Staff 10493 Posted ... Hello! VPN DNS and "Assigned IP address" technical specifications just changed. All the changes have been reported in the https://airvpn.org/specs page. The changed section is: Assigned IP Servers support both IPv4 and IPv6 tunnels and are reachable over IPv4 and IPv6 on entry-IP addresses. DNS server address is the same as gateway, in both IPv4 and IPv6 layer. Chosen IPv4 Local Address OpenVPN: 10.{daemon}.*.*, Subnet-Mask: 255.255.255.0 WireGuard: 10.128.0.0/10 Chosen IPv6 Unique Local Address (ULA) OpenVPN: fde6:7a:7d20:{daemon}::/48 WireGuard: fd7d:76ee:e68f:a993::/64 The new sections are: DoH, DoT Every gateway/daemon assigned to you acts as a DNS (port 53), DoH (dns-over-http, port 443), DoT (dns-over-tls, port 853). DoH and DoT don't add any actual benefit, because plain DNS requests are encrypted inside our tunnel anyway. However, users might need it for special configurations. In such cases, use dns.airservers.org (automatically resolved into VPN gateway address). Our DNS returns a NXDOMAIN for "use-application-dns.net", for compatibility reasons. Special resolutions check.airservers.org - Gateway IPv4 and IPv6 addressesexit.airservers.org - Exit-IPv4 and exit-IPv6 addressesuse-application-dns.net - NXDOMAIN, for DoH compatibility, ensuring Air DNS will be used (for anti-geolocation features) Special URLs https://check.airservers.org - Info about connected serverhttps://check.airservers.org/api/ - Same as above, in JSON Use https://ipv4.airservers.org or https://ipv6.airservers.org - Same as above, specific IP layer Kind regards and datalove AirVPN Staff 3 go558a83nk, User of AirVPN and dIecbasC reacted to this Quote Share this post Link to post
go558a83nk 383 Posted ... does check.airservers.org only resolve if we're using AirDNS? Quote Share this post Link to post
zombie1982 5 Posted ... For me too: Name not resolved if I use dnscrypt-proxy with cloudflare Quote Share this post Link to post
Tech Jedi Alex 1528 Posted ... Those links print info about the server you're connected to. Of course they only work with AirDNS – no other resolver even knows you're connected to a VPN when you query it. 1 Staff reacted to this Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
