singh124 0 Posted ... (edited) I just setup AirVPN on my Netgear R6400v2 running DD-WRT and it works fine, the only issue is that the connection is much slower than a direct connection to AirVPN. Using Eddie I can easily reach 80-90mbps, but using the same server on my router I only get a max of 25mpbs. With the vpn off on the router, I get full speed just fine. I tried disabling LZO compression and it does not make any difference. Is there anything else I can do to improve the speed on DD-WRT? Looking at CPU usage, the router is not using much processing power so I don't believe its a limitation of the router itself. Edited ... by singh124 Share this post Link to post
Tech Jedi Alex 1522 Posted ... 23 minutes ago, singh124 said: Looking at CPU usage, the router is not using much processing power so I don't believe its a limitation of the router itself. Still try using ChaCha20-Poly1305 cipher. data-ciphers CHACHA20-POLY1305 data-ciphers-fallback AES-256-GCM . Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
SumRndmDude 22 Posted ... It actually is a limitation on the router itself typically. Most consumer grade routers struggle to encrypt/decrypt all of those packets on the fly and thus the overall speed suffers. Eddie is using your PC's processor, which is much better equipped for this. It's been discussed numerous times on these forums. The ChaCha20 cipher should help, but despite all of my efforts, I could never get any of my routers to get more than 1/2 (usually less) of my overall connection speed. Switching to a pfSense box has it maxed out and matching my connection when connected through the VPN. Share this post Link to post
singh124 0 Posted ... (edited) 2 hours ago, OpenSourcerer said: data-ciphers CHACHA20-POLY1305 When I add this line to "Additional Config" section, OpenVPN doesn't start and does not leave a log. The Status page for OpenVPN is completely blank. Is that not the right section to add it?f 1 hour ago, SumRndmDude said: Switching to a pfSense box has it maxed out I was hoping that I wouldn't need to make a pfSense box because I plan to bring this to a small apartment, so I wanted something small that I can drop in. I actually was able to improve speed a bit by changing LZO compression to Adaptive instead of YES. I can now reach speeds of about 40mb/s, which is better but still not optimal. Is it possible the router is thermal throttling? I noticed even at about 2% cpu usage it is at 60c, which seems a bit high for such little usage. Edited ... by singh124 Share this post Link to post
singh124 0 Posted ... After playing around in the settings more, I have gotten my upload speed to reach 50mbps, but the download speed is only 10mbps? If the upload speed is high, that must mean that the speed is not being limited by the CPU? I'm not 100% sure I have everything set up correctly because since the DD-WRT guide was written it has been updated to add a lot more options that I had to try and figure the correct settings for. Share this post Link to post
SurprisedItWorks 53 Posted ... (edited) I have a Linksys WRT1900ACSv2 running dd-wrt build 46816. This router is faster than yours, but it's no superstar, and over my 200/10 Mbps ISP service my fastest test (dslreports.com/speedtest) thus far is 237.5/10.5 Mbps. This was through an AirVPN server around 1,000 miles from here. I don't know what your issue is, but I'm happy to share my config. When I connect to my router using ssh and do openvpn --version, I see I am on OpenVPN 2.5.2. I think this config should be good, however, for any 2.5.X version. The keys and certs you need to get from the Air configurator with UDP entry 3 port 443 for TLS v1.2 chosen. The four keys/certs have lots of names. Here's what corresponds to what, shown here asAir .conf tag / Air filename / dd-wrt GUI window / dd-wrt nvram var <ca> / ca.crt / "CA Cert" / openvpncl_ca <tls-crypt> / tls-crypt.key / "TLS Key (under advanced options)" / openvpncl_tlsauth <cert> / user.crt / "Public Client Cert" / openvpncl_client <key> / user.key / "Private Client Key" / openvpncl_key You can paste this into the ssh window to configure the other parameters: nvram set openvpncl_enable=1 nvram set openvpncl_mit=1 nvram set openvpncl_mtu=1434 nvram set openvpncl_certtype=1 nvram set openvpncl_tls_btn=1 nvram set openvpncl_tuntap=tun nvram set openvpncl_remoteip=us3.vpn.airdns.org nvram set openvpncl_remoteport=443 nvram set openvpncl_lzo=no nvram set openvpncl_dc1=CHACHA20-POLY1305 nvram set openvpncl_dc2=AES-256-GCM nvram set openvpncl_dc3=AES-256-CBC nvram set openvpncl_cipher=AES-256-CBC nvram set openvpncl_proto=udp4 nvram set openvpncl_auth=SHA512 nvram set openvpncl_config='mssfix 1406 auth-nocache route-delay 5 verb 4 explicit-exit-notify 5 ' This example shows the generic US "server", but you can pick another. Navigate away from the GUI OpenVPN client page and come back, and everything should be filled in and selected. I also add a couple more lines to the Additional Config that are not included in the basic setup above: rcvbuf 360448 sndbuf 360448 I tried 500000, but I saw this in the log: "Socket Buffers: R=[180224->360448] S=[180224->360448]" and this suggested to me that 360448 was, for my particular router anyway, the largest meaningful buffer size. Edited ... by SurprisedItWorks Omission in the original Share this post Link to post
go558a83nk 383 Posted ... On 7/25/2021 at 8:25 PM, singh124 said: After playing around in the settings more, I have gotten my upload speed to reach 50mbps, but the download speed is only 10mbps? If the upload speed is high, that must mean that the speed is not being limited by the CPU? I'm not 100% sure I have everything set up correctly because since the DD-WRT guide was written it has been updated to add a lot more options that I had to try and figure the correct settings for. It's a good chance your ISP is traffic shaping when your upload is faster than download. Try TCP for transport protocol (not UDP) and see if that helps. Share this post Link to post
Stalinium 54 Posted ... I don't think TCP will work and it's actually advised against due to TCP over TCP not working properly. My best bet about download speed is the CPU limit. The router has to run incoming traffic through more firewall checks AND NAT. Does the router have hardware NAT acceleration and enabled? Try disabling firewall or some of its rules/detections to see if it helps. OpenVPN is still single thread and whatever monitoring you're looking at is maybe not detailed enough to see. One other knob to turn is tunnel device: TUN or TAP. And try to reduce tunnel MTU to see if it helps. I don't remember exactly what the common sweetspot values were for MTU but afaik 48 byte steps. So 1452, and then two more steps down too to try out. This will increase overhead. If the fragmentation was a problem it will help still. Do you now have Chacha20 or not? The reason it didn't start was probably an old OpenVPN version. Share this post Link to post
singh124 0 Posted ... It was definitely my router, I just picked up a r7800 and I am getting full speeds now. Thanks for all the tips. Share this post Link to post
