OlDirty
Eddie stops working after upgrading from 2.16 to 2.20
It's in a loop of trying to connect...
. 2021.10.07 11:17:11 - Flushing DNS
I 2021.10.07 11:17:11 - Checking route IPv4
I 2021.10.07 11:17:11 - Checking route IPv6
. 2021.10.07 11:17:33 - Fetch url error:Timeout was reached
. 2021.10.07 11:17:33 - Checking route (2° try)
. 2021.10.07 11:17:55 - Fetch url error:Timeout was reached
. 2021.10.07 11:17:55 - Checking route (3° try)
. 2021.10.07 11:18:19 - Fetch url error:Timeout was reached
E 2021.10.07 11:18:19 - Checking route IPv6 failed.
. 2021.10.07 11:18:19 - OpenVPN > Initialization Sequence Completed
! 2021.10.07 11:18:19 - Disconnecting
Any suggestions on where to start looking?
Edit:
First I tried to change the "Interface used for connection" from "automatic" to my "internet" interface (I have another interface to connect to my NAS). But that didn't help.
Next I tried to change "Internet protocol used for connection" from "IPv4, IPv6" to "IPv4 only". Also that didn't help.
Finally I tried to change "Layer IPv6" from "Inside tunnel if supported, otherwise blocked" to "Blocked". And then it does work!
So something seems wrong with the IPv6 tunnel. Where to start looking to actually solve this? My router config?
edit2:
Although the VPN can now connect using IPv4 only, my browsers still can't surf the web somehow... I can however, for example, ping www.google.com..??
edit3:
After a reboot, also my browsers start working again...
Need more technical info from a support file. Reset everything to how it was (Layer IPv6 > Inside tunnel if supported, otherwise block; Internet Protocol > IPv4, IPv6; Interface > Automatic). Try a connection, then in Logs tab click the lifebelt icon and upload/paste the output here. Logs are included, don't redundantly post the logs as well.
Very strange...
I changed everything back, as you instructed, to gather the support file. But it now works??
Alright, then, a configurator's mistake, probably. If it ever happens again, try the support file :)
I've consistently had issues with Eddie and the TAP adapter. Then only thing I've found to work is running Eddie 2.16.3 and TAP 9.9.23. Even then, I have to prevent Eddie from updating the TAP adapter, and before every start or after each disconnect I have to shut it down and reinstall the adapter before starting Eddie or it will refuse to connect and just loop endlessly.
There is a switch in Eddie Preferences to prevent Eddie from upgrading TAP.
Also, if it's looping, why didn't you post in the forums or open a support ticket before? It doesn't loop silently, it logs errors still.
Frequently, the wintun driver can solve different problems caused by the TAP driver. If you have problems with the TAP driver (including installation issues), try and switch to the wintun one: in "Preferences" > "Advanced" window tick "Use wintun driver" then click "Save", finally re-start Eddie. Eddie 2.19 or higher version is required.
I actually meant to say that I already had the switch set in preferences, but my words came out wrong LOL
And to be honest, it's been like this for upwards of two years. At the time I couldn't find a solution on the forums and after the DAYS of sheer frustration fighting with it I just settled on the (admittedly less than optimal) workaround. I've been loathe to open the proverbial can of worms by messing with it again, but I may do just that now that you've suggested it.
Hello kind folk,
I don't wish to be perceived as a thread-hijacker, but the subject perfectly describes my problem. If the moderator(s) wish to move this to a new thread titled at their discretion, that's fine with me, and with my apologies.
I've been running 2.16 since it was released with no problem except slow network lock, on PCLinuxOS Mate, on an older Dell Inspiron, Win7 era. No DNS leaks, all good. It still serves me well.
When I try to start 2.20, and hit the "Connect to recommended server" button, Eddie goes into a loop I can't get out of without logging out of my Linux session. There's an endless series of "Connecting to <server>", "Disconnecting", "Unexpected: Network interface unknown". No matter how fast I try to close pop-ups, cancel the operation, or exit Eddie, the only escape is a logout or reboot. I have tried changing the Layer IPv6 from "inside tunnel..." to "Blocked"... and back... to no avail.
Here's the screen I see: <Screenshot, attached.>
When I start up 2.20, and extract the lifesaver file before I try to connect, here:
Eddie System/Environment Report - 10/12/2021 - 4:16 AM UTC
Eddie version: 2.20.0
Eddie OS build: linux_x64
Eddie architecture: x64
OS type: Linux
OS name: PCLinuxOS release 2021 (PCLinuxOS) for x86_64Kernel 5.13.10-pclos1 on a Dual-processor x86_64 / \l
OS version: Linux localhost.localdomain 5.13.10-pclos1 #1 SMP Thu Aug 12 21:59:41 CDT 2021 x86_64 x86_64 x86_64 GNU/Linux
OS architecture: x64
Mono /.Net Framework: 5.10.0.140 (tarball Sat Feb 24 15:30:44 UTC 2018); Framework: v4.0.30319
TUN driver: /dev/net/tun
OpenVPN: 2.5.1 - OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10 (/home/peter/Downloads/eddie-ui/bundle/openvpn)
Hummingbird: 3.3.2 - Hummingbird - AirVPN OpenVPN 3 Client 1.1.1 - 7 January 2020 (/home/peter/Downloads/eddie-ui/bundle/hummingbird)
SSH: /usr/bin/ssh: symbol lookup error: /usr/bin/ssh: undefined symbol: EVP_KDF_ctrl, version OPENSSL_1_1_1b (/usr/bin/ssh)
SSL: stunnel 5.56 (/home/peter/Downloads/eddie-ui/bundle/stunnel)
curl: 7.79.1 (/usr/bin/curl)
Profile path: /home/peter/Downloads/eddie-ui//default.profile
Data path: /home/peter/Downloads/eddie-ui/
Application path: /home/peter/Downloads/eddie-ui/bundle
Executable path: /home/peter/Downloads/eddie-ui/bundle/eddie-ui
Command line arguments: (1 args) path="/home/peter/Downloads/eddie-ui/"
Network Lock Active: No
Connected to VPN: No
Detected DNS: 192.168.0.1
Test DNS IPv4: Ok
Test DNS IPv6: Ok
Test Ping IPv4: 108 ms
Test Ping IPv6: Failed
Test HTTP IPv4: Ok
Test HTTP IPv6: Error: curl: (7) Failed to connect to 2a03:b0c0:2:d0::11b4:6001 port 80 after 2 ms: Network is unreachable
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
network.ipv6.mode: block
Logs:
. 2021.10.12 04:16:08 - Eddie version: 2.20.0 / linux_x64, System: Linux, Name: PCLinuxOS release 2021 (PCLinuxOS) for x86_64Kernel 5.13.10-pclos1 on a Dual-processor x86_64 / \l, Version: Linux localhost.localdomain 5.13.10-pclos1 #1 SMP Thu Aug 12 21:59:41 CDT 2021 x86_64 x86_64 x86_64 GNU/Linux, Mono/.Net: 5.10.0.140 (tarball Sat Feb 24 15:30:44 UTC 2018); Framework: v4.0.30319
. 2021.10.12 04:16:08 - Command line arguments (1): path="/home/peter/Downloads/eddie-ui/"
. 2021.10.12 04:16:08 - Raise system privileges
. 2021.10.12 04:16:16 - Profile path: /home/peter/Downloads/eddie-ui//default.profile
. 2021.10.12 04:16:17 - Reading options from /home/peter/Downloads/eddie-ui//default.profile
. 2021.10.12 04:16:20 - Tun Driver - /dev/net/tun
. 2021.10.12 04:16:20 - OpenVPN - Version: 2.5.1 - OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10 (/home/peter/Downloads/eddie-ui/bundle/openvpn)
. 2021.10.12 04:16:20 - SSH - Version: /usr/bin/ssh: symbol lookup error: /usr/bin/ssh: undefined symbol: EVP_KDF_ctrl, version OPENSSL_1_1_1b (/usr/bin/ssh)
. 2021.10.12 04:16:20 - SSL - Version: stunnel 5.56 (/home/peter/Downloads/eddie-ui/bundle/stunnel)
. 2021.10.12 04:16:20 - curl - Version: 7.79.1 (/usr/bin/curl)
. 2021.10.12 04:16:20 - Recovery. Unexpected crash?
