Maharana 0 Posted ... (edited) Hello, Please find below my detailed log from today. It seems like a DNS problem too but different to the one mentioned below. Thanks for your help. Eddie System/Environment Report - 12/24/2020 12:36 PM UTC Eddie version: 2.16.3 Eddie OS build: macos_x64 Eddie architecture: x64 OS type: MacOS OS name: 10.14.6 OS version: Darwin Tims-MacBook-Pro.local 18.7.0 Darwin Kernel Version 18.7.0: Tue Nov 10 00:07:31 PST 2020; root:xnu-4903.278.51~1/RELEASE_X86_64 x86_64 OS architecture: x64 Mono /.Net Framework: v4.0.30319 OpenVPN driver: Expected OpenVPN: 2.4.6 - OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 (/private/var/folders/9_/z3g7kmf94b93ng3t3lrvw64h0000gn/T/AppTranslocation/04891A05-2B1E-4D73-B51F-13E1F82261D4/d/Eddie.app/Contents/MacOS/openvpn) SSH: OpenSSH_7.9p1, LibreSSL 2.7.3 (/usr/bin/ssh) SSL: stunnel 5.48 (/private/var/folders/9_/z3g7kmf94b93ng3t3lrvw64h0000gn/T/AppTranslocation/04891A05-2B1E-4D73-B51F-13E1F82261D4/d/Eddie.app/Contents/MacOS/stunnel) curl: 7.54.0 (/usr/bin/curl) Profile path: /Users/timrenwick/.airvpn/default.xml Data path: /Users/timrenwick/.airvpn Application path: /private/var/folders/9_/z3g7kmf94b93ng3t3lrvw64h0000gn/T/AppTranslocation/04891A05-2B1E-4D73-B51F-13E1F82261D4/d/Eddie.app/Contents/MacOS Executable path: /private/var/folders/9_/z3g7kmf94b93ng3t3lrvw64h0000gn/T/AppTranslocation/04891A05-2B1E-4D73-B51F-13E1F82261D4/d/Eddie.app/Contents/MacOS/Eddie Command line arguments: (0 args) Network Lock Active: No Connected to VPN: No Detected DNS: 10.6.154.1, fde6:7a:7d20:29a::1 Test DNS IPv4: Ok Test DNS IPv6: Ok Test Ping IPv4: 45 ms Test Ping IPv6: 45 ms Test HTTP IPv4: Ok Test HTTP IPv6: Ok Test HTTPS: Ok ---------------------------- Important options not at defaults: login: (omissis) password: (omissis) remember: True key: (omissis) connect: True servers.whitelist: 0b4bb507e27e816b3c512a7460710cb9c375138ddb2452ea966d266d73d6e180,c432bbea2ba76829e428453cd8c78594f1f40c1462d00f17be1faedcc7d45097,0e106721da83105c6a90cd8e9d7769c1424d5cf98238b1d60d851de136b75d17,6833c08795a1ecc816f7f2f4879ff0e27809fbb40e43dbea5c2b4cc1fea66ddc areas.whitelist: jp ui.skip.provider.manifest.failed: True gui.osx.visible: True ---------------------------- Logs: . 2020.12.24 21:22:42 - OpenVPN > /sbin/route add -inet6 fc00:: -prefixlen 7 -iface utun1 . 2020.12.24 21:22:42 - OpenVPN > add net fc00::: gateway utun1 . 2020.12.24 21:22:42 - DNS of a network adapter forced (Wi-Fi, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:22:42 - DNS of a network adapter forced (PPPoE, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:22:42 - DNS of a network adapter forced (PPPoE 2, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:22:42 - DNS of a network adapter forced (Ethernet, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:22:43 - DNS of a network adapter forced (FireWire, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:22:43 - DNS of a network adapter forced (iPhone USB Kayo, from Automatic to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:22:43 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:22:43 - DNS of a network adapter forced (Bluetooth PAN, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:22:43 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:22:43 - Routes, added a new route, 37.120.210.219 for gateway 10.18.234.1 . 2020.12.24 21:22:43 - Routes, added a new route, 2001:ac8:40:48:d4a2:b617:ea37:b0aa for gateway fde6:7a:7d20:eea::1 . 2020.12.24 21:22:43 - Flushing DNS . 2020.12.24 21:22:43 - OpenVPN > Initialization Sequence Completed ! 2020.12.24 21:22:43 - Disconnecting . 2020.12.24 21:22:44 - Routes, removed a route previously added, 37.120.210.219 for gateway 10.18.234.1 . 2020.12.24 21:22:44 - Routes, removed a route previously added, 2001:ac8:40:48:d4a2:b617:ea37:b0aa for gateway fde6:7a:7d20:eea::1 . 2020.12.24 21:22:44 - Sending management termination signal . 2020.12.24 21:22:44 - Management - Send 'signal SIGTERM' . 2020.12.24 21:22:44 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2020.12.24 21:22:44 - OpenVPN > SIGTERM received, sending exit notification to peer . 2020.12.24 21:22:49 - OpenVPN > /sbin/route delete -net 37.120.210.221 172.20.10.1 255.255.255.255 . 2020.12.24 21:22:49 - OpenVPN > delete net 37.120.210.221: gateway 172.20.10.1 . 2020.12.24 21:22:49 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.18.234.1 128.0.0.0 . 2020.12.24 21:22:49 - OpenVPN > delete net 0.0.0.0: gateway 10.18.234.1 . 2020.12.24 21:22:49 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.18.234.1 128.0.0.0 . 2020.12.24 21:22:49 - OpenVPN > delete net 128.0.0.0: gateway 10.18.234.1 . 2020.12.24 21:22:49 - OpenVPN > delete_route_ipv6(::/3) . 2020.12.24 21:22:49 - OpenVPN > /sbin/route delete -inet6 :: -prefixlen 3 -iface utun1 . 2020.12.24 21:22:49 - OpenVPN > delete net ::: gateway utun1 . 2020.12.24 21:22:49 - OpenVPN > delete_route_ipv6(2000::/4) . 2020.12.24 21:22:49 - OpenVPN > /sbin/route delete -inet6 2000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:22:49 - OpenVPN > delete net 2000::: gateway utun1 . 2020.12.24 21:22:49 - OpenVPN > delete_route_ipv6(3000::/4) . 2020.12.24 21:22:49 - OpenVPN > /sbin/route delete -inet6 3000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:22:49 - OpenVPN > delete net 3000::: gateway utun1 . 2020.12.24 21:22:49 - OpenVPN > delete_route_ipv6(fc00::/7) . 2020.12.24 21:22:49 - OpenVPN > /sbin/route delete -inet6 fc00:: -prefixlen 7 -iface utun1 . 2020.12.24 21:22:49 - OpenVPN > delete net fc00::: gateway utun1 . 2020.12.24 21:22:49 - OpenVPN > Closing TUN/TAP interface . 2020.12.24 21:22:49 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:eea::1088 . 2020.12.24 21:22:49 - OpenVPN > delete host fde6:7a:7d20:eea::1088 . 2020.12.24 21:22:49 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2020.12.24 21:22:49 - Connection terminated. . 2020.12.24 21:22:50 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:22:50 - DNS of a network adapter restored to original settings (PPPoE, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:22:50 - DNS of a network adapter restored to original settings (PPPoE 2, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:22:50 - DNS of a network adapter restored to original settings (Ethernet, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:22:50 - DNS of a network adapter restored to original settings (FireWire, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:22:50 - DNS of a network adapter restored to original settings (iPhone USB Kayo, to Automatic) . 2020.12.24 21:22:51 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2020.12.24 21:22:51 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:22:51 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.6.154.1, fde6:7a:7d20:29a::1) I 2020.12.24 21:22:51 - Cancel requested. ! 2020.12.24 21:22:51 - Session terminated. . 2020.12.24 21:28:46 - Updating systems & servers data ... . 2020.12.24 21:28:49 - Systems & servers data update completed I 2020.12.24 21:30:26 - Session starting. I 2020.12.24 21:30:26 - Checking authorization ... ! 2020.12.24 21:30:27 - Connecting to Okab (Japan, Tokyo) . 2020.12.24 21:30:27 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018 . 2020.12.24 21:30:27 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.12.24 21:30:27 - Connection to OpenVPN Management Interface . 2020.12.24 21:30:27 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2020.12.24 21:30:27 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.24 21:30:27 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.24 21:30:27 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.24 21:30:27 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.24 21:30:27 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]37.120.210.221:443 . 2020.12.24 21:30:27 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2020.12.24 21:30:27 - OpenVPN > UDP link local: (not bound) . 2020.12.24 21:30:27 - OpenVPN > UDP link remote: [AF_INET]37.120.210.221:443 . 2020.12.24 21:30:27 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2020.12.24 21:30:27 - OpenVPN > TLS: Initial packet from [AF_INET]37.120.210.221:443, sid=bff3a252 92539d82 . 2020.12.24 21:30:27 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.24 21:30:27 - OpenVPN > VERIFY KU OK . 2020.12.24 21:30:27 - OpenVPN > Validating certificate extended key usage . 2020.12.24 21:30:27 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.24 21:30:27 - OpenVPN > VERIFY EKU OK . 2020.12.24 21:30:27 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Okab, emailAddress=info@airvpn.org . 2020.12.24 21:30:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.24 21:30:27 - OpenVPN > [Okab] Peer Connection Initiated with [AF_INET]37.120.210.221:443 . 2020.12.24 21:30:29 - OpenVPN > SENT CONTROL [Okab]: 'PUSH_REQUEST' (status=1) . 2020.12.24 21:30:29 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.18.234.1,dhcp-option DNS6 fde6:7a:7d20:eea::1,tun-ipv6,route-gateway 10.18.234.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:eea::1088/64 fde6:7a:7d20:eea::1,ifconfig 10.18.234.138 255.255.255.0,peer-id 1,cipher AES-256-GCM' . 2020.12.24 21:30:29 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2020.12.24 21:30:29 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2020.12.24 21:30:29 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2020.12.24 21:30:29 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2020.12.24 21:30:29 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2020.12.24 21:30:29 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2020.12.24 21:30:29 - OpenVPN > OPTIONS IMPORT: peer-id set . 2020.12.24 21:30:29 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2020.12.24 21:30:29 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2020.12.24 21:30:29 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2020.12.24 21:30:29 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.24 21:30:29 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.24 21:30:29 - OpenVPN > ROUTE_GATEWAY 172.20.10.1/255.255.255.240 IFACE=en5 HWADDR=46:00:10:3f:39:58 . 2020.12.24 21:30:29 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2020.12.24 21:30:29 - OpenVPN > ROUTE6_GATEWAY fe80::ccb:d7f9:9a6c:61fd IFACE=en5 . 2020.12.24 21:30:29 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16) . 2020.12.24 21:30:29 - OpenVPN > Opened utun device utun1 . 2020.12.24 21:30:29 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2020.12.24 21:30:29 - OpenVPN > /sbin/ifconfig utun1 delete . 2020.12.24 21:30:29 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2020.12.24 21:30:29 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2020.12.24 21:30:29 - OpenVPN > /sbin/ifconfig utun1 10.18.234.138 10.18.234.138 netmask 255.255.255.0 mtu 1500 up . 2020.12.24 21:30:29 - OpenVPN > /sbin/route add -net 10.18.234.0 10.18.234.138 255.255.255.0 . 2020.12.24 21:30:29 - OpenVPN > add net 10.18.234.0: gateway 10.18.234.138 . 2020.12.24 21:30:29 - OpenVPN > /sbin/ifconfig utun1 inet6 fde6:7a:7d20:eea::1088/64 . 2020.12.24 21:30:29 - OpenVPN > add_route_ipv6(fde6:7a:7d20:eea::/64 -> fde6:7a:7d20:eea::1088 metric 0) dev utun1 . 2020.12.24 21:30:29 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:eea:: -prefixlen 64 -iface utun1 . 2020.12.24 21:30:29 - OpenVPN > add net fde6:7a:7d20:eea::: gateway utun1: File exists . 2020.12.24 21:30:29 - OpenVPN > route: writing to routing socket: File exists . 2020.12.24 21:30:29 - OpenVPN > /sbin/route add -net 37.120.210.221 172.20.10.1 255.255.255.255 . 2020.12.24 21:30:29 - OpenVPN > add net 37.120.210.221: gateway 172.20.10.1 . 2020.12.24 21:30:29 - OpenVPN > /sbin/route add -net 0.0.0.0 10.18.234.1 128.0.0.0 . 2020.12.24 21:30:29 - OpenVPN > add net 0.0.0.0: gateway 10.18.234.1 . 2020.12.24 21:30:29 - OpenVPN > /sbin/route add -net 128.0.0.0 10.18.234.1 128.0.0.0 . 2020.12.24 21:30:29 - OpenVPN > add net 128.0.0.0: gateway 10.18.234.1 . 2020.12.24 21:30:29 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:eea::1 metric -1) dev utun1 . 