New problem started in the last few weeks. On Imac, 10.14.6, Mojave and Eddie 2.19.7. So either on reboot or after quitting Eddie and restarting, it gets stuck at checking ipv4. Eventually, I cancel. Takes at least a minute to cancel. After that I simply click to connect to server, and it connects right away. Any ideas?
. 2021.03.05 19:05:14 - Eddie version: 2.19.7 / macos_x64, System: MacOS, Name: macOS 10.14.6, Version: 10.14.6 (Build 18G8022), Mono/.Net: v4.0.30319
. 2021.03.05 19:05:14 - Command line arguments (0):
. 2021.03.05 19:05:16 - Profile path: /Users/$$$$$$/.config/eddie/default.profile
. 2021.03.05 19:05:16 - Reading options from /Users/$$$$$$/.config/eddie/default.profile
. 2021.03.05 19:05:18 - Tun Driver - Expected
. 2021.03.05 19:05:18 - OpenVPN - Version: 2.5.0 - OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
. 2021.03.05 19:05:18 - SSH - Version: OpenSSH_7.9p1, LibreSSL 2.7.3 (/usr/bin/ssh)
. 2021.03.05 19:05:18 - SSL - Version: stunnel 5.56 (/Applications/Eddie.app/Contents/MacOS/stunnel)
. 2021.03.05 19:05:18 - Recovery. Unexpected crash?
. 2021.03.05 19:05:18 - Routes, removed an existing route, 184.75.221.35 for gateway 10.28.22.1
. 2021.03.05 19:05:18 - Routes, removed an existing route, 2606:6080:1001:e:2e9c:bad5:dbdd:84ea for gateway fde6:7a:7d20:1816::1
. 2021.03.05 19:05:18 - Routes, added a new route, 184.75.223.195 for gateway 10.29.58.1
. 2021.03.05 19:05:18 - Routes, added a new route, 2606:6080:1002:4:88e7:e893:3692:25d2 for gateway fde6:7a:7d20:193a::1
. 2021.03.05 19:05:18 - Routes, removed an existing route, 184.75.221.3 for gateway 10.20.250.1
. 2021.03.05 19:05:18 - Routes, removed an existing route, 2606:6080:1001:d:c59c:6e9a:3115:6f2f for gateway fde6:7a:7d20:10fa::1
. 2021.03.05 19:05:18 - Routes, added a new route, 137.63.71.51 for gateway 10.31.86.1
. 2021.03.05 19:05:18 - Routes, added a new route, 2606:6080:1001:18:8d41:9604:d435:36b6 for gateway fde6:7a:7d20:1b56::1
. 2021.03.05 19:05:18 - Routes, added a new route, 104.254.90.203 for gateway 10.8.86.1
. 2021.03.05 19:05:18 - Routes, added a new route, 2606:6080:2001:7:8e6:43a8:fb13:2f6d for gateway fde6:7a:7d20:456::1
. 2021.03.05 19:05:18 - Routes, added a new route, 104.254.90.187 for gateway 10.28.86.1
. 2021.03.05 19:05:18 - Routes, added a new route, 2606:6080:2001:5:48ec:2d6:cc35:3864 for gateway fde6:7a:7d20:1856::1
. 2021.03.05 19:05:18 - Routes, added a new route, 104.254.90.195 for gateway 10.29.246.1
. 2021.03.05 19:05:18 - Routes, added a new route, 2606:6080:2001:6:e14e:c3f3:8562:6916 for gateway fde6:7a:7d20:19f6::1
. 2021.03.05 19:05:18 - Routes, removed an existing route, 192.30.89.75 for gateway 10.35.102.1
. 2021.03.05 19:05:18 - Routes, removed an existing route, 2606:9580:100:f:5792:2dec:a4b6:2419 for gateway fde6:7a:7d20:1f66::1
. 2021.03.05 19:05:18 - Routes, added a new route, 192.30.89.59 for gateway 10.20.70.1
. 2021.03.05 19:05:18 - Routes, added a new route, 2606:9580:100:d:2bd7:c37b:24c2:c069 for gateway fde6:7a:7d20:1046::1
. 2021.03.05 19:05:19 - Routes, added a new route, 192.30.89.59 for gateway 10.20.70.1
. 2021.03.05 19:05:19 - Routes, added a new route, 2606:9580:100:d:2bd7:c37b:24c2:c069 for gateway fde6:7a:7d20:1046::1
. 2021.03.05 19:05:19 - Routes, removed an existing route, 192.30.89.51 for gateway 10.19.6.1
. 2021.03.05 19:05:19 - Routes, removed an existing route, 2606:9580:100:c:8757:8ee:ec9c:991c for gateway fde6:7a:7d20:f06::1
. 2021.03.05 19:05:19 - Routes, added a new route, 192.30.89.67 for gateway 10.35.70.1
. 2021.03.05 19:05:19 - Routes, added a new route, 2606:9580:100:e:d075:a67e:1f9c:139d for gateway fde6:7a:7d20:1f46::1
. 2021.03.05 19:05:19 - Routes, added a new route, 192.30.89.27 for gateway 10.15.230.1
. 2021.03.05 19:05:19 - Routes, added a new route, 2606:9580:103:a:fda7:1f4c:8c40:8c3e for gateway fde6:7a:7d20:be6::1
! 2021.03.05 19:05:19 - Activation of Network Lock - macOS - PF
I 2021.03.05 19:05:20 - Ready
. 2021.03.05 19:05:21 - Collect information about AirVPN completed
I 2021.03.05 19:05:22 - Session starting.
