r34lity23 0 Posted ... After some trouble I have managed to get bluetit working inside a proxmox lxc container. However enabling network lock results in the following issue: Sep 17 17:47:04 VPNGateway1 bluetit[998]: External network is reachable via gateway 192.168.1.254 through interface eth0 Sep 17 17:47:04 VPNGateway1 bluetit[998]: Successfully connected to D-Bus Sep 17 17:47:04 VPNGateway1 bluetit[998]: Reading run control directives from file /etc/airvpn/bluetit.rc Sep 17 17:47:04 VPNGateway1 bluetit[998]: IPv6 is available in this system Sep 17 17:47:04 VPNGateway1 bluetit[998]: WARNING: networklockpersist directive found in /etc/airvpn/bluetit.rc. networklock directive is ignored. Sep 17 17:47:04 VPNGateway1 bluetit[998]: Bluetit successfully initialized and ready Sep 17 17:47:04 VPNGateway1 systemd[1]: Started AirVPN Bluetit Daemon. Sep 17 17:47:04 VPNGateway1 bluetit[998]: Enabling persistent network filter and lock Sep 17 17:47:04 VPNGateway1 systemd[1]: bluetit.service: Main process exited, code=killed, status=11/SEGV Sep 17 17:47:04 VPNGateway1 systemd[1]: bluetit.service: Failed with result 'signal'. Any advice on how to troubleshoot this would be great. Thanks Quote Share this post Link to post
Tech Jedi Alex 1567 Posted ... Bluetit tried to access a part of memory which doesn't belong to it (SEGV = segmentation fault). I think LXC's sandboxing is the cause. Maybe that Bluetit container is not permitted to execute iptables and nf_tables modules of the host, or execute iptables/nft? Is there something like a permission system in Proxmox? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
r34lity23 0 Posted ... Thanks a lot for your reply. Yeah I was thinking something along those lines, however I am able to update iptables manually. Both I and Bluetit are running as root so I would have thought it should work. Quote Share this post Link to post
Tech Jedi Alex 1567 Posted ... Yeah, I don't know how to trace the execution of Bluetit and point a finger at possible actions. Can you start Bluetit manually with the root user and try again? As in, execute Bluetit in the terminal. In a second terminal you can then try to connect again. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
r34lity23 0 Posted ... On 9/18/2021 at 7:23 PM, OpenSourcerer said: Yeah, I don't know how to trace the execution of Bluetit and point a finger at possible actions. Yeah that's pretty much where I am too, I wish I could get a more verbose output to find out exactly what is going on. With my latest testing it does definitely seem to be some sort of permissions issue with updating the firewall as I have now also tried in a debian system with nftables and the error is exactly the same. Quote Share this post Link to post
Tech Jedi Alex 1567 Posted ... As a layman's idea, two things come into mind. gdb, the GNU debugger for C and probably C++ programs, and strace, a system call trace tool. Both are complicated to my eye, but maybe they can help one pinpoint where it goes haywire. Maybe LXC does have a similar thingy helping one notice what makes a program be killed in a container. Apart from that, I will stop my inputs from coming. Have nothing clever to write, anyway Try asking in LXC communities, too, and good luck! Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
r34lity23 0 Posted ... No worries, thanks for your help! I have opened a support ticket and I will make sure to update this thread if I manage to get it resolved. Quote Share this post Link to post
