Not connected, Your IP: 216.73.216.7
magu2k
Still having conenction issues on W10
WIndows 10.
I installed some time ago and when recently my sub ran out, I decided it was time to upgrade. So I installed the newer version.
Can not connect. Or on occasion it appears to conenct and be working just fine, but can not seem to pass any traffic. I checked around the settings there appears to be no gateway or DNS configured. I added a manual DNS server, and it shows in the connection properties, but still requires a gateway.
Symptoms in this situation include very long times to establish link (hangs for quite a while on: Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
When the connection does establish it shows a bit of traffic flow, but will be unable to connect to any sites or anything at all. Disconnecting results in very long disconnect times.
If I toggle check that tunnel works (in advanced) and check airvpn dns (DNS) it seems to change it so that it does not make any connection whatsoever, teh connection jsut fails and tries a different server until you cancel. This too results in a very long time to disconnect.
Eddie System/Environment Report - 5/2/2021 - 9:47 PM UTC
Eddie version: 2.19.7
Eddie OS build: windows_x64
Eddie architecture: x64
OS type: Windows
OS name: Windows 10 Enterprise
OS version: Microsoft Windows NT 10.0.18363.0
OS architecture: x64
Mono /.Net Framework: v4.0.30319
TUN driver: 0901: 9.24.2; wintun: 0.8
OpenVPN: 2.5.0 - OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
Hummingbird:  ()
SSH: OpenSSH_for_Windows_7.7p1, LibreSSL 2.6.5 (C:\WINDOWS\System32\OpenSSH\\ssh.exe)
SSL: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
Profile path: C:\Program Files\AirVPN\default.profile
Data path: C:\Program Files\AirVPN
Application path: C:\Program Files\AirVPN
Executable path: C:\Program Files\AirVPN\Eddie-UI.exe
Command line arguments: (0 args)
Network Lock Active: No
Connected to VPN: Yes, Gienah
Detected DNS: 1.1.1.1
Test DNS IPv4: Failed
Test DNS IPv6: Failed
Test Ping IPv4: Failed
Test Ping IPv6: Failed
Test HTTP IPv4: Error: Fetch url error:Couldn't connect to server
Test HTTP IPv6: Error: Fetch url error:Couldn't connect to server
Test HTTPS: Error: Fetch url error:Couldn't resolve host name
login: (omissis)
password: (omissis)
remember: True
dns.servers: 1.1.1.1
dns.check: False
netlock.allow_dns: True
network.entry.iplayer: ipv4-only
network.ipv6.mode: block
network.ipv6.autoswitch: False
os.single_instance: False
advanced.expert: True
advanced.check.route: False
windows.ssh.plink.force: False
windows.wintun: True
Logs:
. 2021.05.02 15:15:55 - Eddie version: 2.19.7 / windows_x64, System: Windows, Name: Windows 10 Enterprise, Version: Microsoft Windows NT 10.0.18363.0, Mono/.Net: v4.0.30319
. 2021.05.02 15:15:55 - Command line arguments (0):
. 2021.05.02 15:15:55 - Raise system privileges
. 2021.05.02 15:15:59 - Profile path: C:\Program Files\AirVPN\default.profile
. 2021.05.02 15:15:59 - Reading options from C:\Program Files\AirVPN\default.profile
. 2021.05.02 15:16:00 - Tun Driver - 0901: 9.24.2; wintun: 0.8
. 2021.05.02 15:16:00 - OpenVPN - Version: 2.5.0 - OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2021.05.02 15:16:00 - SSH - Version: OpenSSH_for_Windows_7.7p1, LibreSSL 2.6.5 (C:\WINDOWS\System32\OpenSSH\\ssh.exe)
. 2021.05.02 15:16:00 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
. 2021.05.02 15:16:01 - Recovery. Unexpected crash?
. 2021.05.02 15:16:01 - Routes, added a new route, 192.30.89.27 for gateway 10.15.226.1
I 2021.05.02 15:16:01 - Ready
. 2021.05.02 15:16:02 - Collect information about AirVPN completed
I 2021.05.02 15:16:51 - Session starting.
I 2021.05.02 15:16:51 - Checking authorization ...
. 2021.05.02 15:16:52 - IPv6 disabled with packet filtering.
! 2021.05.02 15:16:52 - Connecting to Eltanin (Netherlands, Alblasserdam)
. 2021.05.02 15:16:52 - OpenVPN > OpenVPN 2.5.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 28 2020
. 2021.05.02 15:16:52 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2021.05.02 15:16:52 - OpenVPN > library versions: OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10
. 2021.05.02 15:16:52 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.02 15:16:52 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.02 15:16:52 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.02 15:16:52 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.02 15:16:52 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]134.19.179.149:443
. 2021.05.02 15:16:52 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2021.05.02 15:16:52 - OpenVPN > UDP link local: (not bound)
. 2021.05.02 15:16:52 - OpenVPN > UDP link remote: [AF_INET]134.19.179.149:443
. 2021.05.02 15:16:52 - OpenVPN > TLS: Initial packet from [AF_INET]134.19.179.149:443, sid=a0c1145f 605e947e
. 2021.05.02 15:16:52 - OpenVPN > VERIFY KU OK
. 2021.05.02 15:16:52 - OpenVPN > Validating certificate extended key usage
. 2021.05.02 15:16:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.05.02 15:16:52 - OpenVPN > VERIFY EKU OK
. 2021.05.02 15:16:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Eltanin, emailAddress=info@airvpn.org
. 2021.05.02 15:16:52 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.05.02 15:16:52 - OpenVPN > [Eltanin] Peer Connection Initiated with [AF_INET]134.19.179.149:443
. 2021.05.02 15:16:53 - OpenVPN > SENT CONTROL [Eltanin]: 'PUSH_REQUEST' (status=1)
. 2021.05.02 15:16:53 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.33.206.1,dhcp-option DNS6 fde6:7a:7d20:1dce::1,tun-ipv6,route-gateway 10.33.206.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1dce::10e1/64 fde6:7a:7d20:1dce::1,ifconfig 10.33.206.227 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2021.05.02 15:16:53 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.05.02 15:16:53 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1dce::1'
. 2021.05.02 15:16:53 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2021.05.02 15:16:53 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:1dce::10e1/64 fde6:7a:7d20:1dce::1'
. 2021.05.02 15:16:53 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.05.02 15:16:53 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.05.02 15:16:53 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.05.02 15:16:53 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.05.02 15:16:53 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.05.02 15:16:53 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.05.02 15:16:53 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.05.02 15:16:53 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.05.02 15:16:53 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.05.02 15:16:53 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.02 15:16:53 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.02 15:16:53 - OpenVPN > interactive service msg_channel=0
. 2021.05.02 15:16:53 - OpenVPN > ROUTE_GATEWAY 192.168.46.1/255.255.255.0 I=8 HWADDR=60:45:cb:9d:89:bf
. 2021.05.02 15:16:53 - OpenVPN > open_tun
. 2021.05.02 15:16:53 - OpenVPN > wintun device [Local Area Connection 2] opened
. 2021.05.02 15:16:54 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 22 static 10.33.206.227 255.255.255.0
. 2021.05.02 15:16:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 22 all
. 2021.05.02 15:16:56 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set dns 22 static 10.33.206.1 validate=no
. 2021.05.02 15:16:57 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 22 all
. 2021.05.02 15:16:57 - OpenVPN > IPv4 MTU set to 1500 on interface 22 using SetIpInterfaceEntry()
. 2021.05.02 15:16:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 134.19.179.149 MASK 255.255.255.255 192.168.46.1
. 2021.05.02 15:16:57 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.05.02 15:16:57 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.05.02 15:16:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.33.206.1
. 2021.05.02 15:16:57 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4
. 2021.05.02 15:16:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.33.206.1
. 2021.05.02 15:16:57 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2021.05.02 15:16:57 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2021.05.02 15:17:59 - DNS leak protection with packet filtering enabled.
. 2021.05.02 15:17:59 - DNS IPv4 of a network adapter forced (Ethernet 1, from manual (192.168.46.1) to 10.33.206.1)
. 2021.05.02 15:17:59 - Routes, added a new route, 134.19.179.147 for gateway 10.33.206.1
. 2021.05.02 15:17:59 - Unable to compute route for 2a00:1678:2470:cccc:cfb7:46af:a9e0:df91: IPv6 VPN gateway not available.
. 2021.05.02 15:17:59 - Flushing DNS
! 2021.05.02 15:17:59 - Connected.
. 2021.05.02 15:17:59 - OpenVPN > Initialization Sequence Completed
! 2021.05.02 15:22:42 - Disconnecting
. 2021.05.02 15:22:42 - Routes, removed a route previously added, 134.19.179.147 for gateway 10.33.206.1
. 2021.05.02 15:22:42 - Sending soft termination signal
. 2021.05.02 15:22:46 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2021.05.02 15:22:47 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 134.19.179.149 MASK 255.255.255.255 192.168.46.1
. 2021.05.02 15:22:47 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2021.05.02 15:22:47 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.33.206.1
. 2021.05.02 15:22:47 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.33.206.1
. 2021.05.02 15:22:47 - OpenVPN > Closing TUN/TAP interface
. 2021.05.02 15:22:48 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete dns 22 all
. 2021.05.02 15:22:49 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 22 10.33.206.227 store=active
. 2021.05.02 15:22:49 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2021.05.02 15:22:49 - Connection terminated.
. 2021.05.02 15:23:55 - IPv6 restored with packet filtering.
. 2021.05.02 15:23:55 - DNS IPv4 of a network adapter restored to original settings (Ethernet 1, to 192.168.46.1)
. 2021.05.02 15:23:55 - DNS leak protection with packet filtering disabled.
. 2021.05.02 15:23:55 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv4
. 2021.05.02 15:23:55 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv6
. 2021.05.02 15:23:55 - Flushing DNS
! 2021.05.02 15:23:55 - Session terminated.
I 2021.05.02 15:24:03 - Session starting.
I 2021.05.02 15:24:03 - Checking authorization ...
. 2021.05.02 15:24:03 - IPv6 disabled with packet filtering.
