56Kmodem 3 Posted ... edit: fixed it with revo-uninstaller and reinstalling again. I tried the beta client and ticked the option something like 'optain elevated priviliges' to test things out. And now I can not start Eddie anymore. Uninstall and reinstall an older version did not work. Several reboots did not work. Portable does not work. I tried the common fixes deleting the service stuff (this does nothing) and furiously uninstalling/rebooting/installing and trying to find any config file to get rid of that elevated stuff.... This is crazy how hardcoded this is. Any ideas? 1 cashski reacted to this Quote Share this post Link to post
Staff 10411 Posted ... @56Kmodem Hello! With revo, did you fix the problem in Eddie 2.21 beta 2 or in Eddie 2.20.0? Kind regards Quote Share this post Link to post
56Kmodem 3 Posted ... Had the same problem with both versions after trying the beta. Revo removed some leftover files I guess which are not covered up with your default uninstaller. Quote Share this post Link to post
Staff 10411 Posted ... @56Kmodem Thank you, it's probably the configuration file "default.profile" which is not removed by the uninstaller (correctly, because it's an uninstall and not a purge) and which is not upward compatible. It remains to be seen why the problem arose in the first place with 2.21 beta. The very first time you had the problem, were you testing beta 1 or beta 2? What is your exact Windows version? Kind regards 1 56Kmodem reacted to this Quote Share this post Link to post
56Kmodem 3 Posted ... Tested: Eddie 2.21 beta 2 Windows Version: 10.0.19042 Build 19042 1 1 cashski and Staff reacted to this Quote Share this post Link to post
mtropy 0 Posted ... I am having this same issue and don't seem to be able to fix it neither after running revo and cleaning up the leftover files. Any help? Quote Share this post Link to post
joxcox2 0 Posted ... Have the same issue. Version 2.20.0 Delete and reinstall from initial download (eddie-ui_2.20.0_macos-10.15_arm64_portable) seems to clear the problem for a few days. Then it returns. Quote Share this post Link to post
mtropy 0 Posted ... hi is there any advice to get this sorted? It's really a pain in the neck. Thanks! Quote Share this post Link to post
