BKK20 0 Posted ... Hi, I would like to start a website behind airvpn on my own server at home. I bought a domain and I wanna set the a record to the ip of the exit airvpn server. Unfortunately, the domain host use the standard http port 80 for forwarding. But for airvpn, first I need a remote port which is linked to local port 80. But i cannot set/change it to the remote port on the domain provider. What should I do? Quote Share this post Link to post
Staff 10489 Posted ... @BKK20 Hello! Not a problem: the listening port of your web server is decided by your web server, according to how you configure it. Domain names have nothing to do with ports. Please check:https://airvpn.org/faq/port_forwarding/ Kind regards Quote Share this post Link to post
BKK20 0 Posted ... Thanks, but the "A record" port from the domain host is fixed to http, 80. actually, the port from the domain host has to change to the remote port from airvpn. How can I do it? Locally on my server, its not a problem that the webserver is listening to port 80. But to reach my webserver from the internet, the a record has to listen to the remote port. Do you understand my problem? thanks in advance! Quote Share this post Link to post
Staff 10489 Posted ... @BKK20 Hello! DNS doesn't provide port numbers and DNS records do not listen to anything. It's some running software which "listens". And it's the client the one which picks the destination port to try. In a browser, if the port number is not specified, normally :80 for HTTP and :443 for HTTPS are added to complete the URL. The client must always specify the port as well, it's a mandatory field in TCP and UDP packets. Separate name and port with a colon. Example: http://somename.org:12345 As an additional option, you can also "re-map" your remotely forwarded port(s) to different port numbers. In this way packets reaching remote VPN server port will be forwarded to your node on another port number. Kind regards 1 BKK20 reacted to this Quote Share this post Link to post
BKK20 0 Posted ... How can I do it? For example I bought the domain example.com If someone type the domain in the browser, there should be a redirection to my webserver at home behind airvpn. The webserver is listen to local port 80 and remote port ist 34343. Does it mean the user hast to type in the browser example.com:43433? actually he should not type any portnumber on the browser. Do you have a small tutorial? Quote Share this post Link to post
Staff 10489 Posted ... @BKK20 Hello! The user running the client (the browser in this case) must always type the remote port when it's not 80 or 443, which are added automatically if missing. Name and port must be separated by a colon. The port is an integral and mandatory part of HTTP URL since when it was defined in 1994, 27 years ago. More in general, an HTTP URL conforms, and has always conformed, to the generic URI syntax, see also: https://en.wikipedia.org/wiki/URL Kind regards Quote Share this post Link to post
BKK20 0 Posted ... I know that, but I need the solution for AirVPN? Does nobody understand me? My new domain should be reachable from the internet behind an AirVPN Server with the standard port http, https. But as everyone knows that I cannot forward port 80, I have to use an remote port. But the client at the internet should not enter enter any remote port. He should just enter the domain name like all other websites. Quote Share this post Link to post
Staff 10489 Posted ... 22 minutes ago, BKK20 said: I know that, but I need the solution for AirVPN? Does nobody understand me? Hello! Yes of course. Maybe you have missed the answers twice, please check them:https://airvpn.org/forums/topic/49776-own-webhosting-port-fowarding-set-a-record/?do=findComment&comment=169233https://airvpn.org/forums/topic/49776-own-webhosting-port-fowarding-set-a-record/?do=findComment&comment=169282 Kind regards Quote Share this post Link to post
BKK20 0 Posted ... Hmh ok. I will try it like described: 1) Set "a record" by domain host to the Server IP Adress from AirVPN e.g. www.example.com -> 140.140.150.150 2) Add AirVPN Port Forwarding e.g. RemotePort 34567 -> local port 80 After that if I enter in my browser www.example.com (without any port). I get a respsone from my server Is it working like this? Quote Share this post Link to post
Staff 10489 Posted ... @BKK20 Step 1 is almost correct: please remember that our VPN servers have different entry and exit-IP addresses The relevant DNS record must be set to the exit-IP address. Step 2 is correct.. "after that" is not correct. The proper URI for your browser would be http://www.example.com:34567 or https://www.example.com:34567 (http or https according to your web server settings). Also remember to access your web server running behind a VPN server from a machine that's not connected to the same VPN server. Kind regards 1 BKK20 reacted to this Quote Share this post Link to post
BKK20 0 Posted ... Great, thanks! That means without the remote port at the end of the domain name it's not possible. That also means, if I want to have a website like others in the internet (just enter domain name, w/o port number) I have to buy a web hosting package externally. I cannot do it with AirVPN. Quote Share this post Link to post
Staff 10489 Posted ... @BKK20 Exactly. The port is always added as it is an integral part of the URI, but when omitted in the URI, this is auto-completed with :80 and :443 respectively for HTTP and HTTPS, as we already told you twice. AirVPN does not allow remote inbound port forwarding of ports between 1 and 2048, as reported in the FAQ and the manual. AirVPN is not a hosting provider. You might rent a VPS or a dedicated server to run your web server or any other service, and then you may make your service reachable on any port you like. If you don't need any privacy or anonymity layer for your web server (or other service), that's a logical solution, and it's not expensive. Kind regards 1 BKK20 reacted to this Quote Share this post Link to post
BKK20 0 Posted ... In case you know: If I host a website at home with a remote port via AirVPN, is google able to scan the website, respectively does the crawler from google find my website even it's not port 80? Quote Share this post Link to post
Staff 10489 Posted ... 6 minutes ago, BKK20 said: In case you know: If I host a website at home with a remote port via AirVPN, is google able to scan the website, respectively does the crawler from google find my website even it's not port 80? Yes, Google Search can index web sites even when the web server listens to non-standard ports, according to some Google executives.https://webmasters.stackexchange.com/questions/77378/does-google-treat-different-ports-as-different-siteshttps://webmasters.stackexchange.com/questions/61762/does-google-crawl-and-index-sites-hosted-on-an-ip-address-only-with-no-domain-n/61767#61767 Kind regards 1 BKK20 reacted to this Quote Share this post Link to post
Tech Jedi Alex 1527 Posted ... If I may add more info, fortunately Google Search adheres to the robots.txt "standard". So if you add this to a robots.txt in the root of your webspace, everything hosted in that webspace won't be crawled. User-agent: * Disallow: / Specifically for Google, their bot checks the "robots" meta tag in the header of a webpage to determine whether to index it or not. See Hacker News. 1 BKK20 reacted to this Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
