steflon 0 Posted ... Long term Eddie user. In the past I never had issues adding multiple IP addresses, but updated to 2.18.9 today and I can't add more than 1 IP address. 'Guide' says one address per line, but when I hit return it submits changes. Shift+return highlights what has been written. It has been years since I've had issues, so I'm a bit rusty with Eddie IPs. Can I put a range? I really just need to list a few local devices that are not on the same VLAN and a couple external addresses I want to allow through for VNC. "Local traffic" option doesn't seem to be cover other VLANs.. Intel Mac - Big Sur (11.3) Thanks! Quote Share this post Link to post
Tech Jedi Alex 1518 Posted ... 4 hours ago, steflon said: 2.18.9 Current version is 2.20. You might want to upgrade and see if that fixes it. 4 hours ago, steflon said: Can I put a range? Yes. 4 hours ago, steflon said: "Local traffic" option doesn't seem to be cover other VLANs Ugh, you're the first one ever to use VLANs. Not sure Eddie/OpenVPN supports that, or if it really is something Eddie/OpenVPN must support. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
steflon 0 Posted ... Thank you for your reply! Can you give an example of a range? The support doc says "Separate each address with a new line", but that isn't possible due to 'return' issue described in OP. 2.20 didn't resolve the issue. Comma separation seems to work occaisonally. Would an IP range of "192.168.1.1 - 192.168.1.25" work? I was hoping identifying an entire subnet such as 192.168.1.1/24 would work, but no luck. Thanks again for your input. Quote Share this post Link to post
Tech Jedi Alex 1518 Posted ... 13 hours ago, steflon said: The support doc says "Separate each address with a new line", but that isn't possible due to 'return' issue described in OP. Cannot reproduce with Eddie 2.20 and Mono 6.12.0 on Linux. I can enter new lines. 13 hours ago, steflon said: Would an IP range of "192.168.1.1 - 192.168.1.25" work? I was hoping identifying an entire subnet such as 192.168.1.1/24 would work, but no luck. While the former describes a range in human-readable notation, there are few programs capable of parsing it, nmap being one example. The vast majority should work with CIDR notation. Strange that Eddie doesn't… For your convenience, here's a complete list of IPs in the 192.168.1.0/24 range you can paste into the IPs allowed section: 192.168.1.1 192.168.1.2 192.168.1.3 192.168.1.4 192.168.1.5 192.168.1.6 192.168.1.7 192.168.1.8 192.168.1.9 192.168.1.10 192.168.1.11 192.168.1.12 192.168.1.13 192.168.1.14 192.168.1.15 192.168.1.16 192.168.1.17 192.168.1.18 192.168.1.19 192.168.1.20 192.168.1.21 192.168.1.22 192.168.1.23 192.168.1.24 192.168.1.25 192.168.1.26 192.168.1.27 192.168.1.28 192.168.1.29 192.168.1.30 192.168.1.31 192.168.1.32 192.168.1.33 192.168.1.34 192.168.1.35 192.168.1.36 192.168.1.37 192.168.1.38 192.168.1.39 192.168.1.40 192.168.1.41 192.168.1.42 192.168.1.43 192.168.1.44 192.168.1.45 192.168.1.46 192.168.1.47 192.168.1.48 192.168.1.49 192.168.1.50 192.168.1.51 192.168.1.52 192.168.1.53 192.168.1.54 192.168.1.55 192.168.1.56 192.168.1.57 192.168.1.58 192.168.1.59 192.168.1.60 192.168.1.61 192.168.1.62 192.168.1.63 192.168.1.64 192.168.1.65 192.168.1.66 192.168.1.67 192.168.1.68 192.168.1.69 192.168.1.70 192.168.1.71 192.168.1.72 192.168.1.73 192.168.1.74 192.168.1.75 192.168.1.76 192.168.1.77 192.168.1.78 192.168.1.79 192.168.1.80 192.168.1.81 192.168.1.82 192.168.1.83 192.168.1.84 192.168.1.85 192.168.1.86 192.168.1.87 192.168.1.88 192.168.1.89 192.168.1.90 192.168.1.91 192.168.1.92 192.168.1.93 192.168.1.94 192.168.1.95 192.168.1.96 192.168.1.97 192.168.1.98 192.168.1.99 192.168.1.100 192.168.1.101 192.168.1.102 192.168.1.103 192.168.1.104 192.168.1.105 192.168.1.106 192.168.1.107 192.168.1.108 192.168.1.109 192.168.1.110 192.168.1.111 192.168.1.112 192.168.1.113 192.168.1.114 192.168.1.115 192.168.1.116 192.168.1.117 192.168.1.118 192.168.1.119 192.168.1.120 192.168.1.121 192.168.1.122 192.168.1.123 192.168.1.124 192.168.1.125 192.168.1.126 192.168.1.127 192.168.1.128 192.168.1.129 192.168.1.130 192.168.1.131 192.168.1.132 192.168.1.133 192.168.1.134 192.168.1.135 192.168.1.136 192.168.1.137 192.168.1.138 192.168.1.139 192.168.1.140 192.168.1.141 192.168.1.142 192.168.1.143 192.168.1.144 192.168.1.145 192.168.1.146 192.168.1.147 192.168.1.148 192.168.1.149 192.168.1.150 192.168.1.151 192.168.1.152 192.168.1.153 192.168.1.154 192.168.1.155 192.168.1.156 192.168.1.157 192.168.1.158 192.168.1.159 192.168.1.160 192.168.1.161 192.168.1.162 192.168.1.163 192.168.1.164 192.168.1.165 192.168.1.166 192.168.1.167 192.168.1.168 192.168.1.169 192.168.1.170 192.168.1.171 192.168.1.172 192.168.1.173 192.168.1.174 192.168.1.175 192.168.1.176 192.168.1.177 192.168.1.178 192.168.1.179 192.168.1.180 192.168.1.181 192.168.1.182 192.168.1.183 192.168.1.184 192.168.1.185 192.168.1.186 192.168.1.187 192.168.1.188 192.168.1.189 192.168.1.190 192.168.1.191 192.168.1.192 192.168.1.193 192.168.1.194 192.168.1.195 192.168.1.196 192.168.1.197 192.168.1.198 192.168.1.199 192.168.1.200 192.168.1.201 192.168.1.202 192.168.1.203 192.168.1.204 192.168.1.205 192.168.1.206 192.168.1.207 192.168.1.208 192.168.1.209 192.168.1.210 192.168.1.211 192.168.1.212 192.168.1.213 192.168.1.214 192.168.1.215 192.168.1.216 192.168.1.217 192.168.1.218 192.168.1.219 192.168.1.220 192.168.1.221 192.168.1.222 192.168.1.223 192.168.1.224 192.168.1.225 192.168.1.226 192.168.1.227 192.168.1.228 192.168.1.229 192.168.1.230 192.168.1.231 192.168.1.232 192.168.1.233 192.168.1.234 192.168.1.235 192.168.1.236 192.168.1.237 192.168.1.238 192.168.1.239 192.168.1.240 192.168.1.241 192.168.1.242 192.168.1.243 192.168.1.244 192.168.1.245 192.168.1.246 192.168.1.247 192.168.1.248 192.168.1.249 192.168.1.250 192.168.1.251 192.168.1.252 192.168.1.253 192.168.1.254 . Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
