Hello everybody. I am using Eddie+Hummingbird on Linux. I can't connect last hours, though servers stats are visible in Eddie. When using Hummingbird option i got error about too many reconnections. If only Eddie, then stuck on ipv4 route check. Tried on other machine with Windows OS - everything is ok. Logs in files. Thank for further help.
Log.txt
System Report.txt
Edited ... by Korch
Thank you for posting the system report right away.
Can you try a connection without Network Lock? (Preferences > Network Lock > Mode: None)
Thanks for your respond. Tried without Network Lock, look like nothing changed. Meanwhile tried to change protocols and eddie without hummingbird connects on vary tcp ports, but not default udp and other. And i still see the "curl: (28) Connection timed out after 20000 milliseconds" error. This is strange.  Hummingbird in terminal doesn't connect too, though.
Tried to reinstall eddie too :) Didn't have this errors before today.
. 2021.04.09 19:39:15 - Eddie version: 2.20.0 / linux_x64, System: Linux, Name: Arch Linux \r (\l), Version: Linux anarchy 5.11.12-arch1-1 #1 SMP PREEMPT Wed, 07 Apr 2021 21:48:28 +0000 x86_64 GNU/Linux, Mono/.Net: 6.12.0 (makepkg/a22ed3f094e Tue Dec 22 06:01:50 PM -03 2020); Framework: v4.0.30319
. 2021.04.09 19:39:15 - Command line arguments (2): path.resources="/usr/share/eddie-ui" path.exec="/usr/bin/eddie-ui"
. 2021.04.09 19:39:16 - Profile path: /home/korch/.config/eddie/default.profile
. 2021.04.09 19:39:16 - Reading options from /home/korch/.config/eddie/default.profile
. 2021.04.09 19:39:17 - Tun Driver - /dev/net/tun
. 2021.04.09 19:39:17 - OpenVPN - Version: 2.5.1 - OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10 (/usr/bin/openvpn)
. 2021.04.09 19:39:17 - SSH - Version: OpenSSH_8.5p1, OpenSSL 1.1.1k  25 Mar 2021 (/usr/bin/ssh)
. 2021.04.09 19:39:17 - SSL - Version: Initializing (/usr/bin/stunnel)
. 2021.04.09 19:39:17 - curl - Version: 7.76.0 (/usr/bin/curl)
I 2021.04.09 19:39:18 - Ready
. 2021.04.09 19:39:19 - Collect information about AirVPN completed
I 2021.04.09 19:39:24 - Session starting.
I 2021.04.09 19:39:24 - Checking authorization ...
. 2021.04.09 19:39:25 - IPv6 disabled on network adapter (default)
. 2021.04.09 19:39:25 - IPv6 disabled on network adapter (enp5s0)
! 2021.04.09 19:39:25 - Connecting to Jabbah (Netherlands, Alblasserdam)
. 2021.04.09 19:39:25 - OpenVPN > OpenVPN 2.5.1 [git:makepkg/f186691b32e68362+] x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Feb 24 2021
. 2021.04.09 19:39:25 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2021.04.09 19:39:25 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.04.09 19:39:25 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.04.09 19:39:25 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.04.09 19:39:25 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.04.09 19:39:25 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.186.26:443
. 2021.04.09 19:39:25 - OpenVPN > Socket Buffers: R=[131072->131072] S=[16384->16384]
. 2021.04.09 19:39:25 - OpenVPN > Attempting to establish TCP connection with [AF_INET]213.152.186.26:443 [nonblock]
. 2021.04.09 19:39:25 - OpenVPN > TCP connection established with [AF_INET]213.152.186.26:443
. 2021.04.09 19:39:25 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2021.04.09 19:39:25 - OpenVPN > TCP_CLIENT link remote: [AF_INET]213.152.186.26:443
. 2021.04.09 19:39:25 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.186.26:443, sid=260976b9 5329f1c1
. 2021.04.09 19:39:25 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.04.09 19:39:25 - OpenVPN > VERIFY KU OK
. 2021.04.09 19:39:25 - OpenVPN > Validating certificate extended key usage