. 2021.10.12 04:16:20 - IPv6 restored on network adapter (default)
. 2021.10.12 04:16:20 - IPv6 restored on network adapter (eth0)
I 2021.10.12 04:16:24 - Ready
. 2021.10.12 04:16:26 - Collect information about AirVPN completed
Network Interfaces and Routes:
    "support_ipv4": true,
    "support_ipv6": true,
    "routes": [
            "address": "0.0.0.0\/0",
            "gateway": "192.168.0.1",
            "interface": "eth0"
            "address": "::\/0",
            "gateway": "fe80::1a0f:76ff:fe7c:f8c2",
            "interface": "eth0",
            "metric": "1024"
    "interfaces": [
            "friendly": "lo",
            "id": "lo",
            "name": "lo",
            "description": "lo",
            "type": "Loopback",
            "status": "Unknown",
            "bytes_received": "2865916",
            "bytes_sent": "2865916",
            "ips": [
                "127.0.0.1",
                "::1"
            "gateways": [],
            "bind": true
            "friendly": "eth0",
            "id": "eth0",
            "name": "eth0",
            "description": "eth0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_received": "566777412",
            "bytes_sent": "62895089",
            "ips": [
                "192.168.0.117",
                "fe80::225:64ff:fe88:f0ac"
            "gateways": [
                "192.168.0.1",
            "bind": true
    "ipv4-default-gateway": "192.168.0.1",
    "ipv4-default-interface": "eth0",
    "ipv6-default-gateway": "fe80::1a0f:76ff:fe7c:f8c2",
    "ipv6-default-interface": "eth0"
ip addr show:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 00:25:64:88:f0:ac brd ff:ff:ff:ff:ff:ff
    inet 192.168.0.117/24 brd 192.168.0.255 scope global eth0
    inet6 fe80::225:64ff:fe88:f0ac/64 scope link
ip link show:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
ip -4 route show:
default via 192.168.0.1 dev eth0
127.0.0.0/8 dev lo scope link
169.254.0.0/16 dev eth0 scope link metric 1002
192.168.0.0/24 dev eth0 proto kernel scope link src 192.168.0.117
ip -6 route show:
unreachable ::/96 dev lo metric 1024 pref medium
unreachable ::ffff:0.0.0.0/96 dev lo metric 1024 pref medium
unreachable 2002:a00::/24 dev lo metric 1024 pref medium
unreachable 2002:7f00::/24 dev lo metric 1024 pref medium
unreachable 2002:a9fe::/32 dev lo metric 1024 pref medium
unreachable 2002:ac10::/28 dev lo metric 1024 pref medium
unreachable 2002:c0a8::/32 dev lo metric 1024 pref medium
unreachable 2002:e000::/19 dev lo metric 1024 pref medium
unreachable 3ffe:ffff::/32 dev lo metric 1024 pref medium
fe80::/64 dev eth0 proto kernel metric 256 pref medium
default via fe80::1a0f:76ff:fe7c:f8c2 dev eth0 proto ra metric 1024 expires 3580sec hoplimit 64 pref medium
When I start up 2.16, and do the same thing, here:
Eddie System/Environment Report - 10/12/2021 4:40 AM UTC
Eddie version: 2.16.3
OS type: Linux
Mono /.Net Framework: 4.6.2 (Stable 4.6.2.16/ac9e222); Framework: v4.0.30319
OpenVPN driver: Found, /dev/net/tun
OpenVPN: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (/home/peter/Downloads/eddie-ui_2.16.3_linux_x64_portable/eddie-ui_2.16.3_linux_x64_portable/openvpn)
SSH: OpenSSH_8.7p1, OpenSSL 1.1.1l  24 Aug 2021 (/usr/bin/ssh)
SSL: stunnel 5.40 (/home/peter/Downloads/eddie-ui_2.16.3_linux_x64_portable/eddie-ui_2.16.3_linux_x64_portable/stunnel)
Profile path: /home/peter/Downloads/eddie-ui_2.16.3_linux_x64_portable/eddie-ui_2.16.3_linux_x64_portable/default.xml
Data path: /home/peter/Downloads/eddie-ui_2.16.3_linux_x64_portable/eddie-ui_2.16.3_linux_x64_portable
Application path: /home/peter/Downloads/eddie-ui_2.16.3_linux_x64_portable/eddie-ui_2.16.3_linux_x64_portable
Executable path: /home/peter/Downloads/eddie-ui_2.16.3_linux_x64_portable/eddie-ui_2.16.3_linux_x64_portable/eddie-ui
Command line arguments: (2 args) console.mode="none" linux.dbus="unix:abstract=/tmp/dbus-3kX6kcssM3,guid=020347e1ef765ea9c63feb0261650f86"
Test DNS IPv4: Ok
Test DNS IPv6: Ok
Test Ping IPv4: 60 ms
Test Ping IPv6: -1 ms
Test HTTP IPv4: Ok
Test HTTP IPv6: Error:curl: (7) Failed to connect to ipv6.eddie.website port 80 after 218 ms: Network is unreachable
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
Logs:
. 2021.10.12 04:40:29 - Eddie version: 2.16.3 / linux_x64, System: Linux, Name: PCLinuxOS release 2021 (PCLinuxOS) for x86_64Kernel 5.13.10-pclos1 on a Dual-processor x86_64 / \l, Version: Linux localhost.localdomain 5.13.10-pclos1 #1 SMP Thu Aug 12 21:59:41 CDT 2021 x86_64 x86_64 x86_64 GNU/Linux, Mono/.Net: 4.6.2 (Stable 4.6.2.16/ac9e222); Framework: v4.0.30319
