02 12:15:52 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2022.03.02 12:15:52 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.10.242.1
. 2022.03.02 12:15:52 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.10.242.1
. 2022.03.02 12:15:52 - OpenVPN > delete_route_ipv6(::/3)
. 2022.03.02 12:15:52 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 13 fe80::8 store=active
. 2022.03.02 12:15:52 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2022.03.02 12:15:52 - OpenVPN > delete_route_ipv6(2000::/4)
. 2022.03.02 12:15:52 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 13 fe80::8 store=active
. 2022.03.02 12:15:52 - OpenVPN > delete_route_ipv6(3000::/4)
. 2022.03.02 12:15:52 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 13 fe80::8 store=active
. 2022.03.02 12:15:52 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2022.03.02 12:15:52 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 13 fe80::8 store=active
. 2022.03.02 12:15:52 - OpenVPN > Closing TUN/TAP interface
. 2022.03.02 12:15:52 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 13 all
. 2022.03.02 12:15:52 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:6f2::/64)
. 2022.03.02 12:15:52 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:6f2::/64 13 fe80::8 store=active
. 2022.03.02 12:15:52 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 13 fde6:7a:7d20:6f2::10c0 store=active
. 2022.03.02 12:15:52 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete dns 13 all
. 2022.03.02 12:15:52 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 13 10.10.242.194 store=active
. 2022.03.02 12:15:53 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2022.03.02 12:15:53 - Connection terminated.
. 2022.03.02 12:15:53 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 3, to automatic)
. 2022.03.02 12:15:53 - DNS leak protection with packet filtering disabled.
. 2022.03.02 12:15:53 - Interface Local Area Connection 3 metric restored from 3 to Automatic, layer IPv4
. 2022.03.02 12:15:53 - Interface Local Area Connection 3 metric restored from 3 to Automatic, layer IPv6
. 2022.03.02 12:15:53 - Flushing DNS
! 2022.03.02 12:15:53 - Session terminated.
. 2022.03.02 12:37:03 - Collect information about AirVPN completed
. 2022.03.02 17:39:00 - Above log line repeated 10 times more
! 2022.03.02 17:39:00 - Logged out.
I 2022.03.02 17:39:00 - Checking login ...
! 2022.03.02 17:39:05 - Logged in.
I 2022.03.02 17:39:17 - Session starting.
I 2022.03.02 17:39:18 - Checking authorization ...
! 2022.03.02 17:39:19 - Connecting to Yildun (United States of America, Miami)
. 2022.03.02 17:39:19 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021
. 2022.03.02 17:39:19 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2022.03.02 17:39:19 - OpenVPN > library versions: OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10
. 2022.03.02 17:39:19 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.03.02 17:39:19 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.03.02 17:39:19 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.03.02 17:39:19 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.03.02 17:39:19 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]173.44.55.181:443
. 2022.03.02 17:39:19 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2022.03.02 17:39:19 - OpenVPN > UDP link local: (not bound)
. 2022.03.02 17:39:19 - OpenVPN > UDP link remote: [AF_INET]173.44.55.181:443
. 2022.03.02 17:39:19 - OpenVPN > TLS: Initial packet from [AF_INET]173.44.55.181:443, sid=67bf84ce 1e1ed475
. 2022.03.02 17:39:21 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 17:39:21 - OpenVPN > VERIFY KU OK
. 2022.03.02 17:39:21 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 17:39:21 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 17:39:21 - OpenVPN > VERIFY EKU OK
. 2022.03.02 17:39:21 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Yildun, emailAddress=info@airvpn.org
. 2022.03.02 17:39:22 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 17:39:22 - OpenVPN > [Yildun] Peer Connection Initiated with [AF_INET]173.44.55.181:443
. 2022.03.02 17:39:23 - OpenVPN > SENT CONTROL [Yildun]: 'PUSH_REQUEST' (status=1)
. 2022.03.02 17:39:23 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.32.178.1,dhcp-option DNS6 fde6:7a:7d20:1cb2::1,tun-ipv6,route-gateway 10.32.178.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1cb2::1085/64 fde6:7a:7d20:1cb2::1,ifconfig 10.32.178.135 255.255.255.0,peer-id 7,cipher AES-256-GCM'