! 2021.05.02 15:24:03 - Connecting to Cygnus (Netherlands, Alblasserdam)
. 2021.05.02 15:24:04 - OpenVPN > OpenVPN 2.5.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 28 2020
. 2021.05.02 15:24:04 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2021.05.02 15:24:04 - OpenVPN > library versions: OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10
. 2021.05.02 15:24:04 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.02 15:24:04 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.02 15:24:04 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.02 15:24:04 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.02 15:24:04 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.246:443
. 2021.05.02 15:24:04 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2021.05.02 15:24:04 - OpenVPN > UDP link local: (not bound)
. 2021.05.02 15:24:04 - OpenVPN > UDP link remote: [AF_INET]213.152.161.246:443
. 2021.05.02 15:24:04 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.246:443, sid=f7b728c3 6dc54653
. 2021.05.02 15:24:04 - OpenVPN > VERIFY KU OK
. 2021.05.02 15:24:04 - OpenVPN > Validating certificate extended key usage
. 2021.05.02 15:24:04 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.05.02 15:24:04 - OpenVPN > VERIFY EKU OK
. 2021.05.02 15:24:04 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Cygnus, emailAddress=info@airvpn.org
. 2021.05.02 15:24:04 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.05.02 15:24:04 - OpenVPN > [Cygnus] Peer Connection Initiated with [AF_INET]213.152.161.246:443
. 2021.05.02 15:24:04 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.14.238.1,dhcp-option DNS6 fde6:7a:7d20:aee::1,tun-ipv6,route-gateway 10.14.238.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:aee::1001/64 fde6:7a:7d20:aee::1,ifconfig 10.14.238.3 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2021.05.02 15:24:04 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.05.02 15:24:04 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:aee::1'
. 2021.05.02 15:24:04 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2021.05.02 15:24:04 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:aee::1001/64 fde6:7a:7d20:aee::1'
. 2021.05.02 15:24:04 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.05.02 15:24:04 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.05.02 15:24:04 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.05.02 15:24:04 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.05.02 15:24:04 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.05.02 15:24:04 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.05.02 15:24:04 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.05.02 15:24:04 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.05.02 15:24:04 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.05.02 15:24:04 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.02 15:24:04 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.02 15:24:04 - OpenVPN > interactive service msg_channel=0
. 2021.05.02 15:24:04 - OpenVPN > ROUTE_GATEWAY 192.168.46.1/255.255.255.0 I=8 HWADDR=60:45:cb:9d:89:bf
. 2021.05.02 15:24:04 - OpenVPN > open_tun
. 2021.05.02 15:24:04 - OpenVPN > wintun device [Local Area Connection 2] opened
. 2021.05.02 15:24:05 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 22 static 10.14.238.3 255.255.255.0
. 2021.05.02 15:24:06 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 22 all
. 2021.05.02 15:24:08 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set dns 22 static 10.14.238.1 validate=no
. 2021.05.02 15:24:09 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 22 all
. 2021.05.02 15:24:09 - OpenVPN > IPv4 MTU set to 1500 on interface 22 using SetIpInterfaceEntry()
. 2021.05.02 15:24:09 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.246 MASK 255.255.255.255 192.168.46.1
. 2021.05.02 15:24:09 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.05.02 15:24:09 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.05.02 15:24:09 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.14.238.1
. 2021.05.02 15:24:09 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4
. 2021.05.02 15:24:09 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.14.238.1
. 2021.05.02 15:24:09 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2021.05.02 15:24:09 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2021.05.02 15:25:13 - DNS leak protection with packet filtering enabled.
. 2021.05.02 15:25:13 - DNS IPv4 of a network adapter forced (Local Area Connection 2, from manual (10.14.238.1) to 1.1.1.1)
. 2021.05.02 15:25:13 - DNS IPv4 of a network adapter forced (Ethernet 1, from manual (192.168.46.1) to 1.1.1.1)
. 2021.05.02 15:25:13 - Routes, added a new route, 213.152.161.244 for gateway 10.14.238.1
. 2021.05.02 15:25:13 - Unable to compute route for 2a00:1678:2470:49:9349:d7bc:f715:bb08: IPv6 VPN gateway not available.
. 2021.05.02 15:25:13 - Flushing DNS
! 2021.05.02 15:25:14 - Connected.
. 2021.05.02 15:25:14 - OpenVPN > Initialization Sequence Completed
! 2021.05.02 15:26:08 - Disconnecting
. 2021.05.02 15:26:08 - Routes, removed a route previously added, 213.152.161.244 for gateway 10.14.238.1
. 2021.05.02 15:26:08 - Sending soft termination signal
. 2021.05.02 15:26:11 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2021.05.02 15:26:13 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.246 MASK 255.255.255.255 192.168.46.1
. 2021.05.02 15:26:13 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2021.05.02 15:26:13 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.14.238.1
. 2021.05.02 15:26:13 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.14.238.1
. 2021.05.02 15:26:13 - OpenVPN > Closing TUN/TAP interface
. 2021.05.02 15:26:14 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete dns 22 all
. 2021.05.02 15:26:15 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 22 10.14.238.3 store=active
. 2021.05.02 15:26:15 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2021.05.02 15:26:15 - Connection terminated.
. 2021.05.02 15:27:24 - IPv6 restored with packet filtering.
. 2021.05.02 15:27:24 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection 2, to 10.14.238.1)
. 2021.05.02 15:27:24 - DNS IPv4 of a network adapter restored to original settings (Ethernet 1, to 192.168.46.1)
. 2021.05.02 15:27:24 - DNS leak protection with packet filtering disabled.
. 2021.05.02 15:27:24 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv4
. 2021.05.02 15:27:24 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv6
. 2021.05.02 15:27:24 - Flushing DNS
! 2021.05.02 15:27:24 - Session terminated.
. 2021.05.02 15:32:36 - ping 1
. 2021.05.02 15:32:36 - ping 2 W
. 2021.05.02 15:32:36 - ping 2 WE
I 2021.05.02 15:42:40 - Session starting.
I 2021.05.02 15:42:40 - Checking authorization ...
. 2021.05.02 15:42:41 - IPv6 disabled with packet filtering.
! 2021.05.02 15:42:41 - Connecting to Cygnus (Netherlands, Alblasserdam)
. 2021.05.02 15:42:41 - OpenVPN > OpenVPN 2.5.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 28 2020
. 2021.05.02 15:42:41 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2021.05.02 15:42:41 - OpenVPN > library versions: OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10
. 2021.05.02 15:42:41 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.02 15:42:41 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.02 15:42:41 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.02 15:42:41 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.02 15:42:41 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.246:443
. 2021.05.02 15:42:41 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2021.05.02 15:42:41 - OpenVPN > UDP link local: (not bound)
. 2021.05.02 15:42:41 - OpenVPN > UDP link remote: [AF_INET]213.152.161.246:443
. 2021.05.02 15:42:41 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.246:443, sid=57c178b6 8cceae25
. 2021.05.02 15:42:41 - OpenVPN > VERIFY KU OK
. 2021.05.02 15:42:41 - OpenVPN > Validating certificate extended key usage
. 2021.05.02 15:42:41 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.05.02 15:42:41 - OpenVPN > VERIFY EKU OK
. 2021.05.02 15:42:41 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Cygnus, emailAddress=info@airvpn.org
. 2021.05.02 15:42:41 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.05.02 15:42:41 - OpenVPN > [Cygnus] Peer Connection Initiated with [AF_INET]213.152.161.246:443
. 2021.05.02 15:42:42 - OpenVPN > SENT CONTROL [Cygnus]: 'PUSH_REQUEST' (status=1)
. 2021.05.02 15:42:42 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.14.238.1,dhcp-option DNS6 fde6:7a:7d20:aee::1,tun-ipv6,route-gateway 10.14.238.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:aee::1001/64 fde6:7a:7d20:aee::1,ifconfig 10.14.238.3 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2021.05.02 15:42:42 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.05.02 15:42:42 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:aee::1'
. 2021.05.02 15:42:42 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2021.05.02 15:42:42 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:aee::1001/64 fde6:7a:7d20:aee::1'
. 2021.05.02 15:42:42 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.05.02 15:42:42 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.05.02 15:42:42 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.05.02 15:42:42 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.05.02 15:42:42 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.05.02 15:42:42 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.05.02 15:42:42 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.05.02 15:42:42 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.05.02 15:42:42 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.05.02 15:42:42 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.02 15:42:42 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.02 15:42:42 - OpenVPN > interactive service msg_channel=0
. 2021.05.02 15:42:42 - OpenVPN > ROUTE_GATEWAY 192.168.46.1/255.255.255.0 I=8 HWADDR=60:45:cb:9d:89:bf
. 2021.05.02 15:42:42 - OpenVPN > open_tun
. 2021.05.02 15:42:42 - OpenVPN > wintun device [Local Area Connection 2] opened
. 2021.05.02 15:42:43 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 22 static 10.14.238.3 255.255.255.0
. 2021.05.02 15:42:44 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 22 all
. 2021.05.02 15:42:45 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set dns 22 static 10.14.238.1 validate=no
. 2021.05.02 15:42:46 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 22 all
. 2021.05.02 15:42:46 - OpenVPN > IPv4 MTU set to 1500 on interface 22 using SetIpInterfaceEntry()
. 2021.05.02 15:42:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.246 MASK 255.255.255.255 192.168.46.1
. 2021.05.02 15:42:46 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.05.02 15:42:46 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.05.02 15:42:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.14.238.1
. 2021.05.02 15:42:46 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4
. 2021.05.02 15:42:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.14.238.1
. 2021.05.02 15:42:46 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2021.05.02 15:42:46 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2021.05.02 15:43:56 - DNS leak protection with packet filtering enabled.
. 2021.05.02 15:43:56 - DNS IPv4 of a network adapter forced (Local Area Connection 2, from manual (10.14.238.1) to 1.1.1.1)
. 2021.05.02 15:43:56 - DNS IPv4 of a network adapter forced (Ethernet 1, from manual (192.168.46.1) to 1.1.1.1)
. 2021.05.02 15:43:56 - Routes, added a new route, 213.152.161.244 for gateway 10.14.238.1
. 2021.05.02 15:43:56 - Unable to compute route for 2a00:1678:2470:49:9349:d7bc:f715:bb08: IPv6 VPN gateway not available.
. 2021.05.02 15:43:56 - Flushing DNS
! 2021.05.02 15:43:56 - Connected.
. 2021.05.02 15:43:56 - OpenVPN > Initialization Sequence Completed
. 2021.05.02 15:44:44 - ping 1
. 2021.05.02 15:44:44 - ping 2 W
. 2021.05.02 15:44:44 - ping 2 WE
. 2021.05.02 15:44:52 - OpenVPN > [Cygnus] Inactivity timeout (--ping-restart), restarting
. 2021.05.02 15:44:52 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2021.05.02 15:44:52 - OpenVPN > Restart pause, 5 second(s)
! 2021.05.02 15:44:52 - Disconnecting
. 2021.05.02 15:44:52 - Routes, removed a route previously added, 213.152.161.244 for gateway 10.14.238.1
. 2021.05.02 15:44:52 - Sending soft termination signal
. 2021.05.02 15:44:57 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.246 MASK 255.255.255.255 192.168.46.1
. 2021.05.02 15:44:57 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2021.05.02 15:44:57 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.14.238.1
. 2021.05.02 15:44:57 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.14.238.1
. 2021.05.02 15:44:57 - OpenVPN > Closing TUN/TAP interface
. 2021.05.02 15:44:58 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete dns 22 all
. 2021.05.02 15:44:59 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 22 10.14.238.3 store=active
. 2021.05.02 15:44:59 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2021.05.02 15:44:59 - Connection terminated.
. 2021.05.02 15:46:10 - IPv6 restored with packet filtering.
. 2021.05.02 15:46:10 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection 2, to 10.14.238.1)
. 2021.05.02 15:46:10 - DNS IPv4 of a network adapter restored to original settings (Ethernet 1, to 192.168.46.1)
. 2021.05.02 15:46:10 - DNS leak protection with packet filtering disabled.
. 2021.05.02 15:46:10 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv4
. 2021.05.02 15:46:10 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv6
. 2021.05.02 15:46:11 - Collect information about AirVPN completed
I 2021.05.02 15:46:13 - Checking authorization ...
. 2021.05.02 15:46:13 - Flushing DNS
! 2021.05.02 15:46:14 - Session terminated.
I 2021.05.02 15:47:09 - Session starting.
I 2021.05.02 15:47:09 - Checking authorization ...
. 2021.05.02 15:47:09 - IPv6 disabled with packet filtering.