. 2021.03.05 19:05:22 - Waiting for latency tests (180 to go)
. 2021.03.05 19:05:23 - Collect information about AirVPN completed
. 2021.03.05 19:05:23 - Waiting for latency tests (154 to go)
. 2021.03.05 19:05:24 - Waiting for latency tests (112 to go)
. 2021.03.05 19:05:29 - Waiting for latency tests (100 to go)
. 2021.03.05 19:05:30 - Waiting for latency tests (60 to go)
. 2021.03.05 19:05:31 - Waiting for latency tests (2 to go)
I 2021.03.05 19:05:32 - Checking authorization ...
! 2021.03.05 19:05:32 - Connecting to Pisces (Canada, Vancouver)
. 2021.03.05 19:05:33 - OpenVPN > OpenVPN 2.5.0 x86_64-apple-darwin19.5.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Oct 28 2020
. 2021.03.05 19:05:33 - OpenVPN > library versions: OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10
. 2021.03.05 19:05:33 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.03.05 19:05:33 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.03.05 19:05:33 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.03.05 19:05:33 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.03.05 19:05:33 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]192.30.89.29:443
. 2021.03.05 19:05:33 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2021.03.05 19:05:33 - OpenVPN > UDP link local: (not bound)
. 2021.03.05 19:05:33 - OpenVPN > UDP link remote: [AF_INET]192.30.89.29:443
. 2021.03.05 19:05:33 - OpenVPN > TLS: Initial packet from [AF_INET]192.30.89.29:443, sid=a6df5175 c7d10c04
. 2021.03.05 19:05:33 - OpenVPN > VERIFY KU OK
. 2021.03.05 19:05:33 - OpenVPN > Validating certificate extended key usage
. 2021.03.05 19:05:33 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.03.05 19:05:33 - OpenVPN > VERIFY EKU OK
. 2021.03.05 19:05:33 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Pisces, emailAddress=info@airvpn.org
. 2021.03.05 19:05:33 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.03.05 19:05:33 - OpenVPN > [Pisces] Peer Connection Initiated with [AF_INET]192.30.89.29:443
. 2021.03.05 19:05:33 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2021.03.05 19:05:33 - OpenVPN > route: writing to routing socket: File exists
. 2021.03.05 19:05:33 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.15.230.1,dhcp-option DNS6 fde6:7a:7d20:be6::1,tun-ipv6,route-gateway 10.15.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:be6::1018/64 fde6:7a:7d20:be6::1,ifconfig 10.15.230.26 255.255.255.0,peer-id 5,cipher AES-256-GCM'
. 2021.03.05 19:05:33 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.03.05 19:05:33 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.03.05 19:05:33 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.03.05 19:05:33 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.03.05 19:05:33 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.03.05 19:05:33 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.03.05 19:05:33 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.03.05 19:05:33 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.03.05 19:05:33 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.03.05 19:05:33 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.03.05 19:05:33 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.03.05 19:05:33 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.03.05 19:05:33 - OpenVPN > ROUTE_GATEWAY 192.168.1.254/255.255.255.0 IFACE=en0 HWADDR=68:5b:35:7f:89:b2
. 2021.03.05 19:05:33 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.03.05 19:05:33 - OpenVPN > ROUTE6_GATEWAY fe80::9e1e:95ff:fed2:4590 IFACE=en0
. 2021.03.05 19:05:33 - OpenVPN > Opened utun device utun1
. 2021.03.05 19:05:33 - OpenVPN > /sbin/ifconfig utun1 delete
. 2021.03.05 19:05:33 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2021.03.05 19:05:33 - OpenVPN > /sbin/ifconfig utun1 10.15.230.26 10.15.230.26 netmask 255.255.255.0 mtu 1500 up
. 2021.03.05 19:05:33 - OpenVPN > /sbin/route add -net 10.15.230.0 10.15.230.26 255.255.255.0
. 2021.03.05 19:05:33 - OpenVPN > add net 10.15.230.0: gateway 10.15.230.26
. 2021.03.05 19:05:33 - OpenVPN > /sbin/ifconfig utun1 inet6 fde6:7a:7d20:be6::1018/64 mtu 1500 up
. 2021.03.05 19:05:33 - OpenVPN > add_route_ipv6(fde6:7a:7d20:be6::/64 -> fde6:7a:7d20:be6::1018 metric 0) dev utun1
. 2021.03.05 19:05:33 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:be6:: -prefixlen 64 -iface utun1
. 2021.03.05 19:05:33 - OpenVPN > add net fde6:7a:7d20:be6::: gateway utun1: File exists
. 2021.03.05 19:05:33 - OpenVPN > /sbin/route add -net 192.30.89.29 192.168.1.254 255.255.255.255
. 2021.03.05 19:05:33 - OpenVPN > add net 192.30.89.29: gateway 192.168.1.254
. 2021.03.05 19:05:33 - OpenVPN > /sbin/route add -net 0.0.0.0 10.15.230.1 128.0.0.0
. 2021.03.05 19:05:33 - OpenVPN > add net 0.0.0.0: gateway 10.15.230.1