. 2021.10.12 04:40:29 - Reading options from /home/peter/Downloads/eddie-ui_2.16.3_linux_x64_portable/eddie-ui_2.16.3_linux_x64_portable/default.xml
. 2021.10.12 04:40:30 - Command line arguments (2): console.mode="none" linux.dbus="unix:abstract=/tmp/dbus-3kX6kcssM3,guid=020347e1ef765ea9c63feb0261650f86"
. 2021.10.12 04:40:30 - Profile path: /home/peter/Downloads/eddie-ui_2.16.3_linux_x64_portable/eddie-ui_2.16.3_linux_x64_portable/default.xml
. 2021.10.12 04:40:32 - OpenVPN Driver - Found, /dev/net/tun
. 2021.10.12 04:40:32 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (/home/peter/Downloads/eddie-ui_2.16.3_linux_x64_portable/eddie-ui_2.16.3_linux_x64_portable/openvpn)
. 2021.10.12 04:40:32 - SSH - Version: OpenSSH_8.7p1, OpenSSL 1.1.1l  24 Aug 2021 (/usr/bin/ssh)
. 2021.10.12 04:40:32 - SSL - Version: stunnel 5.40 (/home/peter/Downloads/eddie-ui_2.16.3_linux_x64_portable/eddie-ui_2.16.3_linux_x64_portable/stunnel)
. 2021.10.12 04:40:32 - curl - Version: 7.79.1 (/usr/bin/curl)
. 2021.10.12 04:40:32 - Certification Authorities: /home/peter/Downloads/eddie-ui_2.16.3_linux_x64_portable/eddie-ui_2.16.3_linux_x64_portable/res//cacert.pem
. 2021.10.12 04:40:32 - Updating systems & servers data ...
I 2021.10.12 04:40:32 - Ready
. 2021.10.12 04:40:34 - Systems & servers data update completed
    "routes": [
            "interface": "eth0"
            "address": "::\/0",
            "metric": "1024"
    "interfaces": [
            "friendly": "lo",
            "id": "lo",
            "name": "lo",
            "type": "Loopback",
            "bytes_received": "811509",
            "bytes_sent": "811509",
            "ips": [
                "127.0.0.1",
                "::1"
            "gateways": [],
            "bind": true
            "friendly": "eth0",
            "id": "eth0",
            "name": "eth0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_received": "1589811",
            "bytes_sent": "1275224",
            "ips": [
                "192.168.0.117",
            "gateways": [
                "192.168.0.1",
            "bind": true
UID: 0
Run as normal user: False; ID:0; Name:peter
ip addr show:
ip link show:
ip -4 route show:
ip -6 route show:
default via fe80::1a0f:76ff:fe7c:f8c2 dev eth0 proto ra metric 1024 expires 3559sec hoplimit 64 pref medium
Any suggestion? I emphasize that I am satisfied with 2.16.3, it works fine for me.
I'm not computer illiterate, I was writing BASIC and Z80 assembly language in the 1980s. But that changed from occupation to hobby. Now I'm a networking newbie, so please be gentle :).
I'm in over my head here, so any insights are appreciated with thanks.
Edited ... by Rational35
Removed narrative text from code block, minor edits.
Would be better if you logged the connection attempt, too. Either enable logging to file (Preferences > Logging > Logging on file enabled and Log debug) or launch eddie-ui in a terminal to have its output written to it. Then connect.
Also, this one I don't quite get:
Are you using portable Eddie versions?
Yes, I'm using portable Eddie versions.
Here's the log:
. 2021.10.13 04:55:58 - Shell(13) of '/usr/bin/secret-tool', 4 args: 'store';'--label='Eddie, saved password for c16996c0840d035da42ab07bc706743180d70a7e32f328bdc99846808e95e88c profile'';''Eddie Profile'';''c16996c0840d035da42ab07bc706743180d70a7e32f328bdc99846808e95e88c'';
. 2021.10.13 04:56:17 - Shell(13) done in 19465 ms, exit: 1, err: 'secret-tool: Object does not exist at path “/org/freedesktop/secrets/collection/login”'
I 2021.10.13 04:58:16 - Checking login ...
! 2021.10.13 04:58:18 - Logged in.
I 2021.10.13 04:58:31 - Session starting.
. 2021.10.13 04:58:32 - Waiting for latency tests (134 to go)
. 2021.10.13 04:58:34 - Waiting for latency tests (125 to go)
. 2021.10.13 04:58:35 - Waiting for latency tests (113 to go)
. 2021.10.13 04:58:36 - Waiting for latency tests (108 to go)
. 2021.10.13 04:58:39 - Waiting for latency tests (90 to go)
. 2021.10.13 04:58:40 - Waiting for latency tests (85 to go)
. 2021.10.13 04:58:43 - Waiting for latency tests (81 to go)
. 2021.10.13 04:58:45 - Waiting for latency tests (62 to go)
. 2021.10.13 04:58:46 - Waiting for latency tests (60 to go)
. 2021.10.13 04:58:47 - Waiting for latency tests (55 to go)
. 2021.10.13 04:58:48 - Waiting for latency tests (43 to go)
. 2021.10.13 04:58:49 - Waiting for latency tests (37 to go)
. 2021.10.13 04:58:50 - Waiting for latency tests (25 to go)
. 2021.10.13 04:58:51 - Waiting for latency tests (15 to go)
. 2021.10.13 04:58:53 - Waiting for latency tests (13 to go)
. 2021.10.13 04:58:54 - Waiting for latency tests (11 to go)
I 2021.10.13 04:58:55 - Checking authorization ...