! 2021.05.02 15:47:09 - Connecting to Gienah (Netherlands, Alblasserdam)
. 2021.05.02 15:47:09 - OpenVPN > OpenVPN 2.5.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 28 2020
. 2021.05.02 15:47:09 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2021.05.02 15:47:09 - OpenVPN > library versions: OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10
. 2021.05.02 15:47:09 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.02 15:47:09 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.02 15:47:09 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.02 15:47:09 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.02 15:47:09 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.96:443
. 2021.05.02 15:47:09 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2021.05.02 15:47:09 - OpenVPN > UDP link local: (not bound)
. 2021.05.02 15:47:09 - OpenVPN > UDP link remote: [AF_INET]213.152.162.96:443
. 2021.05.02 15:47:10 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.96:443, sid=58f6e9ad 43c302db
. 2021.05.02 15:47:10 - OpenVPN > VERIFY KU OK
. 2021.05.02 15:47:10 - OpenVPN > Validating certificate extended key usage
. 2021.05.02 15:47:10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.05.02 15:47:10 - OpenVPN > VERIFY EKU OK
. 2021.05.02 15:47:10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Gienah, emailAddress=info@airvpn.org
. 2021.05.02 15:47:10 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.05.02 15:47:10 - OpenVPN > [Gienah] Peer Connection Initiated with [AF_INET]213.152.162.96:443
. 2021.05.02 15:47:10 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.17.206.1,dhcp-option DNS6 fde6:7a:7d20:dce::1,tun-ipv6,route-gateway 10.17.206.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:dce::1013/64 fde6:7a:7d20:dce::1,ifconfig 10.17.206.21 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2021.05.02 15:47:10 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.05.02 15:47:10 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:dce::1'
. 2021.05.02 15:47:10 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2021.05.02 15:47:10 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:dce::1013/64 fde6:7a:7d20:dce::1'
. 2021.05.02 15:47:10 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.05.02 15:47:10 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.05.02 15:47:10 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.05.02 15:47:10 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.05.02 15:47:10 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.05.02 15:47:10 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.05.02 15:47:10 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.05.02 15:47:10 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.05.02 15:47:10 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.05.02 15:47:10 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.02 15:47:10 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.02 15:47:10 - OpenVPN > interactive service msg_channel=0
. 2021.05.02 15:47:10 - OpenVPN > ROUTE_GATEWAY 192.168.46.1/255.255.255.0 I=8 HWADDR=60:45:cb:9d:89:bf
. 2021.05.02 15:47:10 - OpenVPN > open_tun
. 2021.05.02 15:47:10 - OpenVPN > wintun device [Local Area Connection 2] opened
. 2021.05.02 15:47:11 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 22 static 10.17.206.21 255.255.255.0
. 2021.05.02 15:47:12 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 22 all
. 2021.05.02 15:47:13 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set dns 22 static 10.17.206.1 validate=no
. 2021.05.02 15:47:14 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 22 all
. 2021.05.02 15:47:15 - OpenVPN > IPv4 MTU set to 1500 on interface 22 using SetIpInterfaceEntry()
. 2021.05.02 15:47:15 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.96 MASK 255.255.255.255 192.168.46.1
. 2021.05.02 15:47:15 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.05.02 15:47:15 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.05.02 15:47:15 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.17.206.1
. 2021.05.02 15:47:15 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4
. 2021.05.02 15:47:15 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.17.206.1
. 2021.05.02 15:47:15 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2021.05.02 15:47:15 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2021.05.02 15:47:16 - DNS leak protection with packet filtering enabled.
. 2021.05.02 15:47:16 - DNS IPv4 of a network adapter forced (Local Area Connection 2, from manual (10.17.206.1) to 1.1.1.1)
. 2021.05.02 15:47:17 - DNS IPv4 of a network adapter forced (Ethernet 1, from manual (192.168.46.1) to 1.1.1.1)
. 2021.05.02 15:47:17 - Routes, added a new route, 213.152.162.94 for gateway 10.17.206.1
. 2021.05.02 15:47:17 - Unable to compute route for 2a00:1678:2470:32:a6d0:3939:bb6b:a0e4: IPv6 VPN gateway not available.
. 2021.05.02 15:47:17 - Flushing DNS
! 2021.05.02 15:47:17 - Connected.
. 2021.05.02 15:47:17 - OpenVPN > Initialization Sequence Completed
. 2021.05.02 15:47:44 - ping 1
. 2021.05.02 15:47:44 - ping 2 W
. 2021.05.02 15:47:44 - ping 2 WE
Network Interfaces and Routes:
    "support_ipv4": true,
    "support_ipv6": true,
    "routes": [
            "address": "0.0.0.0\/0",
            "interface": "{C1D6F2D2-47A3-4D0E-A619-0BFC819C750F}",
            "gateway": "192.168.46.1",
            "metric": "281"
            "address": "0.0.0.0\/1",
            "interface": "{35F3906F-E2E0-4D36-AF0E-D5E576CE0C5D}",
            "gateway": "10.17.206.1",
            "metric": "3"
            "address": "10.17.206.0\/24",
            "gateway": "link",
            "metric": "259"
            "address": "10.17.206.21",
            "gateway": "link",
            "metric": "259"
            "address": "10.17.206.255",
            "gateway": "link",
            "metric": "259"
            "address": "127.0.0.0\/8",
            "interface": "{6BB4F047-2706-11E5-9BBE-806E6F6E6963}",
            "gateway": "link",
            "metric": "331"
            "address": "127.0.0.1",
            "gateway": "link",
            "metric": "331"
            "address": "127.255.255.255",
            "gateway": "link",
            "metric": "331"
            "address": "128.0.0.0\/1",
            "metric": "3"
            "address": "192.168.46.0\/24",
            "gateway": "link",
            "metric": "281"
            "address": "192.168.46.46",
            "gateway": "link",
            "metric": "281"
            "address": "192.168.46.255",
            "gateway": "link",
            "metric": "281"
            "address": "213.152.162.94",
            "metric": "4"
            "address": "213.152.162.96",
            "metric": "25"
            "address": "224.0.0.0\/4",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "259"
            "address": "255.255.255.255",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "259"
            "address": "::1",
            "gateway": "link",
            "metric": "331"
            "address": "fe80::\/64",
            "gateway": "link",
            "metric": "259"
            "gateway": "link",
            "metric": "281"
            "address": "fe80::3d59:49f6:4351:ad62",
            "gateway": "link",
            "metric": "259"
            "address": "fe80::61af:e689:92a:cbf0",
            "gateway": "link",
            "metric": "281"
            "address": "ff00::\/8",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "259"
            "gateway": "link",
            "metric": "281"
    "interfaces": [
            "friendly": "Local Area Connection 2",
            "id": "{35F3906F-E2E0-4D36-AF0E-D5E576CE0C5D}",
            "name": "Local Area Connection 2",
            "description": "Wintun Userspace Tunnel",
            "type": "Virtual",
            "status": "Up",
            "bytes_received": "250912",
            "bytes_sent": "350509",
            "ips": [
                "10.17.206.21"
            "gateways": [
                "10.17.206.1"
            "bind": true,
            "dns4": "1.1.1.1",
            "dns6": null
            "friendly": "Ethernet 1",
            "id": "{C1D6F2D2-47A3-4D0E-A619-0BFC819C750F}",
            "name": "Ethernet 1",
            "description": "Intel(R) I211 Gigabit Network Connection #2",
            "type": "Ethernet",
            "status": "Up",
            "bytes_received": "207591012893",
            "bytes_sent": "2800587630640",
            "ips": [
                "192.168.46.46"
            "gateways": [
                "192.168.46.1"
            "bind": true,
            "dns4": "1.1.1.1",
            "dns6": null
            "friendly": "Local Area Connection",
            "id": "{CBD8A5E0-C167-4987-AC66-C122610B30EB}",
            "name": "Local Area Connection",
            "description": "TAP-Windows Adapter V9",
            "type": "Virtual",
            "status": "Down",
            "bytes_received": "2760877",
            "bytes_sent": "834998",
            "ips": [
                "fe80::6d23:5304:b0d4:1e14",
                "169.254.30.20"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Ethernet 3",
            "id": "{54F8390A-81A4-4643-940E-6A68AB2B31A4}",
            "name": "Ethernet 3",
            "description": "Windscribe VPN",
            "type": "Ethernet",
            "status": "Down",
            "bytes_received": "0",
            "bytes_sent": "0",
            "ips": [
                "fe80::2d35:2f20:3df6:4b09",
                "169.254.75.9"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Loopback Pseudo-Interface 1",
            "id": "{6BB4F047-2706-11E5-9BBE-806E6F6E6963}",
            "name": "Loopback Pseudo-Interface 1",
            "description": "Software Loopback Interface 1",
            "type": "Loopback",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "::1",
                "127.0.0.1"
            "gateways": [],
            "bind": true,
            "dns4": null,
            "dns6": null
    "ipv4-default-gateway": "10.17.206.1",
    "ipv4-default-interface": "{35F3906F-E2E0-4D36-AF0E-D5E576CE0C5D}"
ipconfig /all:
Windows IP Configuration
   Host Name . . . . . . . . . . . . : mmpc46-010
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Unknown adapter Local Area Connection 2:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Wintun Userspace Tunnel
   Physical Address. . . . . . . . . :
   DHCP Enabled. . . . . . . . . . . : No
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::3d59:49f6:4351:ad62%22(Preferred)
   IPv4 Address. . . . . . . . . . . : 10.17.206.21(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . :
   DNS Servers . . . . . . . . . . . : 1.1.1.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Ethernet 1:
   Description . . . . . . . . . . . : Intel(R) I211 Gigabit Network Connection #2
   Physical Address. . . . . . . . . : 60-45-CB-9D-89-BF
   Link-local IPv6 Address . . . . . : fe80::61af:e689:92a:cbf0%8(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.46.46(Preferred)
   Default Gateway . . . . . . . . . : 192.168.46.1
   DHCPv6 IAID . . . . . . . . . . . : 325076427
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-23-74-D4-9E-60-45-CB-9D-89-BF
Unknown adapter Local Area Connection:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : TAP-Windows Adapter V9
   Physical Address. . . . . . . . . : 00-FF-CB-D8-A5-E0
   DHCP Enabled. . . . . . . . . . . : Yes
Ethernet adapter Ethernet 3:
   Description . . . . . . . . . . . : Windscribe VPN
   Physical Address. . . . . . . . . : 00-FF-54-F8-39-0A
Above is the windows connection properties , no gateway. However, still often get errors when trying to connect to sites saying the DNS could nto be found. Also turning off firewall appears to cause the connection time to be much faster than with firewall on with the testing I have been doing today. Still can nto get an actual working tunnel where I can pass data through.
There is a new stable available.
Does the same thing happen with TAP?
Have tried TAP but will try again, and yeah the downgrade was intentional, but will try going back to the newest release tonight
I first switched to TAP without changing other settings. It connected, but again no through traffic., I tried again with custom DNS removed.
