stok 0 Posted ... As the title states, I'm pretty new to VPN, so I'm trying to see if there is any way to reduce packet loss while gaming. I'm pretty sure it is up to my Internet Provider though. But any way to reduce the amount of packets loss through a VPN connection? Thanks! Quote Share this post Link to post
OpenSourcerer 1487 Posted ... I think OpenVPN optimization largely boils down to tailoring MTU sizes to your setup so that they perfectly match your use case. But if you experience packet loss, something is not right at all with your connection. Can you provide logs, or in case of Eddie a support file (Logs > lifebelt icon), of a connection which suffers from packet loss as you describe, please? 1 stok reacted to this Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
stok 0 Posted ... On 12/1/2020 at 4:24 AM, OpenSourcerer said: I think OpenVPN optimization largely boils down to tailoring MTU sizes to your setup so that they perfectly match your use case. But if you experience packet loss, something is not right at all with your connection. Can you provide logs, or in case of Eddie a support file (Logs > lifebelt icon), of a connection which suffers from packet loss as you describe, please? Yes, I can see what's up with he logs. I usually lose packets around 4 P.M. - 8 P.M. most noticeably on Rocket League. I believe it's their servers. But I can see what happens tomorrow while running the VPN on their servers. The VPN seems to help stabilize the packet loss from what I have seen thus far. However, some packets still get dropped. Quote Share this post Link to post
stok 0 Posted ... (edited) Eddie System/Environment Report - 12/20/2020 - 5:43 AM UTC Eddie version: 2.18.9 Eddie OS build: windows_x64 Eddie architecture: x64 OS type: Windows OS name: Windows 10 Home OS version: Microsoft Windows NT 10.0.19042.0 OS architecture: x64 Mono /.Net Framework: v4.0.30319 TUN driver: 0901: 9.24.2; wintun: Not found OpenVPN: 2.4.8 - OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) Hummingbird: () SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe) SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) curl: 7.68.0 (C:\Program Files\AirVPN\curl.exe) Profile path: C:\Program Files\AirVPN\default.profile Data path: C:\Program Files\AirVPN Application path: C:\Program Files\AirVPN Executable path: C:\Program Files\AirVPN\Eddie-UI.exe Command line arguments: (0 args) Network Lock Active: No Connected to VPN: Yes, Nahn Detected DNS: 10.35.70.1, 2001:578:3f::30, 2001:578:3f:1::30, 68.105.28.11, 68.105.28.12, 68.105.29.11, fde6:7a:7d20:1f46::1 Test DNS IPv4: Ok Test DNS IPv6: Ok Test Ping IPv4: 193 ms Test Ping IPv6: 213 ms Test HTTP IPv4: Ok Test HTTP IPv6: Ok Test HTTPS: Ok ---------------------------- Important options not at defaults: login: (omissis) password: (omissis) remember: True log.level.debug: True ---------------------------- Logs: . 2020.12.19 09:19:35 - Eddie version: 2.18.9 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.19042.0, Mono/.Net: v4.0.30319 . 2020.12.19 09:19:35 - Command line arguments (0): . 2020.12.19 09:19:38 - Raise system privileges . 2020.12.19 09:19:41 - Profile path: C:\Program Files\AirVPN\default.profile . 2020.12.19 09:19:42 - Reading options from C:\Program Files\AirVPN\default.profile . 2020.12.19 09:19:43 - Shell(1) of 'C:\windows\system32\route.exe', 2 args: '-4';'PRINT'; . 2020.12.19 09:19:44 - Shell(1) done in 203 ms, exit: 0, out: '=========================================================================== . 2020.12.19 09:19:44 - Interface List . 2020.12.19 09:19:44 - 15...10 05 01 46 1d 37 ......Realtek PCIe GBE Family Controller . 2020.12.19 09:19:44 - 4...00 ff 1b 7c f9 a9 ......TAP-Windows Adapter V9 . 2020.12.19 09:19:44 - 5...f4 96 34 d2 71 b2 ......Microsoft Wi-Fi Direct Virtual Adapter . 