freekodakbro
AirVPN Keeps Disconnecting and Connecting to the VPN and fails "checking route IPV4.
I just bought AirVPN. But Eddie, (Windows 10 UI) Just keeps connecting and disconnecting to servers. And fails the checking route to IPV4. I have no idea what's happening and i keep getting spammed by these alerts. I've used a lot of VPN's but this has never happend to me.
Edited ... by freekodakbro
The error is here:
I 2021.03.27 14:40:08 - Checking route IPv4
. 2021.03.27 14:40:08 - Fetch url error:SSL peer certificate or SSH remote key was not OK
Could be intermittent, but just to be sure, can you try a connection over a different network?
I have the same issue only it fails at the IPv6 test - on any server I choose.  I noticed the new update and performed that, it did not work unfortunately.  Performed a system test:
Test DNS IPv4: Ok
Test DNS IPv6: Failed
Test Ping IPv4: 98 ms
Test Ping IPv6: Failed
Test HTTP IPv4: Ok
Test HTTP IPv6: Error: Fetch url error:Couldn't connect to server
Test HTTPS: Ok
2021.03.27 21:38:17 - Checking route IPv4
I 2021.03.27 21:38:18 - Checking route IPv6
. 2021.03.27 21:38:39 - Fetch url error:Timeout was reached
. 2021.03.27 21:38:39 - Checking route (2° try)
. 2021.03.27 21:39:02 - Fetch url error:Timeout was reached
. 2021.03.27 21:39:02 - Checking route (3° try)
. 2021.03.27 21:39:25 - Fetch url error:Timeout was reached
E 2021.03.27 21:39:25 - Checking route IPv6 failed.
. 2021.03.27 21:39:25 - OpenVPN > Initialization Sequence Completed
! 2021.03.27 21:39:25 - Disconnecting
I have another computer with Eddie and it works fine.  Any help would be appreciated - and thanks in advance!
Different issue, Mr. InTheBackground, kindly open your own thread next time. Your quick fix is to disable IPv6.
On 3/28/2021 at 12:28 AM, OpenSourcerer said:
The error is here:
Still doesn't work unfortunately.
