Judas4all 3 Posted ... Hi guys, I'm running my pfSense setup since a long while and recently I've upgraded to the 2.5.1 release. After that I've noticed that port forwarding stopped working. It looks like the Firewall and NAT does what it should. I'm a bit lost... any ideas ? Quote Share this post Link to post
ParnBlade 0 Posted ... Hello, same things happen to my setup. pfSense 2.5.0 with config for Airvpn tuto = port forwarding work // upgrade pfSense 2.5.1 port forwarding KO Test with config from https://nguvu.org same things Test with last version of OPNsense same thing. It's seems that there is a problème a top of the tunnel vpn. I continu to test Quote Share this post Link to post
Judas4all 3 Posted ... Thanks @ParnBlade, I was just about to re-do my setup with the mentioned guide, but if you have already tried it I will leave it as it is. Do you think this is something AirVPN could help with ? Or is this a bug in the pfSense config ? I found that the support forum of pfSense isn't really supportive when it comes to VPN configuration with any 3rd Party vendor. Quote Share this post Link to post
Judas4all 3 Posted ... I might try a downgrade by doing a fresh install and importing my previous config. 2.5.0 is available here:https://nyifiles.netgate.com/mirror/downloads/ Quote Share this post Link to post
Judas4all 3 Posted ... Just by reading the Release notes (the 3rd time now) I spotted this:https://redmine.pfsense.org/issues/11805https://docs.netgate.com/pfsense/en/latest/releases/21-02-2_2-5-1.html Quote Share this post Link to post
Judas4all 3 Posted ... Ok, the today's DEV version fixed it:https://i.imgur.com/yopuUVC.png Quote Share this post Link to post
flat4 95 Posted ... Well that sucks, no wonder my syncthing has been been working since I upgraded. I guess I will have to wait until they fix it on the stable, no brave enough to go to the developer. Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
nocturnaltabernacle 2 Posted ... Unchecking these boxes fixed it for me on 2.5.1. Just make sure these don't have unintended consequences for your configuration. 2 flat4 and Caius Iulius reacted to this Quote Share this post Link to post