. 2022.03.02 17:39:23 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2022.03.02 17:39:23 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.03.02 17:39:23 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2022.03.02 17:39:23 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.03.02 17:39:23 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.03.02 17:39:23 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.03.02 17:39:23 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.03.02 17:39:23 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2022.03.02 17:39:23 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2022.03.02 17:39:23 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2022.03.02 17:39:23 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 17:39:23 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 17:39:23 - OpenVPN > interactive service msg_channel=0
. 2022.03.02 17:39:23 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=21 HWADDR=e8:d0:fc:9b:f8:ff
. 2022.03.02 17:39:23 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2022.03.02 17:39:23 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found.   (code=1168)
. 2022.03.02 17:39:23 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2022.03.02 17:39:23 - OpenVPN > open_tun
. 2022.03.02 17:39:23 - OpenVPN > wintun device [Local Area Connection 3] opened
. 2022.03.02 17:39:23 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 13 static 10.32.178.135 255.255.255.0
. 2022.03.02 17:39:23 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 13 all
. 2022.03.02 17:39:23 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set dns 13 static 10.32.178.1 validate=no
. 2022.03.02 17:39:24 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 13 all
. 2022.03.02 17:39:24 - OpenVPN > IPv4 MTU set to 1500 on interface 13 using SetIpInterfaceEntry()
. 2022.03.02 17:39:24 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 13 fde6:7a:7d20:1cb2::1085/128 store=active
. 2022.03.02 17:39:24 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1cb2::/64 -> fde6:7a:7d20:1cb2::1085 metric 0) dev Local Area Connection 3
. 2022.03.02 17:39:24 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1cb2::/64 13 fe80::8 store=active
. 2022.03.02 17:39:24 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2022.03.02 17:39:24 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 13 all
. 2022.03.02 17:39:24 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 13 static fde6:7a:7d20:1cb2::1 validate=no
. 2022.03.02 17:39:24 - OpenVPN > IPv6 MTU set to 1500 on interface 13 using SetIpInterfaceEntry()
. 2022.03.02 17:39:24 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 173.44.55.181 MASK 255.255.255.255 192.168.1.1
. 2022.03.02 17:39:24 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2022.03.02 17:39:24 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2022.03.02 17:39:24 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.32.178.1
. 2022.03.02 17:39:24 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4
. 2022.03.02 17:39:24 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.32.178.1
. 2022.03.02 17:39:24 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1cb2::1 metric -1) dev Local Area Connection 3
. 2022.03.02 17:39:24 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 13 fe80::8 store=active
. 2022.03.02 17:39:24 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1cb2::1 metric -1) dev Local Area Connection 3
. 2022.03.02 17:39:24 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 13 fe80::8 store=active
. 2022.03.02 17:39:24 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1cb2::1 metric -1) dev Local Area Connection 3
. 2022.03.02 17:39:24 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 13 fe80::8 store=active
. 2022.03.02 17:39:24 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1cb2::1 metric -1) dev Local Area Connection 3
. 2022.03.02 17:39:24 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 13 fe80::8 store=active
. 2022.03.02 17:39:25 - Interface Local Area Connection 3 metric changed from Automatic to 3, layer IPv4
. 2022.03.02 17:39:25 - Interface Local Area Connection 3 metric changed from Automatic to 3, layer IPv6
. 2022.03.02 17:39:25 - DNS leak protection with packet filtering enabled.
. 2022.03.02 17:39:25 - DNS IPv6 of a network adapter forced (Local Area Connection 3, from automatic to fde6:7a:7d20:1cb2::1)
. 2022.03.02 17:39:25 - Routes, added a new route, 173.44.55.179 for gateway 10.32.178.1
. 2022.03.02 17:39:26 - Routes, added a new route, 2607:ff48:aa81:201:1fe5:86ea:10ec:84cc for gateway fde6:7a:7d20:1cb2::1
. 2022.03.02 17:39:26 - Flushing DNS
I 2022.03.02 17:39:26 - Checking route IPv4
. 2022.03.02 17:39:26 - Fetch url error:Couldn't connect to server
. 2022.03.02 17:39:26 - Checking route (2° try)
I 2022.03.02 17:39:29 - Checking route IPv6
I 2022.03.02 17:39:30 - Checking DNS
! 2022.03.02 17:39:32 - Connected.
