lordpatate
Port forwarding does not seems to work anymore
I have setup a port forward in airpvn client area with one free port listed. So far so good. My openvpn is configured correctly on pfsense 2.5.1 (I can use this tunnel with a vm that get the correct ip from the air vpn tunnel). Now I try ot test the port forward.
- Setup a web server that listen on my port forward (this vm can access to airpvn)
- Added a nat in pf to allow port forward to this vm's ip
- Checked all firewall rules on this opn vpn interface to allow the trafic
But any tests I made show that the trafic never reach pfsense..
I try a low level tcpdump on the openvpn interface and never see the trafic on that port. So maybe there is an issue before pfsense...
I am wondering if you guys see this kind of issue recently.
Thanks for any help or advices.
Same for me.
Before GRC Shields UP was showing selected ports as open... now as stealth... why?
EDIT: Seems to be only related tp pfsense 2.5.1 does not exist in 2.5.0
Edited ... by rysP97cxFQPY45Wn
Found out the problem