. 2021.03.05 19:05:33 - OpenVPN > /sbin/route add -net 128.0.0.0 10.15.230.1 128.0.0.0
. 2021.03.05 19:05:33 - OpenVPN > add net 128.0.0.0: gateway 10.15.230.1
. 2021.03.05 19:05:33 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:be6::1 metric -1) dev utun1
. 2021.03.05 19:05:33 - OpenVPN > /sbin/route add -inet6 :: -prefixlen 3 -iface utun1
. 2021.03.05 19:05:33 - OpenVPN > add net ::: gateway utun1
. 2021.03.05 19:05:33 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:be6::1 metric -1) dev utun1
. 2021.03.05 19:05:33 - OpenVPN > /sbin/route add -inet6 2000:: -prefixlen 4 -iface utun1
. 2021.03.05 19:05:33 - OpenVPN > add net 2000::: gateway utun1
. 2021.03.05 19:05:33 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:be6::1 metric -1) dev utun1
. 2021.03.05 19:05:33 - OpenVPN > /sbin/route add -inet6 3000:: -prefixlen 4 -iface utun1
. 2021.03.05 19:05:33 - OpenVPN > add net 3000::: gateway utun1
. 2021.03.05 19:05:33 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:be6::1 metric -1) dev utun1
. 2021.03.05 19:05:33 - OpenVPN > /sbin/route add -inet6 fc00:: -prefixlen 7 -iface utun1
. 2021.03.05 19:05:33 - OpenVPN > add net fc00::: gateway utun1
. 2021.03.05 19:05:34 - DNS of a network adapter forced (Ethernet, from Automatic to 10.15.230.1, fde6:7a:7d20:be6::1)
. 2021.03.05 19:05:34 - DNS of a network adapter forced (iPad USB, from Automatic to 10.15.230.1, fde6:7a:7d20:be6::1)
. 2021.03.05 19:05:34 - DNS of a network adapter forced (Wi-Fi, from 10.4.0.1 to 10.15.230.1, fde6:7a:7d20:be6::1)
. 2021.03.05 19:05:34 - DNS of a network adapter forced (Bluetooth PAN, from Automatic to 10.15.230.1, fde6:7a:7d20:be6::1)
. 2021.03.05 19:05:34 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.15.230.1, fde6:7a:7d20:be6::1)
. 2021.03.05 19:05:34 - Routes, added a new route, 192.30.89.27 for gateway 10.15.230.1
. 2021.03.05 19:05:34 - Routes, added a new route, 2606:9580:103:a:fda7:1f4c:8c40:8c3e for gateway fde6:7a:7d20:be6::1
. 2021.03.05 19:05:34 - Flushing DNS
. 2021.03.05 19:05:34 - Flush DNS via dscacheutil
. 2021.03.05 19:05:34 - Flush DNS via nDNSResponder
I 2021.03.05 19:05:35 - Checking route IPv4
. 2021.03.05 19:06:50 - Fetch url error:Couldn't connect to server
. 2021.03.05 19:06:50 - Checking route (2° try)
. 2021.03.05 19:08:06 - Fetch url error:Couldn't connect to server
. 2021.03.05 19:08:06 - Checking route (3° try)
. 2021.03.05 19:09:23 - Fetch url error:Couldn't connect to server
. 2021.03.05 19:09:23 - OpenVPN > Initialization Sequence Completed
! 2021.03.05 19:09:23 - Disconnecting
. 2021.03.05 19:09:24 - Routes, removed a route previously added, 192.30.89.27 for gateway 10.15.230.1
. 2021.03.05 19:09:24 - Routes, removed a route previously added, 2606:9580:103:a:fda7:1f4c:8c40:8c3e for gateway fde6:7a:7d20:be6::1
. 2021.03.05 19:09:24 - Sending soft termination signal
. 2021.03.05 19:09:24 - OpenVPN > event_wait : Interrupted system call (code=4)
. 2021.03.05 19:09:24 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2021.03.05 19:09:29 - OpenVPN > /sbin/route delete -net 192.30.89.29 192.168.1.254 255.255.255.255
. 2021.03.05 19:09:29 - OpenVPN > delete net 192.30.89.29: gateway 192.168.1.254
. 2021.03.05 19:09:29 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.15.230.1 128.0.0.0
. 2021.03.05 19:09:29 - OpenVPN > delete net 0.0.0.0: gateway 10.15.230.1
. 2021.03.05 19:09:29 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.15.230.1 128.0.0.0
. 2021.03.05 19:09:29 - OpenVPN > delete net 128.0.0.0: gateway 10.15.230.1
. 2021.03.05 19:09:29 - OpenVPN > delete_route_ipv6(::/3)
. 2021.03.05 19:09:29 - OpenVPN > /sbin/route delete -inet6 :: -prefixlen 3 -iface utun1
. 2021.03.05 19:09:29 - OpenVPN > delete net ::: gateway utun1
. 2021.03.05 19:09:29 - OpenVPN > delete_route_ipv6(2000::/4)
. 2021.03.05 19:09:29 - OpenVPN > /sbin/route delete -inet6 2000:: -prefixlen 4 -iface utun1
. 2021.03.05 19:09:29 - OpenVPN > delete net 2000::: gateway utun1
. 2021.03.05 19:09:29 - OpenVPN > delete_route_ipv6(3000::/4)
. 2021.03.05 19:09:29 - OpenVPN > /sbin/route delete -inet6 3000:: -prefixlen 4 -iface utun1
. 2021.03.05 19:09:29 - OpenVPN > delete net 3000::: gateway utun1
. 2021.03.05 19:09:29 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2021.03.05 19:09:29 - OpenVPN > /sbin/route delete -inet6 fc00:: -prefixlen 7 -iface utun1
. 2021.03.05 19:09:29 - OpenVPN > delete net fc00::: gateway utun1
. 2021.03.05 19:09:29 - OpenVPN > Closing TUN/TAP interface
. 2021.03.05 19:09:29 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:be6::1018
. 2021.03.05 19:09:29 - OpenVPN > delete host fde6:7a:7d20:be6::1018
. 2021.03.05 19:09:29 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2021.03.05 19:09:29 - Connection terminated.