2020.12.19 09:19:44 - 16...f4 96 34 d2 71 b1 ......Intel(R) Dual Band Wireless-AC 3168 . 2020.12.19 09:19:44 - 14...f4 96 34 d2 71 b5 ......Bluetooth Device (Personal Area Network) . 2020.12.19 09:19:44 - 1...........................Software Loopback Interface 1 . 2020.12.19 09:19:44 - =========================================================================== . 2020.12.19 09:19:44 - IPv4 Route Table . 2020.12.19 09:19:44 - =========================================================================== . 2020.12.19 09:19:44 - Active Routes: . 2020.12.19 09:19:44 - Network Destination Netmask Gateway Interface Metric . 2020.12.19 09:19:44 - 0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.2 25 . 2020.12.19 09:19:44 - 127.0.0.0 255.0.0.0 On-link 127.0.0.1 331 . 2020.12.19 09:19:44 - 127.0.0.1 255.255.255.255 On-link 127.0.0.1 331 . 2020.12.19 09:19:44 - 127.255.255.255 255.255.255.255 On-link 127.0.0.1 331 . 2020.12.19 09:19:44 - 192.168.0.0 255.255.255.0 On-link 192.168.0.2 281 . 2020.12.19 09:19:44 - 192.168.0.2 255.255.255.255 On-link 192.168.0.2 281 . 2020.12.19 09:19:44 - 192.168.0.255 255.255.255.255 On-link 192.168.0.2 281 . 2020.12.19 09:19:44 - 224.0.0.0 240.0.0.0 On-link 127.0.0.1 331 . 2020.12.19 09:19:44 - 224.0.0.0 240.0.0.0 On-link 192.168.0.2 281 . 2020.12.19 09:19:44 - 255.255.255.255 255.255.255.255 On-link 127.0.0.1 331 . 2020.12.19 09:19:44 - 255.255.255.255 255.255.255.255 On-link 192.168.0.2 281 . 2020.12.19 09:19:44 - =========================================================================== . 2020.12.19 09:19:44 - Persistent Routes: . 2020.12.19 09:19:44 - None' . 2020.12.19 09:19:44 - Shell(2) of 'C:\windows\system32\route.exe', 2 args: '-6';'PRINT'; . 2020.12.19 09:19:44 - Shell(2) done in 31 ms, exit: 0, out: '=========================================================================== . 2020.12.19 09:19:44 - Interface List . 2020.12.19 09:19:44 - 15...10 05 01 46 1d 37 ......Realtek PCIe GBE Family Controller . 2020.12.19 09:19:44 - 4...00 ff 1b 7c f9 a9 ......TAP-Windows Adapter V9 . 2020.12.19 09:19:44 - 5...f4 96 34 d2 71 b2 ......Microsoft Wi-Fi Direct Virtual Adapter . 2020.12.19 09:19:44 - 16...f4 96 34 d2 71 b1 ......Intel(R) Dual Band Wireless-AC 3168 . 2020.12.19 09:19:44 - 14...f4 96 34 d2 71 b5 ......Bluetooth Device (Personal Area Network) . 2020.12.19 09:19:44 - 1...........................Software Loopback Interface 1 . 2020.12.19 09:19:44 - =========================================================================== . 2020.12.19 09:19:44 - IPv6 Route Table . 2020.12.19 09:19:44 - =========================================================================== . 2020.12.19 09:19:44 - Active Routes: . 2020.12.19 09:19:44 - If Metric Network Destination Gateway . 2020.12.19 09:19:44 - 15 281 ::/0 fe80::3e04:61ff:fee2:c162 . 2020.12.19 09:19:44 - 1 331 ::1/128 On-link . 2020.12.19 09:19:44 - 15 281 2600:8801:100:e90::/64 On-link . 2020.12.19 09:19:44 - 15 281 2600:8801:100:e90:383b:b7cd:acaf:48a4/128 . 2020.12.19 09:19:44 - On-link . 2020.12.19 09:19:44 - 15 281 2600:8801:100:e90:3c88:5725:8530:c428/128 . 2020.12.19 09:19:44 - On-link . 2020.12.19 09:19:44 - 15 281 fe80::/64 On-link . 2020.12.19 09:19:44 - 15 281 fe80::383b:b7cd:acaf:48a4/128 . 2020.12.19 09:19:44 - On-link . 2020.12.19 09:19:44 - 1 331 ff00::/8 On-link . 2020.12.19 09:19:44 - 15 281 ff00::/8 On-link . 2020.12.19 09:19:44 - =========================================================================== . 2020.12.19 09:19:44 - Persistent Routes: . 2020.12.19 09:19:44 - If Metric Network Destination Gateway . 2020.12.19 09:19:44 - 0 4294967295 2a0d:5600:2:4:557:907e:7abb:8b73/128 . 2020.12.19 09:19:44 - fde6:7a:7d20:1696::1 . 2020.12.19 09:19:44 - ===========================================================================' . 2020.12.19 09:19:44 - Elevated: Command:wfp . 