2020.12.24 21:30:29 - OpenVPN > /sbin/route add -inet6 :: -prefixlen 3 -iface utun1 . 2020.12.24 21:30:29 - OpenVPN > add net ::: gateway utun1 . 2020.12.24 21:30:29 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:eea::1 metric -1) dev utun1 . 2020.12.24 21:30:29 - OpenVPN > /sbin/route add -inet6 2000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:30:29 - OpenVPN > add net 2000::: gateway utun1 . 2020.12.24 21:30:29 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:eea::1 metric -1) dev utun1 . 2020.12.24 21:30:29 - OpenVPN > /sbin/route add -inet6 3000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:30:29 - OpenVPN > add net 3000::: gateway utun1 . 2020.12.24 21:30:29 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:eea::1 metric -1) dev utun1 . 2020.12.24 21:30:29 - OpenVPN > /sbin/route add -inet6 fc00:: -prefixlen 7 -iface utun1 . 2020.12.24 21:30:29 - OpenVPN > add net fc00::: gateway utun1 . 2020.12.24 21:30:30 - DNS of a network adapter forced (Wi-Fi, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:30:30 - DNS of a network adapter forced (PPPoE, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:30:30 - DNS of a network adapter forced (PPPoE 2, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:30:30 - DNS of a network adapter forced (Ethernet, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:30:30 - DNS of a network adapter forced (FireWire, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:30:30 - DNS of a network adapter forced (iPhone USB Kayo, from Automatic to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:30:30 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:30:30 - DNS of a network adapter forced (Bluetooth PAN, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:30:40 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:30:40 - Routes, added a new route, 37.120.210.219 for gateway 10.18.234.1 . 2020.12.24 21:30:40 - Routes, added a new route, 2001:ac8:40:48:d4a2:b617:ea37:b0aa for gateway fde6:7a:7d20:eea::1 . 2020.12.24 21:30:40 - Flushing DNS I 2020.12.24 21:30:40 - Checking route IPv4 I 2020.12.24 21:30:41 - Checking route IPv6 I 2020.12.24 21:30:41 - Checking DNS . 2020.12.24 21:30:43 - Checking DNS failed: . 2020.12.24 21:30:43 - Checking DNS (2° try) . 2020.12.24 21:30:47 - Checking DNS failed: . 2020.12.24 21:30:47 - Checking DNS (3° try) . 2020.12.24 21:30:50 - Checking DNS failed: E 2020.12.24 21:30:50 - Checking DNS failed. . 2020.12.24 21:30:50 - OpenVPN > Initialization Sequence Completed ! 2020.12.24 21:30:50 - Disconnecting . 2020.12.24 21:30:50 - Routes, removed a route previously added, 37.120.210.219 for gateway 10.18.234.1 . 2020.12.24 21:30:50 - Routes, removed a route previously added, 2001:ac8:40:48:d4a2:b617:ea37:b0aa for gateway fde6:7a:7d20:eea::1 . 2020.12.24 21:30:50 - Sending management termination signal . 2020.12.24 21:30:50 - Management - Send 'signal SIGTERM' . 2020.12.24 21:30:51 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2020.12.24 21:30:51 - OpenVPN > SIGTERM received, sending exit notification to peer . 2020.12.24 21:30:55 - OpenVPN > /sbin/route delete -net 37.120.210.221 172.20.10.1 255.255.255.255 . 2020.12.24 21:30:55 - OpenVPN > delete net 37.120.210.221: gateway 172.20.10.1 . 2020.12.24 21:30:55 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.18.234.1 128.0.0.0 . 2020.12.24 21:30:55 - OpenVPN > delete net 0.0.0.0: gateway 10.18.234.1 . 2020.12.24 21:30:55 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.18.234.1 128.0.0.0 . 2020.12.24 21:30:55 - OpenVPN > delete net 128.0.0.0: gateway 10.18.234.1 . 2020.12.24 21:30:55 - OpenVPN > delete_route_ipv6(::/3) . 2020.12.24 21:30:55 - OpenVPN > /sbin/route delete -inet6 :: -prefixlen 3 -iface utun1 . 2020.12.24 21:30:55 - OpenVPN > delete net ::: gateway utun1 . 2020.12.24 21:30:55 - OpenVPN > delete_route_ipv6(2000::/4) . 2020.12.24 21:30:55 - OpenVPN > /sbin/route delete -inet6 2000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:30:55 - OpenVPN > delete net 2000::: gateway utun1 . 2020.12.24 21:30:55 - OpenVPN > delete_route_ipv6(3000::/4) . 2020.12.24 21:30:55 - OpenVPN > /sbin/route delete -inet6 3000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:30:55 - OpenVPN > delete net 3000::: gateway utun1 . 2020.12.24 21:30:55 - OpenVPN > delete_route_ipv6(fc00::/7) . 2020.12.24 21:30:55 - OpenVPN > /sbin/route delete -inet6 fc00:: -prefixlen 7 -iface utun1 . 2020.12.24 21:30:55 - OpenVPN > delete net fc00::: gateway utun1 . 2020.12.24 21:30:55 - OpenVPN > Closing TUN/TAP interface . 2020.12.24 21:30:55 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:eea::1088 . 2020.12.24 21:30:55 - OpenVPN > delete host fde6:7a:7d20:eea::1088 . 2020.12.24 21:30:55 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2020.12.24 21:30:55 - Connection terminated. . 2020.12.24 21:30:55 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:30:55 - DNS of a network adapter restored to original settings (PPPoE, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:30:55 - DNS of a network adapter restored to original settings (PPPoE 2, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:30:55 - DNS of a network adapter restored to original settings (Ethernet, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:30:55 - DNS of a network adapter restored to original settings (FireWire, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:30:55 - DNS of a network adapter restored to original settings (iPhone USB Kayo, to Automatic) . 2020.12.24 21:30:55 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2020.12.24 21:30:55 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:30:55 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.6.154.1, fde6:7a:7d20:29a::1) I 2020.12.24 21:30:58 - Checking authorization ... ! 2020.12.24 21:30:59 - Connecting to Iskandar (Japan, Tokyo) . 2020.12.24 21:31:00 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018 . 2020.12.24 21:31:00 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.12.24 21:31:00 - Connection to OpenVPN Management Interface . 2020.12.24 21:31:00 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2020.12.24 21:31:00 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.24 21:31:00 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.24 21:31:00 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.24 21:31:00 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.24 21:31:00 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]82.102.28.109:443 . 2020.12.24 21:31:00 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2020.12.24 21:31:00 - OpenVPN > UDP link local: (not bound) . 2020.12.24 21:31:00 - OpenVPN > UDP link remote: [AF_INET]82.102.28.109:443 . 2020.12.24 21:31:00 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2020.12.24 21:31:00 - OpenVPN > TLS: Initial packet from [AF_INET]82.102.28.109:443, sid=cb3724e4 3302d9dc . 2020.12.24 21:31:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.24 21:31:00 - OpenVPN > VERIFY KU OK . 2020.12.24 21:31:00 - OpenVPN > Validating certificate extended key usage . 2020.12.24 21:31:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.24 21:31:00 - OpenVPN > VERIFY EKU OK . 2020.12.24 21:31:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Iskandar, emailAddress=info@airvpn.org . 2020.12.24 21:31:02 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.24 21:31:02 - OpenVPN > [Iskandar] Peer Connection Initiated with [AF_INET]82.102.28.109:443 . 2020.12.24 21:31:03 - OpenVPN > SENT CONTROL [Iskandar]: 'PUSH_REQUEST' (status=1) . 2020.12.24 21:31:03 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.19.170.1,dhcp-option DNS6 fde6:7a:7d20:faa::1,tun-ipv6,route-gateway 10.19.170.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:faa::108d/64 fde6:7a:7d20:faa::1,ifconfig 10.19.170.143 255.255.255.0,peer-id 4,cipher AES-256-GCM' . 2020.12.24 21:31:03 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2020.12.24 21:31:03 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2020.12.24 21:31:03 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2020.12.24 21:31:03 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2020.12.24 21:31:03 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2020.12.24 21:31:03 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2020.12.24 21:31:03 - OpenVPN > OPTIONS IMPORT: peer-id set . 2020.12.24 21:31:03 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2020.12.24 21:31:03 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2020.12.24 21:31:03 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2020.12.24 21:31:03 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.24 21:31:03 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.24 21:31:03 - OpenVPN > ROUTE_GATEWAY 172.20.10.1/255.255.255.240 IFACE=en5 HWADDR=46:00:10:3f:39:58 . 2020.12.24 21:31:03 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2020.12.24 21:31:03 - OpenVPN > ROUTE6_GATEWAY fe80::ccb:d7f9:9a6c:61fd IFACE=en5 . 2020.12.24 21:31:03 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16) . 2020.12.24 21:31:03 - OpenVPN > Opened utun device utun1 . 2020.12.24 21:31:03 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2020.12.24 21:31:03 - OpenVPN > /sbin/ifconfig utun1 delete . 2020.12.24 21:31:04 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2020.12.24 21:31:04 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2020.12.24 21:31:04 - OpenVPN > /sbin/ifconfig utun1 10.19.170.143 10.19.170.143 netmask 255.255.255.0 mtu 1500 up . 2020.12.24 21:31:04 - OpenVPN > /sbin/route add -net 10.19.170.0 10.19.170.143 255.255.255.0 . 2020.12.24 21:31:04 - OpenVPN > add net 10.19.170.0: gateway 10.19.170.143 . 2020.12.24 21:31:04 - OpenVPN > /sbin/ifconfig utun1 inet6 fde6:7a:7d20:faa::108d/64 . 2020.12.24 21:31:04 - OpenVPN > add_route_ipv6(fde6:7a:7d20:faa::/64 -> fde6:7a:7d20:faa::108d metric 0) dev utun1 . 2020.12.24 21:31:04 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:faa:: -prefixlen 64 -iface utun1 . 2020.12.24 21:31:04 - OpenVPN > route: writing to routing socket: File exists . 2020.12.24 21:31:04 - OpenVPN > add net fde6:7a:7d20:faa::: gateway utun1: File exists . 2020.12.24 21:31:04 - OpenVPN > /sbin/route add -net 82.102.28.109 172.20.10.1 255.255.255.255 . 2020.12.24 21:31:04 - OpenVPN > add net 82.102.28.109: gateway 172.20.10.1 . 2020.12.24 21:31:04 - OpenVPN > /sbin/route add -net 0.0.0.0 10.19.170.1 128.0.0.0 . 2020.12.24 21:31:04 - OpenVPN > add net 0.0.0.0: gateway 10.19.170.1 . 2020.12.24 21:31:04 - OpenVPN > /sbin/route add -net 128.0.0.0 10.19.170.1 128.0.0.0 . 2020.12.24 21:31:04 - OpenVPN > add net 128.0.0.0: gateway 10.19.170.1 . 2020.12.24 21:31:04 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:faa::1 metric -1) dev utun1 . 2020.12.24 21:31:04 - OpenVPN > /sbin/route add -inet6 :: -prefixlen 3 -iface utun1 . 2020.12.24 21:31:04 - OpenVPN > add net ::: gateway utun1 . 2020.12.24 21:31:04 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:faa::1 metric -1) dev utun1 . 2020.12.24 21:31:04 - OpenVPN > /sbin/route add -inet6 2000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:31:04 - OpenVPN > add net 2000::: gateway utun1 . 2020.12.24 21:31:04 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:faa::1 metric -1) dev utun1 . 2020.12.24 21:31:04 - OpenVPN > /sbin/route add -inet6 3000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:31:04 - OpenVPN > add net 3000::: gateway utun1 . 2020.12.24 21:31:04 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:faa::1 metric -1) dev utun1 . 2020.12.24 21:31:04 - OpenVPN > /sbin/route add -inet6 fc00:: -prefixlen 7 -iface utun1 . 2020.12.24 21:31:04 - OpenVPN > add net fc00::: gateway utun1 . 2020.12.24 21:31:04 - DNS of a network adapter forced (Wi-Fi, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.19.170.1, fde6:7a:7d20:faa::1) . 2020.12.24 21:31:05 - DNS of a network adapter forced (PPPoE, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.19.170.1, fde6:7a:7d20:faa::1) . 2020.12.24 21:31:05 - DNS of a network adapter forced (PPPoE 2, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.19.170.1, fde6:7a:7d20:faa::1) . 