. 2022.03.02 17:39:32 - OpenVPN > Initialization Sequence Completed
. 2022.03.02 18:07:45 - Collect information about AirVPN completed
. 2022.03.02 18:37:03 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 18:37:03 - OpenVPN > VERIFY KU OK
. 2022.03.02 18:37:03 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 18:37:03 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 18:37:03 - OpenVPN > VERIFY EKU OK
. 2022.03.02 18:37:03 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Yildun, emailAddress=info@airvpn.org
. 2022.03.02 18:37:03 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 18:37:03 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 18:37:03 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 18:37:51 - Collect information about AirVPN completed
! 2022.03.02 18:59:45 - Disconnecting
. 2022.03.02 18:59:45 - Routes, removed a route previously added, 173.44.55.179 for gateway 10.32.178.1
. 2022.03.02 18:59:45 - Routes, removed a route previously added, 2607:ff48:aa81:201:1fe5:86ea:10ec:84cc for gateway fde6:7a:7d20:1cb2::1
. 2022.03.02 18:59:45 - Sending soft termination signal
. 2022.03.02 18:59:48 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2022.03.02 18:59:50 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 173.44.55.181 MASK 255.255.255.255 192.168.1.1
. 2022.03.02 18:59:50 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2022.03.02 18:59:50 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.32.178.1
. 2022.03.02 18:59:50 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.32.178.1
. 2022.03.02 18:59:50 - OpenVPN > delete_route_ipv6(::/3)
. 2022.03.02 18:59:50 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 13 fe80::8 store=active
. 2022.03.02 18:59:50 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2022.03.02 18:59:50 - OpenVPN > delete_route_ipv6(2000::/4)
. 2022.03.02 18:59:50 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 13 fe80::8 store=active
. 2022.03.02 18:59:50 - OpenVPN > delete_route_ipv6(3000::/4)
. 2022.03.02 18:59:50 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 13 fe80::8 store=active
. 2022.03.02 18:59:50 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2022.03.02 18:59:50 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 13 fe80::8 store=active
. 2022.03.02 18:59:50 - OpenVPN > Closing TUN/TAP interface
. 2022.03.02 18:59:50 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 13 all
. 2022.03.02 18:59:50 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1cb2::/64)
. 2022.03.02 18:59:50 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1cb2::/64 13 fe80::8 store=active
. 2022.03.02 18:59:50 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 13 fde6:7a:7d20:1cb2::1085 store=active
. 2022.03.02 18:59:50 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete dns 13 all
. 2022.03.02 18:59:51 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 13 10.32.178.135 store=active
. 2022.03.02 18:59:51 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2022.03.02 18:59:51 - Connection terminated.
. 2022.03.02 18:59:51 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 3, to automatic)
. 2022.03.02 18:59:51 - DNS leak protection with packet filtering disabled.
. 2022.03.02 18:59:52 - Interface Local Area Connection 3 metric restored from 3 to Automatic, layer IPv4
. 2022.03.02 18:59:52 - Interface Local Area Connection 3 metric restored from 3 to Automatic, layer IPv6
I 2022.03.02 18:59:52 - Checking authorization ...
. 2022.03.02 18:59:53 - IPv6 disabled with packet filtering.
! 2022.03.02 18:59:53 - Connecting to Metallah (United States of America, Pennsylvania)
. 2022.03.02 18:59:53 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021
. 2022.03.02 18:59:53 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2022.03.02 18:59:53 - OpenVPN > library versions: OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10
. 2022.03.02 18:59:53 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.03.02 18:59:53 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.03.02 18:59:53 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.03.02 18:59:53 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.03.02 18:59:53 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]156.96.151.134:443
. 2022.03.02 18:59:53 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2022.03.02 18:59:53 - OpenVPN > UDP link local: (not bound)
. 2022.03.02 18:59:53 - OpenVPN > UDP link remote: [AF_INET]156.96.151.134:443
. 2022.03.02 18:59:53 - OpenVPN > TLS: Initial packet from [AF_INET]156.96.151.134:443, sid=e7f9f223 7ddd3015
. 2022.03.02 18:59:53 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 18:59:53 - OpenVPN > VERIFY KU OK
. 2022.03.02 18:59:53 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 18:59:53 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 18:59:53 - OpenVPN > VERIFY EKU OK
. 2022.03.02 18:59:53 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Metallah, emailAddress=info@airvpn.org
. 2022.03.02 18:59:54 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 18:59:54 - OpenVPN > [Metallah] Peer Connection Initiated with [AF_INET]156.96.151.134:443
