regulator 2 Posted ... when playing with hummingbird on my raspberrypi, I once killed the process and managed to bring the bird into a quite strange state. What´s the best way to get back to normal? pi@raspi:~ $ uname -srm Linux 5.10.17-v7l+ armv7l pi@raspi:~ $ sudo hummingbird -e Hummingbird - AirVPN OpenVPN 3 Client 1.1.2 - 4 June 2021 It seems this program did not exit gracefully or has been killed. Your system may not be working properly and your network connection may not work as expected. To recover your network settings, run this program again and use the "--recover-network" option. pi@raspi:~ $ sudo hummingbird --recover-network Hummingbird - AirVPN OpenVPN 3 Client 1.1.2 - 4 June 2021 It seems this program has properly exited in its last run and it has already restored network settings on exit. Network recovery is not needed. 1 strictum reacted to this Share this post Link to post
Tech Jedi Alex 1524 Posted ... (edited) # rm -v /etc/airvpn/{hummingbird.lock,*.airvpnbackup,*-save.txt} . Edited ... by OpenSourcerer Refined command for future readers Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
regulator 2 Posted ... Thank you for the suggestion, but unfortunately no luck: pi@raspi:~ $ ls -al /etc/airvpn/ total 24 drwxr-xr-x 2 root root 4096 Jul 31 13:08 . drwxr-xr-x 135 root root 12288 Jul 31 09:28 .. -rw-r--r-- 1 root root 1086 Jul 24 20:34 ip6tables-save.txt -rw-r--r-- 1 root root 962 Jul 24 20:34 iptables-save.txt pi@raspi:~ $ sudo hummingbird -e Hummingbird - AirVPN OpenVPN 3 Client 1.1.2 - 4 June 2021 It seems this program did not exit gracefully or has been killed. Your system may not be working properly and your network connection may not work as expected. To recover your network settings, run this program again and use the "--recover-network" option. pi@raspi:~ $ sudo hummingbird --recover-network Hummingbird - AirVPN OpenVPN 3 Client 1.1.2 - 4 June 2021 It seems this program has properly exited in its last run and it has already restored network settings on exit. Network recovery is not needed. Share this post Link to post
Tech Jedi Alex 1524 Posted ... Both of these txt files, too. Then it should work. 1 strictum reacted to this Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
regulator 2 Posted ... Thanks a lot. after deleting all files in /etc/airvpn hummingbird works again like a charm! 1 strictum reacted to this Share this post Link to post
Tech Jedi Alex 1524 Posted ... Try not to kill the bird again. 1 regulator reacted to this Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