2020.12.19 09:19:44 - Shell(3) of 'C:\Program Files\AirVPN\openvpn.exe', 1 args: '--version'; . 2020.12.19 09:19:45 - Shell(3) done in 391 ms, exit: 1, out: 'OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019 . 2020.12.19 09:19:45 - library versions: OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 . 2020.12.19 09:19:45 - Windows version 6.2 (Windows 8 or greater) 64bit . 2020.12.19 09:19:45 - Originally developed by James Yonan . 2020.12.19 09:19:45 - Copyright (C) 2002-2018 OpenVPN Inc <sales@openvpn.net> . 2020.12.19 09:19:45 - Compile time defines: enable_async_push=no enable_comp_stub=no enable_crypto=yes enable_crypto_ofb_cfb=yes enable_debug=yes enable_def_auth=yes enable_dlopen=unknown enable_dlopen_self=unknown enable_dlopen_self_static=unknown enable_fast_install=needless enable_fragment=yes enable_iproute2=no enable_libtool_lock=yes enable_lz4=yes enable_lzo=yes enable_management=yes enable_multihome=yes enable_pam_dlopen=no enable_pedantic=no enable_pf=yes enable_pkcs11=yes enable_plugin_auth_pam=no enable_plugin_down_root=no enable_plugins=yes enable_port_share=yes enable_selinux=no enable_server=yes enable_shared=yes enable_shared_with_static_runtimes=yes enable_small=no enable_static=yes enable_strict=no enable_strict_options=no enable_systemd=no enable_werror=no enable_win32_dll=yes enable_x509_alt_username=no with_aix_soname=aix with_crypto_library=openssl with_gnu_ld=yes with_mem_check=no with_special_build= with_sysroot=no' . 2020.12.19 09:19:45 - Shell(4) of 'C:\Program Files\AirVPN\plink.exe', 1 args: '-V'; . 2020.12.19 09:19:45 - Shell(4) done in 31 ms, exit: 1, out: 'plink: Release 0.67' . 2020.12.19 09:19:45 - Shell(5) of 'C:\Program Files\AirVPN\stunnel.exe', 1 args: '-version'; . 2020.12.19 09:19:46 - Shell(5) done in 938 ms, exit: 0, err: 'stunnel 5.40 on x86-pc-mingw32-gnu platform . 2020.12.19 09:19:46 - Compiled/running with OpenSSL 1.0.2k 26 Jan 2017 . 2020.12.19 09:19:46 - Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI . 2020.12.19 09:19:46 - Global options: . 2020.12.19 09:19:46 - RNDbytes = 64 . 2020.12.19 09:19:46 - RNDoverwrite = yes . 2020.12.19 09:19:46 - taskbar = yes . 2020.12.19 09:19:46 - Service-level options: . 2020.12.19 09:19:46 - ciphers = HIGH:!DH:!aNULL:!SSLv2 . 2020.12.19 09:19:46 - curve = prime256v1 . 2020.12.19 09:19:46 - debug = notice . 2020.12.19 09:19:46 - logId = sequential . 2020.12.19 09:19:46 - options = NO_SSLv2 . 2020.12.19 09:19:46 - options = NO_SSLv3 . 2020.12.19 09:19:46 - sessionCacheSize = 1000 . 2020.12.19 09:19:46 - sessionCacheTimeout = 300 seconds . 2020.12.19 09:19:46 - stack = 65536 bytes . 2020.12.19 09:19:46 - TIMEOUTbusy = 300 seconds . 2020.12.19 09:19:46 - TIMEOUTclose = 60 seconds . 2020.12.19 09:19:46 - TIMEOUTconnect = 10 seconds . 2020.12.19 09:19:46 - TIMEOUTidle = 43200 seconds . 2020.12.19 09:19:46 - verify = none' . 2020.12.19 09:19:46 - Shell(6) of 'C:\Program Files\AirVPN\curl.exe', 1 args: '--version'; . 2020.12.19 09:19:46 - Shell(6) done in 453 ms, exit: 0, out: 'curl 7.68.0 (x86_64-pc-win32) libcurl/7.68.0 OpenSSL/1.1.1d (Schannel) zlib/1.2.11 brotli/1.0.7 WinIDN libssh2/1.9.0 nghttp2/1.40.0 . 2020.12.19 09:19:46 - Release-Date: 2020-01-08 . 2020.12.19 09:19:46 - Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps pop3 pop3s rtsp scp sftp smb smbs smtp smtps telnet tftp . 2020.12.19 09:19:46 - Features: AsynchDNS HTTP2 HTTPS-proxy IDN IPv6 Kerberos Largefile MultiSSL NTLM SPNEGO SSL SSPI TLS-SRP brotli libz' . 2020.12.19 09:19:46 - Tun Driver - 0901: 9.24.2; wintun: Not found . 2020.12.19 09:19:46 - OpenVPN - Version: 2.4.8 - OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2020.12.19 09:19:46 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe) . 2020.12.19 09:19:46 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) . 2020.12.19 09:19:46 - curl - Version: 7.68.0 (C:\Program Files\AirVPN\curl.exe) . 