LukeSade 0 Posted ... I have been trying to setup a csgo server behind the vpn using port forwarding however it doesn't seem to be working i can't connect to the server but without the vpn if i normally port forward from my router it's working, I also tested a Minecraft server with port forwarding and AirVPN and that works too. If anybody has managed to setup a csgo server with airvpn comment please thanks Quote Share this post Link to post
Tech Jedi Alex 1525 Posted ... Make sure it listens on the VPN interface. You could also post the CS:GO server config and any Minecraft server's configs if you're comfortable sharing them. There was some talk about Minecraft denying service to VPN users in the past because two of Mojang's APIs, mcoapi.minecraft.net and authserver.mojang.com, block access in that case. It's a reason why clients can't login and servers can't use the user authentication feature (so barring anyone from connecting). In the case of Minecraft, what you could try is set offline-mode=true if it's a private server, and use open source clients like MultiMC to launch Minecraft without logging in. It's also more or less known that Valve don't like VPN users too much, either, though I've got no idea whether they take extreme measures such as this when users log into CS:GO matches. I think they rely more on VAC there. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
LukeSade 0 Posted ... No by minecraft i meant i hosted a minecraft server w/o issue using port forwarding, and i can play cs with vpn on w/o even port forwarding that's not the issue, my main issue is i can't host a cs server on my pc Quote Share this post Link to post
Tech Jedi Alex 1525 Posted ... I see. In any case, the CS:GO server config may help. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Nirvoth 0 Posted ... (edited) I had a similar struggle until I realized the port I forwarded wasn’t the exact one my server process was using—turned out the game switched it on launch. Double-check your config and console logs to be sure. Edited ... by Tech Jedi Alex Delete ad for questionable skin selling site Quote Share this post Link to post