2020.12.24 21:31:05 - DNS of a network adapter forced (Ethernet, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.19.170.1, fde6:7a:7d20:faa::1) . 2020.12.24 21:31:05 - DNS of a network adapter forced (FireWire, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.19.170.1, fde6:7a:7d20:faa::1) . 2020.12.24 21:31:05 - DNS of a network adapter forced (iPhone USB Kayo, from Automatic to 10.19.170.1, fde6:7a:7d20:faa::1) . 2020.12.24 21:31:05 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.19.170.1, fde6:7a:7d20:faa::1) . 2020.12.24 21:31:05 - DNS of a network adapter forced (Bluetooth PAN, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.19.170.1, fde6:7a:7d20:faa::1) . 2020.12.24 21:31:06 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.19.170.1, fde6:7a:7d20:faa::1) . 2020.12.24 21:31:06 - Routes, added a new route, 82.102.28.107 for gateway 10.19.170.1 . 2020.12.24 21:31:06 - Routes, added a new route, 2001:ac8:40:8:ff92:53b9:316d:b8a7 for gateway fde6:7a:7d20:faa::1 . 2020.12.24 21:31:06 - Flushing DNS I 2020.12.24 21:31:06 - Checking route IPv4 I 2020.12.24 21:31:06 - Checking route IPv6 I 2020.12.24 21:31:07 - Checking DNS . 2020.12.24 21:31:08 - Checking DNS failed: . 2020.12.24 21:31:08 - Checking DNS (2° try) . 2020.12.24 21:31:11 - Checking DNS failed: . 2020.12.24 21:31:11 - Checking DNS (3° try) . 2020.12.24 21:31:15 - Checking DNS failed: E 2020.12.24 21:31:15 - Checking DNS failed. . 2020.12.24 21:31:15 - OpenVPN > Initialization Sequence Completed ! 2020.12.24 21:31:15 - Disconnecting . 2020.12.24 21:31:15 - Routes, removed a route previously added, 82.102.28.107 for gateway 10.19.170.1 . 2020.12.24 21:31:15 - Routes, removed a route previously added, 2001:ac8:40:8:ff92:53b9:316d:b8a7 for gateway fde6:7a:7d20:faa::1 . 2020.12.24 21:31:15 - Sending management termination signal . 2020.12.24 21:31:15 - Management - Send 'signal SIGTERM' . 2020.12.24 21:31:15 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2020.12.24 21:31:15 - OpenVPN > SIGTERM received, sending exit notification to peer . 2020.12.24 21:31:20 - OpenVPN > /sbin/route delete -net 82.102.28.109 172.20.10.1 255.255.255.255 . 2020.12.24 21:31:20 - OpenVPN > delete net 82.102.28.109: gateway 172.20.10.1 . 2020.12.24 21:31:20 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.19.170.1 128.0.0.0 . 2020.12.24 21:31:20 - OpenVPN > delete net 0.0.0.0: gateway 10.19.170.1 . 2020.12.24 21:31:20 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.19.170.1 128.0.0.0 . 2020.12.24 21:31:20 - OpenVPN > delete net 128.0.0.0: gateway 10.19.170.1 . 2020.12.24 21:31:20 - OpenVPN > delete_route_ipv6(::/3) . 2020.12.24 21:31:20 - OpenVPN > /sbin/route delete -inet6 :: -prefixlen 3 -iface utun1 . 2020.12.24 21:31:20 - OpenVPN > delete net ::: gateway utun1 . 2020.12.24 21:31:20 - OpenVPN > delete_route_ipv6(2000::/4) . 2020.12.24 21:31:20 - OpenVPN > /sbin/route delete -inet6 2000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:31:20 - OpenVPN > delete net 2000::: gateway utun1 . 2020.12.24 21:31:20 - OpenVPN > delete_route_ipv6(3000::/4) . 2020.12.24 21:31:20 - OpenVPN > /sbin/route delete -inet6 3000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:31:20 - OpenVPN > delete net 3000::: gateway utun1 . 2020.12.24 21:31:20 - OpenVPN > delete_route_ipv6(fc00::/7) . 2020.12.24 21:31:20 - OpenVPN > /sbin/route delete -inet6 fc00:: -prefixlen 7 -iface utun1 . 2020.12.24 21:31:20 - OpenVPN > delete net fc00::: gateway utun1 . 2020.12.24 21:31:20 - OpenVPN > Closing TUN/TAP interface . 2020.12.24 21:31:20 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:faa::108d . 2020.12.24 21:31:20 - OpenVPN > delete host fde6:7a:7d20:faa::108d . 2020.12.24 21:31:20 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2020.12.24 21:31:20 - Connection terminated. . 2020.12.24 21:31:20 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:31:20 - DNS of a network adapter restored to original settings (PPPoE, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:31:20 - DNS of a network adapter restored to original settings (PPPoE 2, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:31:20 - DNS of a network adapter restored to original settings (Ethernet, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:31:20 - DNS of a network adapter restored to original settings (FireWire, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:31:20 - DNS of a network adapter restored to original settings (iPhone USB Kayo, to Automatic) . 2020.12.24 21:31:20 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2020.12.24 21:31:20 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:31:20 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.6.154.1, fde6:7a:7d20:29a::1) I 2020.12.24 21:31:23 - Checking authorization ... ! 2020.12.24 21:31:24 - Connecting to Biham (Japan, Tokyo) . 2020.12.24 21:31:24 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018 . 2020.12.24 21:31:24 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.12.24 21:31:24 - Connection to OpenVPN Management Interface . 2020.12.24 21:31:24 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2020.12.24 21:31:24 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.24 21:31:24 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.24 21:31:24 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.24 21:31:24 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.24 21:31:24 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]37.120.210.213:443 . 2020.12.24 21:31:24 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2020.12.24 21:31:24 - OpenVPN > UDP link local: (not bound) . 2020.12.24 21:31:24 - OpenVPN > UDP link remote: [AF_INET]37.120.210.213:443 . 2020.12.24 21:31:24 - OpenVPN > TLS: Initial packet from [AF_INET]37.120.210.213:443, sid=0c3c5ae6 7c71e682 . 2020.12.24 21:31:24 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2020.12.24 21:31:24 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.24 21:31:24 - OpenVPN > VERIFY KU OK . 2020.12.24 21:31:24 - OpenVPN > Validating certificate extended key usage . 2020.12.24 21:31:24 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.24 21:31:24 - OpenVPN > VERIFY EKU OK . 2020.12.24 21:31:24 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Biham, emailAddress=info@airvpn.org . 2020.12.24 21:31:25 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.24 21:31:25 - OpenVPN > [Biham] Peer Connection Initiated with [AF_INET]37.120.210.213:443 . 2020.12.24 21:31:26 - OpenVPN > SENT CONTROL [Biham]: 'PUSH_REQUEST' (status=1) . 2020.12.24 21:31:26 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.6.138.1,dhcp-option DNS6 fde6:7a:7d20:28a::1,tun-ipv6,route-gateway 10.6.138.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:28a::1093/64 fde6:7a:7d20:28a::1,ifconfig 10.6.138.149 255.255.255.0,peer-id 2,cipher AES-256-GCM' . 2020.12.24 21:31:26 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2020.12.24 21:31:26 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2020.12.24 21:31:26 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2020.12.24 21:31:26 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2020.12.24 21:31:26 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2020.12.24 21:31:26 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2020.12.24 21:31:26 - OpenVPN > OPTIONS IMPORT: peer-id set . 2020.12.24 21:31:26 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2020.12.24 21:31:26 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2020.12.24 21:31:26 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2020.12.24 21:31:26 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.24 21:31:26 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.24 21:31:26 - OpenVPN > ROUTE_GATEWAY 172.20.10.1/255.255.255.240 IFACE=en5 HWADDR=46:00:10:3f:39:58 . 2020.12.24 21:31:26 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2020.12.24 21:31:26 - OpenVPN > ROUTE6_GATEWAY fe80::ccb:d7f9:9a6c:61fd IFACE=en5 . 2020.12.24 21:31:26 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16) . 2020.12.24 21:31:26 - OpenVPN > Opened utun device utun1 . 2020.12.24 21:31:26 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2020.12.24 21:31:26 - OpenVPN > /sbin/ifconfig utun1 delete . 2020.12.24 21:31:26 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2020.12.24 21:31:26 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2020.12.24 21:31:26 - OpenVPN > /sbin/ifconfig utun1 10.6.138.149 10.6.138.149 netmask 255.255.255.0 mtu 1500 up . 2020.12.24 21:31:26 - OpenVPN > /sbin/route add -net 10.6.138.0 10.6.138.149 255.255.255.0 . 2020.12.24 21:31:26 - OpenVPN > add net 10.6.138.0: gateway 10.6.138.149 . 2020.12.24 21:31:26 - OpenVPN > /sbin/ifconfig utun1 inet6 fde6:7a:7d20:28a::1093/64 . 2020.12.24 21:31:26 - OpenVPN > add_route_ipv6(fde6:7a:7d20:28a::/64 -> fde6:7a:7d20:28a::1093 metric 0) dev utun1 . 2020.12.24 21:31:26 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:28a:: -prefixlen 64 -iface utun1 . 2020.12.24 21:31:26 - OpenVPN > add net fde6:7a:7d20:28a::: gateway utun1: File exists . 2020.12.24 21:31:26 - OpenVPN > route: writing to routing socket: File exists . 2020.12.24 21:31:26 - OpenVPN > /sbin/route add -net 37.120.210.213 172.20.10.1 255.255.255.255 . 2020.12.24 21:31:26 - OpenVPN > add net 37.120.210.213: gateway 172.20.10.1 . 2020.12.24 21:31:26 - OpenVPN > /sbin/route add -net 0.0.0.0 10.6.138.1 128.0.0.0 . 2020.12.24 21:31:26 - OpenVPN > add net 0.0.0.0: gateway 10.6.138.1 . 2020.12.24 21:31:26 - OpenVPN > /sbin/route add -net 128.0.0.0 10.6.138.1 128.0.0.0 . 2020.12.24 21:31:26 - OpenVPN > add net 128.0.0.0: gateway 10.6.138.1 . 2020.12.24 21:31:26 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:28a::1 metric -1) dev utun1 . 2020.12.24 21:31:26 - OpenVPN > /sbin/route add -inet6 :: -prefixlen 3 -iface utun1 . 2020.12.24 21:31:26 - OpenVPN > add net ::: gateway utun1 . 2020.12.24 21:31:26 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:28a::1 metric -1) dev utun1 . 2020.12.24 21:31:26 - OpenVPN > /sbin/route add -inet6 2000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:31:26 - OpenVPN > add net 2000::: gateway utun1 . 2020.12.24 21:31:26 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:28a::1 metric -1) dev utun1 . 2020.12.24 21:31:26 - OpenVPN > /sbin/route add -inet6 3000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:31:26 - OpenVPN > add net 3000::: gateway utun1 . 2020.12.24 21:31:26 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:28a::1 metric -1) dev utun1 . 2020.12.24 21:31:26 - OpenVPN > /sbin/route add -inet6 fc00:: -prefixlen 7 -iface utun1 . 2020.12.24 21:31:26 - OpenVPN > add net fc00::: gateway utun1 . 2020.12.24 21:31:26 - DNS of a network adapter forced (Wi-Fi, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.6.138.1, fde6:7a:7d20:28a::1) . 2020.12.24 21:31:26 - DNS of a network adapter forced (PPPoE, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.6.138.1, fde6:7a:7d20:28a::1) . 2020.12.24 21:31:26 - DNS of a network adapter forced (PPPoE 2, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.6.138.1, fde6:7a:7d20:28a::1) . 2020.12.24 21:31:27 - DNS of a network adapter forced (Ethernet, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.6.138.1, fde6:7a:7d20:28a::1) . 2020.12.24 21:31:27 - DNS of a network adapter forced (FireWire, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.6.138.1, fde6:7a:7d20:28a::1) . 2020.12.24 21:31:27 - DNS of a network adapter forced (iPhone USB Kayo, from Automatic to 10.6.138.1, fde6:7a:7d20:28a::1) . 2020.12.24 21:31:27 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.6.138.1, fde6:7a:7d20:28a::1) . 2020.12.24 21:31:27 - DNS of a network adapter forced (Bluetooth PAN, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.6.138.1, fde6:7a:7d20:28a::1) . 2020.12.24 21:31:27 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.6.138.1, fde6:7a:7d20:28a::1) . 2020.12.24 21:31:27 - Routes, added a new route, 37.120.210.211 for gateway 10.6.138.1 . 