2020.12.19 09:19:46 - Elevated: Command:wfp . 2020.12.19 09:19:48 - Recovery. Unexpected crash? . 2020.12.19 09:19:48 - Elevated: Command:route . 2020.12.19 09:19:49 - Routes, added a new route, 2606:9580:103:a:fda7:1f4c:8c40:8c3e for gateway fde6:7a:7d20:be6::1 . 2020.12.19 09:19:49 - Elevated: Command:route . 2020.12.19 09:19:49 - Routes, removed an existing route, 2a0d:5600:2:4:557:907e:7abb:8b73 for gateway fde6:7a:7d20:1696::1 I 2020.12.19 09:19:49 - Ready . 2020.12.19 09:19:51 - Collect information about AirVPN completed I 2020.12.19 09:21:01 - Session starting. I 2020.12.19 09:21:02 - Checking authorization ... ! 2020.12.19 09:21:02 - Connecting to Chalawan (United States of America, Phoenix, Arizona) . 2020.12.19 09:21:02 - Elevated: Command:process_openvpn . 2020.12.19 09:21:03 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019 . 2020.12.19 09:21:03 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.12.19 09:21:03 - OpenVPN > library versions: OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 . 2020.12.19 09:21:04 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.19 09:21:04 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.19 09:21:04 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.19 09:21:04 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.19 09:21:04 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.21:443 . 2020.12.19 09:21:04 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2020.12.19 09:21:04 - OpenVPN > UDP link local: (not bound) . 2020.12.19 09:21:04 - OpenVPN > UDP link remote: [AF_INET]193.37.254.21:443 . 2020.12.19 09:21:04 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.21:443, sid=224bb9ca 1af0dd7d . 2020.12.19 09:21:04 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.19 09:21:04 - OpenVPN > VERIFY KU OK . 2020.12.19 09:21:04 - OpenVPN > Validating certificate extended key usage . 2020.12.19 09:21:04 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.19 09:21:04 - OpenVPN > VERIFY EKU OK . 2020.12.19 09:21:04 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Chalawan, emailAddress=info@airvpn.org . 2020.12.19 09:21:04 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.19 09:21:04 - OpenVPN > [Chalawan] Peer Connection Initiated with [AF_INET]193.37.254.21:443 . 2020.12.19 09:21:05 - OpenVPN > SENT CONTROL [Chalawan]: 'PUSH_REQUEST' (status=1) . 2020.12.19 09:21:05 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.29.214.1,dhcp-option DNS6 fde6:7a:7d20:19d6::1,tun-ipv6,route-gateway 10.29.214.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:19d6::1084/64 fde6:7a:7d20:19d6::1,ifconfig 10.29.214.134 255.255.255.0,peer-id 2,cipher AES-256-GCM' . 2020.12.19 09:21:05 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2020.12.19 09:21:05 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2020.12.19 09:21:05 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2020.12.19 09:21:05 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2020.12.19 09:21:05 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2020.12.19 09:21:05 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2020.12.19 09:21:05 - OpenVPN > OPTIONS IMPORT: peer-id set . 2020.12.19 09:21:05 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2020.12.19 09:21:05 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2020.12.19 09:21:05 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2020.12.19 09:21:05 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 09:21:05 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 09:21:05 - OpenVPN > interactive service msg_channel=0 . 2020.12.19 09:21:05 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=10:05:01:46:1d:37 . 2020.12.19 09:21:05 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2020.12.19 09:21:05 - OpenVPN > GetBestInterfaceEx() returned if=15 . 