WookieeB 0 Posted ... Hi all, Updated Eddie to the most recent stable and tried to download a torrent through Qbittorrent (v4.1.9.1) from 1337x. When I add the magnet link it just sits on "Retrieving metadata". I tried downloading a torrent from Ubuntu and it was added to the queue fine but it shows as stalled and their are no trackers listed. I know my version of Qbittorrent is out of date...... I tried this whole process earlier this year (update Eddie, torrents wouldn't work, updated torrent client, didn't work, troubleshot and go through forums....) I ended up doing a system restore and decided to deal with it later. Later is here! I also tried dl'ing the Ubuntu with Eddie off and have the same result: torrent shows in transfer window but no trackers load. I tried changing the listening port here and in the software with no effect. I attached log for Qb. I am not opposed to changing torrent clients if that is the easiest fix! EDIT Tried disabling Eddie and network lock, torrents won't load that way either. Everything worked prior to Eddie update. Any help would be most appreciated! Thanks kindly! log.txt Eddie_20210913_084910.txt Share this post Link to post
Tech Jedi Alex 1531 Posted ... Moved to off-topic as support with qB is requested. 1 hour ago, WookieeB said: Everything worked prior to Eddie update. Correlation != Causation. Please try upgrading qB to latest version first. qB offers an official PPA for this. Test it with the newest version and if unsuccessful, come back here. 1 Just a Fred reacted to this Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
WookieeB 0 Posted ... Updated qB still same issues as before. Please note I am not running Ubuntu, was just using that as a tester torrent download from the Ubuntu site. It still shows no trackers but will load the torrent in the main widnow. If trying torrent from 1337x or TPB just sits on retrieving metadata and never loads past that. Share this post Link to post
Tech Jedi Alex 1531 Posted ... 9/13/21 7:55 AM - The network interface defined is invalid: ethernet_10 Did you configure qB to bind to some interface or IP? This looks like it's cut off from the world because it can't find a previously present interface. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
WookieeB 0 Posted ... 47 minutes ago, OpenSourcerer said: 9/13/21 7:55 AM - The network interface defined is invalid: ethernet_10 Did you configure qB to bind to some interface or IP? This looks like it's cut off from the world because it can't find a previously present interface. I didn't change any of the settings from when it worked. It looks like it is grabbing the proper network connection, LAC3 which is the TAP-Windows Adapter. Share this post Link to post
Tech Jedi Alex 1531 Posted ... 14 minutes ago, WookieeB said: I didn't change any of the settings from when it worked. It looks like it is grabbing the proper network connection, LAC3 which is the TAP-Windows Adapter. It's not what the logs are saying. You're showing us the settings here. Try to reset this to All interfaces, close qB, reconnect the VPN and try to reset this to TAP. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
WookieeB 0 Posted ... 5 minutes ago, OpenSourcerer said: It's not what the logs are saying. You're showing us the settings here. Try to reset this to All interfaces, close qB, reconnect the VPN and try to reset this to TAP. Awesome, that seemed to do the trick. Thanks for the assistance! Share this post Link to post
