LukeSade 0 Posted ... I was testing out a port i forwarded in the client area of the website, and am using eddie client to connect with the vpn. Upon using Port Forwarding Tester with the TCP protocol port appears open on Port Checker website however i change the protocol to UDP(in Port Forwarding Tester) the port appears closed on Port Checker. Any solutions? Quote Share this post Link to post
Staff 10421 Posted ... Hello! Are you sure that your UDP port (in your local network interface) exists? Maybe the listening software accepts TCP packets, not UDP ones. Anyway UDP tests are not reliable for the very UDP nature (it's connectionless). Kind regards Quote Share this post Link to post
Stalinium 54 Posted ... (edited) Afaik for the UDP test to work, you must have a client application running that would respond to that incoming test packet. As an additional note, to eliminate any flukes, wait some time after adding a new port on the website and only then connect to a server (5-10min give or take - I had it not apply instantly in one occasion). I wouldn't fully trust these testing websites. You could though monitor the traffic arriving at that port with Wireshark (when using these websites) to really see what's going on. In the Wireshark main menu, put "port 12345" where it says "...using this capture filter:" then double click the VPN interface (TUN/TAP) to start the capture. Now it will only capture traffic for the port you're interested in. Edited ... by Stalinium Quote Share this post Link to post
LukeSade 0 Posted ... My main issue was i was trying to setup a CSGO server which uses UDP and it wasn't working but the Minecraft server which uses TCP was, now i'm not sure if it's related to TCP or UDP but that seemed plausible ig Quote Share this post Link to post