2020.12.19 09:21:05 - OpenVPN > GDG6: II=15 DP=::/0 NH=fe80::3e04:61ff:fee2:c162 . 2020.12.19 09:21:05 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0 . 2020.12.19 09:21:05 - OpenVPN > ROUTE6_GATEWAY fe80::3e04:61ff:fee2:c162 I=15 . 2020.12.19 09:21:05 - OpenVPN > open_tun . 2020.12.19 09:21:05 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{1B7CF9A9-83C9-4156-8020-597EB10B973E}.tap . 2020.12.19 09:21:05 - OpenVPN > TAP-Windows Driver Version 9.24 . 2020.12.19 09:21:05 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.29.214.0/10.29.214.134/255.255.255.0 [SUCCEEDED] . 2020.12.19 09:21:05 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.29.214.134/255.255.255.0 on interface {1B7CF9A9-83C9-4156-8020-597EB10B973E} [DHCP-serv: 10.29.214.254, lease-time: 31536000] . 2020.12.19 09:21:05 - OpenVPN > Successful ARP Flush on interface [4] {1B7CF9A9-83C9-4156-8020-597EB10B973E} . 2020.12.19 09:21:06 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=4 fde6:7a:7d20:19d6::1084 store=active . 2020.12.19 09:21:12 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Local Area Connection static fde6:7a:7d20:19d6::1 validate=no . 2020.12.19 09:21:12 - Shell(7) of 'C:\windows\system32\route.exe', 2 args: '-6';'PRINT'; . 2020.12.19 09:21:12 - Shell(7) done in 31 ms, exit: 0, out: '=========================================================================== . 2020.12.19 09:21:12 - Interface List . 2020.12.19 09:21:12 - 15...10 05 01 46 1d 37 ......Realtek PCIe GBE Family Controller . 2020.12.19 09:21:12 - 4...00 ff 1b 7c f9 a9 ......TAP-Windows Adapter V9 . 2020.12.19 09:21:12 - 5...f4 96 34 d2 71 b2 ......Microsoft Wi-Fi Direct Virtual Adapter . 2020.12.19 09:21:12 - 16...f4 96 34 d2 71 b1 ......Intel(R) Dual Band Wireless-AC 3168 . 2020.12.19 09:21:12 - 14...f4 96 34 d2 71 b5 ......Bluetooth Device (Personal Area Network) . 2020.12.19 09:21:12 - 1...........................Software Loopback Interface 1 . 2020.12.19 09:21:12 - =========================================================================== . 2020.12.19 09:21:12 - IPv6 Route Table . 2020.12.19 09:21:12 - =========================================================================== . 2020.12.19 09:21:12 - Active Routes: . 2020.12.19 09:21:12 - If Metric Network Destination Gateway . 2020.12.19 09:21:12 - 15 281 ::/0 fe80::3e04:61ff:fee2:c162 . 2020.12.19 09:21:12 - 1 331 ::1/128 On-link . 2020.12.19 09:21:12 - 15 281 2600:8801:100:e90::/64 On-link . 2020.12.19 09:21:12 - 15 281 2600:8801:100:e90:383b:b7cd:acaf:48a4/128 . 2020.12.19 09:21:12 - On-link . 2020.12.19 09:21:12 - 15 281 2600:8801:100:e90:3c88:5725:8530:c428/128 . 2020.12.19 09:21:12 - On-link . 2020.12.19 09:21:12 - 4 281 2606:9580:103:a:fda7:1f4c:8c40:8c3e/128 . 2020.12.19 09:21:12 - fde6:7a:7d20:be6::1 . 2020.12.19 09:21:12 - 4 281 fde6:7a:7d20:19d6::/64 On-link . 2020.12.19 09:21:12 - 4 281 fde6:7a:7d20:19d6::/64 fe80::8 . 2020.12.19 09:21:12 - 4 281 fde6:7a:7d20:19d6::1084/128 . 2020.12.19 09:21:12 - On-link . 2020.12.19 09:21:12 - 4 281 fe80::/64 On-link . 2020.12.19 09:21:12 - 15 281 fe80::/64 On-link . 2020.12.19 09:21:12 - 4 281 fe80::1c7c:68c1:fb88:8fb/128 . 2020.12.19 09:21:12 - On-link . 2020.12.19 09:21:12 - 15 281 fe80::383b:b7cd:acaf:48a4/128 . 2020.12.19 09:21:12 - On-link . 2020.12.19 09:21:12 - 1 331 ff00::/8 On-link . 2020.12.19 09:21:12 - 4 281 ff00::/8 On-link . 2020.12.19 09:21:12 - 15 281 ff00::/8 On-link . 2020.12.19 09:21:12 - =========================================================================== . 2020.12.19 09:21:12 - Persistent Routes: . 2020.12.19 09:21:12 - If Metric Network Destination Gateway . 2020.12.19 09:21:12 - 0 4294967295 2606:9580:103:a:fda7:1f4c:8c40:8c3e/128 . 2020.12.19 09:21:12 - fde6:7a:7d20:be6::1 . 2020.12.19 09:21:12 - ===========================================================================' . 