. 2021.03.05 19:09:29 - DNS of a network adapter restored to original settings (Ethernet, to Automatic)
. 2021.03.05 19:09:30 - DNS of a network adapter restored to original settings (iPad USB, to Automatic)
. 2021.03.05 19:09:30 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.4.0.1)
. 2021.03.05 19:09:30 - DNS of a network adapter restored to original settings (Bluetooth PAN, to Automatic)
. 2021.03.05 19:09:30 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
I 2021.03.05 19:09:30 - Cancel requested.
! 2021.03.05 19:09:30 - Session terminated.
I 2021.03.05 19:09:39 - Session starting.
I 2021.03.05 19:09:40 - Checking authorization ...
! 2021.03.05 19:09:40 - Connecting to Pisces (Canada, Vancouver)
. 2021.03.05 19:09:40 - OpenVPN > OpenVPN 2.5.0 x86_64-apple-darwin19.5.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Oct 28 2020
. 2021.03.05 19:09:40 - OpenVPN > library versions: OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10
. 2021.03.05 19:09:40 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.03.05 19:09:40 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.03.05 19:09:40 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.03.05 19:09:40 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.03.05 19:09:40 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]192.30.89.29:443
. 2021.03.05 19:09:40 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2021.03.05 19:09:40 - OpenVPN > UDP link local: (not bound)
. 2021.03.05 19:09:40 - OpenVPN > UDP link remote: [AF_INET]192.30.89.29:443
. 2021.03.05 19:09:40 - OpenVPN > TLS: Initial packet from [AF_INET]192.30.89.29:443, sid=9e1ae873 e15ac318
. 2021.03.05 19:09:40 - OpenVPN > VERIFY KU OK
. 2021.03.05 19:09:40 - OpenVPN > Validating certificate extended key usage
. 2021.03.05 19:09:40 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.03.05 19:09:40 - OpenVPN > VERIFY EKU OK
. 2021.03.05 19:09:40 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Pisces, emailAddress=info@airvpn.org
. 2021.03.05 19:09:40 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.03.05 19:09:40 - OpenVPN > [Pisces] Peer Connection Initiated with [AF_INET]192.30.89.29:443
. 2021.03.05 19:09:41 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2021.03.05 19:09:41 - OpenVPN > route: writing to routing socket: File exists
. 2021.03.05 19:09:41 - OpenVPN > SENT CONTROL [Pisces]: 'PUSH_REQUEST' (status=1)
. 2021.03.05 19:09:41 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.15.230.1,dhcp-option DNS6 fde6:7a:7d20:be6::1,tun-ipv6,route-gateway 10.15.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:be6::1018/64 fde6:7a:7d20:be6::1,ifconfig 10.15.230.26 255.255.255.0,peer-id 5,cipher AES-256-GCM'
. 2021.03.05 19:09:41 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.03.05 19:09:41 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.03.05 19:09:41 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.03.05 19:09:41 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.03.05 19:09:41 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.03.05 19:09:41 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.03.05 19:09:41 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.03.05 19:09:41 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.03.05 19:09:41 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.03.05 19:09:41 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.03.05 19:09:41 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.03.05 19:09:41 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.03.05 19:09:41 - OpenVPN > ROUTE_GATEWAY 192.168.1.254/255.255.255.0 IFACE=en0 HWADDR=68:5b:35:7f:89:b2
. 2021.03.05 19:09:41 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.03.05 19:09:41 - OpenVPN > ROUTE6_GATEWAY fe80::9e1e:95ff:fed2:4590 IFACE=en0
. 2021.03.05 19:09:41 - OpenVPN > Opened utun device utun1
. 2021.03.05 19:09:41 - OpenVPN > /sbin/ifconfig utun1 delete
. 2021.03.05 19:09:41 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2021.03.05 19:09:41 - OpenVPN > /sbin/ifconfig utun1 10.15.230.26 10.15.230.26 netmask 255.255.255.0 mtu 1500 up
. 2021.03.05 19:09:41 - OpenVPN > /sbin/route add -net 10.15.230.0 10.15.230.26 255.255.255.0