! 2021.10.13 04:58:56 - Connecting to Agena (Canada, Toronto, Ontario)
. 2021.10.13 04:58:56 - OpenVPN > OpenVPN 2.5.1 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Mar  9 2021
. 2021.10.13 04:58:56 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2021.10.13 04:58:56 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.10.13 04:58:56 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.10.13 04:58:56 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.10.13 04:58:56 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.10.13 04:58:56 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.213:443
. 2021.10.13 04:58:56 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2021.10.13 04:58:56 - OpenVPN > UDP link local: (not bound)
. 2021.10.13 04:58:56 - OpenVPN > UDP link remote: [AF_INET]184.75.223.213:443
. 2021.10.13 04:58:56 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.213:443, sid=3d4bf742 e89b7f47
. 2021.10.13 04:58:57 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.10.13 04:58:57 - OpenVPN > VERIFY KU OK
. 2021.10.13 04:58:57 - OpenVPN > Validating certificate extended key usage
. 2021.10.13 04:58:57 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.10.13 04:58:57 - OpenVPN > VERIFY EKU OK
. 2021.10.13 04:58:57 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Agena, emailAddress=info@airvpn.org
. 2021.10.13 04:58:57 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.10.13 04:58:57 - OpenVPN > [Agena] Peer Connection Initiated with [AF_INET]184.75.223.213:443
. 2021.10.13 04:58:58 - OpenVPN > SENT CONTROL [Agena]: 'PUSH_REQUEST' (status=1)
. 2021.10.13 04:58:59 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.4.202.1,dhcp-option DNS6 fde6:7a:7d20:ca::1,tun-ipv6,route-gateway 10.4.202.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:ca::1030/64 fde6:7a:7d20:ca::1,ifconfig 10.4.202.50 255.255.255.0,peer-id 8,cipher AES-256-GCM'
. 2021.10.13 04:58:59 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.10.13 04:58:59 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.10.13 04:58:59 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.10.13 04:58:59 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.10.13 04:58:59 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.10.13 04:58:59 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.10.13 04:58:59 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.10.13 04:58:59 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.10.13 04:58:59 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.10.13 04:58:59 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.10.13 04:58:59 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.10.13 04:58:59 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.10.13 04:58:59 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=eth0 HWADDR=00:25:64:88:f0:ac
. 2021.10.13 04:58:59 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.10.13 04:58:59 - OpenVPN > net_route_v6_best_gw query: dst ::
. 2021.10.13 04:58:59 - OpenVPN > sitnl_send: rtnl: generic error (-113): No route to host
. 2021.10.13 04:58:59 - OpenVPN > ROUTE6: default_gateway=UNDEF
W 2021.10.13 04:58:59 - Unexpected: Network interface unknown - Stack:   at Eddie.Core.Threads.Session.CheckTunNetworkInterface (System.String id) [0x00090] in <2f7a356d3d534026978af9d9844a9374>:0
W 2021.10.13 04:58:59 -     at Eddie.Core.Threads.Session.ProcessLogEvent (System.String source, System.String message) [0x00b97] in <2f7a356d3d534026978af9d9844a9374>:0
. 2021.10.13 04:58:59 - OpenVPN > /bin/ip link set dev tun0 up mtu 1500
. 2021.10.13 04:58:59 - OpenVPN > Linux ip link set failed: could not execute external program
. 2021.10.13 04:58:59 - OpenVPN > Exiting due to fatal error
! 2021.10.13 04:58:59 - Disconnecting
. 2021.10.13 04:58:59 - Connection terminated.
. 2021.10.13 04:58:59 - Elevated: Command:dns-switch-rename-restore
I 2021.10.13 04:59:03 - Checking authorization ...
! 2021.10.13 04:59:03 - Connecting to Aludra (Canada, Toronto, Ontario)
. 2021.10.13 04:59:03 - Elevated: Command:process_openvpn
. 2021.10.13 04:59:03 - OpenVPN > OpenVPN 2.5.1 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Mar  9 2021
. 2021.10.13 04:59:03 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2021.10.13 04:59:03 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.10.13 04:59:03 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.10.13 04:59:03 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.10.13 04:59:03 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.10.13 04:59:03 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.205:443
. 2021.10.13 04:59:03 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2021.10.13 04:59:03 - OpenVPN > UDP link local: (not bound)
. 2021.10.13 04:59:03 - OpenVPN > UDP link remote: [AF_INET]104.254.90.205:443
. 2021.10.13 04:59:03 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.205:443, sid=9f1ddddd 71fe621c
. 2021.10.13 04:59:03 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.10.13 04:59:03 - OpenVPN > VERIFY KU OK
. 2021.10.13 04:59:03 - OpenVPN > Validating certificate extended key usage
. 2021.10.13 04:59:03 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.10.13 04:59:03 - OpenVPN > VERIFY EKU OK
. 2021.10.13 04:59:03 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Aludra, emailAddress=info@airvpn.org
. 2021.10.13 04:59:04 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.10.13 04:59:04 - OpenVPN > [Aludra] Peer Connection Initiated with [AF_INET]104.254.90.205:443
. 2021.10.13 04:59:04 - OpenVPN > SENT CONTROL [Aludra]: 'PUSH_REQUEST' (status=1)
. 2021.10.13 04:59:04 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.8.74.1,dhcp-option DNS6 fde6:7a:7d20:44a::1,tun-ipv6,route-gateway 10.8.74.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:44a::10bd/64 fde6:7a:7d20:44a::1,ifconfig 10.8.74.191 255.255.255.0,peer-id 6,cipher AES-256-GCM'
. 2021.10.13 04:59:04 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.10.13 04:59:04 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.10.13 04:59:04 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.10.13 04:59:04 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.10.13 04:59:04 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.10.13 04:59:04 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.10.13 04:59:04 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.10.13 04:59:04 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.10.13 04:59:04 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.10.13 04:59:04 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.10.13 04:59:04 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.10.13 04:59:04 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.10.13 04:59:04 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=eth0 HWADDR=00:25:64:88:f0:ac
. 2021.10.13 04:59:04 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.10.13 04:59:04 - OpenVPN > net_route_v6_best_gw query: dst ::
. 2021.10.13 04:59:04 - OpenVPN > sitnl_send: rtnl: generic error (-113): No route to host
. 2021.10.13 04:59:04 - OpenVPN > ROUTE6: default_gateway=UNDEF
W 2021.10.13 04:59:04 - Unexpected: Network interface unknown - Stack:   at Eddie.Core.Threads.Session.CheckTunNetworkInterface (System.String id) [0x00090] in <2f7a356d3d534026978af9d9844a9374>:0
W 2021.10.13 04:59:04 -     at Eddie.Core.Threads.Session.ProcessLogEvent (System.String source, System.String message) [0x00b97] in <2f7a356d3d534026978af9d9844a9374>:0
. 2021.10.13 04:59:04 - OpenVPN > /bin/ip link set dev tun0 up mtu 1500
. 2021.10.13 04:59:04 - OpenVPN > Linux ip link set failed: could not execute external program
. 2021.10.13 04:59:04 - OpenVPN > Exiting due to fatal error
! 2021.10.13 04:59:04 - Disconnecting
. 2021.10.13 04:59:04 - Sending soft termination signal
. 2021.10.13 04:59:04 - Elevated: Command:kill
. 2021.10.13 04:59:04 - Connection terminated.
