I am setting up AirVPN through OpenVPN on a raspberry pi, with ufw as a killswitch. I am new to all of this, but here is what I have so far.
Here is the output of ufw status, showing rules. The ufw default is to deny all incoming and outgoing traffic.
To                           Action      From
Anywhere              ALLOW    127.0.0.1
Anywhere              ALLOW       172.16.0.0/16
172.16.0.0/16           ALLOW       Anywhere
Anywhere on tun0  ALLOW       Anywhere
443                         ALLOW       Anywhere
Anywhere on tun  ALLOW       Anywhere
Anywhere (v6) on tun0   ALLOW       Anywhere (v6)
443 (v6)                  ALLOW       Anywhere (v6)
Anywhere (v6) on tun  ALLOW       Anywhere (v6)
Anywhere               ALLOW OUT   Anywhere on tun0
53                            ALLOW OUT   Anywhere
Anywhere (v6)        ALLOW OUT   Anywhere (v6) on tun0
53 (v6)                     ALLOW OUT   Anywhere (v6)
The local network and loopback are allowed. VPN traffic, on tun0 is allowed. Port 53 is allowed for DNS.
Here is my ovpn config file. Comes from the config generator, but with the up and down script for systemd added.
client
dev tun
script-security 2
up /etc/openvpn/update-systemd-resolved
down /etc/openvpn/update-systemd-resolved
down-pre
remote america.vpn.airdns.org 443
resolv-retry infinite
nobind
persist-key
persist-tun
auth-nocache
route-delay 5
verb 3
explicit-exit-notify 5
push-peer-info
setenv UV_IPV6 yes
remote-cert-tls server
cipher AES-256-CBC
comp-lzo no
proto udp
key-direction 1
<ca>
then keys.
With UFW disabled, openvpn works. When ufw is turned on while vpn is running, I get the repeating message:
2022-02-08 23:44:57 write UDP: Operation not permitted (code=1)
and the connection does not work.
Thanks in advance for any help :)
Some additional information from /var/log/ufw.log, many entries of the following 2 lines:
Feb  3 23:47:13 raspberrypi-### kernel: [ 1196.775603] [UFW BLOCK] IN=eth0 OUT= MAC=33:33:00:01:00:03:cc:48:3a:48:84:e6:86:dd SRC=fe80:0000:0000:0000:904b:2a9a:273a:1515 DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=70 TC=0 HOPLIMIT=1 FLOWLBL=301632 PROTO=UDP SPT=58606 DPT=5355 LEN=30
and its opposite (i think - out on eth0):
Feb  3 23:47:10 raspberrypi-### kernel: [ 1193.191846] [UFW BLOCK] IN= OUT=eth0 SRC=172.28.44.39 DST=172.28.47.255 LEN=49 TOS=0x00 PREC=0x00 TTL=64 ID=59073 DF PROTO=UDP SPT=42969 DPT=32412 LEN=29
can post full log if helpful.
