Not connected, Your IP: 216.73.216.32
Staff
Eddie Desktop 2.21 beta released
1 hour ago, Clodo said:
@koob
Not sure how you reach the WireGuard error, WireGuard is implemented but only for selected beta-tester for the moment.
You find "WireGuard" in "Protocol" section, OR you see the tab "Providers"?
Just encountered while doing apt get upgrade on Debian and this showed in the log file .
18 hours ago, puff-m-d said:
I am having one issue with this new beta version. When I boot my system (with Eddie set to start with system), I now get an UAC prompt from Windows for Eddie-UI.exe that I must confirm. I have not seen this since the Eddie-Service-Elevated.exe was added to the Eddie package and Eddie-UI.exe was rewritten several versions back.
I did a complete removal of Eddie (including profile and tunnel drivers), then did a fresh install leaving all settings at default. I still get an UAC prompt for Eddie-UI.exe from Windows at boot that must be confirmed.
This seems to be a bug but of course there is always the possibility that I may be doing something wrong.
Windows 10 Pro 64-bit Version 21H1 (OS Build 19043.1110)
Mmmm
Try to launch, confirm prompt UAC, Preferences -> General check "Don't ask elevation every run", EXIT Eddie.
Now, with Eddie closed, Windows -> Services , "Eddie Elevation Service" is running ? If yes, relaunch Eddie, ask again UAC? Thanks
I installed the beta on top of 2.20 on 64bit 21H1, and I started getting Wireguard error where it automatically started connecting with WireGuard and failing over and over again without me changing any option. Changing protocol settings in the menu also didn't last but was always reset to Automatic. Once I removed Eddie, rebooted and installed the beta again it connected normally without trying to use WireGuard.
Hello @Clodo,
Confirmed, "Don't ask elevation every run" is checked.
Yes.
No, an UAC prompt does not appear.
The strange thing is that I only get an UAC prompt from Windows on boot if I have Eddie set to "Start with System". Any manual start of Eddie never produces an UAC prompt...
I hope that this helps...
here is the debug log for macOS 10.15.7 DNS hick-up.
The first two tries are when Eddie is being started while wlan is off, the third try is when wlan is on while Eddie was started (only 10s wait-time compared to the first 2 tries) strange..
The "refresh connection list, ping"-button is only working in the beginning. When Eddie is running for a while it results in an empty Latency column.
eddie_2021-07-26.log
11 hours ago, Clodo said:
After the testing, our Config Generator will be able to create WireGuard .conf file, usable without Eddie (wg / wg-quick or any official WireGuard app).
Awesome work, thank you! :)
On 7/22/2021 at 10:53 PM, iwih2gk said:
Then I went back to Eddie 2.20 and see the debian version is recognized as 11.
. 2021.07.22 20:05:49 - Cannot retrieve information about AirVPN: Object reference not set to an instance of an object
"Object reference not set to an instance of an object" is a generic error.
In this case, occur because 2.21 update your profile, and when you return to 2.20 stable, 2.20 can't read it.
This will be fixed soon, in the mean-time, delete your profile file to avoid this error.
******************** ps - I forgot to watch the apt-get closely and was wondering if 2.21 called some debian updates at the same time.  Does 2.21 add extra files to the OS or not?
No.
Also, you have IPv6 disabled as os-level, that cause an issue in the 2.21beta that prevent connection.
Please wait, we will release a new version in a few days that fix also this issue.
21 hours ago, puff-m-d said:
Hello @Clodo,
Confirmed, "Don't ask elevation every run" is checked. Yes. No, an UAC prompt does not appear.
Thanks. Probably Eddie UI start BEFORE the service, and try to relaunch. I'm investigating this issue, i hope a fix in the next release in few days. Thanks again.
No.
Yep.  Still "old school" running the OS with IPv6 prevented at system boot.  For sure no leaks on "6" that way, LOL!
I appreciate the follow through on your part.  I could not figure out what I might do to correct it.  I am in no hurry and have gone back to 2.20 running Bullseye.  Slick as hell.  Like the 5.0 + image/kernel on Bullseye.  Several pieces of software unrelated to AirVpn are running much better on Bullseye.