. 2021.03.05 19:09:41 - OpenVPN > add net 10.15.230.0: gateway 10.15.230.26
. 2021.03.05 19:09:41 - OpenVPN > /sbin/ifconfig utun1 inet6 fde6:7a:7d20:be6::1018/64 mtu 1500 up
. 2021.03.05 19:09:41 - OpenVPN > add_route_ipv6(fde6:7a:7d20:be6::/64 -> fde6:7a:7d20:be6::1018 metric 0) dev utun1
. 2021.03.05 19:09:41 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:be6:: -prefixlen 64 -iface utun1
. 2021.03.05 19:09:41 - OpenVPN > add net fde6:7a:7d20:be6::: gateway utun1: File exists
. 2021.03.05 19:09:41 - OpenVPN > /sbin/route add -net 192.30.89.29 192.168.1.254 255.255.255.255
. 2021.03.05 19:09:41 - OpenVPN > add net 192.30.89.29: gateway 192.168.1.254
. 2021.03.05 19:09:41 - OpenVPN > /sbin/route add -net 0.0.0.0 10.15.230.1 128.0.0.0
. 2021.03.05 19:09:41 - OpenVPN > add net 0.0.0.0: gateway 10.15.230.1
. 2021.03.05 19:09:41 - OpenVPN > /sbin/route add -net 128.0.0.0 10.15.230.1 128.0.0.0
. 2021.03.05 19:09:41 - OpenVPN > add net 128.0.0.0: gateway 10.15.230.1
. 2021.03.05 19:09:41 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:be6::1 metric -1) dev utun1
. 2021.03.05 19:09:41 - OpenVPN > /sbin/route add -inet6 :: -prefixlen 3 -iface utun1
. 2021.03.05 19:09:41 - OpenVPN > add net ::: gateway utun1
. 2021.03.05 19:09:41 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:be6::1 metric -1) dev utun1
. 2021.03.05 19:09:41 - OpenVPN > /sbin/route add -inet6 2000:: -prefixlen 4 -iface utun1
. 2021.03.05 19:09:41 - OpenVPN > add net 2000::: gateway utun1
. 2021.03.05 19:09:41 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:be6::1 metric -1) dev utun1
. 2021.03.05 19:09:41 - OpenVPN > /sbin/route add -inet6 3000:: -prefixlen 4 -iface utun1
. 2021.03.05 19:09:41 - OpenVPN > add net 3000::: gateway utun1
. 2021.03.05 19:09:41 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:be6::1 metric -1) dev utun1
. 2021.03.05 19:09:41 - OpenVPN > /sbin/route add -inet6 fc00:: -prefixlen 7 -iface utun1
. 2021.03.05 19:09:41 - OpenVPN > add net fc00::: gateway utun1
. 2021.03.05 19:09:42 - DNS of a network adapter forced (Ethernet, from Automatic to 10.15.230.1, fde6:7a:7d20:be6::1)
. 2021.03.05 19:09:42 - DNS of a network adapter forced (iPad USB, from Automatic to 10.15.230.1, fde6:7a:7d20:be6::1)
. 2021.03.05 19:09:42 - DNS of a network adapter forced (Wi-Fi, from 10.4.0.1 to 10.15.230.1, fde6:7a:7d20:be6::1)
. 2021.03.05 19:09:42 - DNS of a network adapter forced (Bluetooth PAN, from Automatic to 10.15.230.1, fde6:7a:7d20:be6::1)
. 2021.03.05 19:09:42 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.15.230.1, fde6:7a:7d20:be6::1)
. 2021.03.05 19:09:42 - Routes, added a new route, 192.30.89.27 for gateway 10.15.230.1
. 2021.03.05 19:09:42 - Routes, added a new route, 2606:9580:103:a:fda7:1f4c:8c40:8c3e for gateway fde6:7a:7d20:be6::1
. 2021.03.05 19:09:42 - Flushing DNS
. 2021.03.05 19:09:42 - Flush DNS via dscacheutil
. 2021.03.05 19:09:42 - Flush DNS via nDNSResponder
I 2021.03.05 19:09:43 - Checking route IPv4
I 2021.03.05 19:09:43 - Checking route IPv6
I 2021.03.05 19:09:44 - Checking DNS
! 2021.03.05 19:09:44 - Connected.
. 2021.03.05 19:09:44 - OpenVPN > Initialization Sequence Completed
Edited ... by OpenSourcerer
Apply LOG format to logs
Attaching the System log, if that helps. Wondering if the problem has something to do with this:
Test DNS IPv4: Ok
Test DNS IPv6: Ok
Test Ping IPv4: Failed
Test Ping IPv6: Failed
Test HTTP IPv4: Ok
Test HTTP IPv6: Ok
Test HTTPS: Ok
Eddie Sys Log
Test DNS IPv4: Ok
Test DNS IPv6: Ok
Test HTTP IPv4: Ok
Test HTTP IPv6: Ok
Test HTTPS: Ok
OK, no ideas. Can someone simply explain to me why all the above tests would be fine other than "ping"?
I cannot really help you as my experience with macOS is rudimentary at best, but if you don't get an answer in a reaonable time frame, consider opening a ticket.
Well, I'm not sure it warrants a ticket or not. At worst it is just an irritant. It's just strange that it will not initially connect and then after a cancel and a reconnect, it connects instantly. It's a "Twilight Zone" problem!
23 minutes ago, dIecbasC said:
Is your firewall blocking ICMP / ICMP6?
Actually I checked and it is.
I will uncheck it and see if that makes a difference and let you know.
