mcana77
ANSWERED PFsense OpenVPN is no longer connecting
Hello All,
So I was browsing this morning as I normally do on a Saturday morning and suddenly, no connectivity.
I have a pfSense FW (Ver 2.5.0-Release) that is always on and connected to AirVPN for my local subnet. Logging into my pfSense showed that indeed OpenVPN was no longer connected and I cannot seem to connect. I noted the line that stated "write UDPv4: No route to host (code=65)" and I am wondering what may have changed on the AirVPN servers or am I doing something wrong?
Any help would be greatly appreciated.
I setup the pfsense using this guide -> (whoever you are sir or madam, you rock!)
Apr 24 16:02:42    openvpn    69767    write UDPv4: No route to host (code=65)
Apr 24 16:02:40    openvpn    69767    write UDPv4: No route to host (code=65)
Apr 24 16:02:40    openvpn    69767    UDPv4 link remote: [AF_INET]64.42.179.58:443
Apr 24 16:02:40    openvpn    69767    UDPv4 link local (bound): [AF_INET]192.168.1.17:0
Apr 24 16:02:40    openvpn    69767    Socket Buffers: R=[42080->42080] S=[57344->57344]
Apr 24 16:02:40    openvpn    69767    TCP/UDP: Preserving recently used remote address: [AF_INET]64.42.179.58:443
Apr 24 16:02:40    openvpn    69767    Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
Apr 24 16:02:40    openvpn    69767    Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
Apr 24 16:02:40    openvpn    69767    Data Channel MTU parms [ L:1622 D:1450 EF:122 EB:406 ET:0 EL:3 ]
Apr 24 16:02:40    openvpn    69767    Control Channel MTU parms [ L:1622 D:1184 EF:66 EB:0 ET:0 EL:3 ]
Apr 24 16:02:40    openvpn    69767    Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Apr 24 16:02:40    openvpn    69767    Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Apr 24 16:02:40    openvpn    69767    WARNING: experimental option --capath /var/etc/openvpn/client1/ca
Apr 24 16:02:40    openvpn    69767    NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Apr 24 16:02:40    openvpn    69767    mlockall call succeeded
Apr 24 16:02:40    openvpn    69767    MANAGEMENT: unix domain socket listening on /var/etc/openvpn/client1/sock
Apr 24 16:02:40    openvpn    69452    library versions: OpenSSL 1.1.1i-freebsd 8 Dec 2020, LZO 2.10
Apr 24 16:02:40    openvpn    69452    OpenVPN 2.5.0 amd64-portbld-freebsd12.2 [SSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Feb 5 2021
Apr 24 16:02:40    openvpn    69452    auth_user_pass_file = '/var/etc/openvpn/client1/up'
this is your problem
auth SHA1
go ahaed with the new how to
a few option are different to the old HowTo it is a few years old.
https://nguvu.org/pfsense/pfsense-baseline-setup/
Thanks Wolke68. I actually have a backup unit that is flashed and ready to go in case I have an issue, so I went ahead wiped it and put 2.5.1 on it. I'm in the middle of configuring that one now. It is a little more complicated than the first version I followed several years ago and I don't totally understand VLAN routing but I am learning. Still not connecting even though I'm well past the OpenVPN configuration but I will keep going and hopefully get this ironed out sometime this week.
Appreciate your response!
Same problem here. Solution:
I changed:
  • TLS Key Usage Mode: TLS Authentication
  • TLS keydir direction: Direction 1
  • Auth digest algorithm: SHA1
You can see what config is generated from the web interface (for debugging):
ps aux | grep openvpn
root     6829   0.0  0.4  17340 17416  -  Ss   08:18      0:01.75 /usr/local/sbin/openvpn --config /var/etc/openvpn/client1/config.ovpn
looks like this is all confusion around which entry IP are tls-crypt and which are tls-auth.  tls-auth entry points use sha1.  tls-crypt entry points use sha512 and tls encryption+auth.
so, keep an eye on which config you make.  details matter. :)
every time I see the nguvu.org link posted.   its always the same issue you revealed
every time.
 I have always used Entry 3's with TLS-crypt fortunately
First, Thank you to each member looking at and replying to my post from April 2021. It has been since that point that I have not had my pFsense running, and put it aside to just use the eddie client on my main system.
I really appreciate you all and will give a thumbs up if I can connect again with the pFsense!
Thank you!
entry 3 requires two changes:
1. under TLS KEY USAGE MODE  its set to encryption and authentication.    (normally just TLS auth)
2. auth digest alg = SHA 512.    (normally 160)
so in bold is used if using entry point 3.   otherwise use non bold
good luck!
Thanks Air, So I changed the entries for both TLS Key Usage mode and the auth digest as you recommended but I also noticed "AUTH: Received control message: AUTH_FAILED" so I went back and generated a new config (for TLS-Auth) and to update my certs (and host - america3.vpn.airdns.org).  FINALLY! I think my feebile brain may understand this a little better! lol.
Would like to ask this question as well... what options should I be passing in the OpenVPN client?
Very much appreciate all of you folks who responded!!
Dec 3 13:24:20 openvpn 95058 Initialization Sequence Completed
if you mean custom options this is what I have:
remote-cert-tls server;
tls-version-min 1.2;
remote 1.1.1.1 443;
1.1.1.1 is a valid IP address of a Airvpn server.   in case the connection drops it will reconnect to the next in line automatically 443 is the port it will connect on
Quote
remote 1.1.1.1 443;
Nice. Thank you again.
good luck!
Same issue for me. Thanks.
