Nano Fernandez 0 Posted ... Hello everyone, I need a recommendation for a decent/not-expensive router with OpenVpn to be used with AirVPN. I took a look at something like GL.iNet GL-MT300N... ...BUT they seem to be chinese tools with vulnerabilities and backdoors, so that is for me like bodyjumping from a plane with a very good helmet but a very bad parachute. I suppose that people here in the forum should have good answers and experience in this topic. So, could you please recommend some portable/small Routers for Airvpn with no vulnerabilities and with a decent level of security? Thanks in advance!! Quote Share this post Link to post
Casper31 73 Posted ... I have good experience with the "GL-AR750S-Ext". I use the router when I am travelling. The compagny is trusty and they upload upgrades regularly . Of course security is more than a router.. . Greetings,Linse Quote Share this post Link to post
SurprisedItWorks 54 Posted ... If you are able to find a used Netgear R7800 (X4S Nighthawk) at a reasonable price (new ones are pricey), that is pretty universally agreed in the dd-wrt forums these days to be the least troublesome router with solid speed for use with dd-wrt. Supposedly it runs OpenVPN at around 100 Mbps, and there are flashing instructions in the forum at https://forum.dd-wrt.com/phpBB2/viewtopic.php?t=320614. The AirVPN setup how-to is at https://forum.dd-wrt.com/phpBB2/viewtopic.php?t=321856, though note it has not been updated yet for OpenVPN 2.5. Find general dd-wrt OpenVPN guidance, including notes on changes needed for OpenVPN 2.5, at https://forum.dd-wrt.com/phpBB2/viewtopic.php?t=327398. You'll need to register as a forum user and be logged in to download the pdfs. The forum that discusses the R7800 and related routers is at https://forum.dd-wrt.com/phpBB2/viewforum.php?f=28, and it's important to check the new-build thread there for any build you are considering flashing, just to make sure R7800 owners are not having trouble with it. There is a dd-wrt router database that is referenced in a million online how-to articles outside the dd-wrt forums. Ignore it. Its build recommendations are poor, sometimes disastrously so. Usually the latest build is the right one for that router. Re solutions other than dd-wrt, I do know that those Asus routers running AsusWRT offer OpenVPN, though they use Broadcom wifi hardware rather than the generally preferred Atheros wifi hardware. If you go that way, pick a model that is supported by (with many users) AsusWRT-Merlin (see https://www.asuswrt-merlin.net/), so that you will have the option of eventually upgrading your firmware to it. AsusWRT-Merlin is much less aggressive than dd-wrt with adding exotic features. It fixes bugs in the original AsusWRT and extends router capabilities in certain areas in a relatively gentle way. I believe I remember that OpenVPN Policy Based Routing (routing some but not all clients through the VPN) is one of its additional features. You'll either want PBR or two routers, one for VPN and one for bypassing it, in any practical router-VPN setup. I know little about other options so will let others comment. Good luck. 2 db-001 and Nano Fernandez reacted to this Quote Share this post Link to post
Nano Fernandez 0 Posted ... I could read this about GL.inethttps://nvd.nist.gov/vuln/detail/CVE-2019-6272#vulnCurrentDescriptionTitle Command injection vulnerability in login_cgi in GL.iNet GL-AR300M-Lite devices with firmware 2.27 allows remote attackers to execute arbitrary code. It is also known about many devices having some kind of leakage of data, hardware-embedded inside the chip (smartphones, routers, and so on...)... as it seems to be pretty lucrative beeing able to catch cryptocurrency passwords and many other data. So I wonder if it makes sense having a VPN running in a router like that. I would be like a data tunnel with some holes for others to look inside. Even more, most of the data is being recorded, and despite that today may be hard to decode, it could be pretty easy in just a few years. Quote Share this post Link to post
Air4141841 30 Posted ... if have used multiple Netgate appliances and they have all worked flawlessly :https://www.netgate.com/products/appliances/ currently using a 3100 now Quote Share this post Link to post
Air4141841 30 Posted ... https://www.netgate.com/products/appliances/ runs my 100Mb symmetrical fiber like nothing Quote Share this post Link to post