2020.12.24 21:31:27 - Routes, added a new route, 2001:ac8:40:47:41eb:a0c5:e8b2:dfbe for gateway fde6:7a:7d20:28a::1 . 2020.12.24 21:31:31 - Flushing DNS I 2020.12.24 21:31:31 - Checking route IPv4 I 2020.12.24 21:31:31 - Checking route IPv6 I 2020.12.24 21:31:32 - Checking DNS . 2020.12.24 21:31:33 - Checking DNS failed: . 2020.12.24 21:31:33 - Checking DNS (2° try) . 2020.12.24 21:31:36 - Checking DNS failed: . 2020.12.24 21:31:36 - Checking DNS (3° try) . 2020.12.24 21:31:40 - Checking DNS failed: E 2020.12.24 21:31:40 - Checking DNS failed. . 2020.12.24 21:31:40 - OpenVPN > Initialization Sequence Completed ! 2020.12.24 21:31:40 - Disconnecting . 2020.12.24 21:31:40 - Routes, removed a route previously added, 37.120.210.211 for gateway 10.6.138.1 . 2020.12.24 21:31:40 - Routes, removed a route previously added, 2001:ac8:40:47:41eb:a0c5:e8b2:dfbe for gateway fde6:7a:7d20:28a::1 . 2020.12.24 21:31:40 - Sending management termination signal . 2020.12.24 21:31:40 - Management - Send 'signal SIGTERM' . 2020.12.24 21:31:41 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2020.12.24 21:31:41 - OpenVPN > SIGTERM received, sending exit notification to peer . 2020.12.24 21:31:45 - OpenVPN > /sbin/route delete -net 37.120.210.213 172.20.10.1 255.255.255.255 . 2020.12.24 21:31:45 - OpenVPN > delete net 37.120.210.213: gateway 172.20.10.1 . 2020.12.24 21:31:45 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.6.138.1 128.0.0.0 . 2020.12.24 21:31:45 - OpenVPN > delete net 0.0.0.0: gateway 10.6.138.1 . 2020.12.24 21:31:45 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.6.138.1 128.0.0.0 . 2020.12.24 21:31:45 - OpenVPN > delete net 128.0.0.0: gateway 10.6.138.1 . 2020.12.24 21:31:45 - OpenVPN > delete_route_ipv6(::/3) . 2020.12.24 21:31:45 - OpenVPN > /sbin/route delete -inet6 :: -prefixlen 3 -iface utun1 . 2020.12.24 21:31:45 - OpenVPN > delete net ::: gateway utun1 . 2020.12.24 21:31:45 - OpenVPN > delete_route_ipv6(2000::/4) . 2020.12.24 21:31:45 - OpenVPN > /sbin/route delete -inet6 2000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:31:45 - OpenVPN > delete net 2000::: gateway utun1 . 2020.12.24 21:31:45 - OpenVPN > delete_route_ipv6(3000::/4) . 2020.12.24 21:31:45 - OpenVPN > /sbin/route delete -inet6 3000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:31:45 - OpenVPN > delete net 3000::: gateway utun1 . 2020.12.24 21:31:45 - OpenVPN > delete_route_ipv6(fc00::/7) . 2020.12.24 21:31:45 - Connection terminated. . 2020.12.24 21:31:45 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:31:45 - DNS of a network adapter restored to original settings (PPPoE, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:31:45 - DNS of a network adapter restored to original settings (PPPoE 2, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:31:45 - DNS of a network adapter restored to original settings (Ethernet, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:31:45 - DNS of a network adapter restored to original settings (FireWire, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:31:45 - DNS of a network adapter restored to original settings (iPhone USB Kayo, to Automatic) . 2020.12.24 21:31:45 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2020.12.24 21:31:45 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:31:45 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:31:45 - OpenVPN > /sbin/route delete -inet6 fc00:: -prefixlen 7 -iface utun1 . 2020.12.24 21:31:45 - OpenVPN > delete net fc00::: gateway utun1 . 2020.12.24 21:31:45 - OpenVPN > Closing TUN/TAP interface . 2020.12.24 21:31:45 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:28a::1093 . 2020.12.24 21:31:45 - OpenVPN > delete host fde6:7a:7d20:28a::1093 . 2020.12.24 21:31:45 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting I 2020.12.24 21:31:48 - Checking authorization ... ! 2020.12.24 21:31:49 - Connecting to Taphao (Japan, Tokyo) . 2020.12.24 21:31:49 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018 . 2020.12.24 21:31:49 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.12.24 21:31:49 - Connection to OpenVPN Management Interface . 2020.12.24 21:31:49 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2020.12.24 21:31:49 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.24 21:31:49 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.24 21:31:49 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.24 21:31:49 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.24 21:31:49 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.148.16.213:443 . 2020.12.24 21:31:49 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2020.12.24 21:31:49 - OpenVPN > UDP link local: (not bound) . 2020.12.24 21:31:49 - OpenVPN > UDP link remote: [AF_INET]193.148.16.213:443 . 2020.12.24 21:31:50 - OpenVPN > TLS: Initial packet from [AF_INET]193.148.16.213:443, sid=9ba9bac6 1e8b3d0c . 2020.12.24 21:31:50 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2020.12.24 21:31:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.24 21:31:50 - OpenVPN > VERIFY KU OK . 2020.12.24 21:31:50 - OpenVPN > Validating certificate extended key usage . 2020.12.24 21:31:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.24 21:31:50 - OpenVPN > VERIFY EKU OK . 2020.12.24 21:31:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Taphao, emailAddress=info@airvpn.org . 2020.12.24 21:31:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.24 21:31:50 - OpenVPN > [Taphao] Peer Connection Initiated with [AF_INET]193.148.16.213:443 . 2020.12.24 21:31:51 - OpenVPN > SENT CONTROL [Taphao]: 'PUSH_REQUEST' (status=1) . 2020.12.24 21:31:51 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.23.202.1,dhcp-option DNS6 fde6:7a:7d20:13ca::1,tun-ipv6,route-gateway 10.23.202.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:13ca::1062/64 fde6:7a:7d20:13ca::1,ifconfig 10.23.202.100 255.255.255.0,peer-id 1,cipher AES-256-GCM' . 2020.12.24 21:31:51 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2020.12.24 21:31:51 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2020.12.24 21:31:51 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2020.12.24 21:31:51 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2020.12.24 21:31:51 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2020.12.24 21:31:51 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2020.12.24 21:31:51 - OpenVPN > OPTIONS IMPORT: peer-id set . 2020.12.24 21:31:51 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2020.12.24 21:31:51 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2020.12.24 21:31:51 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2020.12.24 21:31:51 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.24 21:31:51 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.24 21:31:51 - OpenVPN > ROUTE_GATEWAY 172.20.10.1/255.255.255.240 IFACE=en5 HWADDR=46:00:10:3f:39:58 . 2020.12.24 21:31:51 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2020.12.24 21:31:51 - OpenVPN > ROUTE6_GATEWAY fe80::ccb:d7f9:9a6c:61fd IFACE=en5 . 2020.12.24 21:31:51 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16) . 2020.12.24 21:31:51 - OpenVPN > Opened utun device utun1 . 2020.12.24 21:31:51 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2020.12.24 21:31:51 - OpenVPN > /sbin/ifconfig utun1 delete . 2020.12.24 21:31:51 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2020.12.24 21:31:51 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2020.12.24 21:31:51 - OpenVPN > /sbin/ifconfig utun1 10.23.202.100 10.23.202.100 netmask 255.255.255.0 mtu 1500 up . 2020.12.24 21:31:51 - OpenVPN > /sbin/route add -net 10.23.202.0 10.23.202.100 255.255.255.0 . 2020.12.24 21:31:51 - OpenVPN > add net 10.23.202.0: gateway 10.23.202.100 . 2020.12.24 21:31:51 - OpenVPN > /sbin/ifconfig utun1 inet6 fde6:7a:7d20:13ca::1062/64 . 2020.12.24 21:31:51 - OpenVPN > add_route_ipv6(fde6:7a:7d20:13ca::/64 -> fde6:7a:7d20:13ca::1062 metric 0) dev utun1 . 2020.12.24 21:31:51 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:13ca:: -prefixlen 64 -iface utun1 . 2020.12.24 21:31:51 - OpenVPN > add net fde6:7a:7d20:13ca::: gateway utun1: File exists . 2020.12.24 21:31:51 - OpenVPN > route: writing to routing socket: File exists . 2020.12.24 21:31:51 - OpenVPN > /sbin/route add -net 193.148.16.213 172.20.10.1 255.255.255.255 . 2020.12.24 21:31:51 - OpenVPN > add net 193.148.16.213: gateway 172.20.10.1 . 2020.12.24 21:31:51 - OpenVPN > /sbin/route add -net 0.0.0.0 10.23.202.1 128.0.0.0 . 2020.12.24 21:31:51 - OpenVPN > add net 0.0.0.0: gateway 10.23.202.1 . 2020.12.24 21:31:51 - OpenVPN > /sbin/route add -net 128.0.0.0 10.23.202.1 128.0.0.0 . 2020.12.24 21:31:51 - OpenVPN > add net 128.0.0.0: gateway 10.23.202.1 . 2020.12.24 21:31:51 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:13ca::1 metric -1) dev utun1 . 2020.12.24 21:31:51 - OpenVPN > /sbin/route add -inet6 :: -prefixlen 3 -iface utun1 . 2020.12.24 21:31:51 - OpenVPN > add net ::: gateway utun1 . 2020.12.24 21:31:51 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:13ca::1 metric -1) dev utun1 . 2020.12.24 21:31:51 - OpenVPN > /sbin/route add -inet6 2000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:31:51 - OpenVPN > add net 2000::: gateway utun1 . 2020.12.24 21:31:51 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:13ca::1 metric -1) dev utun1 . 2020.12.24 21:31:51 - OpenVPN > /sbin/route add -inet6 3000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:31:51 - OpenVPN > add net 3000::: gateway utun1 . 2020.12.24 21:31:51 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:13ca::1 metric -1) dev utun1 . 2020.12.24 21:31:51 - OpenVPN > /sbin/route add -inet6 fc00:: -prefixlen 7 -iface utun1 . 2020.12.24 21:31:51 - OpenVPN > add net fc00::: gateway utun1 . 2020.12.24 21:31:51 - DNS of a network adapter forced (Wi-Fi, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.23.202.1, fde6:7a:7d20:13ca::1) . 2020.12.24 21:31:52 - DNS of a network adapter forced (PPPoE, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.23.202.1, fde6:7a:7d20:13ca::1) . 2020.12.24 21:31:52 - DNS of a network adapter forced (PPPoE 2, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.23.202.1, fde6:7a:7d20:13ca::1) . 2020.12.24 21:31:52 - DNS of a network adapter forced (Ethernet, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.23.202.1, fde6:7a:7d20:13ca::1) . 2020.12.24 21:31:52 - DNS of a network adapter forced (FireWire, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.23.202.1, fde6:7a:7d20:13ca::1) . 2020.12.24 21:31:52 - DNS of a network adapter forced (iPhone USB Kayo, from Automatic to 10.23.202.1, fde6:7a:7d20:13ca::1) . 2020.12.24 21:31:52 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.23.202.1, fde6:7a:7d20:13ca::1) . 2020.12.24 21:31:52 - DNS of a network adapter forced (Bluetooth PAN, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.23.202.1, fde6:7a:7d20:13ca::1) . 2020.12.24 21:31:53 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.23.202.1, fde6:7a:7d20:13ca::1) . 2020.12.24 21:31:53 - Routes, added a new route, 193.148.16.211 for gateway 10.23.202.1 . 2020.12.24 21:31:53 - Routes, added a new route, 2001:ac8:40:12:5578:37e:193f:d5ea for gateway fde6:7a:7d20:13ca::1 . 2020.12.24 21:31:53 - Flushing DNS I 2020.12.24 21:31:53 - Checking route IPv4 I 2020.12.24 21:31:54 - Checking route IPv6 I 2020.12.24 21:31:55 - Checking DNS . 2020.12.24 21:31:56 - Checking DNS failed: . 2020.12.24 21:31:56 - Checking DNS (2° try) . 2020.12.24 21:31:59 - Checking DNS failed: . 2020.12.24 21:31:59 - Checking DNS (3° try) . 2020.12.24 21:32:05 - Checking DNS failed: E 2020.12.24 21:32:05 - Checking DNS failed. . 2020.12.24 21:32:05 - OpenVPN > Initialization Sequence Completed ! 2020.12.24 21:32:05 - Disconnecting . 2020.12.24 21:32:05 - Routes, removed a route previously added, 193.148.16.211 for gateway 10.23.202.1 . 2020.12.24 21:32:05 - Routes, removed a route previously added, 2001:ac8:40:12:5578:37e:193f:d5ea for gateway fde6:7a:7d20:13ca::1 . 2020.12.24 21:32:05 - Sending management termination signal . 2020.12.24 21:32:05 - Management - Send 'signal SIGTERM' . 