macfanboy 0 Posted ... Hi I have setup qbitttorrent web UI and it seems to work when I type in the computer IP address in the browser. The problem is that I would like to use it from outside network as well. I suppose that I would need to do some port forwarding in AirVPN and set up DDNS ? Can anyone explain to me how to do that as I am a total noob when it comes to networking 😅 Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... 37 minutes ago, anonymous-vpner said: I suppose that I would need to do some port forwarding in AirVPN and set up DDNS ? Yes, but DDNS is not a necessity. It helps tremendously reaching the host, though. 37 minutes ago, anonymous-vpner said: Can anyone explain to me how to do that as I am a total noob when it comes to networking 😅 There are two ways: Forward a random port. In the Local port field, enter 8080. Forward a random port, but leave Local port field empty. Look at what port you got assigned, then configure the qBittorrent WebUI to use this port. In all cases: In qBittorrent settings > Advanced, check if qBittorrent binds to the tunnel adapter (TAP-Windows on Windows, utun0 on macOS, tun0 on Linux). If it's not visible, especially on macOS and Linux, connect to AirVPN first. In DDNS, enter the name you want to reach it with. If the name is myname, the WebUI will then be reachable on myname.airdns.org:#####, ##### being the remote port. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
macfanboy 0 Posted ... Okay so I have forwarded the port and set the DDNS name while doing that. But what next ? How do I set up the Web UI tab ? Thank you Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... I will assume you went with way 2, so in qB settings > Web UI, set the port to the remote port you just got assigned. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
macfanboy 0 Posted ... 1 minute ago, OpenSourcerer said: I will assume you went with way 2, so in qB settings > Web UI, set the port to the remote port you just got assigned. No I went to port forwarding on this website, and assigned random port to 8809, and put a name in DDNS field, that's all I did. Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... Yes, this is the first part of way 2. Now go to qB's settings, go to the Web UI tab and enter 8809 in the port field. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
macfanboy 0 Posted ... I am sorry I meant port 8080, which is qB's default in the Web UI tab. Now the question is what do I put in the IP address field ? My computers IP ? Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... Ah okay, then it's the other way. In this case, everything in qB should remain at its default. IP is an asterisk *, port is 8080. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
macfanboy 0 Posted ... Okay so I set it up like that but I still can't access it anyhow, I did type the dns address I browser and it won't work. Any ideas what am I doing wrong ? Thanks Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... Just to be sure: You tried accessing it by browing to http://torrentos.airdns.org:49948, right? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Tech Jedi Alex 1524 Posted ... Is the port open? $ ss -tuln $ nc -zv 127.0.0.1 8080 Is it even reachable from the outside? (Execute with another Linux machine): $ dig a in torrentos.airdns.org +short | nc -zv - 49948 . Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