2020.12.19 09:21:12 - Detected an OpenVPN bug (On-Link route on VPN range), autofix. . 2020.12.19 09:21:12 - Elevated: Command:windows-workaround-25139 . 2020.12.19 09:21:12 - OpenVPN > add_route_ipv6(fde6:7a:7d20:19d6::/64 -> fde6:7a:7d20:19d6::1084 metric 0) dev Local Area Connection . 2020.12.19 09:21:12 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:19d6::/64 interface=4 fe80::8 store=active . 2020.12.19 09:21:12 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.12.19 09:21:17 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2020.12.19 09:21:17 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 193.37.254.21 MASK 255.255.255.255 192.168.0.1 . 2020.12.19 09:21:17 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.12.19 09:21:17 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.12.19 09:21:17 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.29.214.1 . 2020.12.19 09:21:17 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.12.19 09:21:17 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.12.19 09:21:17 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.29.214.1 . 2020.12.19 09:21:17 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.12.19 09:21:17 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.12.19 09:21:17 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:19d6::1 metric -1) dev Local Area Connection . 2020.12.19 09:21:17 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=4 fe80::8 store=active . 2020.12.19 09:21:17 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.12.19 09:21:17 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:19d6::1 metric -1) dev Local Area Connection . 2020.12.19 09:21:17 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=4 fe80::8 store=active . 2020.12.19 09:21:17 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.12.19 09:21:17 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:19d6::1 metric -1) dev Local Area Connection . 2020.12.19 09:21:17 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=4 fe80::8 store=active . 2020.12.19 09:21:17 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.12.19 09:21:17 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:19d6::1 metric -1) dev Local Area Connection . 2020.12.19 09:21:17 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=4 fe80::8 store=active . 2020.12.19 09:21:17 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.12.19 09:21:17 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4 . 2020.12.19 09:21:17 - Elevated: Command:set-interface-metric . 2020.12.19 09:21:17 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6 . 2020.12.19 09:21:17 - Elevated: Command:set-interface-metric . 2020.12.19 09:21:17 - Elevated: Command:wfp . 2020.12.19 09:21:17 - Above log line repeated 5 times more . 2020.12.19 09:21:17 - DNS leak protection with packet filtering enabled. . 2020.12.19 09:21:17 - Shell(8) of 'C:\windows\system32\route.exe', 2 args: '-4';'PRINT'; . 2020.12.19 09:21:17 - Shell(8) done in 78 ms, exit: 0, out: '=========================================================================== . 2020.12.19 09:21:17 - Interface List . 2020.12.19 09:21:17 - 4...00 ff 1b 7c f9 a9 ......TAP-Windows Adapter V9 . 2020.12.19 09:21:17 - 15...10 05 01 46 1d 37 ......Realtek PCIe GBE Family Controller . 2020.12.19 09:21:17 - 5...f4 96 34 d2 71 b2 ......Microsoft Wi-Fi Direct Virtual Adapter . 2020.12.19 09:21:17 - 16...f4 96 34 d2 71 b1 ......Intel(R) Dual Band Wireless-AC 3168 . 2020.12.19 09:21:17 - 14...f4 96 34 d2 71 b5 ......Bluetooth Device (Personal Area Network) . 2020.12.19 09:21:17 - 1...........................Software Loopback Interface 1 . 2020.12.19 09:21:17 - =========================================================================== . 2020.12.19 09:21:17 - IPv4 Route Table . 