. 2021.10.13 04:59:04 - Elevated: Command:dns-switch-rename-restore
I 2021.10.13 04:59:07 - Checking authorization ...
! 2021.10.13 04:59:08 - Connecting to Sharatan (Canada, Toronto, Ontario)
. 2021.10.13 04:59:08 - Elevated: Command:process_openvpn
. 2021.10.13 04:59:08 - OpenVPN > OpenVPN 2.5.1 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Mar  9 2021
. 2021.10.13 04:59:08 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2021.10.13 04:59:08 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.10.13 04:59:08 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.10.13 04:59:08 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.10.13 04:59:08 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.10.13 04:59:08 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.197:443
. 2021.10.13 04:59:08 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2021.10.13 04:59:08 - OpenVPN > UDP link local: (not bound)
. 2021.10.13 04:59:08 - OpenVPN > UDP link remote: [AF_INET]104.254.90.197:443
. 2021.10.13 04:59:08 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.197:443, sid=9cfc54d6 72479f91
. 2021.10.13 04:59:08 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.10.13 04:59:08 - OpenVPN > VERIFY KU OK
. 2021.10.13 04:59:08 - OpenVPN > Validating certificate extended key usage
. 2021.10.13 04:59:08 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.10.13 04:59:08 - OpenVPN > VERIFY EKU OK
. 2021.10.13 04:59:08 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sharatan, emailAddress=info@airvpn.org
. 2021.10.13 04:59:08 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.10.13 04:59:08 - OpenVPN > [Sharatan] Peer Connection Initiated with [AF_INET]104.254.90.197:443
. 2021.10.13 04:59:09 - OpenVPN > SENT CONTROL [Sharatan]: 'PUSH_REQUEST' (status=1)
. 2021.10.13 04:59:09 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.29.234.1,dhcp-option DNS6 fde6:7a:7d20:19ea::1,tun-ipv6,route-gateway 10.29.234.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:19ea::1033/64 fde6:7a:7d20:19ea::1,ifconfig 10.29.234.53 255.255.255.0,peer-id 5,cipher AES-256-GCM'
. 2021.10.13 04:59:09 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.10.13 04:59:09 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.10.13 04:59:09 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.10.13 04:59:09 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.10.13 04:59:09 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.10.13 04:59:09 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.10.13 04:59:09 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.10.13 04:59:09 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.10.13 04:59:09 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.10.13 04:59:09 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.10.13 04:59:09 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.10.13 04:59:09 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.10.13 04:59:09 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=eth0 HWADDR=00:25:64:88:f0:ac
. 2021.10.13 04:59:09 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.10.13 04:59:09 - OpenVPN > net_route_v6_best_gw query: dst ::
. 2021.10.13 04:59:09 - OpenVPN > sitnl_send: rtnl: generic error (-113): No route to host
. 2021.10.13 04:59:09 - OpenVPN > ROUTE6: default_gateway=UNDEF
W 2021.10.13 04:59:09 - Unexpected: Network interface unknown - Stack:   at Eddie.Core.Threads.Session.CheckTunNetworkInterface (System.String id) [0x00090] in <2f7a356d3d534026978af9d9844a9374>:0
W 2021.10.13 04:59:09 -     at Eddie.Core.Threads.Session.ProcessLogEvent (System.String source, System.String message) [0x00b97] in <2f7a356d3d534026978af9d9844a9374>:0
. 2021.10.13 04:59:09 - OpenVPN > /bin/ip link set dev tun0 up mtu 1500
. 2021.10.13 04:59:09 - OpenVPN > Linux ip link set failed: could not execute external program
. 2021.10.13 04:59:09 - OpenVPN > Exiting due to fatal error
! 2021.10.13 04:59:09 - Disconnecting
. 2021.10.13 04:59:09 - Sending soft termination signal
. 2021.10.13 04:59:09 - Elevated: Command:kill
. 2021.10.13 04:59:09 - Connection terminated.
. 2021.10.13 04:59:09 - Elevated: Command:dns-switch-rename-restore
I 2021.10.13 04:59:12 - Checking authorization ...