WireGuard support is welcomed, but how will the privacy issues of the WG server daemon be handled, namely, the static assignment of internal IP addresses? Will AirVPN use a dynamic WG https://git.zx2c4.com/wg-dynamic/about/docs/idea.md? If not, how is AirVPN able to offer similar level of privacy for customers using WireGuard as for those using OpenVPN?
How about obfuscation of WireGuard packets? Are you planning to include a self-made patch to hide the usage of WireGuard or do you trust to SSH and TLS tunneling?
staff offered me to share any bugs in this thread.
I just wanted to let you know that no connection is possible if IPv6 is disabled system-wide. Although i set "Ipv6 layer" to "Block" in the Eddie client, the connection still fails.
I reverted to v2.20.0 for now.
Here is my full log from Eddie, "Lifebelt" - Icon
Thank you!
Regards
BB
Eddie System/Environment Report - 7/27/2021 - 5:34 PM UTC
Eddie version: 2.21.0beta
Eddie OS build: linux_x64
Eddie architecture: x64
OS type: Linux
OS name: Unknown
OS version: Linux RYZEN 5.11.0-25-generic #27-Ubuntu SMP Fri Jul 9 23:06:29 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
OS architecture: x64
Mono /.Net Framework: 6.12.0.122 (tarball Mon Feb 22 17:33:28 UTC 2021); Framework: v4.0.30319
TUN driver: /dev/net/tun
OpenVPN: 2.5.3 - OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10 (/usr/local/sbin/openvpn)
Hummingbird:  ()
WireGuard: 1.0.0
SSH: OpenSSH_8.4p1 Ubuntu-5ubuntu1, OpenSSL 1.1.1j  16 Feb 2021 (/usr/bin/ssh)
SSL: stunnel 5.56 (/usr/bin/stunnel4)
curl: 7.74.0 (/usr/bin/curl)
Profile path: /home/b0t0x/.config/eddie/default.profile
Data path: /home/b0t0x/.config/eddie
Application path: /usr/lib/eddie-ui
Executable path: /usr/lib/eddie-ui/eddie-ui.exe
Command line arguments: (2 args) path.resources="/usr/share/eddie-ui" path.exec="/usr/bin/eddie-ui"
Network Lock Active: No
Connected to VPN: No
Detected DNS: 127.0.0.53
Test DNS IPv4: Ok
Test DNS IPv6: Failed
Test Ping IPv4: 31 ms
Test Ping IPv6: Failed
Test HTTP IPv4: Ok
Test HTTP IPv6: Error: curl: (7) Couldn't connect to server
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
key: (omissis)
updater.channel: beta
areas.blacklist: us,de,ca,se,ua,ee,sg,jp,nz,lv,br
mode.type: openvpn
mode.protocol: UDP
mode.port: 1194
mode.alt: 2
netlock.mode: linux_iptables
netlock.allow_private: False
netlock.allow_dhcp: False
network.entry.iplayer: ipv4-only
network.ipv6.mode: block
openvpn.custom: mssfix 1400
reneg-sec 1800
openvpn.sndbuf: 524288
openvpn.rcvbuf: 524288
advanced.expert: True
advanced.manifest.refresh: 10
gui.notifications: False
Logs:
. 2021.07.27 19:33:45 - Eddie version: 2.21.0beta / linux_x64, System: Linux, Name: Unknown, Version: Linux RYZEN 5.11.0-25-generic #27-Ubuntu SMP Fri Jul 9 23:06:29 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux, Mono/.Net: 6.12.0.122 (tarball Mon Feb 22 17:33:28 UTC 2021); Framework: v4.0.30319
. 2021.07.27 19:33:45 - Command line arguments (2): path.resources="/usr/share/eddie-ui" path.exec="/usr/bin/eddie-ui"
. 2021.07.27 19:33:45 - Raise system privileges
. 2021.07.27 19:33:52 - Reading options from /home/b0t0x/.config/eddie/default.profile
. 2021.07.27 19:33:53 - Tun Driver - /dev/net/tun
. 2021.07.27 19:33:53 - OpenVPN - Version: 2.5.3 - OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10 (/usr/local/sbin/openvpn)
. 2021.07.27 19:33:53 - SSH - Version: OpenSSH_8.4p1 Ubuntu-5ubuntu1, OpenSSL 1.1.1j  16 Feb 2021 (/usr/bin/ssh)
. 2021.07.27 19:33:53 - SSL - Version: stunnel 5.56 (/usr/bin/stunnel4)
. 2021.07.27 19:33:53 - curl - Version: 7.74.0 (/usr/bin/curl)
I 2021.07.27 19:33:54 - Ready
. 2021.07.27 19:33:55 - Collect information about AirVPN completed
I 2021.07.27 19:34:35 - Session starting.
