Not connected, Your IP: 3.236.253.192
airvpnforumuser
ANSWERED issue with asus router using OpenVPN client
I am using an ASUS Router AX-U and when I import the OpenVPN config file it gives an error: vpnclient2: Get CA failed, when I try another OpenVPN config file I get another error: vpnclient1: Get Key failed
The router uses OpenVPN 2.4.11 arm-buildroot-linux-gnueabi
Can anyone please advise how to get this working? Following the 2015 [1] guide seems to not work anymore.
[1]:
To answer my own question: I had to select the option to " Separate keys/certs from .ovpn file "
Then, I imported them as follows:
Import CA file: ca.crt
Client certificate: user.crt
Client key: user.key
Static key: ta.key
It connected okay, but couldn't get my wifi device to connect to internet so far.