! 2021.10.13 04:59:14 - Connecting to Alhena (Canada, Toronto, Ontario)
. 2021.10.13 04:59:14 - Elevated: Command:process_openvpn
. 2021.10.13 04:59:14 - OpenVPN > OpenVPN 2.5.1 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Mar  9 2021
. 2021.10.13 04:59:14 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2021.10.13 04:59:14 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.10.13 04:59:14 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.10.13 04:59:14 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.10.13 04:59:14 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.10.13 04:59:14 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]162.219.176.5:443
. 2021.10.13 04:59:14 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2021.10.13 04:59:14 - OpenVPN > UDP link local: (not bound)
. 2021.10.13 04:59:14 - OpenVPN > UDP link remote: [AF_INET]162.219.176.5:443
. 2021.10.13 04:59:14 - OpenVPN > TLS: Initial packet from [AF_INET]162.219.176.5:443, sid=ed71a37c 474f8889
. 2021.10.13 04:59:14 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.10.13 04:59:14 - OpenVPN > VERIFY KU OK
. 2021.10.13 04:59:14 - OpenVPN > Validating certificate extended key usage
. 2021.10.13 04:59:14 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.10.13 04:59:14 - OpenVPN > VERIFY EKU OK
. 2021.10.13 04:59:14 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Alhena, emailAddress=info@airvpn.org
. 2021.10.13 04:59:14 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.10.13 04:59:14 - OpenVPN > [Alhena] Peer Connection Initiated with [AF_INET]162.219.176.5:443
. 2021.10.13 04:59:14 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.6.106.1,dhcp-option DNS6 fde6:7a:7d20:26a::1,tun-ipv6,route-gateway 10.6.106.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:26a::106e/64 fde6:7a:7d20:26a::1,ifconfig 10.6.106.112 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2021.10.13 04:59:14 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.10.13 04:59:14 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.10.13 04:59:14 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.10.13 04:59:14 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.10.13 04:59:14 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.10.13 04:59:14 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.10.13 04:59:14 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.10.13 04:59:14 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.10.13 04:59:14 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.10.13 04:59:14 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.10.13 04:59:14 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.10.13 04:59:14 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.10.13 04:59:14 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=eth0 HWADDR=00:25:64:88:f0:ac
. 2021.10.13 04:59:14 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.10.13 04:59:14 - OpenVPN > net_route_v6_best_gw query: dst ::
. 2021.10.13 04:59:14 - OpenVPN > sitnl_send: rtnl: generic error (-113): No route to host
. 2021.10.13 04:59:14 - OpenVPN > ROUTE6: default_gateway=UNDEF
W 2021.10.13 04:59:14 - Unexpected: Network interface unknown - Stack:   at Eddie.Core.Threads.Session.CheckTunNetworkInterface (System.String id) [0x00090] in <2f7a356d3d534026978af9d9844a9374>:0
W 2021.10.13 04:59:14 -     at Eddie.Core.Threads.Session.ProcessLogEvent (System.String source, System.String message) [0x00b97] in <2f7a356d3d534026978af9d9844a9374>:0
. 2021.10.13 04:59:14 - OpenVPN > /bin/ip link set dev tun0 up mtu 1500
. 2021.10.13 04:59:14 - OpenVPN > Linux ip link set failed: could not execute external program
. 2021.10.13 04:59:14 - OpenVPN > Exiting due to fatal error
! 2021.10.13 04:59:14 - Disconnecting
. 2021.10.13 04:59:14 - Sending soft termination signal
. 2021.10.13 04:59:14 - Elevated: Command:kill
. 2021.10.13 04:59:15 - Connection terminated.
. 2021.10.13 04:59:15 - Elevated: Command:dns-switch-rename-restore
I 2021.10.13 04:59:18 - Checking authorization ...
! 2021.10.13 04:59:19 - Connecting to Alphirk (Netherlands, Alblasserdam)
. 2021.10.13 04:59:19 - Elevated: Command:process_openvpn
. 2021.10.13 04:59:19 - OpenVPN > OpenVPN 2.5.1 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Mar  9 2021
. 2021.10.13 04:59:19 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2021.10.13 04:59:19 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.10.13 04:59:19 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.10.13 04:59:19 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.10.13 04:59:19 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.10.13 04:59:19 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.187.217:443
. 2021.10.13 04:59:19 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2021.10.13 04:59:19 - OpenVPN > UDP link local: (not bound)
. 2021.10.13 04:59:19 - OpenVPN > UDP link remote: [AF_INET]213.152.187.217:443
. 2021.10.13 04:59:19 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.187.217:443, sid=bd892177 5591f630
. 2021.10.13 04:59:19 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.10.13 04:59:19 - OpenVPN > VERIFY KU OK
. 2021.10.13 04:59:19 - OpenVPN > Validating certificate extended key usage
. 2021.10.13 04:59:19 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.10.13 04:59:19 - OpenVPN > VERIFY EKU OK
. 2021.10.13 04:59:19 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Alphirk, emailAddress=info@airvpn.org
. 2021.10.13 04:59:19 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.10.13 04:59:19 - OpenVPN > [Alphirk] Peer Connection Initiated with [AF_INET]213.152.187.217:443
. 2021.10.13 04:59:19 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.7.106.1,dhcp-option DNS6 fde6:7a:7d20:36a::1,tun-ipv6,route-gateway 10.7.106.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:36a::1017/64 fde6:7a:7d20:36a::1,ifconfig 10.7.106.25 255.255.255.0,peer-id 5,cipher AES-256-GCM'
. 2021.10.13 04:59:19 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.10.13 04:59:19 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.10.13 04:59:19 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.10.13 04:59:19 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.10.13 04:59:19 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.10.13 04:59:19 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.10.13 04:59:19 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.10.13 04:59:19 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.10.13 04:59:19 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.10.13 04:59:19 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.10.13 04:59:19 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.10.13 04:59:19 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.10.13 04:59:19 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=eth0 HWADDR=00:25:64:88:f0:ac
. 2021.10.13 04:59:19 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.10.13 04:59:19 - OpenVPN > net_route_v6_best_gw query: dst ::
. 2021.10.13 04:59:19 - OpenVPN > sitnl_send: rtnl: generic error (-113): No route to host
. 2021.10.13 04:59:19 - OpenVPN > ROUTE6: default_gateway=UNDEF
W 2021.10.13 04:59:19 - Unexpected: Network interface unknown - Stack:   at Eddie.Core.Threads.Session.CheckTunNetworkInterface (System.String id) [0x00090] in <2f7a356d3d534026978af9d9844a9374>:0
W 2021.10.13 04:59:19 -     at Eddie.Core.Threads.Session.ProcessLogEvent (System.String source, System.String message) [0x00b97] in <2f7a356d3d534026978af9d9844a9374>:0
. 2021.10.13 04:59:20 - OpenVPN > /bin/ip link set dev tun0 up mtu 1500
. 2021.10.13 04:59:20 - OpenVPN > Linux ip link set failed: could not execute external program
. 2021.10.13 04:59:20 - OpenVPN > Exiting due to fatal error
! 2021.10.13 04:59:20 - Disconnecting
. 2021.10.13 04:59:20 - Sending soft termination signal
. 2021.10.13 04:59:20 - Elevated: Command:kill
. 2021.10.13 04:59:20 - Connection terminated.
. 2021.10.13 04:59:20 - Elevated: Command:dns-switch-rename-restore
I 2021.10.13 04:59:23 - Checking authorization ...