2020.12.19 09:21:17 - =========================================================================== . 2020.12.19 09:21:17 - Active Routes: . 2020.12.19 09:21:17 - Network Destination Netmask Gateway Interface Metric . 2020.12.19 09:21:17 - 0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.2 25 . 2020.12.19 09:21:17 - 0.0.0.0 128.0.0.0 10.29.214.1 10.29.214.134 3 . 2020.12.19 09:21:17 - 10.29.214.0 255.255.255.0 On-link 10.29.214.134 259 . 2020.12.19 09:21:17 - 10.29.214.134 255.255.255.255 On-link 10.29.214.134 259 . 2020.12.19 09:21:17 - 10.29.214.255 255.255.255.255 On-link 10.29.214.134 259 . 2020.12.19 09:21:17 - 127.0.0.0 255.0.0.0 On-link 127.0.0.1 331 . 2020.12.19 09:21:17 - 127.0.0.1 255.255.255.255 On-link 127.0.0.1 331 . 2020.12.19 09:21:17 - 127.255.255.255 255.255.255.255 On-link 127.0.0.1 331 . 2020.12.19 09:21:17 - 128.0.0.0 128.0.0.0 10.29.214.1 10.29.214.134 3 . 2020.12.19 09:21:17 - 192.168.0.0 255.255.255.0 On-link 192.168.0.2 281 . 2020.12.19 09:21:17 - 192.168.0.2 255.255.255.255 On-link 192.168.0.2 281 . 2020.12.19 09:21:17 - 192.168.0.255 255.255.255.255 On-link 192.168.0.2 281 . 2020.12.19 09:21:17 - 193.37.254.21 255.255.255.255 192.168.0.1 192.168.0.2 25 . 2020.12.19 09:21:17 - 224.0.0.0 240.0.0.0 On-link 127.0.0.1 331 . 2020.12.19 09:21:17 - 224.0.0.0 240.0.0.0 On-link 10.29.214.134 259 . 2020.12.19 09:21:17 - 224.0.0.0 240.0.0.0 On-link 192.168.0.2 281 . 2020.12.19 09:21:17 - 255.255.255.255 255.255.255.255 On-link 127.0.0.1 331 . 2020.12.19 09:21:17 - 255.255.255.255 255.255.255.255 On-link 10.29.214.134 259 . 2020.12.19 09:21:17 - 255.255.255.255 255.255.255.255 On-link 192.168.0.2 281 . 2020.12.19 09:21:17 - =========================================================================== . 2020.12.19 09:21:17 - Persistent Routes: . 2020.12.19 09:21:17 - None' . 2020.12.19 09:21:17 - Shell(9) of 'C:\windows\system32\route.exe', 2 args: '-6';'PRINT'; . 2020.12.19 09:21:17 - Shell(9) done in 31 ms, exit: 0, out: '=========================================================================== . 2020.12.19 09:21:17 - Interface List . 2020.12.19 09:21:17 - 4...00 ff 1b 7c f9 a9 ......TAP-Windows Adapter V9 . 2020.12.19 09:21:17 - 15...10 05 01 46 1d 37 ......Realtek PCIe GBE Family Controller . 2020.12.19 09:21:17 - 5...f4 96 34 d2 71 b2 ......Microsoft Wi-Fi Direct Virtual Adapter . 2020.12.19 09:21:17 - 16...f4 96 34 d2 71 b1 ......Intel(R) Dual Band Wireless-AC 3168 . 2020.12.19 09:21:17 - 14...f4 96 34 d2 71 b5 ......Bluetooth Device (Personal Area Network) . 2020.12.19 09:21:17 - 1...........................Software Loopback Interface 1 . 2020.12.19 09:21:17 - =========================================================================== . 2020.12.19 09:21:17 - IPv6 Route Table . 2020.12.19 09:21:17 - =========================================================================== . 2020.12.19 09:21:17 - Active Routes: . 2020.12.19 09:21:17 - If Metric Network Destination Gateway . 2020.12.19 09:21:17 - 15 281 ::/0 fe80::3e04:61ff:fee2:c162 . 2020.12.19 09:21:17 - 4 259 ::/3 fe80::8 . 2020.12.19 09:21:17 - 1 331 ::1/128 On-link . 2020.12.19 09:21:17 - 4 259 2000::/4 fe80::8 . 2020.12.19 09:21:17 - 15 281 2600:8801:100:e90::/64 On-link . 2020.12.19 09:21:17 - 15 281 2600:8801:100:e90:383b:b7cd:acaf:48a4/128 . 2020.12.19 09:21:17 - On-link . 2020.12.19 09:21:17 - 15 281 2600:8801:100:e90:3c88:5725:8530:c428/128 . 2020.12.19 09:21:17 - On-link . 2020.12.19 09:21:17 - 4 259 2606:9580:103:a:fda7:1f4c:8c40:8c3e/128 . 2020.12.19 09:21:17 - fde6:7a:7d20:be6::1 . 2020.12.19 09:21:17 - 4 259 3000::/4 fe80::8 . 2020.12.19 09:21:17 - 4 259 fc00::/7 fe80::8 . 2020.12.19 09:21:17 - 4 259 fde6:7a:7d20:19d6::/64 fe80::8 . 2020.12.19 09:21:17 - 4 259 fde6:7a:7d20:19d6::1084/128 . 2020.12.19 09:21:17 - On-link . 2020.12.19 09:21:17 - 4 259 fe80::/64 On-link . 2020.12.19 09:21:17 - 15 281 fe80::/64 On-link . 