. 2022.03.02 18:59:55 - OpenVPN > SENT CONTROL [Metallah]: 'PUSH_REQUEST' (status=1)
. 2022.03.02 18:59:55 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.22.146.1,route-gateway 10.22.146.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.22.146.132 255.255.255.0,peer-id 7,cipher AES-256-GCM'
. 2022.03.02 18:59:55 - OpenVPN > Pushed option removed by filter: 'redirect-gateway def1 bypass-dhcp'
. 2022.03.02 18:59:55 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.03.02 18:59:55 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2022.03.02 18:59:55 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.03.02 18:59:55 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.03.02 18:59:55 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.03.02 18:59:55 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.03.02 18:59:55 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2022.03.02 18:59:55 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2022.03.02 18:59:55 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2022.03.02 18:59:55 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 18:59:55 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 18:59:55 - OpenVPN > interactive service msg_channel=0
. 2022.03.02 18:59:55 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=21 HWADDR=e8:d0:fc:9b:f8:ff
. 2022.03.02 18:59:55 - OpenVPN > open_tun
. 2022.03.02 18:59:55 - OpenVPN > wintun device [Local Area Connection 3] opened
. 2022.03.02 18:59:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 13 static 10.22.146.132 255.255.255.0
. 2022.03.02 18:59:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 13 all
. 2022.03.02 18:59:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set dns 13 static 10.22.146.1 validate=no
. 2022.03.02 18:59:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 13 all
. 2022.03.02 18:59:56 - OpenVPN > IPv4 MTU set to 1500 on interface 13 using SetIpInterfaceEntry()
. 2022.03.02 18:59:56 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 156.96.151.134 MASK 255.255.255.255 192.168.1.1
. 2022.03.02 18:59:56 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2022.03.02 18:59:56 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2022.03.02 18:59:56 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.22.146.1
. 2022.03.02 18:59:56 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4
. 2022.03.02 18:59:56 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.22.146.1
. 2022.03.02 18:59:56 - Interface Local Area Connection 3 metric changed from Automatic to 3, layer IPv4
. 2022.03.02 18:59:56 - Interface Local Area Connection 3 metric changed from Automatic to 3, layer IPv6
. 2022.03.02 18:59:56 - DNS leak protection with packet filtering enabled.
. 2022.03.02 18:59:57 - Routes, added a new route, 156.96.151.132 for gateway 10.22.146.1
. 2022.03.02 18:59:57 - Flushing DNS
I 2022.03.02 18:59:57 - Checking route IPv4
. 2022.03.02 18:59:57 - Fetch url error:Couldn't connect to server
. 2022.03.02 18:59:57 - Checking route (2° try)
. 2022.03.02 18:59:58 - Fetch url error:Couldn't connect to server
. 2022.03.02 18:59:58 - Checking route (3° try)
I 2022.03.02 19:00:02 - Checking DNS
! 2022.03.02 19:00:03 - Connected.
. 2022.03.02 19:00:03 - OpenVPN > Initialization Sequence Completed
! 2022.03.02 19:04:01 - Disconnecting
. 2022.03.02 19:04:01 - Routes, removed a route previously added, 156.96.151.132 for gateway 10.22.146.1
. 2022.03.02 19:04:01 - Sending soft termination signal
. 2022.03.02 19:04:05 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2022.03.02 19:04:07 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 156.96.151.134 MASK 255.255.255.255 192.168.1.1
. 2022.03.02 19:04:07 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2022.03.02 19:04:07 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.22.146.1
. 2022.03.02 19:04:07 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.22.146.1
. 2022.03.02 19:04:07 - OpenVPN > Closing TUN/TAP interface
. 2022.03.02 19:04:07 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete dns 13 all
. 2022.03.02 19:04:07 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 13 10.22.146.132 store=active
. 2022.03.02 19:04:07 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2022.03.02 19:04:07 - Connection terminated.
. 2022.03.02 19:04:08 - IPv6 restored with packet filtering.
. 2022.03.02 19:04:08 - DNS leak protection with packet filtering disabled.
. 2022.03.02 19:04:08 - Interface Local Area Connection 3 metric restored from 3 to Automatic, layer IPv4
. 2022.03.02 19:04:08 - Interface Local Area Connection 3 metric restored from 3 to Automatic, layer IPv6
. 2022.03.02 19:04:08 - Flushing DNS
! 2022.03.02 19:04:08 - Session terminated.
! 2022.03.02 19:04:10 - Logged out.
I 2022.03.02 19:04:15 - Checking login ...
! 2022.03.02 19:04:16 - Logged in.
I 2022.03.02 19:04:34 - Session starting.
I 2022.03.02 19:04:35 - Checking authorization ...
. 2022.03.02 19:04:37 - IPv6 disabled with packet filtering.