! 2021.10.13 04:59:24 - Connecting to Lesath (Canada, Toronto, Ontario)
. 2021.10.13 04:59:24 - Elevated: Command:process_openvpn
. 2021.10.13 04:59:24 - OpenVPN > OpenVPN 2.5.1 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Mar  9 2021
. 2021.10.13 04:59:24 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2021.10.13 04:59:24 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.10.13 04:59:24 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.10.13 04:59:24 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.10.13 04:59:24 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.10.13 04:59:24 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.5:443
. 2021.10.13 04:59:24 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2021.10.13 04:59:24 - OpenVPN > UDP link local: (not bound)
. 2021.10.13 04:59:24 - OpenVPN > UDP link remote: [AF_INET]184.75.221.5:443
. 2021.10.13 04:59:24 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.5:443, sid=cea33d4d 57b744cc
. 2021.10.13 04:59:24 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.10.13 04:59:24 - OpenVPN > VERIFY KU OK
. 2021.10.13 04:59:24 - OpenVPN > Validating certificate extended key usage
. 2021.10.13 04:59:24 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.10.13 04:59:24 - OpenVPN > VERIFY EKU OK
. 2021.10.13 04:59:24 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Lesath, emailAddress=info@airvpn.org
. 2021.10.13 04:59:24 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.10.13 04:59:24 - OpenVPN > [Lesath] Peer Connection Initiated with [AF_INET]184.75.221.5:443
. 2021.10.13 04:59:24 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.20.234.1,dhcp-option DNS6 fde6:7a:7d20:10ea::1,tun-ipv6,route-gateway 10.20.234.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:10ea::106d/64 fde6:7a:7d20:10ea::1,ifconfig 10.20.234.111 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2021.10.13 04:59:24 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.10.13 04:59:24 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.10.13 04:59:24 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.10.13 04:59:24 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.10.13 04:59:24 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.10.13 04:59:24 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.10.13 04:59:24 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.10.13 04:59:24 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.10.13 04:59:24 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.10.13 04:59:24 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.10.13 04:59:24 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.10.13 04:59:24 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.10.13 04:59:24 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=eth0 HWADDR=00:25:64:88:f0:ac
. 2021.10.13 04:59:24 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.10.13 04:59:24 - OpenVPN > net_route_v6_best_gw query: dst ::
. 2021.10.13 04:59:24 - OpenVPN > sitnl_send: rtnl: generic error (-113): No route to host
. 2021.10.13 04:59:24 - OpenVPN > ROUTE6: default_gateway=UNDEF
W 2021.10.13 04:59:24 - Unexpected: Network interface unknown - Stack:   at Eddie.Core.Threads.Session.CheckTunNetworkInterface (System.String id) [0x00090] in <2f7a356d3d534026978af9d9844a9374>:0
W 2021.10.13 04:59:24 -     at Eddie.Core.Threads.Session.ProcessLogEvent (System.String source, System.String message) [0x00b97] in <2f7a356d3d534026978af9d9844a9374>:0
. 2021.10.13 04:59:24 - OpenVPN > /bin/ip link set dev tun0 up mtu 1500
. 2021.10.13 04:59:24 - OpenVPN > Linux ip link set failed: could not execute external program
. 2021.10.13 04:59:24 - OpenVPN > Exiting due to fatal error
! 2021.10.13 04:59:24 - Disconnecting
. 2021.10.13 04:59:24 - Sending soft termination signal
. 2021.10.13 04:59:24 - Elevated: Command:kill
. 2021.10.13 04:59:25 - Connection terminated.
. 2021.10.13 04:59:25 - Elevated: Command:dns-switch-rename-restore
I 2021.10.13 04:59:28 - Checking authorization ...
! 2021.10.13 04:59:28 - Connecting to Aljanah (Netherlands, Alblasserdam)
. 2021.10.13 04:59:28 - Elevated: Command:process_openvpn
. 2021.10.13 04:59:29 - OpenVPN > OpenVPN 2.5.1 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Mar  9 2021
. 2021.10.13 04:59:29 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2021.10.13 04:59:29 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.10.13 04:59:29 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.10.13 04:59:29 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.10.13 04:59:29 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.10.13 04:59:29 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]134.19.179.173:443
. 2021.10.13 04:59:29 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2021.10.13 04:59:29 - OpenVPN > UDP link local: (not bound)
. 2021.10.13 04:59:29 - OpenVPN > UDP link remote: [AF_INET]134.19.179.173:443
. 2021.10.13 04:59:29 - OpenVPN > TLS: Initial packet from [AF_INET]134.19.179.173:443, sid=1dcd7765 a7767a36
. 2021.10.13 04:59:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.10.13 04:59:29 - OpenVPN > VERIFY KU OK
. 2021.10.13 04:59:29 - OpenVPN > Validating certificate extended key usage
. 2021.10.13 04:59:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.10.13 04:59:29 - OpenVPN > VERIFY EKU OK
. 2021.10.13 04:59:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Aljanah, emailAddress=info@airvpn.org
. 2021.10.13 04:59:29 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.10.13 04:59:29 - OpenVPN > [Aljanah] Peer Connection Initiated with [AF_INET]134.19.179.173:443
. 2021.10.13 04:59:29 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.29.138.1,dhcp-option DNS6 fde6:7a:7d20:198a::1,tun-ipv6,route-gateway 10.29.138.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:198a::10ee/64 fde6:7a:7d20:198a::1,ifconfig 10.29.138.240 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2021.10.13 04:59:29 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.10.13 04:59:29 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.10.13 04:59:29 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.10.13 04:59:29 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.10.13 04:59:29 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.10.13 04:59:29 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.10.13 04:59:29 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.10.13 04:59:29 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.10.13 04:59:29 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.10.13 04:59:29 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.10.13 04:59:29 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.10.13 04:59:29 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.10.13 04:59:29 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=eth0 HWADDR=00:25:64:88:f0:ac
. 2021.10.13 04:59:29 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.10.13 04:59:29 - OpenVPN > net_route_v6_best_gw query: dst ::
. 2021.10.13 04:59:29 - OpenVPN > sitnl_send: rtnl: generic error (-113): No route to host
. 2021.10.13 04:59:29 - OpenVPN > ROUTE6: default_gateway=UNDEF
W 2021.10.13 04:59:29 - Unexpected: Network interface unknown - Stack:   at Eddie.Core.Threads.Session.CheckTunNetworkInterface (System.String id) [0x00090] in <2f7a356d3d534026978af9d9844a9374>:0
W 2021.10.13 04:59:29 -     at Eddie.Core.Threads.Session.ProcessLogEvent (System.String source, System.String message) [0x00b97] in <2f7a356d3d534026978af9d9844a9374>:0
. 2021.10.13 04:59:29 - OpenVPN > /bin/ip link set dev tun0 up mtu 1500
. 2021.10.13 04:59:29 - OpenVPN > Linux ip link set failed: could not execute external program
. 2021.10.13 04:59:29 - OpenVPN > Exiting due to fatal error
! 2021.10.13 04:59:29 - Disconnecting
. 2021.10.13 04:59:29 - Connection terminated.
. 2021.10.13 04:59:29 - Elevated: Command:dns-switch-rename-restore
I 2021.10.13 04:59:33 - Checking authorization ...