That actually seemed to work. Unchecked "Enable stealth mode" quit Eddie, restarted and bingo! Connected right away. Much obliged dlecbasC. Not being very tech savy, I really appreciate all the help I get form the tech informed among you! For interest sake, here is the new log:
. 2021.03.07 19:14:51 - Eddie version: 2.19.7 / macos_x64, System: MacOS, Name: macOS 10.14.6, Version: 10.14.6 (Build 18G8022), Mono/.Net: v4.0.30319
. 2021.03.07 19:14:51 - Command line arguments (0):
. 2021.03.07 19:14:55 - Profile path: /Users/$$$$$$/.config/eddie/default.profile
. 2021.03.07 19:14:55 - Reading options from /Users/$$$$$$/.config/eddie/default.profile
. 2021.03.07 19:14:57 - Tun Driver - Expected
. 2021.03.07 19:14:57 - OpenVPN - Version: 2.5.0 - OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
. 2021.03.07 19:14:57 - SSH - Version: OpenSSH_7.9p1, LibreSSL 2.7.3 (/usr/bin/ssh)
. 2021.03.07 19:14:57 - SSL - Version: stunnel 5.56 (/Applications/Eddie.app/Contents/MacOS/stunnel)
. 2021.03.07 19:14:57 - Recovery. Unexpected crash?
. 2021.03.07 19:14:57 - Routes, removed an existing route, 184.75.221.35 for gateway 10.28.22.1
. 2021.03.07 19:14:57 - Routes, removed an existing route, 2606:6080:1001:e:2e9c:bad5:dbdd:84ea for gateway fde6:7a:7d20:1816::1
. 2021.03.07 19:14:57 - Routes, added a new route, 184.75.223.195 for gateway 10.29.58.1
. 2021.03.07 19:14:57 - Routes, added a new route, 2606:6080:1002:4:88e7:e893:3692:25d2 for gateway fde6:7a:7d20:193a::1
. 2021.03.07 19:14:57 - Routes, removed an existing route, 184.75.221.3 for gateway 10.20.250.1
. 2021.03.07 19:14:57 - Routes, removed an existing route, 2606:6080:1001:d:c59c:6e9a:3115:6f2f for gateway fde6:7a:7d20:10fa::1
. 2021.03.07 19:14:57 - Routes, added a new route, 137.63.71.51 for gateway 10.31.86.1
. 2021.03.07 19:14:57 - Routes, added a new route, 2606:6080:1001:18:8d41:9604:d435:36b6 for gateway fde6:7a:7d20:1b56::1
. 2021.03.07 19:14:57 - Routes, added a new route, 104.254.90.203 for gateway 10.8.86.1
. 2021.03.07 19:14:57 - Routes, added a new route, 2606:6080:2001:7:8e6:43a8:fb13:2f6d for gateway fde6:7a:7d20:456::1
. 2021.03.07 19:14:57 - Routes, added a new route, 104.254.90.187 for gateway 10.28.86.1
. 2021.03.07 19:14:57 - Routes, added a new route, 2606:6080:2001:5:48ec:2d6:cc35:3864 for gateway fde6:7a:7d20:1856::1
. 2021.03.07 19:14:57 - Routes, added a new route, 104.254.90.195 for gateway 10.29.246.1
. 2021.03.07 19:14:57 - Routes, added a new route, 2606:6080:2001:6:e14e:c3f3:8562:6916 for gateway fde6:7a:7d20:19f6::1
. 2021.03.07 19:14:57 - Routes, added a new route, 192.30.89.59 for gateway 10.20.70.1
. 2021.03.07 19:14:57 - Routes, added a new route, 2606:9580:100:d:2bd7:c37b:24c2:c069 for gateway fde6:7a:7d20:1046::1
. 2021.03.07 19:14:58 - Routes, added a new route, 2606:9580:100:d:2bd7:c37b:24c2:c069 for gateway fde6:7a:7d20:1046::1
. 2021.03.07 19:14:58 - Routes, added a new route, 192.30.89.59 for gateway 10.20.70.1
. 2021.03.07 19:14:58 - Routes, removed an existing route, 192.30.89.51 for gateway 10.19.6.1
. 2021.03.07 19:14:58 - Routes, removed an existing route, 2606:9580:100:c:8757:8ee:ec9c:991c for gateway fde6:7a:7d20:f06::1
. 2021.03.07 19:14:58 - Routes, added a new route, 192.30.89.67 for gateway 10.35.70.1
. 2021.03.07 19:14:58 - Routes, added a new route, 2606:9580:100:e:d075:a67e:1f9c:139d for gateway fde6:7a:7d20:1f46::1
. 2021.03.07 19:14:58 - Routes, added a new route, 192.30.89.27 for gateway 10.15.230.1
. 2021.03.07 19:14:58 - Routes, added a new route, 2606:9580:103:a:fda7:1f4c:8c40:8c3e for gateway fde6:7a:7d20:be6::1
. 2021.03.07 19:14:58 - Routes, removed an existing route, 192.30.89.75 for gateway 10.35.102.1
. 2021.03.07 19:14:58 - Routes, removed an existing route, 2606:9580:100:f:5792:2dec:a4b6:2419 for gateway fde6:7a:7d20:1f66::1
! 2021.03.07 19:14:58 - Activation of Network Lock - macOS - PF
I 2021.03.07 19:14:59 - Ready
. 2021.03.07 19:15:00 - Collect information about AirVPN completed
I 2021.03.07 19:15:01 - Session starting.