I 2021.07.27 19:34:35 - Checking authorization ...
! 2021.07.27 19:34:36 - Connecting to Alzirr (Netherlands, Alblasserdam)
. 2021.07.27 19:34:36 - Routes, add 213.152.187.207/32 for interface "enp3s0".
. 2021.07.27 19:34:36 - Routes, add 213.152.187.207/32 for interface "enp3s0", already exists.
. 2021.07.27 19:34:36 - OpenVPN > OpenVPN 2.5.3 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jul  4 2021
. 2021.07.27 19:34:36 - OpenVPN > library versions: OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10
. 2021.07.27 19:34:36 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.07.27 19:34:36 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.07.27 19:34:36 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.07.27 19:34:36 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.07.27 19:34:36 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.187.207:1194
. 2021.07.27 19:34:36 - OpenVPN > Socket Buffers: R=[212992->425984] S=[212992->425984]
. 2021.07.27 19:34:36 - OpenVPN > UDP link local: (not bound)
. 2021.07.27 19:34:36 - OpenVPN > UDP link remote: [AF_INET]213.152.187.207:1194
. 2021.07.27 19:34:36 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.187.207:1194, sid=6099ec9c d6432d02
. 2021.07.27 19:34:36 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.07.27 19:34:36 - OpenVPN > VERIFY KU OK
. 2021.07.27 19:34:36 - OpenVPN > Validating certificate extended key usage
. 2021.07.27 19:34:36 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.07.27 19:34:36 - OpenVPN > VERIFY EKU OK
. 2021.07.27 19:34:36 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Alzirr, emailAddress=info@airvpn.org
. 2021.07.27 19:34:36 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2021.07.27 19:34:36 - OpenVPN > [Alzirr] Peer Connection Initiated with [AF_INET]213.152.187.207:1194
. 2021.07.27 19:34:36 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.8.194.1,dhcp-option DNS6 fde6:7a:7d20:4c2::1,tun-ipv6,route-gateway 10.8.194.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:4c2::1077/64 fde6:7a:7d20:4c2::1,ifconfig 10.8.194.121 255.255.255.0,peer-id 5,cipher AES-256-GCM'
. 2021.07.27 19:34:36 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.07.27 19:34:36 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.8.194.1'
. 2021.07.27 19:34:36 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:4c2::1'
. 2021.07.27 19:34:36 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2021.07.27 19:34:36 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:4c2::1077/64 fde6:7a:7d20:4c2::1'
. 2021.07.27 19:34:36 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.07.27 19:34:36 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.07.27 19:34:36 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.07.27 19:34:36 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.07.27 19:34:36 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.07.27 19:34:36 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.07.27 19:34:36 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.07.27 19:34:36 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.07.27 19:34:36 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.07.27 19:34:36 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.07.27 19:34:36 - OpenVPN > TUN/TAP device tun0 opened
. 2021.07.27 19:34:36 - OpenVPN > net_iface_mtu_set: mtu 1500 for tun0
. 2021.07.27 19:34:36 - OpenVPN > net_iface_up: set tun0 up
. 2021.07.27 19:34:36 - OpenVPN > net_addr_v4_add: 10.8.194.121/24 dev tun0
. 2021.07.27 19:34:41 - OpenVPN > Initialization Sequence Completed
. 2021.07.27 19:34:42 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
. 2021.07.27 19:34:42 - Routes, add 0.0.0.0/1 for interface "tun0".
. 2021.07.27 19:34:42 - Routes, add 128.0.0.0/1 for interface "tun0".
. 2021.07.27 19:34:42 - Routes, add 213.152.187.205/32 for interface "tun0".