! 2021.10.13 04:59:33 - Connecting to Suhail (Netherlands, Alblasserdam)
. 2021.10.13 04:59:33 - Elevated: Command:process_openvpn
. 2021.10.13 04:59:34 - OpenVPN > OpenVPN 2.5.1 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Mar  9 2021
. 2021.10.13 04:59:34 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2021.10.13 04:59:34 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.10.13 04:59:34 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.10.13 04:59:34 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.10.13 04:59:34 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.10.13 04:59:34 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]134.19.179.189:443
. 2021.10.13 04:59:34 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2021.10.13 04:59:34 - OpenVPN > UDP link local: (not bound)
. 2021.10.13 04:59:34 - OpenVPN > UDP link remote: [AF_INET]134.19.179.189:443
. 2021.10.13 04:59:34 - OpenVPN > TLS: Initial packet from [AF_INET]134.19.179.189:443, sid=eae003d9 0eb14fcf
. 2021.10.13 04:59:34 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.10.13 04:59:34 - OpenVPN > VERIFY KU OK
. 2021.10.13 04:59:34 - OpenVPN > Validating certificate extended key usage
. 2021.10.13 04:59:34 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.10.13 04:59:34 - OpenVPN > VERIFY EKU OK
. 2021.10.13 04:59:34 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Suhail, emailAddress=info@airvpn.org
. 2021.10.13 04:59:34 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.10.13 04:59:34 - OpenVPN > [Suhail] Peer Connection Initiated with [AF_INET]134.19.179.189:443
. 2021.10.13 04:59:34 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.34.138.1,dhcp-option DNS6 fde6:7a:7d20:1e8a::1,tun-ipv6,route-gateway 10.34.138.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1e8a::1080/64 fde6:7a:7d20:1e8a::1,ifconfig 10.34.138.130 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2021.10.13 04:59:34 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.10.13 04:59:34 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.10.13 04:59:34 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.10.13 04:59:34 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.10.13 04:59:34 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.10.13 04:59:34 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.10.13 04:59:34 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.10.13 04:59:34 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.10.13 04:59:34 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.10.13 04:59:34 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.10.13 04:59:34 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.10.13 04:59:34 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.10.13 04:59:34 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=eth0 HWADDR=00:25:64:88:f0:ac
. 2021.10.13 04:59:34 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.10.13 04:59:34 - OpenVPN > net_route_v6_best_gw query: dst ::
. 2021.10.13 04:59:34 - OpenVPN > sitnl_send: rtnl: generic error (-113): No route to host
. 2021.10.13 04:59:34 - OpenVPN > ROUTE6: default_gateway=UNDEF
W 2021.10.13 04:59:34 - Unexpected: Network interface unknown - Stack:   at Eddie.Core.Threads.Session.CheckTunNetworkInterface (System.String id) [0x00090] in <2f7a356d3d534026978af9d9844a9374>:0
W 2021.10.13 04:59:34 -     at Eddie.Core.Threads.Session.ProcessLogEvent (System.String source, System.String message) [0x00b97] in <2f7a356d3d534026978af9d9844a9374>:0
. 2021.10.13 04:59:34 - OpenVPN > /bin/ip link set dev tun0 up mtu 1500
. 2021.10.13 04:59:34 - OpenVPN > Linux ip link set failed: could not execute external program
. 2021.10.13 04:59:34 - OpenVPN > Exiting due to fatal error
! 2021.10.13 04:59:34 - Disconnecting
. 2021.10.13 04:59:34 - Sending soft termination signal
. 2021.10.13 04:59:34 - Elevated: Command:kill
. 2021.10.13 04:59:34 - Connection terminated.
. 2021.10.13 04:59:34 - Elevated: Command:dns-switch-rename-restore
I 2021.10.13 04:59:38 - Checking authorization ...
Is IPv6 disabled in your system or your network? Somehow I can't tell definitively. If it is, in Eddie Preferences > Networking, set Layer IPv6 to Block as you did before, but this time also set Protocol used for connection to IPv4 only. When I do the first only, v6 is still active, the second option makes Eddie block v6 and only process v4 routes otherwise. I think this might help.
For the other little annoyances, please post the output of these two:
$ ssh -V
$ modinfo tun
On 10/13/2021 at 4:16 AM, OpenSourcerer said:
Is IPv6 disabled in your system or your network? Somehow I can't tell definitively. If it is," I think this might help.
$ ssh -V
$ modinfo tun
Okay, I tried " in Eddie Preferences > Networking, set Layer IPv6 to Block as you did before, but this time also set Protocol used for connection to IPv4 only. When I do the first only, v6 is still active, the second option makes Eddie block v6 and only process v4 routes otherwise." and it made no difference. It still crashes the same way. Eddie 2.16.3 has no problem with IPv6. So I started Eddie 2.16.3, and got the ssh -V and modinfo.tun output in a screenshot. Here:
Eddie_2_16.3_Screen.png.3f8deca250cd4b71efbffacce84ce265.pngssh_modinfo.png.285b0cdf155a6d8dc6dd21594db471ee.png
So, if 2.16.3 runs just fine, is there any compelling reason to upgrade to a newer version?
Don't use screenshots for that, copy-paste it directly in the future.
So if Windows XP runs fine, is there any compelling reason to upgrade to a newer version? That's the nature of your question, not trying to sound like an arse. :)
Please try another stable version of Eddie which isn't as antique as this one. On the Downloads page, click Other versions further down, then select 2.18.9.
Download that version, try to connect with that.
Also, you could try installing 2.20.0. Though, I'm unsure what the package manager is. Distrowatch says it's RPM (so you select OpenSuSE or Fedora/CentOS), but also APT in brackets; not sure what that means.
A little bit related to this, I tried 2.20.0 and could not connect to servers, but with 2.19.7 I can. It stalls when "Checking route IPv6". My internet provider does not support IPv6, so not totally unexpected, but any setting combination from "Settings - Networking" does not allow making the connection work in 2.20.0.
Sorry I'm a bit late back to this topic.
It seems my issues were machine-specific, to one Dell Inspiron desktop, and are no longer of any concern.
On both an older Dell OptiPlex 380, and a new intel NUC11PHKi7CAA1, everything is working fine with Eddie 2.20.0.
Same internet provider, modem, and router, and basic system settings.
Resolved.
Thanks to OpenSourcerer for all your suggestions.
Well, not a solution of the issue but of the situation. :D
Though, let's be honest, you did hijack the thread of another… ;) refrain from doing so in the future, just open a separate topic.