2020.12.24 21:32:05 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2020.12.24 21:32:05 - OpenVPN > SIGTERM received, sending exit notification to peer . 2020.12.24 21:32:10 - OpenVPN > /sbin/route delete -net 193.148.16.213 172.20.10.1 255.255.255.255 . 2020.12.24 21:32:10 - OpenVPN > delete net 193.148.16.213: gateway 172.20.10.1 . 2020.12.24 21:32:10 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.23.202.1 128.0.0.0 . 2020.12.24 21:32:10 - OpenVPN > delete net 0.0.0.0: gateway 10.23.202.1 . 2020.12.24 21:32:10 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.23.202.1 128.0.0.0 . 2020.12.24 21:32:10 - OpenVPN > delete net 128.0.0.0: gateway 10.23.202.1 . 2020.12.24 21:32:10 - OpenVPN > delete_route_ipv6(::/3) . 2020.12.24 21:32:10 - OpenVPN > /sbin/route delete -inet6 :: -prefixlen 3 -iface utun1 . 2020.12.24 21:32:10 - OpenVPN > delete net ::: gateway utun1 . 2020.12.24 21:32:10 - OpenVPN > delete_route_ipv6(2000::/4) . 2020.12.24 21:32:10 - OpenVPN > /sbin/route delete -inet6 2000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:32:10 - OpenVPN > delete net 2000::: gateway utun1 . 2020.12.24 21:32:10 - OpenVPN > delete_route_ipv6(3000::/4) . 2020.12.24 21:32:10 - OpenVPN > /sbin/route delete -inet6 3000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:32:10 - OpenVPN > delete net 3000::: gateway utun1 . 2020.12.24 21:32:10 - OpenVPN > delete_route_ipv6(fc00::/7) . 2020.12.24 21:32:10 - OpenVPN > /sbin/route delete -inet6 fc00:: -prefixlen 7 -iface utun1 . 2020.12.24 21:32:10 - OpenVPN > delete net fc00::: gateway utun1 . 2020.12.24 21:32:10 - OpenVPN > Closing TUN/TAP interface . 2020.12.24 21:32:10 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:13ca::1062 . 2020.12.24 21:32:10 - OpenVPN > delete host fde6:7a:7d20:13ca::1062 . 2020.12.24 21:32:10 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2020.12.24 21:32:10 - Connection terminated. . 2020.12.24 21:32:10 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:32:10 - DNS of a network adapter restored to original settings (PPPoE, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:32:10 - DNS of a network adapter restored to original settings (PPPoE 2, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:32:11 - DNS of a network adapter restored to original settings (Ethernet, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:32:11 - DNS of a network adapter restored to original settings (FireWire, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:32:11 - DNS of a network adapter restored to original settings (iPhone USB Kayo, to Automatic) . 2020.12.24 21:32:11 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2020.12.24 21:32:11 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:32:11 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.6.154.1, fde6:7a:7d20:29a::1) I 2020.12.24 21:32:14 - Checking authorization ... ! 2020.12.24 21:32:15 - Connecting to Okab (Japan, Tokyo) . 2020.12.24 21:32:15 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018 . 2020.12.24 21:32:15 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.12.24 21:32:15 - Connection to OpenVPN Management Interface . 2020.12.24 21:32:15 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2020.12.24 21:32:15 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.24 21:32:15 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.24 21:32:15 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.24 21:32:15 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.24 21:32:15 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]37.120.210.221:443 . 2020.12.24 21:32:15 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2020.12.24 21:32:15 - OpenVPN > UDP link local: (not bound) . 2020.12.24 21:32:15 - OpenVPN > UDP link remote: [AF_INET]37.120.210.221:443 . 2020.12.24 21:32:15 - OpenVPN > TLS: Initial packet from [AF_INET]37.120.210.221:443, sid=6c820e2e 28d955c4 . 2020.12.24 21:32:15 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2020.12.24 21:32:15 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.24 21:32:15 - OpenVPN > VERIFY KU OK . 2020.12.24 21:32:15 - OpenVPN > Validating certificate extended key usage . 2020.12.24 21:32:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.24 21:32:15 - OpenVPN > VERIFY EKU OK . 2020.12.24 21:32:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Okab, emailAddress=info@airvpn.org . 2020.12.24 21:32:16 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.24 21:32:16 - OpenVPN > [Okab] Peer Connection Initiated with [AF_INET]37.120.210.221:443 . 2020.12.24 21:32:17 - OpenVPN > SENT CONTROL [Okab]: 'PUSH_REQUEST' (status=1) . 2020.12.24 21:32:17 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.18.234.1,dhcp-option DNS6 fde6:7a:7d20:eea::1,tun-ipv6,route-gateway 10.18.234.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:eea::1088/64 fde6:7a:7d20:eea::1,ifconfig 10.18.234.138 255.255.255.0,peer-id 1,cipher AES-256-GCM' . 2020.12.24 21:32:17 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2020.12.24 21:32:17 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2020.12.24 21:32:17 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2020.12.24 21:32:17 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2020.12.24 21:32:17 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2020.12.24 21:32:17 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2020.12.24 21:32:17 - OpenVPN > OPTIONS IMPORT: peer-id set . 2020.12.24 21:32:17 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2020.12.24 21:32:17 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2020.12.24 21:32:17 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2020.12.24 21:32:17 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.24 21:32:17 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.24 21:32:17 - OpenVPN > ROUTE_GATEWAY 172.20.10.1/255.255.255.240 IFACE=en5 HWADDR=46:00:10:3f:39:58 . 2020.12.24 21:32:17 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2020.12.24 21:32:17 - OpenVPN > ROUTE6_GATEWAY fe80::ccb:d7f9:9a6c:61fd IFACE=en5 . 2020.12.24 21:32:17 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16) . 2020.12.24 21:32:17 - OpenVPN > Opened utun device utun1 . 2020.12.24 21:32:17 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2020.12.24 21:32:17 - OpenVPN > /sbin/ifconfig utun1 delete . 2020.12.24 21:32:17 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2020.12.24 21:32:17 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2020.12.24 21:32:17 - OpenVPN > /sbin/ifconfig utun1 10.18.234.138 10.18.234.138 netmask 255.255.255.0 mtu 1500 up . 2020.12.24 21:32:17 - OpenVPN > /sbin/route add -net 10.18.234.0 10.18.234.138 255.255.255.0 . 2020.12.24 21:32:17 - OpenVPN > add net 10.18.234.0: gateway 10.18.234.138 . 2020.12.24 21:32:17 - OpenVPN > route: writing to routing socket: File exists . 2020.12.24 21:32:17 - OpenVPN > /sbin/ifconfig utun1 inet6 fde6:7a:7d20:eea::1088/64 . 2020.12.24 21:32:17 - OpenVPN > add_route_ipv6(fde6:7a:7d20:eea::/64 -> fde6:7a:7d20:eea::1088 metric 0) dev utun1 . 2020.12.24 21:32:17 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:eea:: -prefixlen 64 -iface utun1 . 2020.12.24 21:32:17 - OpenVPN > add net fde6:7a:7d20:eea::: gateway utun1: File exists . 2020.12.24 21:32:17 - OpenVPN > /sbin/route add -net 37.120.210.221 172.20.10.1 255.255.255.255 . 2020.12.24 21:32:17 - OpenVPN > add net 37.120.210.221: gateway 172.20.10.1 . 2020.12.24 21:32:17 - OpenVPN > /sbin/route add -net 0.0.0.0 10.18.234.1 128.0.0.0 . 2020.12.24 21:32:17 - OpenVPN > add net 0.0.0.0: gateway 10.18.234.1 . 2020.12.24 21:32:17 - OpenVPN > /sbin/route add -net 128.0.0.0 10.18.234.1 128.0.0.0 . 2020.12.24 21:32:17 - OpenVPN > add net 128.0.0.0: gateway 10.18.234.1 . 2020.12.24 21:32:17 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:eea::1 metric -1) dev utun1 . 2020.12.24 21:32:17 - OpenVPN > /sbin/route add -inet6 :: -prefixlen 3 -iface utun1 . 2020.12.24 21:32:17 - OpenVPN > add net ::: gateway utun1 . 2020.12.24 21:32:17 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:eea::1 metric -1) dev utun1 . 2020.12.24 21:32:17 - OpenVPN > /sbin/route add -inet6 2000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:32:17 - OpenVPN > add net 2000::: gateway utun1 . 2020.12.24 21:32:17 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:eea::1 metric -1) dev utun1 . 2020.12.24 21:32:17 - OpenVPN > /sbin/route add -inet6 3000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:32:17 - OpenVPN > add net 3000::: gateway utun1 . 2020.12.24 21:32:17 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:eea::1 metric -1) dev utun1 . 2020.12.24 21:32:17 - OpenVPN > /sbin/route add -inet6 fc00:: -prefixlen 7 -iface utun1 . 2020.12.24 21:32:17 - OpenVPN > add net fc00::: gateway utun1 . 2020.12.24 21:32:17 - DNS of a network adapter forced (Wi-Fi, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:32:18 - DNS of a network adapter forced (PPPoE, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:32:18 - DNS of a network adapter forced (PPPoE 2, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:32:18 - DNS of a network adapter forced (Ethernet, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:32:18 - DNS of a network adapter forced (FireWire, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:32:18 - DNS of a network adapter forced (iPhone USB Kayo, from Automatic to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:32:18 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:32:18 - DNS of a network adapter forced (Bluetooth PAN, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:32:19 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.18.234.1, fde6:7a:7d20:eea::1) . 2020.12.24 21:32:19 - Routes, added a new route, 37.120.210.219 for gateway 10.18.234.1 . 2020.12.24 21:32:19 - Routes, added a new route, 2001:ac8:40:48:d4a2:b617:ea37:b0aa for gateway fde6:7a:7d20:eea::1 . 2020.12.24 21:32:19 - Flushing DNS I 2020.12.24 21:32:19 - Checking route IPv4 I 2020.12.24 21:32:21 - Checking route IPv6 I 2020.12.24 21:32:22 - Checking DNS . 2020.12.24 21:32:23 - Checking DNS failed: . 2020.12.24 21:32:23 - Checking DNS (2° try) . 2020.12.24 21:32:26 - Checking DNS failed: . 2020.12.24 21:32:26 - Checking DNS (3° try) . 2020.12.24 21:32:29 - Checking DNS failed: E 2020.12.24 21:32:29 - Checking DNS failed. . 2020.12.24 21:32:29 - OpenVPN > Initialization Sequence Completed ! 2020.12.24 21:32:29 - Disconnecting . 2020.12.24 21:32:29 - Routes, removed a route previously added, 37.120.210.219 for gateway 10.18.234.1 . 2020.12.24 21:32:29 - Routes, removed a route previously added, 2001:ac8:40:48:d4a2:b617:ea37:b0aa for gateway fde6:7a:7d20:eea::1 . 2020.12.24 21:32:29 - Sending management termination signal . 2020.12.24 21:32:29 - Management - Send 'signal SIGTERM' . 2020.12.24 21:32:30 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2020.12.24 21:32:30 - OpenVPN > SIGTERM received, sending exit notification to peer . 2020.12.24 21:32:34 - OpenVPN > /sbin/route delete -net 37.120.210.221 172.20.10.1 255.255.255.255 . 2020.12.24 21:32:34 - OpenVPN > delete net 37.120.210.221: gateway 172.20.10.1 . 2020.12.24 21:32:34 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.18.234.1 128.0.0.0 . 2020.12.24 21:32:34 - OpenVPN > delete net 0.0.0.0: gateway 10.18.234.1 . 2020.12.24 21:32:34 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.18.234.1 128.0.0.0 . 2020.12.24 21:32:34 - OpenVPN > delete net 128.0.0.0: gateway 10.18.234.1 . 2020.12.24 21:32:34 - OpenVPN > delete_route_ipv6(::/3) . 2020.12.24 21:32:34 - OpenVPN > /sbin/route delete -inet6 :: -prefixlen 3 -iface utun1 . 2020.12.24 21:32:34 - OpenVPN > delete net ::: gateway utun1 . 2020.12.24 21:32:34 - OpenVPN > delete_route_ipv6(2000::/4) . 2020.12.24 21:32:34 - OpenVPN > /sbin/route delete -inet6 2000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:32:34 - OpenVPN > delete net 2000::: gateway utun1 . 2020.12.24 21:32:34 - OpenVPN > delete_route_ipv6(3000::/4) . 2020.12.24 21:32:34 - OpenVPN > /sbin/route delete -inet6 3000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:32:34 - OpenVPN > delete net 3000::: gateway utun1 . 