Not connected, Your IP: 216.73.216.47
blabla49
[SOLVED] Input string was not in correct format ?
I'm testing out your solution.
Seems to work fine, until I installed comodo, and restarted my computer. When I try to login I get:
16/10/2012 - 10:36 AirVPN client version: 1,7
16/10/2012 - 10:36 Reading options from C:\Users\Alex\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
16/10/2012 - 10:36 OpenVPN bundle version: OpenVPN 2.2.2
16/10/2012 - 10:36 OpenVPN current version: OpenVPN 2.2.2
16/10/2012 - 10:36 Ready.
16/10/2012 - 10:36 Input string was not in a correct format.
On Win 7 32bits.
Thanks.
On Win 7 32bits.
Thanks.
Probably it's not related to Comodo. Anyway you can be sure of this by setting Comodo firewall and Defense+ to "Disabled".
Try to delete the file C:\Users\Alex\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml (while the Air client is not running).
The Air client will re-generate it at the next run (you will have to enter again your login).
Are you using the latest Air client version (1.7)?
Ok deleting the xml worked. I started comodo again, and everything seems ok.
I don't know which version I'm running. Where do I see that ?
Glad to know that the problem is solved. Probably the XML was corrupt and the autofix procedure did not work properly for some reason.
About the version, forget the question. The version is specified at the beginning of the logs that you correctly pasted, you are using 1.7 (currently the latest version).