I then upgraded to 2.20.0, I attempted connecting without further changes to settings, keepign tunnel
Eddie System/Environment Report - 5/5/2021 - 6:30 PM UTC
Eddie version: 2.20.0
OS type: Windows
TUN driver: 0901: 9.24.2; wintun: Not found
OpenVPN: 2.5.1 - OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
Hummingbird:  ()
Connected to VPN: No
Detected DNS: 192.168.46.1
Test DNS IPv4: Ok
Test Ping IPv4: 152 ms
Test HTTP IPv4: Ok
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
dns.check: False
Logs:
. 2021.05.05 12:27:04 - Eddie version: 2.20.0 / windows_x64, System: Windows, Name: Windows 10 Enterprise, Version: Microsoft Windows NT 10.0.18363.0, Mono/.Net: v4.0.30319
. 2021.05.05 12:27:04 - Command line arguments (0):
. 2021.05.05 12:27:04 - Profile path: C:\Program Files\AirVPN\default.profile
. 2021.05.05 12:27:05 - Reading options from C:\Program Files\AirVPN\default.profile
. 2021.05.05 12:27:05 - Tun Driver - 0901: 9.24.2; wintun: Not found
. 2021.05.05 12:27:05 - OpenVPN - Version: 2.5.1 - OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2021.05.05 12:27:05 - SSH - Version: OpenSSH_for_Windows_7.7p1, LibreSSL 2.6.5 (C:\WINDOWS\System32\OpenSSH\\ssh.exe)
. 2021.05.05 12:27:05 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
. 2021.05.05 12:27:06 - Recovery. Unexpected crash?
. 2021.05.05 12:27:06 - Routes, added a new route, 192.30.89.27 for gateway 10.15.226.1
I 2021.05.05 12:27:07 - Ready
. 2021.05.05 12:27:08 - Collect information about AirVPN completed
I 2021.05.05 12:27:20 - Session starting.
I 2021.05.05 12:27:20 - Checking authorization ...
. 2021.05.05 12:27:20 - IPv6 disabled with packet filtering.
! 2021.05.05 12:27:20 - Connecting to Hyadum (Netherlands, Alblasserdam)
. 2021.05.05 12:27:21 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021
. 2021.05.05 12:27:21 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2021.05.05 12:27:21 - OpenVPN > library versions: OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10
. 2021.05.05 12:27:21 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.05 12:27:21 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.05 12:27:21 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.05 12:27:21 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.05 12:27:21 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.37:443
. 2021.05.05 12:27:21 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2021.05.05 12:27:21 - OpenVPN > UDP link local: (not bound)
. 2021.05.05 12:27:21 - OpenVPN > UDP link remote: [AF_INET]213.152.161.37:443
. 2021.05.05 12:27:21 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.37:443, sid=bad03a4d 01d5b4e2
. 2021.05.05 12:27:21 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.05.05 12:27:21 - OpenVPN > VERIFY KU OK
. 2021.05.05 12:27:21 - OpenVPN > Validating certificate extended key usage
. 2021.05.05 12:27:21 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.05.05 12:27:21 - OpenVPN > VERIFY EKU OK
. 2021.05.05 12:27:21 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Hyadum, emailAddress=info@airvpn.org
. 2021.05.05 12:27:21 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.05.05 12:27:21 - OpenVPN > [Hyadum] Peer Connection Initiated with [AF_INET]213.152.161.37:443
. 2021.05.05 12:27:21 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.19.78.1,dhcp-option DNS6 fde6:7a:7d20:f4e::1,tun-ipv6,route-gateway 10.19.78.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:f4e::102d/64 fde6:7a:7d20:f4e::1,ifconfig 10.19.78.47 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2021.05.05 12:27:21 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.05.05 12:27:21 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:f4e::1'
. 2021.05.05 12:27:21 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2021.05.05 12:27:21 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:f4e::102d/64 fde6:7a:7d20:f4e::1'
. 2021.05.05 12:27:21 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.05.05 12:27:21 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.05.05 12:27:21 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.05.05 12:27:21 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.05.05 12:27:21 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.05.05 12:27:21 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.05.05 12:27:21 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.05.05 12:27:21 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.05.05 12:27:21 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.05.05 12:27:21 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.05 12:27:21 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.05 12:27:21 - OpenVPN > interactive service msg_channel=0
. 2021.05.05 12:27:21 - OpenVPN > ROUTE_GATEWAY 192.168.46.1/255.255.255.0 I=8 HWADDR=60:45:cb:9d:89:bf
. 2021.05.05 12:27:21 - OpenVPN > open_tun
. 2021.05.05 12:27:21 - OpenVPN > tap-windows6 device [Local Area Connection] opened
. 2021.05.05 12:27:21 - OpenVPN > TAP-Windows Driver Version 9.24
. 2021.05.05 12:27:21 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.19.78.0/10.19.78.47/255.255.255.0 [SUCCEEDED]
. 2021.05.05 12:27:21 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.19.78.47/255.255.255.0 on interface {CBD8A5E0-C167-4987-AC66-C122610B30EB} [DHCP-serv: 10.19.78.254, lease-time: 31536000]
. 2021.05.05 12:27:21 - OpenVPN > Successful ARP Flush on interface [7] {CBD8A5E0-C167-4987-AC66-C122610B30EB}
. 2021.05.05 12:27:21 - OpenVPN > IPv4 MTU set to 1500 on interface 7 using SetIpInterfaceEntry()
. 2021.05.05 12:27:27 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2021.05.05 12:27:27 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.37 MASK 255.255.255.255 192.168.46.1
. 2021.05.05 12:27:27 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.05.05 12:27:27 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.05.05 12:27:27 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.19.78.1
. 2021.05.05 12:27:27 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.19.78.1
. 2021.05.05 12:27:27 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4
. 2021.05.05 12:27:27 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6
. 2021.05.05 12:28:23 - DNS leak protection with packet filtering enabled.
. 2021.05.05 12:28:23 - DNS IPv4 of a network adapter forced (Local Area Connection, from automatic to 10.19.78.1)
. 2021.05.05 12:28:23 - DNS IPv4 of a network adapter forced (Ethernet 1, from manual (192.168.46.1) to 10.19.78.1)
. 2021.05.05 12:28:23 - Routes, added a new route, 213.152.161.35 for gateway 10.19.78.1
. 2021.05.05 12:28:23 - Unable to compute route for 2a00:1678:2470:43:85b2:1f97:5342:c096: IPv6 VPN gateway not available.
. 2021.05.05 12:28:23 - Flushing DNS
! 2021.05.05 12:28:23 - Connected.
. 2021.05.05 12:28:23 - OpenVPN > Initialization Sequence Completed
. 2021.05.05 12:29:20 - OpenVPN > [Hyadum] Inactivity timeout (--ping-restart), restarting
. 2021.05.05 12:29:20 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2021.05.05 12:29:20 - OpenVPN > Restart pause, 5 second(s)
! 2021.05.05 12:29:20 - Disconnecting
. 2021.05.05 12:29:20 - Routes, removed a route previously added, 213.152.161.35 for gateway 10.19.78.1
. 2021.05.05 12:29:20 - Sending soft termination signal
. 2021.05.05 12:29:25 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.37 MASK 255.255.255.255 192.168.46.1
. 2021.05.05 12:29:25 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2021.05.05 12:29:25 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.19.78.1
. 2021.05.05 12:29:25 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.19.78.1
. 2021.05.05 12:29:25 - OpenVPN > Closing TUN/TAP interface
. 2021.05.05 12:29:25 - OpenVPN > TAP: DHCP address released
. 2021.05.05 12:29:25 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2021.05.05 12:29:25 - Connection terminated.
. 2021.05.05 12:30:19 - IPv6 restored with packet filtering.
. 2021.05.05 12:30:19 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection, to automatic)
. 2021.05.05 12:30:19 - DNS IPv4 of a network adapter restored to original settings (Ethernet 1, to 192.168.46.1)
. 2021.05.05 12:30:19 - DNS leak protection with packet filtering disabled.
. 2021.05.05 12:30:19 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4
. 2021.05.05 12:30:19 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv6
. 2021.05.05 12:30:22 - Flushing DNS
! 2021.05.05 12:30:22 - Session terminated.
. 2021.05.05 12:30:27 - ping 1
. 2021.05.05 12:30:27 - ping 2 W
. 2021.05.05 12:30:27 - ping 2 WE
    "routes": [
            "metric": "281"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "address": "::1",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
    "interfaces": [
            "type": "Ethernet",
            "status": "Up",
            "bytes_received": "257948082773",
            "bytes_sent": "3381523974956",
            "ips": [
                "192.168.46.46"
            "gateways": [
                "192.168.46.1"
            "bind": true,
            "dns4": "192.168.46.1",
            "dns6": null
            "type": "Virtual",
            "status": "Down",
            "bytes_received": "3349562",
            "bytes_sent": "1040754",
            "ips": [
                "169.254.30.20"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "type": "Ethernet",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "169.254.75.9"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "type": "Loopback",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "::1",
                "127.0.0.1"
            "gateways": [],
            "bind": true,
            "dns4": null,
            "dns6": null
    "ipv4-default-gateway": "192.168.46.1",
    "ipv4-default-interface": "{C1D6F2D2-47A3-4D0E-A619-0BFC819C750F}"
ipconfig /all:
   DNS Servers . . . . . . . . . . . : 192.168.46.1
It disconnected on it's own after about 1 min.
Let's try a default Eddie config. Close Eddie if it's running, then In your user directory > AppData > Local > Eddie, rename the default.profile to something.else, then relaunch Eddie. Try a connection, report back. :)
This seemingly worked. However, it disconnected very quickly, so I had no real chance to confirm if the tunnel was working but I did successfully refresh a page where it usually would just fail. Seems to be progress.
Eddie System/Environment Report - 5/6/2021 - 3:20 AM UTC
OS type: Windows
Hummingbird:  ()
Detected DNS: 10.27.142.1
Test HTTP IPv4: Ok
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
dns.check: False
Logs:
. 2021.05.05 21:16:37 - Eddie version: 2.20.0 / windows_x64, System: Windows, Name: Windows 10 Enterprise, Version: Microsoft Windows NT 10.0.18363.0, Mono/.Net: v4.0.30319
. 2021.05.05 21:16:37 - Command line arguments (0):
. 2021.05.05 21:16:38 - Profile path: C:\Program Files\AirVPN\default.profile
. 2021.05.05 21:16:39 - Reading options from C:\Program Files\AirVPN\default.profile
. 2021.05.05 21:16:39 - Tun Driver - 0901: 9.24.2; wintun: Not found
. 2021.05.05 21:16:39 - OpenVPN - Version: 2.5.1 - OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2021.05.05 21:16:39 - SSH - Version: OpenSSH_for_Windows_7.7p1, LibreSSL 2.6.5 (C:\WINDOWS\System32\OpenSSH\\ssh.exe)
. 2021.05.05 21:16:39 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
. 2021.05.05 21:16:40 - Recovery. Unexpected crash?
. 2021.05.05 21:16:41 - Routes, removed an existing route, 192.30.89.27 for gateway 10.15.226.1
I 2021.05.05 21:16:41 - Ready
. 2021.05.05 21:16:42 - Collect information about AirVPN completed
I 2021.05.05 21:16:50 - Session starting.
I 2021.05.05 21:16:50 - Checking authorization ...
. 2021.05.05 21:16:51 - IPv6 disabled with packet filtering.