2020.12.24 21:32:34 - OpenVPN > delete_route_ipv6(fc00::/7) . 2020.12.24 21:32:34 - OpenVPN > /sbin/route delete -inet6 fc00:: -prefixlen 7 -iface utun1 . 2020.12.24 21:32:34 - OpenVPN > delete net fc00::: gateway utun1 . 2020.12.24 21:32:34 - OpenVPN > Closing TUN/TAP interface . 2020.12.24 21:32:34 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:eea::1088 . 2020.12.24 21:32:34 - OpenVPN > delete host fde6:7a:7d20:eea::1088 . 2020.12.24 21:32:34 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2020.12.24 21:32:34 - Connection terminated. . 2020.12.24 21:32:34 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:32:34 - DNS of a network adapter restored to original settings (PPPoE, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:32:34 - DNS of a network adapter restored to original settings (PPPoE 2, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:32:34 - DNS of a network adapter restored to original settings (Ethernet, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:32:34 - DNS of a network adapter restored to original settings (FireWire, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:32:34 - DNS of a network adapter restored to original settings (iPhone USB Kayo, to Automatic) . 2020.12.24 21:32:35 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2020.12.24 21:32:35 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:32:35 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.6.154.1, fde6:7a:7d20:29a::1) I 2020.12.24 21:32:38 - Checking authorization ... ! 2020.12.24 21:32:39 - Connecting to Iskandar (Japan, Tokyo) . 2020.12.24 21:32:39 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018 . 2020.12.24 21:32:39 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.12.24 21:32:39 - Connection to OpenVPN Management Interface . 2020.12.24 21:32:39 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2020.12.24 21:32:39 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.24 21:32:39 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.24 21:32:39 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.24 21:32:39 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.24 21:32:39 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]82.102.28.109:443 . 2020.12.24 21:32:39 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2020.12.24 21:32:39 - OpenVPN > UDP link local: (not bound) . 2020.12.24 21:32:39 - OpenVPN > UDP link remote: [AF_INET]82.102.28.109:443 . 2020.12.24 21:32:39 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2020.12.24 21:32:39 - OpenVPN > TLS: Initial packet from [AF_INET]82.102.28.109:443, sid=b8e47985 741f1413 . 2020.12.24 21:32:39 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.24 21:32:39 - OpenVPN > VERIFY KU OK . 2020.12.24 21:32:39 - OpenVPN > Validating certificate extended key usage . 2020.12.24 21:32:39 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.24 21:32:39 - OpenVPN > VERIFY EKU OK . 2020.12.24 21:32:39 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Iskandar, emailAddress=info@airvpn.org . 2020.12.24 21:32:39 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.24 21:32:39 - OpenVPN > [Iskandar] Peer Connection Initiated with [AF_INET]82.102.28.109:443 . 2020.12.24 21:32:40 - OpenVPN > SENT CONTROL [Iskandar]: 'PUSH_REQUEST' (status=1) . 2020.12.24 21:32:40 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.19.170.1,dhcp-option DNS6 fde6:7a:7d20:faa::1,tun-ipv6,route-gateway 10.19.170.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:faa::108d/64 fde6:7a:7d20:faa::1,ifconfig 10.19.170.143 255.255.255.0,peer-id 4,cipher AES-256-GCM' . 2020.12.24 21:32:40 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2020.12.24 21:32:40 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2020.12.24 21:32:40 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2020.12.24 21:32:40 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2020.12.24 21:32:40 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2020.12.24 21:32:40 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2020.12.24 21:32:40 - OpenVPN > OPTIONS IMPORT: peer-id set . 2020.12.24 21:32:40 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2020.12.24 21:32:40 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2020.12.24 21:32:40 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2020.12.24 21:32:41 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.24 21:32:41 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.24 21:32:41 - OpenVPN > ROUTE_GATEWAY 172.20.10.1/255.255.255.240 IFACE=en5 HWADDR=46:00:10:3f:39:58 . 2020.12.24 21:32:41 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2020.12.24 21:32:41 - OpenVPN > ROUTE6_GATEWAY fe80::ccb:d7f9:9a6c:61fd IFACE=en5 . 2020.12.24 21:32:41 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16) . 2020.12.24 21:32:41 - OpenVPN > Opened utun device utun1 . 2020.12.24 21:32:41 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2020.12.24 21:32:41 - OpenVPN > /sbin/ifconfig utun1 delete . 2020.12.24 21:32:41 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2020.12.24 21:32:41 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2020.12.24 21:32:41 - OpenVPN > /sbin/ifconfig utun1 10.19.170.143 10.19.170.143 netmask 255.255.255.0 mtu 1500 up . 2020.12.24 21:32:41 - OpenVPN > /sbin/route add -net 10.19.170.0 10.19.170.143 255.255.255.0 . 2020.12.24 21:32:41 - OpenVPN > add net 10.19.170.0: gateway 10.19.170.143 . 2020.12.24 21:32:41 - OpenVPN > /sbin/ifconfig utun1 inet6 fde6:7a:7d20:faa::108d/64 . 2020.12.24 21:32:41 - OpenVPN > add_route_ipv6(fde6:7a:7d20:faa::/64 -> fde6:7a:7d20:faa::108d metric 0) dev utun1 . 2020.12.24 21:32:41 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:faa:: -prefixlen 64 -iface utun1 . 2020.12.24 21:32:41 - OpenVPN > add net fde6:7a:7d20:faa::: gateway utun1: File exists . 2020.12.24 21:32:41 - OpenVPN > route: writing to routing socket: File exists . 2020.12.24 21:32:41 - OpenVPN > /sbin/route add -net 82.102.28.109 172.20.10.1 255.255.255.255 . 2020.12.24 21:32:41 - OpenVPN > add net 82.102.28.109: gateway 172.20.10.1 . 2020.12.24 21:32:41 - OpenVPN > /sbin/route add -net 0.0.0.0 10.19.170.1 128.0.0.0 . 2020.12.24 21:32:41 - OpenVPN > add net 0.0.0.0: gateway 10.19.170.1 . 2020.12.24 21:32:41 - OpenVPN > /sbin/route add -net 128.0.0.0 10.19.170.1 128.0.0.0 . 2020.12.24 21:32:41 - OpenVPN > add net 128.0.0.0: gateway 10.19.170.1 . 2020.12.24 21:32:41 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:faa::1 metric -1) dev utun1 . 2020.12.24 21:32:41 - OpenVPN > /sbin/route add -inet6 :: -prefixlen 3 -iface utun1 . 2020.12.24 21:32:41 - OpenVPN > add net ::: gateway utun1 . 2020.12.24 21:32:41 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:faa::1 metric -1) dev utun1 . 2020.12.24 21:32:41 - OpenVPN > /sbin/route add -inet6 2000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:32:41 - OpenVPN > add net 2000::: gateway utun1 . 2020.12.24 21:32:41 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:faa::1 metric -1) dev utun1 . 2020.12.24 21:32:41 - OpenVPN > /sbin/route add -inet6 3000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:32:41 - OpenVPN > add net 3000::: gateway utun1 . 2020.12.24 21:32:41 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:faa::1 metric -1) dev utun1 . 2020.12.24 21:32:41 - OpenVPN > /sbin/route add -inet6 fc00:: -prefixlen 7 -iface utun1 . 2020.12.24 21:32:41 - OpenVPN > add net fc00::: gateway utun1 . 2020.12.24 21:32:41 - DNS of a network adapter forced (Wi-Fi, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.19.170.1, fde6:7a:7d20:faa::1) . 2020.12.24 21:32:42 - DNS of a network adapter forced (PPPoE, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.19.170.1, fde6:7a:7d20:faa::1) . 2020.12.24 21:32:42 - DNS of a network adapter forced (PPPoE 2, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.19.170.1, fde6:7a:7d20:faa::1) . 2020.12.24 21:32:42 - DNS of a network adapter forced (Ethernet, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.19.170.1, fde6:7a:7d20:faa::1) . 2020.12.24 21:32:42 - DNS of a network adapter forced (FireWire, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.19.170.1, fde6:7a:7d20:faa::1) . 2020.12.24 21:32:42 - DNS of a network adapter forced (iPhone USB Kayo, from Automatic to 10.19.170.1, fde6:7a:7d20:faa::1) . 2020.12.24 21:32:42 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.19.170.1, fde6:7a:7d20:faa::1) . 2020.12.24 21:32:42 - DNS of a network adapter forced (Bluetooth PAN, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.19.170.1, fde6:7a:7d20:faa::1) . 2020.12.24 21:32:43 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.19.170.1, fde6:7a:7d20:faa::1) . 2020.12.24 21:32:43 - Routes, added a new route, 82.102.28.107 for gateway 10.19.170.1 . 2020.12.24 21:32:43 - Routes, added a new route, 2001:ac8:40:8:ff92:53b9:316d:b8a7 for gateway fde6:7a:7d20:faa::1 . 2020.12.24 21:32:43 - Flushing DNS I 2020.12.24 21:32:43 - Checking route IPv4 I 2020.12.24 21:32:43 - Checking route IPv6 I 2020.12.24 21:32:44 - Checking DNS . 2020.12.24 21:32:45 - Checking DNS failed: . 2020.12.24 21:32:45 - Checking DNS (2° try) . 2020.12.24 21:32:49 - Checking DNS failed: . 2020.12.24 21:32:49 - Checking DNS (3° try) . 2020.12.24 21:32:52 - Checking DNS failed: E 2020.12.24 21:32:52 - Checking DNS failed. . 2020.12.24 21:32:52 - OpenVPN > Initialization Sequence Completed ! 2020.12.24 21:32:52 - Disconnecting . 2020.12.24 21:32:52 - Routes, removed a route previously added, 82.102.28.107 for gateway 10.19.170.1 . 2020.12.24 21:32:52 - Routes, removed a route previously added, 2001:ac8:40:8:ff92:53b9:316d:b8a7 for gateway fde6:7a:7d20:faa::1 . 2020.12.24 21:32:52 - Sending management termination signal . 2020.12.24 21:32:52 - Management - Send 'signal SIGTERM' . 2020.12.24 21:32:53 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2020.12.24 21:32:53 - OpenVPN > SIGTERM received, sending exit notification to peer . 2020.12.24 21:32:57 - OpenVPN > /sbin/route delete -net 82.102.28.109 172.20.10.1 255.255.255.255 . 2020.12.24 21:32:57 - OpenVPN > delete net 82.102.28.109: gateway 172.20.10.1 . 2020.12.24 21:32:57 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.19.170.1 128.0.0.0 . 2020.12.24 21:32:57 - OpenVPN > delete net 0.0.0.0: gateway 10.19.170.1 . 2020.12.24 21:32:57 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.19.170.1 128.0.0.0 . 2020.12.24 21:32:57 - OpenVPN > delete net 128.0.0.0: gateway 10.19.170.1 . 2020.12.24 21:32:57 - OpenVPN > delete_route_ipv6(::/3) . 2020.12.24 21:32:57 - OpenVPN > /sbin/route delete -inet6 :: -prefixlen 3 -iface utun1 . 2020.12.24 21:32:57 - OpenVPN > delete net ::: gateway utun1 . 2020.12.24 21:32:57 - OpenVPN > delete_route_ipv6(2000::/4) . 2020.12.24 21:32:57 - OpenVPN > /sbin/route delete -inet6 2000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:32:57 - OpenVPN > delete net 2000::: gateway utun1 . 2020.12.24 21:32:57 - OpenVPN > delete_route_ipv6(3000::/4) . 2020.12.24 21:32:57 - OpenVPN > /sbin/route delete -inet6 3000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:32:57 - OpenVPN > delete net 3000::: gateway utun1 . 2020.12.24 21:32:57 - OpenVPN > delete_route_ipv6(fc00::/7) . 2020.12.24 21:32:57 - OpenVPN > /sbin/route delete -inet6 fc00:: -prefixlen 7 -iface utun1 . 2020.12.24 21:32:58 - OpenVPN > delete net fc00::: gateway utun1 . 2020.12.24 21:32:58 - OpenVPN > Closing TUN/TAP interface . 2020.12.24 21:32:58 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:faa::108d . 2020.12.24 21:32:58 - OpenVPN > delete host fde6:7a:7d20:faa::108d . 2020.12.24 21:32:58 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2020.12.24 21:32:58 - Connection terminated. . 