. 2021.03.07 19:15:01 - Waiting for latency tests (181 to go)
. 2021.03.07 19:15:02 - Collect information about AirVPN completed
. 2021.03.07 19:15:02 - Waiting for latency tests (161 to go)
. 2021.03.07 19:15:04 - Waiting for latency tests (113 to go)
. 2021.03.07 19:15:05 - Waiting for latency tests (75 to go)
. 2021.03.07 19:15:06 - Waiting for latency tests (36 to go)
. 2021.03.07 19:15:07 - Waiting for latency tests (11 to go)
I 2021.03.07 19:15:08 - Checking authorization ...
! 2021.03.07 19:15:09 - Connecting to Sham (Canada, Vancouver)
. 2021.03.07 19:15:09 - Routes, added a new route, 107.189.30.10 for gateway 192.168.1.254
. 2021.03.07 19:15:09 - OpenVPN > OpenVPN 2.5.0 x86_64-apple-darwin19.5.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Oct 28 2020
. 2021.03.07 19:15:09 - OpenVPN > library versions: OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10
. 2021.03.07 19:15:09 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.03.07 19:15:09 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.03.07 19:15:09 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.03.07 19:15:09 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.03.07 19:15:09 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]192.30.89.77:443
. 2021.03.07 19:15:09 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2021.03.07 19:15:09 - OpenVPN > UDP link local: (not bound)
. 2021.03.07 19:15:09 - OpenVPN > UDP link remote: [AF_INET]192.30.89.77:443
. 2021.03.07 19:15:09 - OpenVPN > TLS: Initial packet from [AF_INET]192.30.89.77:443, sid=55591d40 db982495
. 2021.03.07 19:15:09 - OpenVPN > VERIFY KU OK
. 2021.03.07 19:15:09 - OpenVPN > Validating certificate extended key usage
. 2021.03.07 19:15:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.03.07 19:15:09 - OpenVPN > VERIFY EKU OK
. 2021.03.07 19:15:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sham, emailAddress=info@airvpn.org
. 2021.03.07 19:15:09 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.03.07 19:15:09 - OpenVPN > [Sham] Peer Connection Initiated with [AF_INET]192.30.89.77:443
. 2021.03.07 19:15:10 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2021.03.07 19:15:10 - OpenVPN > route: writing to routing socket: File exists
. 2021.03.07 19:15:10 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.35.102.1,dhcp-option DNS6 fde6:7a:7d20:1f66::1,tun-ipv6,route-gateway 10.35.102.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1f66::104e/64 fde6:7a:7d20:1f66::1,ifconfig 10.35.102.80 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2021.03.07 19:15:10 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.03.07 19:15:10 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.03.07 19:15:10 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.03.07 19:15:10 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.03.07 19:15:10 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.03.07 19:15:10 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.03.07 19:15:10 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.03.07 19:15:10 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.03.07 19:15:10 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.03.07 19:15:10 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.03.07 19:15:10 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.03.07 19:15:10 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.03.07 19:15:10 - OpenVPN > ROUTE_GATEWAY 192.168.1.254/255.255.255.0 IFACE=en0 HWADDR=68:5b:35:7f:89:b2
. 2021.03.07 19:15:10 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.03.07 19:15:10 - OpenVPN > ROUTE6_GATEWAY fe80::9e1e:95ff:fed2:4590 IFACE=en0
. 2021.03.07 19:15:10 - OpenVPN > Opened utun device utun1
. 2021.03.07 19:15:10 - OpenVPN > /sbin/ifconfig utun1 delete
. 2021.03.07 19:15:10 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2021.03.07 19:15:10 - OpenVPN > /sbin/ifconfig utun1 10.35.102.80 10.35.102.80 netmask 255.255.255.0 mtu 1500 up
. 2021.03.07 19:15:10 - OpenVPN > /sbin/route add -net 10.35.102.0 10.35.102.80 255.255.255.0
. 2021.03.07 19:15:10 - OpenVPN > add net 10.35.102.0: gateway 10.35.102.80
. 2021.03.07 19:15:10 - OpenVPN > /sbin/ifconfig utun1 inet6 fde6:7a:7d20:1f66::104e/64 mtu 1500 up
. 2021.03.07 19:15:10 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1f66::/64 -> fde6:7a:7d20:1f66::104e metric 0) dev utun1
. 2021.03.07 19:15:10 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:1f66:: -prefixlen 64 -iface utun1
. 2021.03.07 19:15:10 - OpenVPN > add net fde6:7a:7d20:1f66::: gateway utun1: File exists
. 2021.03.07 19:15:10 - OpenVPN > /sbin/route add -net 192.30.89.77 192.168.1.254 255.255.255.255
. 2021.03.07 19:15:10 - OpenVPN > add net 192.30.89.77: gateway 192.168.1.254
. 2021.03.07 19:15:10 - OpenVPN > /sbin/route add -net 0.0.0.0 10.35.102.1 128.0.0.0
. 2021.03.07 19:15:10 - OpenVPN > add net 0.0.0.0: gateway 10.35.102.1
. 2021.03.07 19:15:10 - OpenVPN > /sbin/route add -net 128.0.0.0 10.35.102.1 128.0.0.0
. 2021.03.07 19:15:10 - OpenVPN > add net 128.0.0.0: gateway 10.35.102.1