W 2021.07.27 19:34:42 - Routes, add 2a00:1678:1337:7a20:5bfe:98a:a67c:3dd3/128 for interface "tun0" failed: Exception: exit:2; err:RTNETLINK answers: Operation not supported
! 2021.07.27 19:34:42 - Disconnecting
. 2021.07.27 19:34:42 - Sending soft termination signal
. 2021.07.27 19:34:42 - OpenVPN > event_wait : Interrupted system call (code=4)
. 2021.07.27 19:34:42 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2021.07.27 19:34:47 - OpenVPN > Closing TUN/TAP interface
. 2021.07.27 19:34:47 - OpenVPN > net_addr_v4_del: 10.8.194.121 dev tun0
. 2021.07.27 19:34:47 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2021.07.27 19:34:47 - Routes, delete 0.0.0.0/1 for interface "tun0", not exists.
. 2021.07.27 19:34:47 - Routes, delete 128.0.0.0/1 for interface "tun0", not exists.
. 2021.07.27 19:34:47 - Routes, delete 213.152.187.207/32 for interface "enp3s0".
. 2021.07.27 19:34:47 - Routes, delete 213.152.187.205/32 for interface "tun0", not exists.
. 2021.07.27 19:34:47 - Routes, delete 2a00:1678:1337:7a20:5bfe:98a:a67c:3dd3/128 for interface "tun0", not exists.
. 2021.07.27 19:34:47 - Routes, delete 213.152.187.207/32 for interface "enp3s0", not exists.
. 2021.07.27 19:34:47 - DNS of the system restored to original settings (Rename method)
. 2021.07.27 19:34:47 - Connection terminated.
I 2021.07.27 19:34:49 - Cancel requested.
! 2021.07.27 19:34:49 - Session terminated.
Network Interfaces and Routes:
    "support_ipv4": true,
    "support_ipv6": false,
    "routes": [
            "destination": "0.0.0.0\/0",
            "gateway": "192.168.0.1",
            "interface": "enp3s0",
            "metric": "100",
            "proto": "dhcp"
            "destination": "169.254.0.0\/16",
            "metric": "1000",
            "scope": "link"
            "destination": "192.168.0.0\/24",
            "metric": "100",
            "proto": "kernel",
            "scope": "link",
            "src": "192.168.0.115"
    "ipv4-default-gateway": "192.168.0.1",
    "ipv4-default-interface": "enp3s0",
    "interfaces": [
            "friendly": "lo",
            "id": "lo",
            "name": "lo",
            "description": "lo",
            "type": "Loopback",
            "status": "Unknown",
            "bytes_received": "135692",
            "bytes_sent": "135692",
            "ips": [
                "127.0.0.1"
            "bind": true
            "friendly": "enp3s0",
            "id": "enp3s0",
            "name": "enp3s0",
            "description": "enp3s0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_received": "92216249",
            "bytes_sent": "3377401",
            "ips": [
                "192.168.0.115"
            "bind": true
ip addr show:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
2: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether b4:2e:99:95:97:ab brd ff:ff:ff:ff:ff:ff
    inet 192.168.0.115/24 brd 192.168.0.255 scope global dynamic noprefixroute enp3s0
       valid_lft 603016sec preferred_lft 603016sec
ip link show:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
2: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
AMD Ryzen 3950X @ 105W PPL
Gigabyte X570 Aorus Elite
Nvidia RTX 4070 Ti Super
Corsair DDR4-3200 32GB
Yes, is a bug in this version, will be fixed in the next release.
To all: i wrote some posts ago that a new version will be released in a few days: sorry but we discovered an issue that requires time, a new beta version is expected to be released in mid-August. Please have patience, and revert to stable version in the meantime. Thanks.
I'm already running wireguard client on my pfsense box to another VPN provider.  If you need anybody to be testing from that environment give me a shout.
It would be great if the next beta updated Wintun to a newer version than 0.8. There has been significant improvements to it since then but the non standard install method makes it difficult to update independently of Eddie.
I'm running
Edition    Windows 10 Pro
Version    20H2
Installed on    ‎15/‎02/‎2021
OS build    19042.1110
Experience    Windows Feature Experience Pack 120.2212.3530.0
Upon upgrading to the new beta version, my IPv4 address was exposed. After disconnecting, I couldn't get Eddie to connect again. The logfile is attached.
Fortunately, downgrading to Eddie 2.20.0 appears to have solved the problem.
Another problem I would appreciate help with is that after using Eddie's network lock feature, my box will not connect without Eddie installed, running and connected.