! 2021.05.05 21:16:51 - Connecting to Pyxis (Netherlands, Alblasserdam)
. 2021.05.05 21:16:51 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021
. 2021.05.05 21:16:51 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2021.05.05 21:16:51 - OpenVPN > library versions: OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10
. 2021.05.05 21:16:51 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.05 21:16:51 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.05 21:16:51 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.05 21:16:51 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.05 21:16:51 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.236:443
. 2021.05.05 21:16:51 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2021.05.05 21:16:51 - OpenVPN > UDP link local: (not bound)
. 2021.05.05 21:16:51 - OpenVPN > UDP link remote: [AF_INET]213.152.161.236:443
. 2021.05.05 21:16:51 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.236:443, sid=7d7999ee 97242bd8
. 2021.05.05 21:16:51 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.05.05 21:16:51 - OpenVPN > VERIFY KU OK
. 2021.05.05 21:16:51 - OpenVPN > Validating certificate extended key usage
. 2021.05.05 21:16:51 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.05.05 21:16:51 - OpenVPN > VERIFY EKU OK
. 2021.05.05 21:16:51 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Pyxis, emailAddress=info@airvpn.org
. 2021.05.05 21:16:52 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.05.05 21:16:52 - OpenVPN > [Pyxis] Peer Connection Initiated with [AF_INET]213.152.161.236:443
. 2021.05.05 21:16:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.27.142.1,dhcp-option DNS6 fde6:7a:7d20:178e::1,tun-ipv6,route-gateway 10.27.142.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:178e::109b/64 fde6:7a:7d20:178e::1,ifconfig 10.27.142.157 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2021.05.05 21:16:52 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.05.05 21:16:52 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:178e::1'
. 2021.05.05 21:16:52 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2021.05.05 21:16:52 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:178e::109b/64 fde6:7a:7d20:178e::1'
. 2021.05.05 21:16:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.05.05 21:16:52 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.05.05 21:16:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.05.05 21:16:52 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.05.05 21:16:52 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.05.05 21:16:52 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.05.05 21:16:52 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.05.05 21:16:52 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.05.05 21:16:52 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.05.05 21:16:52 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.05 21:16:52 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.05 21:16:52 - OpenVPN > interactive service msg_channel=0
. 2021.05.05 21:16:52 - OpenVPN > ROUTE_GATEWAY 192.168.46.1/255.255.255.0 I=8 HWADDR=60:45:cb:9d:89:bf
. 2021.05.05 21:16:52 - OpenVPN > open_tun
. 2021.05.05 21:16:52 - OpenVPN > tap-windows6 device [Local Area Connection] opened
. 2021.05.05 21:16:52 - OpenVPN > TAP-Windows Driver Version 9.24
. 2021.05.05 21:16:52 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.27.142.0/10.27.142.157/255.255.255.0 [SUCCEEDED]
. 2021.05.05 21:16:52 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.27.142.157/255.255.255.0 on interface {CBD8A5E0-C167-4987-AC66-C122610B30EB} [DHCP-serv: 10.27.142.254, lease-time: 31536000]
. 2021.05.05 21:16:52 - OpenVPN > Successful ARP Flush on interface [7] {CBD8A5E0-C167-4987-AC66-C122610B30EB}
. 2021.05.05 21:16:52 - OpenVPN > IPv4 MTU set to 1500 on interface 7 using SetIpInterfaceEntry()
. 2021.05.05 21:16:57 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2021.05.05 21:16:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.236 MASK 255.255.255.255 192.168.46.1
. 2021.05.05 21:16:57 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.05.05 21:16:57 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.05.05 21:16:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.27.142.1
. 2021.05.05 21:16:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.27.142.1
. 2021.05.05 21:16:57 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4
. 2021.05.05 21:16:57 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6
. 2021.05.05 21:17:56 - DNS leak protection with packet filtering enabled.
. 2021.05.05 21:17:56 - DNS IPv4 of a network adapter forced (Local Area Connection, from automatic to 10.27.142.1)
. 2021.05.05 21:17:56 - DNS IPv4 of a network adapter forced (Ethernet 1, from manual (192.168.46.1) to 10.27.142.1)
. 2021.05.05 21:17:56 - Routes, added a new route, 213.152.161.234 for gateway 10.27.142.1
. 2021.05.05 21:17:56 - Unable to compute route for 2a00:1678:2470:47:4b02:630f:4461:a64: IPv6 VPN gateway not available.
. 2021.05.05 21:17:56 - Flushing DNS
! 2021.05.05 21:17:56 - Connected.
. 2021.05.05 21:17:56 - OpenVPN > Initialization Sequence Completed
. 2021.05.05 21:18:52 - OpenVPN > [Pyxis] Inactivity timeout (--ping-restart), restarting
. 2021.05.05 21:18:52 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2021.05.05 21:18:52 - OpenVPN > Restart pause, 5 second(s)
! 2021.05.05 21:18:52 - Disconnecting
. 2021.05.05 21:18:53 - Routes, removed a route previously added, 213.152.161.234 for gateway 10.27.142.1
. 2021.05.05 21:18:53 - Sending soft termination signal
. 2021.05.05 21:18:57 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.236 MASK 255.255.255.255 192.168.46.1
. 2021.05.05 21:18:57 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2021.05.05 21:18:57 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.27.142.1
. 2021.05.05 21:18:57 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.27.142.1
. 2021.05.05 21:18:57 - OpenVPN > Closing TUN/TAP interface
. 2021.05.05 21:18:58 - OpenVPN > TAP: DHCP address released
. 2021.05.05 21:18:58 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2021.05.05 21:18:58 - Connection terminated.
. 2021.05.05 21:19:58 - IPv6 restored with packet filtering.
. 2021.05.05 21:19:58 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection, to automatic)
. 2021.05.05 21:19:58 - DNS IPv4 of a network adapter restored to original settings (Ethernet 1, to 192.168.46.1)
. 2021.05.05 21:19:58 - DNS leak protection with packet filtering disabled.
. 2021.05.05 21:19:58 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4
. 2021.05.05 21:19:58 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv6
. 2021.05.05 21:20:01 - Waiting for latency tests (42 to go)
. 2021.05.05 21:20:03 - Flushing DNS
! 2021.05.05 21:20:03 - Session terminated.
. 2021.05.05 21:20:07 - ping 1
. 2021.05.05 21:20:07 - ping 2 W
. 2021.05.05 21:20:07 - ping 2 WE
. 2021.05.05 21:20:08 - ping 1
. 2021.05.05 21:20:08 - ping 2 W
. 2021.05.05 21:20:08 - ping 2 WE
    "routes": [
            "metric": "281"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "address": "::1",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
    "interfaces": [
            "type": "Ethernet",
            "status": "Up",
            "bytes_received": "270391340236",
            "bytes_sent": "3385022567322",
            "ips": [
                "192.168.46.46"
            "gateways": [
                "192.168.46.1"
            "bind": true,
            "dns6": null
            "type": "Virtual",
            "status": "Down",
            "bytes_received": "3377826",
            "bytes_sent": "1094532",
            "ips": [
                "169.254.30.20"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "type": "Ethernet",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "169.254.75.9"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "type": "Loopback",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "::1",
                "127.0.0.1"
            "gateways": [],
            "bind": true,
            "dns4": null,
            "dns6": null
ipconfig /all:
Ok I have to take that back it may be the tunnel had already quit, but I can not reproduce getting data through the tunnel. Still disconnects after about 1 minute with no data getting through
6 hours ago, magu2k said:
login: (omissis)
password: (omissis)
remember: True
dns.check: False
netlock.allow_dns: True
network.entry.iplayer: ipv4-only
network.ipv6.mode: block
network.ipv6.autoswitch: False
os.single_instance: False
advanced.expert: True
advanced.check.route: False
windows.ssh.plink.force: False
You are still using the old config, not a default configuration. But maybe it was my error because the profile is somewhere else entirely:
Rename that file, please.
I have to concur, the original location appdata\local I changed the profile name, it remains there with a different name and no new profile created in it's place.
Now using default configuration.
Eddie System/Environment Report - 5/7/2021 - 11:29 PM UTC
Eddie OS build: windows_x64
Eddie architecture: x64
OS type: Windows
OS name: Windows 10 Enterprise
OS version: Microsoft Windows NT 10.0.18363.0
OS architecture: x64
Mono /.Net Framework: v4.0.30319
Hummingbird:  ()
SSH:
plink 0.73
Build platform: 64-bit x86 Windows
Compiler: clang 7.0.0 (tags/RELEASE_700/final), emulating Visual Studio 2013 (12.0), _MSC_VER=1800
Source commit: 745ed3ad3beaf52fc623827e770b3a068b238dd5 (C:\Program Files\AirVPN\plink.exe)
SSL: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
Data path: C:\Program Files\AirVPN
Application path: C:\Program Files\AirVPN
Executable path: C:\Program Files\AirVPN\Eddie-UI.exe
Command line arguments: (0 args)
Network Lock Active: No
Test DNS IPv4: Ok
Test DNS IPv6: Failed
Test Ping IPv4: 153 ms
Test Ping IPv6: Failed
Test HTTP IPv4: Ok
Test HTTP IPv6: Error: Fetch url error:Couldn't connect to server
Test HTTPS: Ok
login: (omissis)
password: (omissis)
Logs:
. 2021.05.07 17:22:32 - Eddie version: 2.20.0 / windows_x64, System: Windows, Name: Windows 10 Enterprise, Version: Microsoft Windows NT 10.0.18363.0, Mono/.Net: v4.0.30319
. 2021.05.07 17:22:32 - Command line arguments (0):
. 2021.05.07 17:22:32 - Profile path: C:\Program Files\AirVPN\default.profile
. 2021.05.07 17:22:32 - Profile options not found, using defaults.
. 2021.05.07 17:22:33 - Tun Driver - 0901: 9.24.2; wintun: Not found
. 2021.05.07 17:22:33 - OpenVPN - Version: 2.5.1 - OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2021.05.07 17:22:33 - SSH - Version: plink 0.73
. 2021.05.07 17:22:33 -     Build platform: 64-bit x86 Windows
. 2021.05.07 17:22:33 -     Compiler: clang 7.0.0 (tags/RELEASE_700/final), emulating Visual Studio 2013 (12.0), _MSC_VER=1800
. 2021.05.07 17:22:33 -     Source commit: 745ed3ad3beaf52fc623827e770b3a068b238dd5 (C:\Program Files\AirVPN\plink.exe)
. 2021.05.07 17:22:33 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
. 2021.05.07 17:22:34 - Recovery. Unexpected crash?
. 2021.05.07 17:22:34 - Routes, removed an existing route, 192.30.89.27 for gateway 10.15.226.1
I 2021.05.07 17:22:34 - Ready
. 2021.05.07 17:22:35 - Collect information about AirVPN completed
I 2021.05.07 17:22:50 - Checking login ...
F 2021.05.07 17:22:51 - Wrong login/password.
F 2021.05.07 17:22:57 - Wrong login/password.
F 2021.05.07 17:24:26 - Wrong login/password.
F 2021.05.07 17:24:37 - Wrong login/password.
. 2021.05.07 17:25:27 - Above log line repeated 4 times more
! 2021.05.07 17:25:27 - Logged in.
I 2021.05.07 17:26:48 - Session starting.
I 2021.05.07 17:26:48 - Checking authorization ...
