zeroone1zero
no scores or latency results listed
After months and months of smooth performance, Eddie v2.18 started acting
up on me.  A couple of days ago I noticed I was connected to 'Vienna'. and had no
scores or latency results listed under 'Servers'.
I checked all the settings and nothing seemed to have changed so I pulled the
AirVPN folder out of a Macrium image and replaced it with the one in Program Files.
Still same issues.  Then I completely uninstalled AirVPN rebooted and installed v2.19.
Still connecting to 'Vienna' no scores and no latency results.  I could try restoring a
Macrium image but thought I'd check to see if there is a known reason & cure for
this odd behaviour.
