Not connected, Your IP: 216.73.216.15
Editing because I was really dumb.....there is no issue here....
Below is my environment information - the only thing that seems off is that I am using MacOS 11.4, not 10.16.
Eddie System/Environment Report - 10/1/2021 - 3:23 AM UTC
Eddie version: 2.20.0
Eddie OS build: macos_x64
Eddie architecture: x64
OS type: MacOS
OS name: macOS 10.16
OS version: 10.16 (Build 20F71)
OS architecture: x64
Mono /.Net Framework: v4.0.30319
TUN driver: Expected
OpenVPN: 2.5.1 - OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
Hummingbird: 3.3.2 - Hummingbird - AirVPN OpenVPN 3 Client 1.1.1 - 7 January 2020 (/Applications/Eddie.app/Contents/MacOS/hummingbird)
SSH: OpenSSH_8.1p1, LibreSSL 2.7.3 (/usr/bin/ssh)
SSL: stunnel 5.56 (/Applications/Eddie.app/Contents/MacOS/stunnel)
Profile path: .config/eddie/default.profile
Data path: .config/eddie
Application path: /Applications/Eddie.app/Contents/MacOS
Executable path: /Applications/Eddie.app/Contents/MacOS/Eddie
Command line arguments: (0 args)
Network Lock Active: No
Connected to VPN: No
Detected DNS: 2001:428::1, 2001:428::2, 192.168.0.1, 205.171.3.65
Edited ... by Augustine Calvino
I missed something obvious; i have no issue