! 2021.05.07 17:26:49 - Connecting to Ran (United States of America, Dallas, Texas)
. 2021.05.07 17:26:49 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021
. 2021.05.07 17:26:49 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2021.05.07 17:26:49 - OpenVPN > library versions: OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10
. 2021.05.07 17:26:49 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.07 17:26:49 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.07 17:26:49 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.07 17:26:49 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.07 17:26:49 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.249.230.29:443
. 2021.05.07 17:26:49 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2021.05.07 17:26:49 - OpenVPN > UDP link local: (not bound)
. 2021.05.07 17:26:49 - OpenVPN > UDP link remote: [AF_INET]199.249.230.29:443
. 2021.05.07 17:26:49 - OpenVPN > TLS: Initial packet from [AF_INET]199.249.230.29:443, sid=446b4e37 3b2638f9
. 2021.05.07 17:26:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.05.07 17:26:49 - OpenVPN > VERIFY KU OK
. 2021.05.07 17:26:49 - OpenVPN > Validating certificate extended key usage
. 2021.05.07 17:26:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.05.07 17:26:49 - OpenVPN > VERIFY EKU OK
. 2021.05.07 17:26:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ran, emailAddress=info@airvpn.org
. 2021.05.07 17:26:49 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.05.07 17:26:49 - OpenVPN > [Ran] Peer Connection Initiated with [AF_INET]199.249.230.29:443
. 2021.05.07 17:26:50 - OpenVPN > SENT CONTROL [Ran]: 'PUSH_REQUEST' (status=1)
. 2021.05.07 17:26:50 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.27.174.1,dhcp-option DNS6 fde6:7a:7d20:17ae::1,tun-ipv6,route-gateway 10.27.174.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:17ae::105f/64 fde6:7a:7d20:17ae::1,ifconfig 10.27.174.97 255.255.255.0,peer-id 4,cipher AES-256-GCM'
. 2021.05.07 17:26:50 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.05.07 17:26:50 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.05.07 17:26:50 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.05.07 17:26:50 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.05.07 17:26:50 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.05.07 17:26:50 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.05.07 17:26:50 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.05.07 17:26:50 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.05.07 17:26:50 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.05.07 17:26:50 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.05.07 17:26:50 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.07 17:26:50 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.07 17:26:50 - OpenVPN > interactive service msg_channel=0
. 2021.05.07 17:26:50 - OpenVPN > ROUTE_GATEWAY 192.168.46.1/255.255.255.0 I=8 HWADDR=60:45:cb:9d:89:bf
. 2021.05.07 17:26:50 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.05.07 17:26:50 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found.   (code=1168)
. 2021.05.07 17:26:50 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2021.05.07 17:26:50 - OpenVPN > open_tun
. 2021.05.07 17:26:50 - OpenVPN > tap-windows6 device [Local Area Connection] opened
. 2021.05.07 17:26:50 - OpenVPN > TAP-Windows Driver Version 9.24
. 2021.05.07 17:26:50 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.27.174.0/10.27.174.97/255.255.255.0 [SUCCEEDED]
. 2021.05.07 17:26:50 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.27.174.97/255.255.255.0 on interface {CBD8A5E0-C167-4987-AC66-C122610B30EB} [DHCP-serv: 10.27.174.254, lease-time: 31536000]
. 2021.05.07 17:26:50 - OpenVPN > Successful ARP Flush on interface [7] {CBD8A5E0-C167-4987-AC66-C122610B30EB}
. 2021.05.07 17:26:50 - OpenVPN > IPv4 MTU set to 1500 on interface 7 using SetIpInterfaceEntry()
. 2021.05.07 17:26:50 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 7 fde6:7a:7d20:17ae::105f/128 store=active
. 2021.05.07 17:26:50 - OpenVPN > add_route_ipv6(fde6:7a:7d20:17ae::/64 -> fde6:7a:7d20:17ae::105f metric 0) dev Local Area Connection
. 2021.05.07 17:26:50 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:17ae::/64 7 fe80::8 store=active
. 2021.05.07 17:26:50 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2021.05.07 17:26:50 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 7 all
. 2021.05.07 17:26:50 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 7 static fde6:7a:7d20:17ae::1 validate=no
. 2021.05.07 17:26:50 - OpenVPN > IPv6 MTU set to 1500 on interface 7 using SetIpInterfaceEntry()
. 2021.05.07 17:26:55 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2021.05.07 17:26:55 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 199.249.230.29 MASK 255.255.255.255 192.168.46.1
. 2021.05.07 17:26:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.05.07 17:26:55 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.05.07 17:26:55 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.27.174.1
. 2021.05.07 17:26:55 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.27.174.1
. 2021.05.07 17:26:55 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:17ae::1 metric -1) dev Local Area Connection
. 2021.05.07 17:26:55 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 7 fe80::8 store=active
. 2021.05.07 17:26:55 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2021.05.07 17:26:55 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:17ae::1 metric -1) dev Local Area Connection
. 2021.05.07 17:26:55 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 7 fe80::8 store=active
. 2021.05.07 17:26:55 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:17ae::1 metric -1) dev Local Area Connection
. 2021.05.07 17:26:55 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 7 fe80::8 store=active
. 2021.05.07 17:26:55 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:17ae::1 metric -1) dev Local Area Connection
. 2021.05.07 17:26:55 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 7 fe80::8 store=active
. 2021.05.07 17:26:55 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4
. 2021.05.07 17:26:55 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6
. 2021.05.07 17:27:48 - DNS leak protection with packet filtering enabled.
. 2021.05.07 17:27:48 - DNS IPv4 of a network adapter forced (Local Area Connection, from automatic to 10.27.174.1)
. 2021.05.07 17:27:48 - DNS IPv6 of a network adapter forced (Local Area Connection, from automatic to fde6:7a:7d20:17ae::1)
. 2021.05.07 17:27:48 - DNS IPv4 of a network adapter forced (Ethernet 1, from manual (192.168.46.1) to 10.27.174.1)
. 2021.05.07 17:27:48 - DNS IPv6 of a network adapter forced (Ethernet 1, from automatic to fde6:7a:7d20:17ae::1)
. 2021.05.07 17:27:48 - Routes, added a new route, 199.249.230.27 for gateway 10.27.174.1
. 2021.05.07 17:27:48 - Routes, added a new route, 2620:7:6001:c443:c943:8b52:172f:4f3a for gateway fde6:7a:7d20:17ae::1
. 2021.05.07 17:27:48 - Flushing DNS
I 2021.05.07 17:27:48 - Checking route IPv4
. 2021.05.07 17:27:48 - Fetch url error:Couldn't connect to server
. 2021.05.07 17:27:48 - Checking route (2° try)
. 2021.05.07 17:27:49 - Fetch url error:Couldn't connect to server
. 2021.05.07 17:27:49 - Checking route (3° try)
. 2021.05.07 17:27:51 - Fetch url error:Couldn't connect to server
E 2021.05.07 17:27:51 - Checking route IPv4 failed.
. 2021.05.07 17:27:51 - OpenVPN > Initialization Sequence Completed
! 2021.05.07 17:27:51 - Disconnecting
. 2021.05.07 17:27:51 - Routes, removed a route previously added, 199.249.230.27 for gateway 10.27.174.1
. 2021.05.07 17:27:51 - Routes, removed a route previously added, 2620:7:6001:c443:c943:8b52:172f:4f3a for gateway fde6:7a:7d20:17ae::1
. 2021.05.07 17:27:51 - Sending soft termination signal
. 2021.05.07 17:27:54 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2021.05.07 17:27:56 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 199.249.230.29 MASK 255.255.255.255 192.168.46.1
. 2021.05.07 17:27:56 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2021.05.07 17:27:56 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.27.174.1
. 2021.05.07 17:27:56 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.27.174.1
. 2021.05.07 17:27:56 - OpenVPN > delete_route_ipv6(::/3)
. 2021.05.07 17:27:56 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 7 fe80::8 store=active
. 2021.05.07 17:27:56 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2021.05.07 17:27:56 - OpenVPN > delete_route_ipv6(2000::/4)
. 2021.05.07 17:27:56 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 7 fe80::8 store=active
. 2021.05.07 17:27:56 - OpenVPN > delete_route_ipv6(3000::/4)
. 2021.05.07 17:27:56 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 7 fe80::8 store=active
. 2021.05.07 17:27:56 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2021.05.07 17:27:56 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 7 fe80::8 store=active
. 2021.05.07 17:27:56 - OpenVPN > Closing TUN/TAP interface
. 2021.05.07 17:27:56 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 7 all
. 2021.05.07 17:27:56 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:17ae::/64)
. 2021.05.07 17:27:56 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:17ae::/64 7 fe80::8 store=active
. 2021.05.07 17:27:56 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 7 fde6:7a:7d20:17ae::105f store=active
. 2021.05.07 17:27:56 - OpenVPN > TAP: DHCP address released
. 2021.05.07 17:27:56 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2021.05.07 17:27:56 - Connection terminated.
. 2021.05.07 17:27:56 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection, to automatic)
. 2021.05.07 17:27:56 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection, to automatic)
. 2021.05.07 17:27:56 - DNS IPv4 of a network adapter restored to original settings (Ethernet 1, to 192.168.46.1)
. 2021.05.07 17:27:56 - DNS IPv6 of a network adapter restored to original settings (Ethernet 1, to automatic)
. 2021.05.07 17:28:50 - DNS leak protection with packet filtering disabled.
. 2021.05.07 17:28:50 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4
. 2021.05.07 17:28:50 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv6
I 2021.05.07 17:28:53 - Cancel requested.
! 2021.05.07 17:28:53 - Session terminated.
. 2021.05.07 17:28:58 - ping 1
. 2021.05.07 17:28:58 - ping 2 W
. 2021.05.07 17:28:59 - ping 2 WE
    "routes": [
            "metric": "281"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "address": "::1",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "331"
    "interfaces": [
            "type": "Ethernet",
            "status": "Up",
            "bytes_received": "290651799173",
            "bytes_sent": "3852062683912",
            "support_ipv6": false,
            "ips": [
                "192.168.46.46"
            "gateways": [
                "192.168.46.1"
            "bind": true,
            "dns6": null
            "type": "Virtual",
            "status": "Down",
            "bytes_received": "3478307",
            "bytes_sent": "1396420",
            "ips": [
                "169.254.30.20"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "type": "Loopback",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "::1",
                "127.0.0.1"
            "gateways": [],
            "bind": true,
            "dns4": null,
            "dns6": null
ipconfig /all:
Hm, okay. The logs hint at a boringly normal connection process, nothing special about it. You may use your old config again.
Are there any firewalls, antivirus suites or other kinds of traffic management applications you may be running? Did you change any settings regarding networking, either in Windows preferences, device manager or other?
This machine uses a static IP on my local network, not dynamic, shouldn't matter.
I am using windows firewall. Disabling it has the same results just when on, it takes about 3-4x longer to connect/disconnect than when firewall is off.
Windows Defender is entirely disabled.
Not using any other suites currently other than software I run only on a schedule/manually (no live /active scanning) at the moment
Do have some Group Policy items configured, but I do not see anything that should impact this.
For the most part, sharing settings are off, I do nto share/printers or drives from this machine on my network, as everything is on seperate NAS machines.
For the netweork adapter, it's onbaord Intel NIC with intel driver (not MS) and .ooks to be basically default other than things like WOL disabled, and Checksum oflload disabled for IPV6, and energy saving features disabled.
Meant to add, for router I run a pfsense machine, I doubt this could come into play but worth mentioning. It is more or less bleeding edge current release builds except on major revisions, so is entirely up to date right now.
When you enable NetLock and disable route checking in Eddie, this should get you connected. The question is, would routing via VPN work? Can you try?
Very odd... but it is workign at the moment.
