Not connected, Your IP: 216.73.217.25
luci_luci
Network Lock Question
Hello, My question is About network lock and how to start my vpn connection correctly using eddie on windows 10.
so what i usually do is i turn on airplane mode in windows and then i start eddie, make sure that network lock is activated and then while eddie is connecting to vpn and turn off airplane mode.
my question is do i need to turn airplane mode before starting eddie to prevent any leaks or that even if i just start eddie with network lock, without the airplane mode being on, there would be no leaks?
oh and if you cant tell i am a newbie in the vpn stuff and i just want to make sure that i am using airvpn correctly.
thank you.
Edited ... by luci_luci
Why are you even disabling airplane mode if your connection is wired, anyway? You can leave it on, it's a wonderful and easy stopper for wireless connections, even if NetLock does a good job itself regardless of other interfaces' states. So this:
is correct.
first of all thank you so much for your response.
second of all, i am so sorry i should have mentioned that i dont use a wired connection, i use a wireless connection so should i keep doing what i'm doing or is it not necessary?
thank you again :)
Oooh, now I see what you're doing. Yes, it's probably safest if you keep doing it the way you do.