. 2021.03.07 19:15:10 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1f66::1 metric -1) dev utun1
. 2021.03.07 19:15:10 - OpenVPN > /sbin/route add -inet6 :: -prefixlen 3 -iface utun1
. 2021.03.07 19:15:10 - OpenVPN > add net ::: gateway utun1
. 2021.03.07 19:15:10 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1f66::1 metric -1) dev utun1
. 2021.03.07 19:15:10 - OpenVPN > /sbin/route add -inet6 2000:: -prefixlen 4 -iface utun1
. 2021.03.07 19:15:10 - OpenVPN > add net 2000::: gateway utun1
. 2021.03.07 19:15:10 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1f66::1 metric -1) dev utun1
. 2021.03.07 19:15:10 - OpenVPN > /sbin/route add -inet6 3000:: -prefixlen 4 -iface utun1
. 2021.03.07 19:15:10 - OpenVPN > add net 3000::: gateway utun1
. 2021.03.07 19:15:10 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1f66::1 metric -1) dev utun1
. 2021.03.07 19:15:10 - OpenVPN > /sbin/route add -inet6 fc00:: -prefixlen 7 -iface utun1
. 2021.03.07 19:15:10 - OpenVPN > add net fc00::: gateway utun1
. 2021.03.07 19:15:11 - DNS of a network adapter forced (Ethernet, from Automatic to 10.35.102.1, fde6:7a:7d20:1f66::1)
. 2021.03.07 19:15:11 - DNS of a network adapter forced (iPad USB, from Automatic to 10.35.102.1, fde6:7a:7d20:1f66::1)
. 2021.03.07 19:15:11 - DNS of a network adapter forced (Wi-Fi, from 10.4.0.1 to 10.35.102.1, fde6:7a:7d20:1f66::1)
. 2021.03.07 19:15:11 - DNS of a network adapter forced (Bluetooth PAN, from Automatic to 10.35.102.1, fde6:7a:7d20:1f66::1)
. 2021.03.07 19:15:11 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.35.102.1, fde6:7a:7d20:1f66::1)
. 2021.03.07 19:15:11 - Routes, restored a previously deleted route, 192.30.89.75 for gateway 10.35.102.1
. 2021.03.07 19:15:11 - Routes, restored a previously deleted route, 2606:9580:100:f:5792:2dec:a4b6:2419 for gateway fde6:7a:7d20:1f66::1
. 2021.03.07 19:15:11 - Flushing DNS
. 2021.03.07 19:15:11 - Flush DNS via dscacheutil
. 2021.03.07 19:15:11 - Flush DNS via nDNSResponder
I 2021.03.07 19:15:12 - Checking route IPv4
I 2021.03.07 19:15:12 - Checking route IPv6
I 2021.03.07 19:15:12 - Checking DNS
! 2021.03.07 19:15:12 - Connected.
. 2021.03.07 19:15:13 - OpenVPN > Initialization Sequence Completed
Oops. Jumped the gun. I shut down Eddie again and restarted, and the initial problem is back. Stuck at checking ipv4 ...... cancel ........reconnect to server ...... connects. Strange happenings!
Updated log:
I 2021.03.07 19:26:46 - Checking route IPv4
. 2021.03.07 19:28:06 - Fetch url error:Couldn't connect to server
. 2021.03.07 19:28:06 - OpenVPN > Initialization Sequence Completed
! 2021.03.07 19:28:06 - Disconnecting
So curious. What would cause the "fetch url error"?
A ticket has been sent. We will see what the admins say.
Got a reply from admin as follows:
"Please try the following settings:
- from Eddie's main window select "Preferences" > "Advanced"
- de-tick "Check if the VPN tunnel works"
- click "Save"
- from Eddie's main windows select "Preferences" > "DNS"
- de-tick "Check Air VPN DNS"
- from Eddie's main window enable "Network Lock" option (important, because you have disable some safety check previously)
Test again a connection to reproduce the issue and check whether the connection goes through this time. If so, go to ipleak.net web site and make sure that everything is fine."
I quit and restarted Eddie twice, and it connected right away both times. I replied to the admin e-mail and will see if there are any further instructions. If not, it appears this problem has been solved.
Just to complete this problem and wrap it up, admin further stated "We're very glad to know it. For some reason the route check error was a false positive. By disabling this check you have resolved the issue. With Network Lock enabled, the route check is redundant and a waste of time, so you can safely use Eddie with the current settings." I will now consider this problem closed. I hope anyone that has the same problem, now or in the future, will benefit from this info.
same issue on startup but i can still use browser to access the internet, i'm really connected. is it completely safe and my mac is fully in Eddie protection? just started getting the Check Route IPv4 about 3 days ago (but i also changed ISP 10 days ago so wasn't sure if that caused it?). i was starting to create a ticket and searched first. 10.12.6 Eddie 2.20.0. sometimes eddie solves it after 5+ minutes. i don't want to put my screenshot here in public view. ps. i can't figure out or find in help how to add an attachment when sending in Contact or Compose New Message (is this how we create a ticket? i don't see anywhere/FAQ how to create a Ticket.). when i do start to compose a contact/new msg there is no option to add an attachment that works. i don't have a "Drag files here to attach..." like i see in this editor box.  i get a "Insert other media">"Insert existing attachment" but not options to add media and in "My Attachments" option there is no method to drag in/add media. it seems this option is disabled on my account? i can only add media in this section.
thanks for any tips!