Eddie System/Environment Report - 5/11/2021 - 2:58 AM UTC
OS type: Windows
Hummingbird:  ()
SSH: OpenSSH_for_Windows_7.7p1, LibreSSL 2.6.5 (C:\WINDOWS\System32\OpenSSH\\ssh.exe)
Network Lock Active: Yes, Windows Filtering Platform
Connected to VPN: Yes, Angetenar
Detected DNS: 10.9.46.1
Test DNS IPv4: Ok
Test Ping IPv4: Failed
Test HTTP IPv4: Error: Fetch url error:Couldn't connect to server
Test HTTPS: Error: Fetch url error:Couldn't connect to server
login: (omissis)
password: (omissis)
remember: True
dns.check: False
windows.ipv6.bypass_dns: True
Logs:
. 2021.05.08 19:34:10 - Eddie version: 2.20.0 / windows_x64, System: Windows, Name: Windows 10 Enterprise, Version: Microsoft Windows NT 10.0.18363.0, Mono/.Net: v4.0.30319
. 2021.05.08 19:34:10 - Command line arguments (0):
. 2021.05.08 19:34:11 - Profile path: C:\Program Files\AirVPN\default.profile
. 2021.05.08 19:34:11 - Reading options from C:\Program Files\AirVPN\default.profile
. 2021.05.08 19:34:12 - Tun Driver - 0901: 9.24.2; wintun: Not found
. 2021.05.08 19:34:12 - OpenVPN - Version: 2.5.1 - OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2021.05.08 19:34:12 - SSH - Version: OpenSSH_for_Windows_7.7p1, LibreSSL 2.6.5 (C:\WINDOWS\System32\OpenSSH\\ssh.exe)
. 2021.05.08 19:34:12 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
. 2021.05.08 19:34:12 - Recovery. Unexpected crash?
. 2021.05.08 19:34:13 - Routes, removed an existing route, 192.30.89.75 for gateway 10.35.110.1
. 2021.05.08 19:34:13 - Routes, removed an existing route, 2606:9580:100:f:5792:2dec:a4b6:2419 for gateway fde6:7a:7d20:1f6e::1
I 2021.05.08 19:34:13 - Ready
. 2021.05.08 19:34:14 - Collect information about AirVPN completed
. 2021.05.10 20:55:55 - Above log line repeated 98 times more
! 2021.05.10 20:55:55 - Activation of Network Lock - Windows Filtering Platform
I 2021.05.10 20:55:57 - Session starting.
I 2021.05.10 20:55:58 - Checking authorization ...
. 2021.05.10 20:55:58 - IPv6 disabled with packet filtering.
! 2021.05.10 20:55:58 - Connecting to Angetenar (Canada, Toronto, Ontario)
. 2021.05.10 20:55:58 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021
. 2021.05.10 20:55:58 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2021.05.10 20:55:58 - OpenVPN > library versions: OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10
. 2021.05.10 20:55:58 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.10 20:55:58 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.10 20:55:58 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.10 20:55:58 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.10 20:55:58 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.165:443
. 2021.05.10 20:55:58 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2021.05.10 20:55:58 - OpenVPN > UDP link local: (not bound)
. 2021.05.10 20:55:58 - OpenVPN > UDP link remote: [AF_INET]184.75.221.165:443
. 2021.05.10 20:55:59 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.165:443, sid=3dd24f56 9450b4f7
. 2021.05.10 20:55:59 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.05.10 20:55:59 - OpenVPN > VERIFY KU OK
. 2021.05.10 20:55:59 - OpenVPN > Validating certificate extended key usage
. 2021.05.10 20:55:59 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.05.10 20:55:59 - OpenVPN > VERIFY EKU OK
. 2021.05.10 20:55:59 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Angetenar, emailAddress=info@airvpn.org
. 2021.05.10 20:55:59 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.05.10 20:55:59 - OpenVPN > [Angetenar] Peer Connection Initiated with [AF_INET]184.75.221.165:443
. 2021.05.10 20:55:59 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.9.46.1,dhcp-option DNS6 fde6:7a:7d20:52e::1,tun-ipv6,route-gateway 10.9.46.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:52e::10af/64 fde6:7a:7d20:52e::1,ifconfig 10.9.46.177 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2021.05.10 20:55:59 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.05.10 20:55:59 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:52e::1'
. 2021.05.10 20:55:59 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2021.05.10 20:55:59 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:52e::10af/64 fde6:7a:7d20:52e::1'
. 2021.05.10 20:55:59 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.05.10 20:55:59 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.05.10 20:55:59 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.05.10 20:55:59 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.05.10 20:55:59 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.05.10 20:55:59 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.05.10 20:55:59 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.05.10 20:55:59 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.05.10 20:55:59 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.05.10 20:55:59 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.10 20:55:59 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.10 20:55:59 - OpenVPN > interactive service msg_channel=0
. 2021.05.10 20:55:59 - OpenVPN > ROUTE_GATEWAY 192.168.46.1/255.255.255.0 I=6 HWADDR=60:45:cb:9d:89:bf
. 2021.05.10 20:55:59 - OpenVPN > open_tun
. 2021.05.10 20:57:01 - OpenVPN > tap-windows6 device [Local Area Connection] opened
. 2021.05.10 20:57:01 - OpenVPN > TAP-Windows Driver Version 9.24
. 2021.05.10 20:57:01 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.9.46.0/10.9.46.177/255.255.255.0 [SUCCEEDED]
. 2021.05.10 20:57:01 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.9.46.177/255.255.255.0 on interface {CBD8A5E0-C167-4987-AC66-C122610B30EB} [DHCP-serv: 10.9.46.254, lease-time: 31536000]
. 2021.05.10 20:57:01 - OpenVPN > Successful ARP Flush on interface [7] {CBD8A5E0-C167-4987-AC66-C122610B30EB}
. 2021.05.10 20:57:01 - OpenVPN > IPv4 MTU set to 1500 on interface 7 using SetIpInterfaceEntry()
. 2021.05.10 20:57:01 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2021.05.10 20:57:01 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.221.165 MASK 255.255.255.255 192.168.46.1
. 2021.05.10 20:57:01 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.05.10 20:57:01 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.05.10 20:57:01 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.9.46.1
. 2021.05.10 20:57:01 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.9.46.1
. 2021.05.10 20:57:01 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4
. 2021.05.10 20:57:01 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6
. 2021.05.10 20:57:01 - DNS leak protection with packet filtering enabled.
. 2021.05.10 20:57:01 - DNS IPv4 of a network adapter forced (Local Area Connection, from automatic to 10.9.46.1)
. 2021.05.10 20:57:01 - DNS IPv4 of a network adapter forced (Ethernet 1, from manual (192.168.46.1) to 10.9.46.1)
. 2021.05.10 20:57:02 - Routes, added a new route, 184.75.221.163 for gateway 10.9.46.1
. 2021.05.10 20:57:02 - Unable to compute route for 2606:6080:1001:12:257a:8b87:f80d:7579: IPv6 VPN gateway not available.
. 2021.05.10 20:57:02 - Flushing DNS
! 2021.05.10 20:57:02 - Connected.
. 2021.05.10 20:57:02 - OpenVPN > Initialization Sequence Completed
. 2021.05.10 20:57:34 - ping 1
. 2021.05.10 20:57:34 - ping 2 W
. 2021.05.10 20:57:34 - ping 2 WE
. 2021.05.10 20:58:50 - ping 1
. 2021.05.10 20:58:50 - ping 2 W
. 2021.05.10 20:58:50 - ping 2 WE
    "routes": [
            "metric": "281"
            "interface": "{CBD8A5E0-C167-4987-AC66-C122610B30EB}",
            "gateway": "10.9.46.1",
            "metric": "3"
            "address": "10.9.46.0\/24",
            "gateway": "link",
            "metric": "259"
            "address": "10.9.46.177",
            "gateway": "link",
            "metric": "259"
            "address": "10.9.46.255",
            "gateway": "link",
            "metric": "259"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "331"
            "metric": "3"
            "address": "184.75.221.163",
            "metric": "4"
            "address": "184.75.221.165",
            "metric": "25"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "259"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "259"
            "gateway": "link",
            "metric": "281"
            "address": "::1",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "259"
            "address": "fe80::6d23:5304:b0d4:1e14",
            "gateway": "link",
            "metric": "259"
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "259"
    "interfaces": [
            "type": "Virtual",
            "status": "Up",
            "bytes_received": "23750",
            "bytes_sent": "34808",
            "ips": [
                "10.9.46.177"
            "gateways": [
                "10.9.46.1"
            "bind": true,
            "dns4": "10.9.46.1",
            "dns6": null
            "type": "Ethernet",
            "status": "Up",
            "bytes_received": "29881609130",
            "bytes_sent": "240924650978",
            "ips": [
                "192.168.46.46"
            "gateways": [
                "192.168.46.1"
            "bind": true,
            "dns6": null
            "type": "Loopback",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "::1",
                "127.0.0.1"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
    "ipv4-default-gateway": "10.9.46.1",
    "ipv4-default-interface": "{CBD8A5E0-C167-4987-AC66-C122610B30EB}"
ipconfig /all:
   Link-local IPv6 Address . . . . . : fe80::6d23:5304:b0d4:1e14%7(Preferred)
   IPv4 Address. . . . . . . . . . . : 10.9.46.177(Preferred)
   Lease Obtained. . . . . . . . . . : Monday, May 10, 2021 8:55:59 PM
   Lease Expires . . . . . . . . . . : Tuesday, May 10, 2022 8:55:58 PM
   DHCP Server . . . . . . . . . . . : 10.9.46.254
   DHCPv6 IAID . . . . . . . . . . . : 117505995
   DNS Servers . . . . . . . . . . . : 10.9.46.1
I tried as you asked with network lock on. I already had check tunnel off. With network lock on, it connected, no traffic went through. But it did not disconnect. I manually disconnected. turned off network lock, and turned off windows firewall (specifically private and public profile) and connected, and it works. So at teh moment I am not sure which did it, but I generally keep public profile on .
Currently it looks liek this
Eddie System/Environment Report - 5/11/2021 - 3:04 AM UTC
OS type: Windows
Hummingbird:  ()
Connected to VPN: Yes, Hassaleh
Detected DNS: 10.18.142.1
Test DNS IPv4: Ok
Test Ping IPv4: 171 ms
Test HTTP IPv4: Ok
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
dns.check: False
Logs:
! 2021.05.10 20:59:47 - Disconnecting
. 2021.05.10 20:59:47 - Routes, removed a route previously added, 184.75.221.163 for gateway 10.9.46.1
. 2021.05.10 20:59:47 - Sending soft termination signal
. 2021.05.10 20:59:50 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2021.05.10 20:59:52 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 184.75.221.165 MASK 255.255.255.255 192.168.46.1
. 2021.05.10 20:59:52 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2021.05.10 20:59:52 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.9.46.1
. 2021.05.10 20:59:52 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.9.46.1
. 2021.05.10 20:59:52 - OpenVPN > Closing TUN/TAP interface
. 2021.05.10 20:59:52 - OpenVPN > TAP: DHCP address released
. 2021.05.10 20:59:52 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2021.05.10 20:59:52 - Connection terminated.
. 2021.05.10 20:59:52 - IPv6 restored with packet filtering.
. 2021.05.10 20:59:52 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection, to automatic)
. 2021.05.10 20:59:52 - DNS IPv4 of a network adapter restored to original settings (Ethernet 1, to 192.168.46.1)
. 2021.05.10 21:00:49 - DNS leak protection with packet filtering disabled.