Thank you
Eddie_20210804_073600.txt
Hi volkhart,
the problem seems to be a filtering rule in the windows firewall.
"W 2021.08.04 07:35:43 - Windows WFP, unexpected: Rule 'dns_block_all' already exists
! 2021.08.04 07:35:43 - Disconnecting"
Greets
kiwi
16 hours ago, kiwi said:
Hi volkhart,
Greets
kiwi
Thank you. That might explain why I could not connect again. But I am still at a loss how this setting came to be after Version 2.21 had already been running. And how was the problem solved when I downgraded back to Version 2.20? And why was my provider's IPv4 address exposed under Version 2.21 in the first place?
Having a weird issue using Hummingbird 1.1.2 with the new Eddie, that happened once in a blue moon in the last version too but not as bad as it is now.. This is still all on the latest Big Sur..
Seems like when my internet connection really gets going, say downloading a public torrent that will come in at like 30MiB/s, Hummingbird starts making the Mac's Notifications start freaking out.
Yesterday while downloading something, internet kicked up to 30MiB/s in QBitTorrent (300 mbits in Eddie's meter), and just a flood of errors while transferring about no buffer space being available. Was about to blame QBitTorrent, but it also happens in good old Safari, or even copying something directly from my Mac to my NAS drive over the local 192.x.x.x network. The minute the connection gets 'up to speed' it will start spitting out those errors, I had over 200 in the few minutes it took to download a torrent yesterday. The files and everything are coming through ok, but those notices just keep popping up every few seconds on the Mac when it happens and my Notification Center is constantly popping up while Im trying to do something else
Turned off Hummingbird last night and not a single issue since. Looks like my log file was wiped when I reconnected but if you need the exact error, I can always recheck Hummingbird and all I need to do is download something that will really kick up my bandwidth and the errors will start flooding in if you need it. This has happened occasionally with Hummingbird, although its way more often now to the point its frustrating when the flood of notifications won't stop. Before this it was manageable and only happened once in awhile.
@Monotremata
Yes, please send us (in a ticket maybe, because this thread is for Eddie) the complete Eddie log (Eddie log will include any log by Hummingbird) pertaining to the event. From your description it definitely sounds like some unexpected OpenVPN3-AirVPN library problem. Do you connect in TCP or UDP?
On 8/10/2021 at 3:45 AM, Staff said:
@Monotremata
I leave it on the default so it connects over UDP every time. Ill grab a log and everything for a ticket. It shouldn't be too hard to make it happen I just need to copy a big file like a movie or something over to my NAS and it should start popping up pretty quickly.
Version 2.21.1 (Thu, 19 Aug 2021 12:19:20 +0000)
  • [change] [windows] OpenVPN 2.5.3 also in Windows 7/8
  • [change] [linux] Removed "libappindicator1" dependency in .deb package
  • [bugfix] [linux] Fixed an issue with portable/AppImage packages ('cannot open shared object file')
  • [bugfix] [windows] Fixed Windows 7 issues
  • [bugfix] [all] Fixed an issue when IPv6 is disabled at system level
  • [bugfix] [windows] Updated libcurl
  • [change] [all] New ping engine
Windows users: now if Wintun is used (default from this version), a network adapter is created when session starts and destroyed when session ends.
Wintun driver is installed (or upgraded) when the adapter is created and removed when the adapter is removed.
We added an option to keep the adapter in Preferences->Advanced window.
Windows/Linux/macOS: we rewrote the latency/ping system to make it work better and faster, resolve some UI issues in Linux and provide more accurate results in macOS.
@airvpnforumuser and other: issues after system suspension, and the error "Windows WFP, unexpected: Rule 'ipv6_block_all' already exists" is still under investigation, it is our next priority.
About Windows OS compatibility: Windows 8 works exactly like Windows 10.  In Windows 7 the latest Wintun driver doesn't work for some currently unknown reason, so it is not used (OpenVPN works with the tapdriver6), and for the same reason Wireguard (which can use ONLY Wintun) will not be supported on Win7.
Kind regards and datalove
Even after 3 downloads: Installer integrity check has failed. NSIS_Error.
As I downloaded it three times, I guess its not a problem on my end (Win 10x64)
Fixed, please retry, sorry.
