Iruy
airvpn on Raspberry Pi 4
I am running the latest version Manjaro ARM minimal on the Raspberry Pi 4. I have no GUI so naturally I generated an .ovpn file to connect with. Both with UDP and TCP I get the following output - with the only difference being whether or not it mentions the use of TCP or UDP:
2021-09-14 18:55:38 DEPRECATED OPTION: --cipher set to 'AES-256-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-256-CBC' to --data-ciphers or change --cipher 'AES-256-CBC' to --data-ciphers-fallback 'AES-256-CBC' to silence this warning.
2021-09-14 18:55:38 OpenVPN 2.5.3 [git:makepkg/ecaf88f8a4e75856+] aarch64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Jun 18 2021
2021-09-14 18:55:38 library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
2021-09-14 18:55:38 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2021-09-14 18:55:38 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2021-09-14 18:55:39 TCP/UDP: Preserving recently used remote address: [AF_INET]134.19.179.130:443
2021-09-14 18:55:39 Socket Buffers: R=[131072->131072] S=[16384->16384]
2021-09-14 18:55:39 Attempting to establish TCP connection with [AF_INET]134.19.179.130:443 [nonblock]
2021-09-14 18:55:39 TCP connection established with [AF_INET]134.19.179.130:443
2021-09-14 18:55:39 TCP_CLIENT link local: (not bound)
2021-09-14 18:55:39 TCP_CLIENT link remote: [AF_INET]134.19.179.130:443
2021-09-14 18:55:39 TLS: Initial packet from [AF_INET]134.19.179.130:443, sid=674abff5 df778ab3
2021-09-14 18:55:39 net_route_v4_best_gw query: dst 0.0.0.0
2021-09-14 18:55:39 net_route_v4_best_gw result: via 192.168.1.126 dev wlan0
2021-09-14 18:55:39 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
2021-09-14 18:55:39 VERIFY KU OK
2021-09-14 18:55:39 Validating certificate extended key usage
2021-09-14 18:55:39 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
2021-09-14 18:55:39 VERIFY EKU OK
2021-09-14 18:55:39 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Piscium, emailAddress=info@airvpn.org
2021-09-14 18:55:39 Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
2021-09-14 18:55:39 [Piscium] Peer Connection Initiated with [AF_INET]134.19.179.130:443
2021-09-14 18:55:39 PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.34.93.1,dhcp-option DNS6 fde6:7a:7d20:1e5d::1,tun-ipv6,route-gateway 10.34.93.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1e5d::10ce/64 fde6:7a:7d20:1e5d::1,ifconfig 10.34.93.208 255.255.255.0,peer-id 0,cipher AES-256-GCM'
2021-09-14 18:55:39 OPTIONS IMPORT: timers and/or timeouts modified
2021-09-14 18:55:39 OPTIONS IMPORT: compression parms modified
2021-09-14 18:55:39 OPTIONS IMPORT: --ifconfig/up options modified
2021-09-14 18:55:39 OPTIONS IMPORT: route options modified
2021-09-14 18:55:39 OPTIONS IMPORT: route-related options modified
2021-09-14 18:55:39 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2021-09-14 18:55:39 OPTIONS IMPORT: peer-id set
2021-09-14 18:55:39 OPTIONS IMPORT: adjusting link_mtu to 1627
2021-09-14 18:55:39 OPTIONS IMPORT: data channel crypto options modified
2021-09-14 18:55:39 Data Channel: using negotiated cipher 'AES-256-GCM'
2021-09-14 18:55:39 Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
2021-09-14 18:55:39 Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
2021-09-14 18:55:39 ROUTE_GATEWAY 192.168.1.126/255.255.255.128 IFACE=wlan0 HWADDR=dc:a6:32:26:fc:da
2021-09-14 18:55:39 GDG6: remote_host_ipv6=n/a
2021-09-14 18:55:39 net_route_v6_best_gw query: dst ::
2021-09-14 18:55:39 sitnl_send: rtnl: generic error (-101): Network is unreachable
2021-09-14 18:55:39 ROUTE6: default_gateway=UNDEF
2021-09-14 18:55:39 ERROR: Cannot open TUN/TAP dev /dev/net/tun: No such device (errno=19)
2021-09-14 18:55:39 Exiting due to fatal error
I am connected to the internet and have DNS working, as a quick ping reveals:
ping -c4 google.com
PING google.com (142.250.200.46) 56(84) bytes of data.
64 bytes from lhr48s30-in-f14.1e100.net (142.250.200.46): icmp_seq=1 ttl=114 time=11.8 ms
64 bytes from lhr48s30-in-f14.1e100.net (142.250.200.46): icmp_seq=2 ttl=114 time=11.5 ms
64 bytes from lhr48s30-in-f14.1e100.net (142.250.200.46): icmp_seq=3 ttl=114 time=13.3 ms
64 bytes from lhr48s30-in-f14.1e100.net (142.250.200.46): icmp_seq=4 ttl=114 time=12.0 ms
--- google.com ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3005ms
rtt min/avg/max/mdev = 11.504/12.144/13.324/0.700 ms
So I'm not sure what's going on. I am on a subnet with mask 255.255.255.128, but my desktop and laptop and some VM's on the same subnet have no issues using eddie, or .ovpn files for that matter,
As far as I can tell it has something to do with bringing up the interface itself. I have `net-tools` installed, so the use of `ifconfig` should make no difference.
Does anyone have any advice?
That's… rare. Do you get anything back if you execute this?
$ modinfo tun
