Hundekuchen123
Error: Nexthop has invalid gateway.
Hi guys running into this issue when trying to connect:
This is running a VPS, i have AirVPN running on other VPS too but this one is a bit tricky...
Any Ideas? Thanks
Log:
sudo openvpn AirVPN_DE-Munich_Mesarthim_UDP-443.ovpn
Tue Jan  5 01:37:41 2021 OpenVPN 2.4.7 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Sep  5 2019
Tue Jan  5 01:37:41 2021 library versions: OpenSSL 1.1.1f  31 Mar 2020, LZO 2.10
Tue Jan  5 01:37:41 2021 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Tue Jan  5 01:37:41 2021 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Tue Jan  5 01:37:41 2021 TCP/UDP: Preserving recently used remote address: [AF_INET]79.143.191.166:443
Tue Jan  5 01:37:41 2021 Socket Buffers: R=[212992->425984] S=[212992->425984]
Tue Jan  5 01:37:41 2021 UDP link local: (not bound)
Tue Jan  5 01:37:41 2021 UDP link remote: [AF_INET]79.143.191.166:443
Tue Jan  5 01:37:41 2021 TLS: Initial packet from [AF_INET]79.143.191.166:443, sid=82acd545 cdf1dc99
Tue Jan  5 01:37:41 2021 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Tue Jan  5 01:37:41 2021 VERIFY KU OK
Tue Jan  5 01:37:41 2021 Validating certificate extended key usage
Tue Jan  5 01:37:41 2021 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Tue Jan  5 01:37:41 2021 VERIFY EKU OK
Tue Jan  5 01:37:41 2021 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Mesarthim, emailAddress=info@airvpn.org
Tue Jan  5 01:37:41 2021 Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
Tue Jan  5 01:37:41 2021 [Mesarthim] Peer Connection Initiated with [AF_INET]79.143.191.166:443
Tue Jan  5 01:37:42 2021 SENT CONTROL [Mesarthim]: 'PUSH_REQUEST' (status=1)
Tue Jan  5 01:37:42 2021 PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.22.104.1,route-gateway 10.22.104.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.22.104.13 255.255.255.0,peer-id 14,cipher AES-256-GCM'
Tue Jan  5 01:37:42 2021 OPTIONS IMPORT: timers and/or timeouts modified
Tue Jan  5 01:37:42 2021 OPTIONS IMPORT: compression parms modified
Tue Jan  5 01:37:42 2021 OPTIONS IMPORT: --ifconfig/up options modified
Tue Jan  5 01:37:42 2021 OPTIONS IMPORT: route options modified
Tue Jan  5 01:37:42 2021 OPTIONS IMPORT: route-related options modified
Tue Jan  5 01:37:42 2021 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Tue Jan  5 01:37:42 2021 OPTIONS IMPORT: peer-id set
Tue Jan  5 01:37:42 2021 OPTIONS IMPORT: adjusting link_mtu to 1625
Tue Jan  5 01:37:42 2021 OPTIONS IMPORT: data channel crypto options modified
Tue Jan  5 01:37:42 2021 Data Channel: using negotiated cipher 'AES-256-GCM'
Tue Jan  5 01:37:42 2021 Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Tue Jan  5 01:37:42 2021 Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Tue Jan  5 01:37:42 2021 ROUTE_GATEWAY 178.238.227.1
Tue Jan  5 01:37:42 2021 TUN/TAP device tun0 opened
Tue Jan  5 01:37:42 2021 TUN/TAP TX queue length set to 100
Tue Jan  5 01:37:42 2021 /sbin/ip link set dev tun0 up mtu 1500
Tue Jan  5 01:37:42 2021 /sbin/ip addr add dev tun0 10.22.104.13/24 broadcast 10.22.104.255
Tue Jan  5 01:37:42 2021 /sbin/ip route add 79.143.191.166/32 via 178.238.227.1
Hm. Post the output of the commands ip -4 a and ip -4 r, please.
