Not connected, Your IP: 216.73.216.117
blacksadcamel
[Proposal] WindowsSpyBlocker hosts lists
  • Name: WindowsSpyBlocker hosts lists (extra/spy/update)
  • Description : Used to help reduce Microsoft spying and tracking on Windows systems.
  • License: MIT
  • A raw URL which our system can fetch from periodically in order to build the list: There are many list formats supplied for different applications (hosts file, openwrt, resolved ips, dnscrypt, etc)
I suppose the best fitting for your dns filtering systems would be the dnscrypt list, which includes only the domain names with wildcards.
WindowsSpyBlocker Spy rules
Spy rules block Windows telemetry
https://raw.githubusercontent.com/crazy-max/WindowsSpyBlocker/master/data/dnscrypt/spy.txt
WindowsSpyBlocker Update rules
Update rules block Windows Update
https://raw.githubusercontent.com/crazy-max/WindowsSpyBlocker/master/data/dnscrypt/update.txt
WindowsSpyBlocker Extra rules
Block third party applications like Skype, Bing, Live, Outlook, NCSI, Microsoft Office.
Be aware that these rules can also block Windows Update and other services.
https://raw.githubusercontent.com/crazy-max/WindowsSpyBlocker/master/data/dnscrypt/extra.txt
Other list formats can be found in their github repo:
https://github.com/crazy-max/WindowsSpyBlocker/tree/master/data
More information about the project can be found on the website (Let them know if you start using them, they will probably love it):
https://crazymax.dev/WindowsSpyBlocker/ Edited ... by blacksadcamel