2020.12.24 21:32:58 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:32:58 - DNS of a network adapter restored to original settings (PPPoE, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:32:58 - DNS of a network adapter restored to original settings (PPPoE 2, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:32:58 - DNS of a network adapter restored to original settings (Ethernet, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:32:58 - DNS of a network adapter restored to original settings (FireWire, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:32:58 - DNS of a network adapter restored to original settings (iPhone USB Kayo, to Automatic) . 2020.12.24 21:32:58 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2020.12.24 21:32:58 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:32:58 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.6.154.1, fde6:7a:7d20:29a::1) I 2020.12.24 21:33:01 - Checking authorization ... ! 2020.12.24 21:33:02 - Connecting to Biham (Japan, Tokyo) . 2020.12.24 21:33:03 - OpenVPN > OpenVPN 2.4.6 x86_64-apple-darwin17.6.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Jul 29 2018 . 2020.12.24 21:33:03 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.12.24 21:33:03 - Connection to OpenVPN Management Interface . 2020.12.24 21:33:03 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2020.12.24 21:33:03 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.24 21:33:03 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.24 21:33:03 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.24 21:33:03 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.24 21:33:03 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]37.120.210.213:443 . 2020.12.24 21:33:03 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144] . 2020.12.24 21:33:03 - OpenVPN > UDP link local: (not bound) . 2020.12.24 21:33:03 - OpenVPN > UDP link remote: [AF_INET]37.120.210.213:443 . 2020.12.24 21:33:03 - OpenVPN > TLS: Initial packet from [AF_INET]37.120.210.213:443, sid=f55c7177 92a86338 . 2020.12.24 21:33:04 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2020.12.24 21:33:04 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.24 21:33:04 - OpenVPN > VERIFY KU OK . 2020.12.24 21:33:04 - OpenVPN > Validating certificate extended key usage . 2020.12.24 21:33:04 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.24 21:33:04 - OpenVPN > VERIFY EKU OK . 2020.12.24 21:33:04 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Biham, emailAddress=info@airvpn.org . 2020.12.24 21:33:04 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.24 21:33:04 - OpenVPN > [Biham] Peer Connection Initiated with [AF_INET]37.120.210.213:443 . 2020.12.24 21:33:06 - OpenVPN > SENT CONTROL [Biham]: 'PUSH_REQUEST' (status=1) . 2020.12.24 21:33:06 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.6.138.1,dhcp-option DNS6 fde6:7a:7d20:28a::1,tun-ipv6,route-gateway 10.6.138.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:28a::1093/64 fde6:7a:7d20:28a::1,ifconfig 10.6.138.149 255.255.255.0,peer-id 2,cipher AES-256-GCM' . 2020.12.24 21:33:06 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2020.12.24 21:33:06 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2020.12.24 21:33:06 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2020.12.24 21:33:06 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2020.12.24 21:33:06 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2020.12.24 21:33:06 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2020.12.24 21:33:06 - OpenVPN > OPTIONS IMPORT: peer-id set . 2020.12.24 21:33:06 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2020.12.24 21:33:06 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2020.12.24 21:33:06 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2020.12.24 21:33:06 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.24 21:33:06 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.24 21:33:06 - OpenVPN > ROUTE_GATEWAY 172.20.10.1/255.255.255.240 IFACE=en5 HWADDR=46:00:10:3f:39:58 . 2020.12.24 21:33:06 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2020.12.24 21:33:06 - OpenVPN > ROUTE6_GATEWAY fe80::ccb:d7f9:9a6c:61fd IFACE=en5 . 2020.12.24 21:33:06 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy (errno=16) . 2020.12.24 21:33:06 - OpenVPN > Opened utun device utun1 . 2020.12.24 21:33:06 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2020.12.24 21:33:06 - OpenVPN > /sbin/ifconfig utun1 delete . 2020.12.24 21:33:06 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address . 2020.12.24 21:33:06 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure . 2020.12.24 21:33:06 - OpenVPN > /sbin/ifconfig utun1 10.6.138.149 10.6.138.149 netmask 255.255.255.0 mtu 1500 up . 2020.12.24 21:33:06 - OpenVPN > /sbin/route add -net 10.6.138.0 10.6.138.149 255.255.255.0 . 2020.12.24 21:33:06 - OpenVPN > route: writing to routing socket: File exists . 2020.12.24 21:33:06 - OpenVPN > add net 10.6.138.0: gateway 10.6.138.149 . 2020.12.24 21:33:06 - OpenVPN > /sbin/ifconfig utun1 inet6 fde6:7a:7d20:28a::1093/64 . 2020.12.24 21:33:06 - OpenVPN > add_route_ipv6(fde6:7a:7d20:28a::/64 -> fde6:7a:7d20:28a::1093 metric 0) dev utun1 . 2020.12.24 21:33:06 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:28a:: -prefixlen 64 -iface utun1 . 2020.12.24 21:33:06 - OpenVPN > add net fde6:7a:7d20:28a::: gateway utun1: File exists . 2020.12.24 21:33:06 - OpenVPN > /sbin/route add -net 37.120.210.213 172.20.10.1 255.255.255.255 . 2020.12.24 21:33:06 - OpenVPN > add net 37.120.210.213: gateway 172.20.10.1 . 2020.12.24 21:33:06 - OpenVPN > /sbin/route add -net 0.0.0.0 10.6.138.1 128.0.0.0 . 2020.12.24 21:33:06 - OpenVPN > add net 0.0.0.0: gateway 10.6.138.1 . 2020.12.24 21:33:06 - OpenVPN > /sbin/route add -net 128.0.0.0 10.6.138.1 128.0.0.0 . 2020.12.24 21:33:06 - OpenVPN > add net 128.0.0.0: gateway 10.6.138.1 . 2020.12.24 21:33:06 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:28a::1 metric -1) dev utun1 . 2020.12.24 21:33:06 - OpenVPN > /sbin/route add -inet6 :: -prefixlen 3 -iface utun1 . 2020.12.24 21:33:06 - OpenVPN > add net ::: gateway utun1 . 2020.12.24 21:33:06 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:28a::1 metric -1) dev utun1 . 2020.12.24 21:33:06 - OpenVPN > /sbin/route add -inet6 2000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:33:06 - OpenVPN > add net 2000::: gateway utun1 . 2020.12.24 21:33:06 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:28a::1 metric -1) dev utun1 . 2020.12.24 21:33:07 - OpenVPN > /sbin/route add -inet6 3000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:33:07 - OpenVPN > add net 3000::: gateway utun1 . 2020.12.24 21:33:07 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:28a::1 metric -1) dev utun1 . 2020.12.24 21:33:07 - OpenVPN > /sbin/route add -inet6 fc00:: -prefixlen 7 -iface utun1 . 2020.12.24 21:33:07 - OpenVPN > add net fc00::: gateway utun1 . 2020.12.24 21:33:07 - DNS of a network adapter forced (Wi-Fi, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.6.138.1, fde6:7a:7d20:28a::1) . 2020.12.24 21:33:07 - DNS of a network adapter forced (PPPoE, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.6.138.1, fde6:7a:7d20:28a::1) . 2020.12.24 21:33:07 - DNS of a network adapter forced (PPPoE 2, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.6.138.1, fde6:7a:7d20:28a::1) . 2020.12.24 21:33:07 - DNS of a network adapter forced (Ethernet, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.6.138.1, fde6:7a:7d20:28a::1) . 2020.12.24 21:33:08 - DNS of a network adapter forced (FireWire, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.6.138.1, fde6:7a:7d20:28a::1) . 2020.12.24 21:33:08 - DNS of a network adapter forced (iPhone USB Kayo, from Automatic to 10.6.138.1, fde6:7a:7d20:28a::1) . 2020.12.24 21:33:08 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.6.138.1, fde6:7a:7d20:28a::1) . 2020.12.24 21:33:08 - DNS of a network adapter forced (Bluetooth PAN, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.6.138.1, fde6:7a:7d20:28a::1) . 2020.12.24 21:33:08 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.6.154.1, fde6:7a:7d20:29a::1 to 10.6.138.1, fde6:7a:7d20:28a::1) . 2020.12.24 21:33:08 - Routes, added a new route, 37.120.210.211 for gateway 10.6.138.1 . 2020.12.24 21:33:08 - Routes, added a new route, 2001:ac8:40:47:41eb:a0c5:e8b2:dfbe for gateway fde6:7a:7d20:28a::1 . 2020.12.24 21:33:08 - Flushing DNS I 2020.12.24 21:33:09 - Checking route IPv4 I 2020.12.24 21:33:09 - Checking route IPv6 I 2020.12.24 21:33:09 - Checking DNS . 2020.12.24 21:33:11 - Checking DNS failed: . 2020.12.24 21:33:11 - Checking DNS (2° try) . 2020.12.24 21:33:13 - Checking DNS failed: . 2020.12.24 21:33:13 - Checking DNS (3° try) . 2020.12.24 21:33:17 - Checking DNS failed: E 2020.12.24 21:33:17 - Checking DNS failed. . 2020.12.24 21:33:17 - OpenVPN > Initialization Sequence Completed ! 2020.12.24 21:33:17 - Disconnecting . 2020.12.24 21:33:17 - Routes, removed a route previously added, 37.120.210.211 for gateway 10.6.138.1 . 2020.12.24 21:33:17 - Routes, removed a route previously added, 2001:ac8:40:47:41eb:a0c5:e8b2:dfbe for gateway fde6:7a:7d20:28a::1 . 2020.12.24 21:33:17 - Sending management termination signal . 2020.12.24 21:33:17 - Management - Send 'signal SIGTERM' . 2020.12.24 21:33:18 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2020.12.24 21:33:18 - OpenVPN > SIGTERM received, sending exit notification to peer . 2020.12.24 21:33:22 - OpenVPN > /sbin/route delete -net 37.120.210.213 172.20.10.1 255.255.255.255 . 2020.12.24 21:33:22 - OpenVPN > delete net 37.120.210.213: gateway 172.20.10.1 . 2020.12.24 21:33:22 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.6.138.1 128.0.0.0 . 2020.12.24 21:33:22 - OpenVPN > delete net 0.0.0.0: gateway 10.6.138.1 . 2020.12.24 21:33:22 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.6.138.1 128.0.0.0 . 2020.12.24 21:33:22 - OpenVPN > delete net 128.0.0.0: gateway 10.6.138.1 . 2020.12.24 21:33:22 - OpenVPN > delete_route_ipv6(::/3) . 2020.12.24 21:33:22 - OpenVPN > /sbin/route delete -inet6 :: -prefixlen 3 -iface utun1 . 2020.12.24 21:33:22 - OpenVPN > delete net ::: gateway utun1 . 2020.12.24 21:33:22 - OpenVPN > delete_route_ipv6(2000::/4) . 2020.12.24 21:33:22 - OpenVPN > /sbin/route delete -inet6 2000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:33:22 - OpenVPN > delete net 2000::: gateway utun1 . 2020.12.24 21:33:22 - OpenVPN > delete_route_ipv6(3000::/4) . 2020.12.24 21:33:22 - OpenVPN > /sbin/route delete -inet6 3000:: -prefixlen 4 -iface utun1 . 2020.12.24 21:33:22 - OpenVPN > delete net 3000::: gateway utun1 . 2020.12.24 21:33:22 - OpenVPN > delete_route_ipv6(fc00::/7) . 2020.12.24 21:33:22 - OpenVPN > /sbin/route delete -inet6 fc00:: -prefixlen 7 -iface utun1 . 2020.12.24 21:33:22 - OpenVPN > delete net fc00::: gateway utun1 . 2020.12.24 21:33:22 - OpenVPN > Closing TUN/TAP interface . 2020.12.24 21:33:22 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:28a::1093 . 2020.12.24 21:33:22 - Connection terminated. . 2020.12.24 21:33:22 - DNS of a network adapter restored to original settings (Wi-Fi, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:33:22 - DNS of a network adapter restored to original settings (PPPoE, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:33:22 - DNS of a network adapter restored to original settings (PPPoE 2, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:33:22 - DNS of a network adapter restored to original settings (Ethernet, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:33:22 - DNS of a network adapter restored to original settings (FireWire, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:33:22 - DNS of a network adapter restored to original settings (iPhone USB Kayo, to Automatic) . 2020.12.24 21:33:22 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic) . 2020.12.24 21:33:22 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:33:22 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.6.154.1, fde6:7a:7d20:29a::1) . 2020.12.24 21:33:22 - OpenVPN > delete host fde6:7a:7d20:28a::1093 . 2020.12.24 21:33:22 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting I 2020.12.24 21:33:24 - Cancel requested. ! 