yurix100
Eddie rejects passwords - and a strange 'passwords' window
I changed my Airvpn password on the website after the reported password leak, and I can obviously still log in here, but Eddie is "stuck" now - I can't press any buttons, and a strange "Passwords..." window appears.
Alternatively I thought I could create a Tunnelblick configuration, but no luck there either - the page says "unknown host."
Edited ... by yurix100
Reboot your computer, then try deleting the profile file. It's somewhere in /Users/username/Applications/Eddie or something.
All this seems a little strange to me, especially the last screenshot. Does this direct link work? https://airvpn.org/generator/
Not sure why I got the "unknown host" window, but I now I can generate a configuration file, and with Tunnelblick I can log in and connect to VPN. I have also deleted my Eddie profile like so
% rm /Users/myusername/.config/eddie/default.profile
and restarted Eddie. Still the same error: "wrong login/password".
