amw 0 Posted ... (edited) I can't get hummingbird to run anymore. Installing airvpn-suite only has bluetit fail with the same error. [amw@alarm hummingbird-linux-armv7l-1.1.2]$ sudo hummingbird -e Hummingbird - AirVPN OpenVPN 3 Client 1.1.2 - 4 June 2021 It seems this program did not exit gracefully or has been killed. Your system may not be working properly and your network connection may not work as expected. To recover your network settings, run this program again and use the "--recover-network" option.[amw@alarm hummingbird-linux-armv7l-1.1.2]$ sudo ls -la /etc/airvpn/ total 148 drwxr-xr-x 2 airvpn airvpn 4096 Oct 29 21:25 . drwxr-xr-x 65 root root 4096 Oct 29 21:26 .. -rw------- 1 airvpn airvpn 121378 Oct 29 21:09 airvpn-manifest.xml -rw------- 1 airvpn airvpn 2203 Oct 29 21:09 bluetit.rc -rw------- 1 airvpn airvpn 1439 Oct 29 21:09 connection_priority.txt -rw------- 1 airvpn airvpn 48 Oct 29 21:09 connection_sequence.csv -rw------- 1 airvpn airvpn 1743 Oct 29 21:09 country_continent.csv -rw------- 1 airvpn airvpn 3730 Oct 29 21:09 country_names.csv lrwxrwxrwx 1 airvpn airvpn 32 Jun 2 2019 resolv.conf.airvpnbackup -> /run/systemd/resolve/resolv.conf There is no lock file in my /etc/airvpn directory as above Edited ... by amw Quote Share this post Link to post
Tech Jedi Alex 1499 Posted ... Did you try --recover-network as you're told? You've got a .airvpnbackup symlink there. Run the option, or make sure your network is reset, then remove the symlink. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
amw 0 Posted ... (edited) Sorry, forgot to mention that. Yes I have run this. It does not detect any issues.Removing the symlink fixed the issue. Thanks! I seems like the --recover-network switch should remove this symlink when no issues are detected. Edited ... by amw Quote Share this post Link to post
Staff 10336 Posted ... @amw Hello! Bug noted, under investigation, thank you! Kind regards Quote Share this post Link to post
