Not connected, Your IP: 216.73.216.28
sammyphantom
airvpn straight up not opening
Just installed AirVPN through Eddie, and it won't open. It also didn't create a shortcut, although I did tell it to do so. I went into the AirVPN folder and attempted to open it through OpenVPN.exe, which didn't work. Anybody know how to fix this? Am I just a massive idiot?
You downloaded the installer of Eddie 2.20.0, yes? You executed it and the installer guided you through the installation? And while doing that you explicitly ticked the option to create a shortcut, if any?
Also, you don't open openvpn.exe, you open eddie.exe. But it shouldn't be necessary, the desktop shortcut should be created.