. 2021.05.10 21:00:49 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4
. 2021.05.10 21:00:49 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv6
. 2021.05.10 21:00:49 - Flushing DNS
! 2021.05.10 21:00:49 - Session terminated.
! 2021.05.10 21:01:11 - Deactivation of Network Lock
I 2021.05.10 21:01:15 - Session starting.
I 2021.05.10 21:01:15 - Checking authorization ...
. 2021.05.10 21:01:16 - IPv6 disabled with packet filtering.
! 2021.05.10 21:01:16 - Connecting to Hassaleh (Netherlands, Alblasserdam)
. 2021.05.10 21:01:16 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021
. 2021.05.10 21:01:16 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2021.05.10 21:01:16 - OpenVPN > library versions: OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10
. 2021.05.10 21:01:16 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.10 21:01:16 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.10 21:01:16 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.10 21:01:16 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.10 21:01:16 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.42:443
. 2021.05.10 21:01:16 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2021.05.10 21:01:16 - OpenVPN > UDP link local: (not bound)
. 2021.05.10 21:01:16 - OpenVPN > UDP link remote: [AF_INET]213.152.161.42:443
. 2021.05.10 21:01:16 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.42:443, sid=a3673712 103ff5f1
. 2021.05.10 21:01:16 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.05.10 21:01:16 - OpenVPN > VERIFY KU OK
. 2021.05.10 21:01:16 - OpenVPN > Validating certificate extended key usage
. 2021.05.10 21:01:16 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.05.10 21:01:16 - OpenVPN > VERIFY EKU OK
. 2021.05.10 21:01:16 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Hassaleh, emailAddress=info@airvpn.org
. 2021.05.10 21:01:16 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.05.10 21:01:16 - OpenVPN > [Hassaleh] Peer Connection Initiated with [AF_INET]213.152.161.42:443
. 2021.05.10 21:01:17 - OpenVPN > SENT CONTROL [Hassaleh]: 'PUSH_REQUEST' (status=1)
. 2021.05.10 21:01:17 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.18.142.1,dhcp-option DNS6 fde6:7a:7d20:e8e::1,tun-ipv6,route-gateway 10.18.142.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:e8e::100d/64 fde6:7a:7d20:e8e::1,ifconfig 10.18.142.15 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2021.05.10 21:01:17 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.05.10 21:01:17 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:e8e::1'
. 2021.05.10 21:01:17 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2021.05.10 21:01:17 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:e8e::100d/64 fde6:7a:7d20:e8e::1'
. 2021.05.10 21:01:17 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.05.10 21:01:17 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.05.10 21:01:17 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.05.10 21:01:17 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.05.10 21:01:17 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.05.10 21:01:17 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.05.10 21:01:17 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.05.10 21:01:17 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.05.10 21:01:17 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.05.10 21:01:17 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.10 21:01:17 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.10 21:01:17 - OpenVPN > interactive service msg_channel=0
. 2021.05.10 21:01:17 - OpenVPN > ROUTE_GATEWAY 192.168.46.1/255.255.255.0 I=6 HWADDR=60:45:cb:9d:89:bf
. 2021.05.10 21:01:17 - OpenVPN > open_tun
. 2021.05.10 21:01:17 - OpenVPN > tap-windows6 device [Local Area Connection] opened
. 2021.05.10 21:01:17 - OpenVPN > TAP-Windows Driver Version 9.24
. 2021.05.10 21:01:17 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.18.142.0/10.18.142.15/255.255.255.0 [SUCCEEDED]
. 2021.05.10 21:01:17 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.18.142.15/255.255.255.0 on interface {CBD8A5E0-C167-4987-AC66-C122610B30EB} [DHCP-serv: 10.18.142.254, lease-time: 31536000]
. 2021.05.10 21:01:17 - OpenVPN > Successful ARP Flush on interface [7] {CBD8A5E0-C167-4987-AC66-C122610B30EB}
. 2021.05.10 21:01:17 - OpenVPN > IPv4 MTU set to 1500 on interface 7 using SetIpInterfaceEntry()
. 2021.05.10 21:01:22 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2021.05.10 21:01:22 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.42 MASK 255.255.255.255 192.168.46.1
. 2021.05.10 21:01:22 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.05.10 21:01:22 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.05.10 21:01:22 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.18.142.1
. 2021.05.10 21:01:22 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.18.142.1
. 2021.05.10 21:01:22 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4
. 2021.05.10 21:01:22 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6
. 2021.05.10 21:01:22 - DNS leak protection with packet filtering enabled.
. 2021.05.10 21:01:22 - DNS IPv4 of a network adapter forced (Local Area Connection, from automatic to 10.18.142.1)
. 2021.05.10 21:01:22 - DNS IPv4 of a network adapter forced (Ethernet 1, from manual (192.168.46.1) to 10.18.142.1)
. 2021.05.10 21:01:22 - Routes, added a new route, 213.152.161.40 for gateway 10.18.142.1
. 2021.05.10 21:01:22 - Unable to compute route for 2a00:1678:2470:44:6d41:b9ad:2395:49d9: IPv6 VPN gateway not available.
. 2021.05.10 21:01:22 - Flushing DNS
! 2021.05.10 21:01:22 - Connected.
. 2021.05.10 21:01:22 - OpenVPN > Initialization Sequence Completed
. 2021.05.10 21:04:45 - ping 1
. 2021.05.10 21:04:45 - ping 2 W
. 2021.05.10 21:04:45 - ping 2 WE
Network Interfaces and Routes:
    "support_ipv4": true,
    "support_ipv6": true,
    "routes": [
            "address": "0.0.0.0\/0",
            "interface": "{C1D6F2D2-47A3-4D0E-A619-0BFC819C750F}",
            "gateway": "192.168.46.1",
            "metric": "281"
            "address": "0.0.0.0\/1",
            "gateway": "10.18.142.1",
            "metric": "3"
            "address": "10.18.142.0\/24",
            "gateway": "link",
            "metric": "259"
            "address": "10.18.142.15",
            "gateway": "link",
            "metric": "259"
            "address": "10.18.142.255",
            "gateway": "link",
            "metric": "259"
            "address": "127.0.0.0\/8",
            "interface": "{6BB4F047-2706-11E5-9BBE-806E6F6E6963}",
            "gateway": "link",
            "metric": "331"
            "address": "127.0.0.1",
            "gateway": "link",
            "metric": "331"
            "address": "127.255.255.255",
            "gateway": "link",
            "metric": "331"
            "address": "128.0.0.0\/1",
            "metric": "3"
            "address": "192.168.46.0\/24",
            "gateway": "link",
            "metric": "281"
            "address": "192.168.46.46",
            "gateway": "link",
            "metric": "281"
            "address": "192.168.46.255",
            "gateway": "link",
            "metric": "281"
            "address": "213.152.161.40",
            "metric": "4"
            "address": "213.152.161.42",
            "metric": "25"
            "address": "224.0.0.0\/4",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "259"
            "gateway": "link",
            "metric": "281"
            "address": "255.255.255.255",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "259"
            "gateway": "link",
            "metric": "281"
            "address": "::1",
            "gateway": "link",
            "metric": "331"
            "address": "fe80::\/64",
            "gateway": "link",
            "metric": "259"
            "gateway": "link",
            "metric": "259"
            "address": "ff00::\/8",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "259"
    "interfaces": [
            "friendly": "Local Area Connection",
            "id": "{CBD8A5E0-C167-4987-AC66-C122610B30EB}",
            "name": "Local Area Connection",
            "description": "TAP-Windows Adapter V9",
            "type": "Virtual",
            "status": "Up",
            "bytes_received": "3242042",
            "bytes_sent": "318105",
            "ips": [
                "10.18.142.15"
            "gateways": [
                "10.18.142.1"
            "bind": true,
            "dns4": "10.18.142.1",
            "dns6": null
            "friendly": "Ethernet 1",
            "id": "{C1D6F2D2-47A3-4D0E-A619-0BFC819C750F}",
            "name": "Ethernet 1",
            "description": "Intel(R) I211 Gigabit Network Connection #2",
            "type": "Ethernet",
            "status": "Up",
            "bytes_received": "29885226516",
            "bytes_sent": "240925177501",
            "ips": [
                "192.168.46.46"
            "gateways": [
                "192.168.46.1"
            "bind": true,
            "dns6": null
            "friendly": "Loopback Pseudo-Interface 1",
            "id": "{6BB4F047-2706-11E5-9BBE-806E6F6E6963}",
            "name": "Loopback Pseudo-Interface 1",
            "description": "Software Loopback Interface 1",
            "type": "Loopback",
            "status": "Up",
            "bytes_received": "0",
            "bytes_sent": "0",
            "ips": [
                "::1",
                "127.0.0.1"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
    "ipv4-default-gateway": "10.18.142.1",
ipconfig /all:
Windows IP Configuration
   Host Name . . . . . . . . . . . . : mmpc46-010
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Unknown adapter Local Area Connection:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : TAP-Windows Adapter V9
   Physical Address. . . . . . . . . : 00-FF-CB-D8-A5-E0
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   IPv4 Address. . . . . . . . . . . : 10.18.142.15(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Monday, May 10, 2021 9:01:17 PM
   Lease Expires . . . . . . . . . . : Tuesday, May 10, 2022 9:01:16 PM
   Default Gateway . . . . . . . . . :
   DHCP Server . . . . . . . . . . . : 10.18.142.254
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-23-74-D4-9E-60-45-CB-9D-89-BF
   DNS Servers . . . . . . . . . . . : 10.18.142.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Ethernet 1:
   Description . . . . . . . . . . . : Intel(R) I211 Gigabit Network Connection #2
   Physical Address. . . . . . . . . : 60-45-CB-9D-89-BF
   DHCP Enabled. . . . . . . . . . . : No
   IPv4 Address. . . . . . . . . . . : 192.168.46.46(Preferred)
   Default Gateway . . . . . . . . . : 192.168.46.1
I am jsut doing some testing to see if I can reproduce it.
Edited ... by OpenSourcerer
Apply LOG format to logs
I have been able to reproduce it. So, at some point in time I set public profile in firewall to block all outgoing. I have no idea when nor why...... who knows. This seems to be the culprit. When I set it to allow outgoing, it seems to work fine, if maybe a bit slow connecting.
This is odd because you explicitly wrote in the past that you tried a connection with Windows Firewall disabled, and now you're telling us allowing outgoing traffic did the trick… seems like you didn't disable the firewall, after all…
Yeah I am pretty sure I was only turning off private profile, which explains a lot. I didn't think of the property of the vpn tunnel being classified as public rather than private. But yet oddly with private firewall turned off, it would connect and disconnect faster? Not sure why, but I do see how I did not consider some thigns sufficiently and it had an impact on troubleshooting this.
Please call the things you did accurately next time. A disabled firewall means a firewall that is not running in a troubleshooter's mind (= there is no chance any filtering is happening, and so firewall could in theory be ruled out), not a disabled profile. Also, who knows how the rulesets "public" and "private" look to you, how you configured it…
What you could do is use Windows Firewall for NetLock (Preferences > Network Lock > Mode: Windows Firewall). I think Eddie saves its state before applying NetLock and restores the previous state when you disable it. This way you could keep your mysterious rules but use something we can troubleshoot when Eddie is running.
I will take that under advisement, thank you for the time you spent to help me troubleshoot this.
