khuffmanjr 1 Posted ... Greetings! Long time airvpn user here. In the past, I used an older eddie-cli on CentOS 7 and when I SIGTERM'd it the netlock would deactivate. Today, I'm trying to setup a new Ubuntu 20.04 machine with eddie-ui or eddie-cli but when I SIGTERM it I can't do anything outside of my LAN. And SIGINT hangs and fails. How am I supposed to gracefully stop eddie on Ubuntu 20.04 from terminal, please? Eddie is being called from a script by a systemd service file, FYI. Thanks! Ken Quote Share this post Link to post
Tech Jedi Alex 1522 Posted ... 17 hours ago, khuffmanjr said: Eddie is being called from a script by a systemd service file, FYI. systemctl stop? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
khuffmanjr 1 Posted ... 7 hours ago, OpenSourcerer said: systemctl stop? Sure, I tried that. But netlock stays active. Can't access anything outside of my network when I 'stop', 'SIGTERM' or 'kill' it. Is there no graceful shutdown to the application? Quote Share this post Link to post
Tech Jedi Alex 1522 Posted ... SIGTERM and SIGINT are supposed to be the graceful kill signals, as far as I remember. Weird that they don't work here… maybe open a ticket to professional support? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
iwih2gk 97 Posted ... My approach is to use NFT rules (no IP tables) with Eddie. That way Eddie will setup a full nft ruleset with network lock running. The NFT rules of course provide the firewall and tunnel security. But if it hangs, or if you just want to be able to "get out" I have the option to flush the entire NFT ruleset in a second or two. Terminal: sudo nft flush ruleset and then its completely flushed. Now the machine is wide open and you are instantly on your ISP's IP, so don't forget that if you go that route. Just a simple idea if you need it. Quote Share this post Link to post
Staff 10415 Posted ... @khuffmanjr Hello! Can you send us both output of Eddie when you stop it by pressing CTRL-C in the shell and when you stop it will kill -SIGTERM ... ? Kind regards Quote Share this post Link to post