2020.12.24 21:33:24 - Session terminated. ---------------------------- Network Interfaces and Routes: { "support_ipv4": true, "support_ipv6": true, "routes": [ { "address": "0.0.0.0\/0", "gateway": "172.20.10.1", "flags": "UGSc", "refs": "115", "use": "1746", "mtu": "1500", "interface": "en5" }, { "address": "0.0.0.127", "gateway": "127.0.0.1", "flags": "UCS", "refs": "0", "use": "0", "mtu": "16384", "interface": "lo0" }, { "address": "127.0.0.1", "gateway": "127.0.0.1", "flags": "UH", "refs": "1", "use": "3036", "mtu": "16384", "interface": "lo0" }, { "address": "169.0.0.254", "gateway": "link#16", "flags": "UCS", "refs": "1", "use": "0", "mtu": "1500", "interface": "en5", "expire": "!" }, { "address": "172.20.0.10\/28", "gateway": "link#16", "flags": "UCS", "refs": "0", "use": "0", "mtu": "1500", "interface": "en5", "expire": "!" }, { "address": "172.20.10.1", "gateway": "link#16", "flags": "UCS", "refs": "3", "use": "0", "mtu": "1500", "interface": "en5", "expire": "!" }, { "address": "172.20.10.1", "gateway": "46:0:10:f3:cb:64", "flags": "UHLWIir", "refs": "64", "use": "135", "mtu": "1500", "interface": "en5", "expire": "85" }, { "address": "172.20.10.8", "gateway": "link#16", "flags": "UCS", "refs": "1", "use": "0", "mtu": "1500", "interface": "en5", "expire": "!" }, { "address": "172.20.10.8", "gateway": "46:0:10:3f:39:58", "flags": "UHLWI", "refs": "0", "use": "648", "mtu": "16384", "interface": "lo0" }, { "address": "224.0.0.0\/4", "gateway": "link#16", "flags": "UmCS", "refs": "3", "use": "0", "mtu": "1500", "interface": "en5", "expire": "!" }, { "address": "224.0.0.251", "gateway": "1:0:5e:0:0:fb", "flags": "UHmLWI", "refs": "0", "use": "0", "mtu": "1500", "interface": "en5" }, { "address": "239.192.152.143", "gateway": "1:0:5e:40:98:8f", "flags": "UHmLWI", "refs": "0", "use": "7", "mtu": "1500", "interface": "en5" }, { "address": "239.255.255.250", "gateway": "1:0:5e:7f:ff:fa", "flags": "UHmLWI", "refs": "0", "use": "30", "mtu": "1500", "interface": "en5" }, { "address": "255.255.255.255", "gateway": "link#16", "flags": "UCS", "refs": "0", "use": "0", "mtu": "1500", "interface": "en5", "expire": "!" }, { "address": "::\/0", "gateway": "fe80::ccb:d7f9:9a6c:61fd%en5", "flags": "UGc", "refs": "67", "use": "0", "mtu": "1500", "interface": "en5" }, { "address": "::\/0", "gateway": "fe80::%utun0", "flags": "UGcI", "refs": "0", "use": "0", "mtu": "2000", "interface": "utun0" }, { "address": "::1", "gateway": "::1", "flags": "UHL", "refs": "3", "use": "4488", "mtu": "16384", "interface": "lo0" }, { "address": "2001:240:2404:f15c::\/64", "gateway": "link#16", "flags": "UC", "refs": "2", "use": "0", "mtu": "1500", "interface": "en5" }, { "address": "2001:240:2404:f15c:42:e524:fe64:eb45", "gateway": "46:0:10:3f:39:58", "flags": "UHL", "refs": "0", "use": "0", "mtu": "16384", "interface": "lo0" }, { "address": "2001:240:2404:f15c:68be:87e4:d847:94d8", "gateway": "46:0:10:f3:cb:64", "flags": "UHLWI", "refs": "0", "use": "31", "mtu": "1500", "interface": "en5" }, { "address": "2001:240:2404:f15c:8c62:9920:4c5f:c0aa", "gateway": "46:0:10:3f:39:58", "flags": "UHL", "refs": "0", "use": "47", "mtu": "16384", "interface": "lo0" }, { "address": "fe80::", "gateway": "fe80::1%lo0", "flags": "UcI", "refs": "1", "use": "0", "mtu": "16384", "interface": "lo0" }, { "address": "fe80::1", "gateway": "link#1", "flags": "UHLI", "refs": "0", "use": "0", "mtu": "16384", "interface": "lo0" }, { "address": "fe80::", "gateway": "fe80::337:dae5:4be8:c289%utun0", "flags": "UcI", "refs": "2", "use": "0", "mtu": "2000", "interface": "utun0" }, { "address": "fe80::337:dae5:4be8:c289", "gateway": "link#14", "flags": "UHLI", "refs": "0", "use": "0", "mtu": "16384", "interface": "lo0" }, { "address": "fe80::", "gateway": "link#16", "flags": "UCI", "refs": "5", "use": "0", "mtu": "1500", "interface": "en5" }, { "address": "fe80::98:60e5:bed6:f9df", "gateway": "link#16", "flags": "UHLWI", "refs": "0", "use": "7", "mtu": "1500", "interface": "en5" }, { "address": "fe80::d7:e9a8:1193:90e5", "gateway": "5c:96:9d:94:3c:49", "flags": "UHLWI", "refs": "0", "use": "2", "mtu": "1500", "interface": "en5" }, { "address": "fe80::ccb:d7f9:9a6c:61fd", "gateway": "46:0:10:f3:cb:64", "flags": "UHLWIir", "refs": "71", "use": "1721", "mtu": "1500", "interface": "en5" }, { "address": "fe80::18ef:76af:673:3623", "gateway": "46:0:10:3f:39:58", "flags": "UHLI", "refs": "0", "use": "129", "mtu": "16384", "interface": "lo0" }, { "address": "fe80::38fe:7fe1:f01e:6bdf", "gateway": "link#16", "flags": "UHLWI", "refs": "0", "use": "14", "mtu": "1500", "interface": "en5" }, { "address": "ff01::", "gateway": "::1", "flags": "UmCI", "refs": "0", "use": "0", "mtu": "16384", "interface": "lo0" }, { "address": "ff01::", "gateway": "link#10", "flags": "UmCI", "refs": "0", "use": "0", "mtu": "1500", "interface": "en1" }, { "address": "ff01::", "gateway": "link#12", "flags": "UmCI", "refs": "0", "use": "0", "mtu": "1484", "interface": "awdl0" }, { "address": "ff01::", "gateway": "fe80::337:dae5:4be8:c289%utun0", "flags": "UmCI", "refs": "0", "use": "0", "mtu": "2000", "interface": "utun0" }, { "address": "ff01::", "gateway": "link#16", "flags": "UmCI", "refs": "0", "use": "0", "mtu": "1500", "interface": "en5" }, { "address": "ff02::", "gateway": "::1", "flags": "UmCI", "refs": "0", "use": "0", "mtu": "16384", "interface": "lo0" }, { "address": "ff02::", "gateway": "link#10", "flags": "UmCI", "refs": "0", "use": "0", "mtu": "1500", "interface": "en1" }, { "address": "ff02::", "gateway": "link#12", "flags": "UmCI", "refs": "0", "use": "0", "mtu": "1484", "interface": "awdl0" }, { "address": "ff02::", "gateway": "fe80::337:dae5:4be8:c289%utun0", "flags": "UmCI", "refs": "0", "use": "0", "mtu": "2000", "interface": "utun0" }, { "address": "ff02::", "gateway": "link#16", "flags": "UmCI", "refs": "0", "use": "0", "mtu": "1500", "interface": "en5" } ], "interfaces": [ { "friendly": "lo0", "id": "lo0", "name": "lo0", "description": "lo0", "type": "Loopback", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "127.0.0.1", "::1", "fe80::1" ], "gateways": [ "127.0.0.1", "::1", "fe80::1" ], "bind": true }, { "friendly": "gif0", "id": "gif0", "name": "gif0", "description": "gif0", "type": "Unknown", "status": "Unknown", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "gateways": [], "bind": false }, { "friendly": "stf0", "id": "stf0", "name": "stf0", "description": "stf0", "type": "Unknown", "status": "Unknown", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "gateways": [], "bind": false }, { "friendly": "EHC29", "id": "EHC29", "name": "EHC29", "description": "EHC29", "type": "Unknown", "status": "Unknown", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "gateways": [], "bind": false }, { "friendly": "EHC26", "id": "EHC26", "name": "EHC26", "description": "EHC26", "type": "Unknown", "status": "Unknown", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "gateways": [], "bind": false }, { "friendly": "XHC20", "id": "XHC20", "name": "XHC20", "description": "XHC20", "type": "Unknown", "status": "Unknown", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "gateways": [], "bind": false }, { "friendly": "FireWire", "id": "fw0", "name": "fw0", "description": "fw0", "type": "Unknown", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "gateways": [], "bind": false }, { "friendly": "Ethernet", "id": "en0", "name": "en0", "description": "en0", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "gateways": [], "bind": false }, { "friendly": "Thunderbolt 1", "id": "en3", "name": "en3", "description": "en3", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "gateways": [], "bind": false }, { "friendly": "Wi-Fi", "id": "en1", "name": "en1", "description": "en1", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "gateways": [], "bind": false }, { "friendly": "p2p0", "id": "p2p0", "name": "p2p0", "description": "p2p0", "type": "Ethernet", "status": "Unknown", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "gateways": [], "bind": false }, { "friendly": "awdl0", "id": "awdl0", "name": "awdl0", "description": "awdl0", "type": "Ethernet", "status": "Unknown", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "gateways": [], "bind": false }, { "friendly": "Thunderbolt Bridge", "id": "bridge0", "name": "bridge0", "description": "bridge0", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "gateways": [], "bind": false }, { "friendly": "utun0", "id": "utun0", "name": "utun0", "description": "utun0", "type": "Unknown", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::337:dae5:4be8:c289" ], "gateways": [ "fe80::", "fe80::337:dae5:4be8:c289" ], "bind": true }, { "friendly": "iPhone USB", "id": "en5", "name": "en5", "description": "en5", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::18ef:76af:673:3623", "172.20.10.8", "2001:240:2404:f15c:42:e524:fe64:eb45", "2001:240:2404:f15c:8c62:9920:4c5f:c0aa" ], "gateways": [ "172.20.10.1", "fe80::ccb:d7f9:9a6c:61fd" ], "bind": true } ], "ipv6-default-gateway": "fe80::", "ipv6-default-interface": "utun0", "ipv4-default-gateway": "172.20.10.1", "ipv4-default-interface": "en5" } ---------------------------- ifconfig: lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384 options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP> inet 127.0.0.1 netmask 0xff000000 inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1 nd6 options=201<PERFORMNUD,DAD> gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280 stf0: flags=0<> mtu 1280 EHC29: flags=0<> mtu 0 EHC26: flags=0<> mtu 0 XHC20: flags=0<> mtu 0 fw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 4078 lladdr 10:dd:b1:ff:fe:32:2d:00 nd6 options=201<PERFORMNUD,DAD> media: autoselect <full-duplex> status: inactive en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=10b<RXCSUM,TXCSUM,VLAN_HWTAGGING,AV> ether a8:20:66:4f:9d:04 nd6 options=201<PERFORMNUD,DAD> media: autoselect (none) status: inactive en3: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500 options=60<TSO4,TSO6> ether d2:00:13:22:d0:00 media: autoselect <full-duplex> status: inactive en1: flags=8823<UP,BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500 ether 5c:96:9d:94:3c:49 nd6 options=201<PERFORMNUD,DAD> media: autoselect (<unknown type>) status: inactive p2p0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 2304 ether 0e:96:9d:94:3c:49 media: autoselect status: inactive awdl0: flags=8902<BROADCAST,PROMISC,SIMPLEX,MULTICAST> mtu 1484 ether 1e:59:26:2c:36:b3 nd6 options=201<PERFORMNUD,DAD> media: autoselect status: inactive bridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=63<RXCSUM,TXCSUM,TSO4,TSO6> ether d2:00:13:22:d0:00 Configuration: id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0 maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200 root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0 ipfilter disabled flags 0x2 member: en3 flags=3<LEARNING,DISCOVER> ifmaxaddr 0 port 9 priority 0 path cost 0 nd6 options=201<PERFORMNUD,DAD> media: <unknown type> status: inactive utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000 inet6 fe80::337:dae5:4be8:c289%utun0 prefixlen 64 scopeid 0xe nd6 options=201<PERFORMNUD,DAD> en5: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 ether 46:00:10:3f:39:58 inet6 fe80::18ef:76af:673:3623%en5 prefixlen 64 secured scopeid 0x10 inet 172.20.10.8 netmask 0xfffffff0 broadcast 172.20.10.15 inet6 2001:240:2404:f15c:42:e524:fe64:eb45 prefixlen 64 autoconf secured inet6 2001:240:2404:f15c:8c62:9920:4c5f:c0aa prefixlen 64 autoconf temporary nd6 options=201<PERFORMNUD,DAD> media: autoselect <full-duplex> status: active Edited ... by OpenSourcerer Apply LOG format to logs Share this post Link to post
Tech Jedi Alex 1499 Posted ... 21 hours ago, Maharana said: to the one mentioned below I only see one issue, which is DNS check failures. But try updating Eddie to 2.18.9 first, see if it still doesn't work. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Maharana 0 Posted ... Hello, Thanks for your help. Really appreciate it, especially at this time of year. I couldn't install 2.18.9 because I'm on Mojave and the forum indicates that 2.18.9 doesn't work on it. So I installed 2.19.6 and it works fine now. Cheers. Share this post Link to post
