polomintus 0 Posted ... Hi guys, I’ve tested using multiple VPN’s (AirVPN, FeralHosting, PIA) and noticing a lack of sex appeal when connected. A lot of people go on about speed loss when using a VPN but this doesn’t seem to be an issue with me, it seems to be a case of a lack of interest even when I know for a fact there are many people wanting to download - evidence of this is as soon as I disconnect, I go from having 1-2 uploads, to around 20-30 almost instantly, almost like people have me on a shit list. Using an external port test I can confirm my VPN port is forwarded (not forwarded in router but the actual VPN). Router / Connection (1000mbit FTTP / Ubiquiti USG Gateway with Cloud Key) uPnP is disabled on the router No ports are forwarded I am using qBitTorrent and the following settings: Connection Peer connection protocol: TCP and uTP Port used for incoming connections: 35844 (VPN Port is Open - Confirmed) Global maximum number of connections: 999 Maximum number of connections per torrent: 999 Global maximum number of upload slots: 999 Maximum number of upload slots per torrent: 999 Proxy: None IP Filtering: Disabled Speed Global Rate Limits Upload: Unlimited Global Rate Limits Download: Unlimited Alternative Rate Limits Upload: Unlimited Alternative Rate Limits Download: Unlimited Apply rate limit to uTP protocol: Disabled Apply rate limit to transport overhead: Disabled Apply rate limit to peers on LAN: Disabled BitTorrent Enable DHT (decentalized network) to find more peers: Disabled Enable peer Exchange (PeX) to find more peers: Disabled Enable Local Peer Discovery to find more peers: Disabled Encryption mode: Allow encryption Enable anonymous mode: Disabled Torrent Queuing: Disabled Seeding Limits: Disabled Advanced Process memory priority (Windows 8 >= 8 only): Normal Network interface: OpenVPN Tap-Windows6 Optional IP address to bind to: All addresses Save resume data interval: 60min Confirm torrent recheck: Enabled Recheck torrents on completion: Disabled Transfer list refresh interval: 1452ms Resolve peer host names: Disabled Resolve peer countries: Enabled Asynchronous I/O threads: 10 File poor size: 40 Outstanding memory when checking torrents: 32MiB Disk cache: -1 (auto) Disk cache expiry interval: 60 s Enable OS cache: Enabled Coalesce read & writes: Enabled Use piece affinity: Disabled Send upload piece suggestions: Disabled Send buffer watermark: 500 KiB Send buffer low watermark: 10 KiB Send buffer watermark factor: 50% Socket backlog size: 30 Outgoing ports (Min) [0: Disabled]: 0 Outgoing ports (Max) [0: Disabled]: 0 UPnP lease duration [0 Permanent lease]: 0 s uTP-TCP mixed mode algorithim: Prefer TCP Allow multiple connections from the same IP address: Enabled Disallow connections to peers on privileged ports: Disabled Enable embedded tracker: Disabled Embedded tracker port: 999 Upload slots behavior: Fixed slots Upload choking algorithm: Fastest upload Always announce to all trackers in a tier: Disabled Always announce to all tiers: Enabled IP Address to report to trackers (requires restart): Blank Max concurrent HTTP announces: 99 Stop tracker timeout: 30 s Peer turnover disconnect percentage: 4% Peer turnover threshold percentage: 90% Peer turnover disconnect interval: 300 s Tips on settings welcomed and any advice appreciated on this topic. Quote Share this post Link to post
Tech Jedi Alex 1515 Posted ... 2 hours ago, polomintus said: Peer connection protocol: TCP and uTP First, change this to TCP. 2 hours ago, polomintus said: Global maximum number of connections: 999 Maximum number of connections per torrent: 999 Global maximum number of upload slots: 999 Maximum number of upload slots per torrent: 999 Use Azureus settings calculator to enter more reasonable values here. 2 hours ago, polomintus said: Global Rate Limits Upload: Unlimited Set a limit to upload, or you risk downlink performance degradation with rising peer numbers downloading from you. 2 hours ago, polomintus said: Enable DHT (decentalized network) to find more peers: Disabled Enable peer Exchange (PeX) to find more peers: Disabled Enable Local Peer Discovery to find more peers: Disabled Why? This way you must rely on trackers only, but public trackers block connections from VPN users, so you may end up with very little peers. 2 hours ago, polomintus said: Always announce to all trackers in a tier: Disabled I'd enable this. 2 hours ago, polomintus said: Enable anonymous mode: Disabled Enable. Beneficial if behind a VPN. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
polomintus 0 Posted ... 8 hours ago, polomintus said: Peer connection protocol: TCP and uTP Quote First, change this to TCP. Don't I run the risk of not uploading to users using only uTP? Quote Set a limit to upload, or you risk downlink performance degradation with rising peer numbers downloading from you. Indeed but unable to saturate the I/O of the hard disks which are SSD NVME which I can when I disable the VPN. The calculator has me at max of 1200 global connections. ---- Quote 8 hours ago, polomintus said: Enable DHT (decentalized network) to find more peers: Disabled Enable peer Exchange (PeX) to find more peers: Disabled Enable Local Peer Discovery to find more peers: Disabled Quote Why? This way you must rely on trackers only, but public trackers block connections from VPN users, so you may end up with very little peers. Some private torrent platforms forbid it. --- Thanks for the advice. Quote Share this post Link to post
Tech Jedi Alex 1515 Posted ... 2 hours ago, polomintus said: Don't I run the risk of not uploading to users using only uTP? uTP in a VPN connection can unintentionally impare Bittorrent performance, both in terms of throughput and connections. This is much more visible inside a VPN tunnel. 2 hours ago, polomintus said: Some private torrent platforms forbid it. They can be disabled on a per-torrent basis if it's flagged accordingly at torrent file creation. qBittorrent adheres to torrents disallowing them. If your private indexers don't do this by themselves, here's something you can tell them to implement. Have you tried the wintun tunnel driver for Windows? Can you try seeding with a Linux distribution (a live CD is sufficient)? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
grovon 0 Posted ... (edited) Just had the same problem, switching from VPN over IPv6 to VPN over IPv4 fixed it. Maybe it's the fault of IPv6 inability to fragment larger packets causing package loss (which causes the UTP problems)?! (actually a problem with the MTU) Edited ... by grovon Quote Share this post Link to post
