I have built a docker container using the https://registry.hub.docker.com/r/markusmcnugen/qbittorrentvpn image containing qbittorrent.
The container is running on a DS1019+ Synology NAS DSM 6.2.4.-25556.
The connection is supposed to be made using the files generated by the OpenVPN Config Generator.
For some reason the container makes no attempt to establish the VPN connection, doileak.com indicates that qb is leaking the router's WAN ip address.
Any thoughts appreciated.
Seems like a problem specific to that container. Ask in the GitHub repo.