! 2022.03.02 19:04:37 - Connecting to Metallah (United States of America, Pennsylvania)
. 2022.03.02 19:04:38 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021
. 2022.03.02 19:04:38 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2022.03.02 19:04:38 - OpenVPN > library versions: OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10
. 2022.03.02 19:04:38 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.03.02 19:04:38 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.03.02 19:04:38 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.03.02 19:04:38 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.03.02 19:04:38 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]156.96.151.134:443
. 2022.03.02 19:04:38 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2022.03.02 19:04:38 - OpenVPN > UDP link local: (not bound)
. 2022.03.02 19:04:38 - OpenVPN > UDP link remote: [AF_INET]156.96.151.134:443
. 2022.03.02 19:04:38 - OpenVPN > TLS: Initial packet from [AF_INET]156.96.151.134:443, sid=9964b1d5 3376e0e1
. 2022.03.02 19:04:38 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.03.02 19:04:38 - OpenVPN > VERIFY KU OK
. 2022.03.02 19:04:38 - OpenVPN > Validating certificate extended key usage
. 2022.03.02 19:04:38 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.03.02 19:04:38 - OpenVPN > VERIFY EKU OK
. 2022.03.02 19:04:38 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Metallah, emailAddress=info@airvpn.org
. 2022.03.02 19:04:38 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2022.03.02 19:04:38 - OpenVPN > [Metallah] Peer Connection Initiated with [AF_INET]156.96.151.134:443
. 2022.03.02 19:04:39 - OpenVPN > SENT CONTROL [Metallah]: 'PUSH_REQUEST' (status=1)
. 2022.03.02 19:04:39 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.22.146.1,route-gateway 10.22.146.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.22.146.132 255.255.255.0,peer-id 7,cipher AES-256-GCM'
. 2022.03.02 19:04:39 - OpenVPN > Pushed option removed by filter: 'redirect-gateway def1 bypass-dhcp'
. 2022.03.02 19:04:39 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.03.02 19:04:39 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2022.03.02 19:04:39 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.03.02 19:04:39 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.03.02 19:04:39 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2022.03.02 19:04:39 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.03.02 19:04:39 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2022.03.02 19:04:39 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2022.03.02 19:04:39 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2022.03.02 19:04:39 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 19:04:39 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.03.02 19:04:39 - OpenVPN > interactive service msg_channel=0
. 2022.03.02 19:04:39 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=21 HWADDR=e8:d0:fc:9b:f8:ff
. 2022.03.02 19:04:39 - OpenVPN > open_tun
. 2022.03.02 19:04:39 - OpenVPN > wintun device [Local Area Connection 3] opened
. 2022.03.02 19:04:39 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 13 static 10.22.146.132 255.255.255.0
. 2022.03.02 19:04:39 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 13 all
. 2022.03.02 19:04:39 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set dns 13 static 10.22.146.1 validate=no
. 2022.03.02 19:04:39 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 13 all
. 2022.03.02 19:04:40 - OpenVPN > IPv4 MTU set to 1500 on interface 13 using SetIpInterfaceEntry()
. 2022.03.02 19:04:40 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 156.96.151.134 MASK 255.255.255.255 192.168.1.1
. 2022.03.02 19:04:40 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2022.03.02 19:04:40 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2022.03.02 19:04:40 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.22.146.1
. 2022.03.02 19:04:40 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4
. 2022.03.02 19:04:40 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.22.146.1
. 2022.03.02 19:04:40 - Interface Local Area Connection 3 metric changed from Automatic to 3, layer IPv4
. 2022.03.02 19:04:40 - Interface Local Area Connection 3 metric changed from Automatic to 3, layer IPv6
. 2022.03.02 19:04:40 - DNS leak protection with packet filtering enabled.
. 2022.03.02 19:04:41 - Routes, added a new route, 156.96.151.132 for gateway 10.22.146.1
. 2022.03.02 19:04:41 - Flushing DNS
I 2022.03.02 19:04:41 - Checking route IPv4
. 2022.03.02 19:04:41 - Fetch url error:Couldn't connect to server
. 2022.03.02 19:04:41 - Checking route (2° try)
. 2022.03.02 19:04:42 - Fetch url error:Couldn't connect to server
. 2022.03.02 19:04:42 - Checking route (3° try)
I 2022.03.02 19:04:46 - Checking DNS
! 2022.03.02 19:04:46 - Connected.
. 2022.03.02 19:04:46 - OpenVPN > Initialization Sequence Completed
. 2022.03.02 19:08:01 - Collect information about AirVPN completed
Edited ... by OpenSourcerer
Apply LOG format to logs