. 2021.04.09 19:39:25 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.04.09 19:39:25 - OpenVPN > VERIFY EKU OK
. 2021.04.09 19:39:25 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Jabbah, emailAddress=info@airvpn.org
. 2021.04.09 19:39:25 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.04.09 19:39:25 - OpenVPN > [Jabbah] Peer Connection Initiated with [AF_INET]213.152.186.26:443
. 2021.04.09 19:39:25 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.19.211.1,dhcp-option DNS6 fde6:7a:7d20:fd3::1,tun-ipv6,route-gateway 10.19.211.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:fd3::1051/64 fde6:7a:7d20:fd3::1,ifconfig 10.19.211.83 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2021.04.09 19:39:25 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.04.09 19:39:25 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:fd3::1'
. 2021.04.09 19:39:25 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2021.04.09 19:39:25 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:fd3::1051/64 fde6:7a:7d20:fd3::1'
. 2021.04.09 19:39:25 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.04.09 19:39:25 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.04.09 19:39:25 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.04.09 19:39:25 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.04.09 19:39:25 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.04.09 19:39:25 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.04.09 19:39:25 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2021.04.09 19:39:25 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.04.09 19:39:25 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.04.09 19:39:25 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.04.09 19:39:25 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.04.09 19:39:25 - OpenVPN > net_route_v4_best_gw query: dst 0.0.0.0
. 2021.04.09 19:39:25 - OpenVPN > net_route_v4_best_gw result: via 100.83.255.254 dev enp5s0
. 2021.04.09 19:39:25 - OpenVPN > ROUTE_GATEWAY 100.83.255.254/255.255.0.0 IFACE=enp5s0 HWADDR=b4:b5:2f:73:29:ea
. 2021.04.09 19:39:25 - OpenVPN > TUN/TAP device tun0 opened
. 2021.04.09 19:39:25 - OpenVPN > net_iface_mtu_set: mtu 1500 for tun0
. 2021.04.09 19:39:25 - OpenVPN > net_iface_up: set tun0 up
. 2021.04.09 19:39:25 - OpenVPN > net_addr_v4_add: 10.19.211.83/24 dev tun0
. 2021.04.09 19:39:31 - OpenVPN > net_route_v4_add: 213.152.186.26/32 via 100.83.255.254 dev [NULL] table 0 metric -1
. 2021.04.09 19:39:31 - OpenVPN > net_route_v4_add: 0.0.0.0/1 via 10.19.211.1 dev [NULL] table 0 metric -1
. 2021.04.09 19:39:31 - OpenVPN > net_route_v4_add: 128.0.0.0/1 via 10.19.211.1 dev [NULL] table 0 metric -1
. 2021.04.09 19:39:31 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
. 2021.04.09 19:39:31 - Routes, added a new route, 213.152.186.24 for gateway 10.19.211.1
. 2021.04.09 19:39:31 - Unable to compute route for 2a00:1678:1337:1936:cf8c:6738:e8ee:6fcf: IPv6 VPN gateway not available.
. 2021.04.09 19:39:31 - Flushing DNS
. 2021.04.09 19:39:31 - Flush DNS - nscd
I 2021.04.09 19:39:31 - Checking route IPv4
E 2021.04.09 19:39:51 - curl: (28) Connection timed out after 20001 milliseconds
I 2021.04.09 19:39:51 - Checking DNS
! 2021.04.09 19:39:52 - Connected.
. 2021.04.09 19:39:52 - OpenVPN > Initialization Sequence Completed
EDIT: Was looking at logs and don't know why but tried to delete network connection at xfce network connections window. It was recreated automatically and now everything is working ok. I don't see any differences in network connection settings, so don't really understand why it helped and how it work. Edited ... by Korch
6 hours ago, OpenSourcerer said:
So, Eddie now connects without issues?
Yes, everything is ok, thanks for your answers.
