Not connected, Your IP: 216.73.216.47
Hello ,
I'm having trouble setting up the connection in Whonix OS.
I'm trying to do a VPN over TOR connection.  USER ----> TOR -----> VPN
I installed Eddie using Debian instructions and have tried the portable version .
I have set the connection (proxy) type to TOR in the settings.
I get these popup notification error messages :
- Unable to find
IP address of tor first node of an established circuit.
- Checking route IPv4 failed.
If anyone has experience setting up AirVPN in WHONIX i could use all the help i can get.
Thank you for your reply.
At least point me in the right direction ? I know i'm a beginner and that is a broad question, but there is no need to completely ignore me .
You're not being ignored, people just don't know how to help you. Try professional support.
