user84773662
Fetch url error:SSL peer certificate or SSH remote key was not OK
Same here.  Just began this afternoon.  Hoping for a quick resolve.
I have uninstalled Eddie 2.20.0 and reinstalled 2.19.7.  That has allowed me to connect to Air Servers.  My android phone, tv box, and blue stacks all connected.  Only Win 10 PC and Eddie 2.20.0 has newly developed problems connecting.
Might want to consider going back to 2.19.7 for now.
Thanks to the OP.
Edited ... by ErrHead
Happening to me as well on windows10. Can't connect to IPV4 or anything and the log is giving some keys error. My machine is dual boot and I switched to linux and it worked first time. Sooo weird. I would prefer to use it on windows10 but if its not going to work for a few days...
Last night i had this issue, for now it seems almost solved.
I 2021.05.01 17:28:02 - Checking route IPv4
. 2021.05.01 17:28:14 - Fetch url error:SSL peer certificate or SSH remote key was not OK
. 2021.05.01 17:28:14 - Checking route (2° try)
. 2021.05.01 17:28:16 - Fetch url error:SSL peer certificate or SSH remote key was not OK
. 2021.05.01 17:28:16 - Checking route (3° try)
. 2021.05.01 17:28:18 - Fetch url error:SSL peer certificate or SSH remote key was not OK
E 2021.05.01 17:28:18 - Checking route IPv4 failed.
. 2021.05.01 17:28:18 - OpenVPN > Initialization Sequence Completed
! 2021.05.01 17:28:18 - Disconnecting
And eddie connected the 2nd time, so its no endless loop anymore
I have the same issue today for the first time.
No matter what server I try I always get: Fetch url error:SSL peer certificate or SSH remote key was not OK
