I have installed Open VPN on Linux (debian/ubuntu), I have used .ovpn configuration files to create certain servers to connect (e.g USA, etc). I am not sure what to put in Network Proxy settings of Open VPN. I can see my ipaddress next to air vpn ip address on ipleak.net. I do not know how to fix this so would like you to help me on this ?
I have three options to use Automatic - Manual - Disable , Disable and Automatic does not work and I still get my ipaddress revealed.
Under Manual I have to provide following details
HTTP Proxy ---- Port
HTTPS Proxy
FTP Proxy
Socks Host
Ignore Hosts - localhost, 127.0.0.0/8, ::1
Nothing, unless you're behind a proxy. Which is not the case, otherwise you wouldn't be able to connect at all.
Depends on where you see it. In Your IP address section, the WebRTC section or the DNS addresses section? All three require different fixes.
This looks like a reference to Eddie, isn't it? Again, a question about ambiguity: Do you mean the Network Lock tab or the DNS tab of its Preferences? Both have got those options.