2020.12.19 09:21:17 - 4 259 fe80::1c7c:68c1:fb88:8fb/128 . 2020.12.19 09:21:17 - On-link . 2020.12.19 09:21:17 - 15 281 fe80::383b:b7cd:acaf:48a4/128 . 2020.12.19 09:21:17 - On-link . 2020.12.19 09:21:17 - 1 331 ff00::/8 On-link . 2020.12.19 09:21:17 - 4 259 ff00::/8 On-link . 2020.12.19 09:21:17 - 15 281 ff00::/8 On-link . 2020.12.19 09:21:17 - =========================================================================== . 2020.12.19 09:21:17 - Persistent Routes: . 2020.12.19 09:21:17 - If Metric Network Destination Gateway . 2020.12.19 09:21:17 - 0 4294967295 2606:9580:103:a:fda7:1f4c:8c40:8c3e/128 . 2020.12.19 09:21:17 - fde6:7a:7d20:be6::1 . 2020.12.19 09:21:17 - ===========================================================================' . 2020.12.19 09:21:17 - Elevated: Command:route . 2020.12.19 09:21:17 - Routes, added a new route, 193.37.254.19 for gateway 10.29.214.1 . 2020.12.19 09:21:17 - Elevated: Command:route . 2020.12.19 09:21:18 - Routes, added a new route, 2a0d:5600:2:6:f362:ba43:29f3:b8a for gateway fde6:7a:7d20:19d6::1 . 2020.12.19 09:21:18 - Flushing DNS . 2020.12.19 09:21:18 - Elevated: Command:dns-flush . 2020.12.19 09:21:18 - Shell(10) of 'C:\windows\system32\ipconfig.exe', 1 args: '/flushdns'; . 2020.12.19 09:21:18 - Shell(10) done in 31 ms, exit: 0, out: 'Windows IP Configuration . 2020.12.19 09:21:18 - Successfully flushed the DNS Resolver Cache.' I 2020.12.19 09:21:18 - Checking route IPv4 I 2020.12.19 09:21:18 - Checking route IPv6 I 2020.12.19 09:21:21 - Checking DNS ! 2020.12.19 09:21:21 - Connected. . 2020.12.19 09:21:21 - OpenVPN > Initialization Sequence Completed . 2020.12.19 09:49:53 - Collect information about AirVPN completed . 2020.12.19 10:15:37 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.19 10:15:37 - OpenVPN > VERIFY KU OK . 2020.12.19 10:15:37 - OpenVPN > Validating certificate extended key usage . 2020.12.19 10:15:37 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.19 10:15:37 - OpenVPN > VERIFY EKU OK . 2020.12.19 10:15:37 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Chalawan, emailAddress=info@airvpn.org . 2020.12.19 10:15:38 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 10:15:38 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 10:15:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.19 10:19:54 - Collect information about AirVPN completed . 2020.12.19 11:10:12 - Above log line repeated 1 times more . 2020.12.19 11:10:12 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.19 11:10:12 - OpenVPN > VERIFY KU OK . 2020.12.19 11:10:12 - OpenVPN > Validating certificate extended key usage . 2020.12.19 11:10:12 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.19 11:10:12 - OpenVPN > VERIFY EKU OK . 2020.12.19 11:10:12 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Chalawan, emailAddress=info@airvpn.org . 2020.12.19 11:10:12 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 11:10:12 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 11:10:12 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.19 11:19:59 - Collect information about AirVPN completed . 2020.12.19 12:04:46 - Above log line repeated 1 times more . 2020.12.19 12:04:46 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.19 12:04:46 - OpenVPN > VERIFY KU OK . 2020.12.19 12:04:46 - OpenVPN > Validating certificate extended key usage . 2020.12.19 12:04:46 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.19 12:04:46 - OpenVPN > VERIFY EKU OK . 2020.12.19 12:04:46 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Chalawan, emailAddress=info@airvpn.org . 2020.12.19 12:04:46 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 12:04:46 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 12:04:46 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.19 12:20:06 - Collect information about AirVPN completed . 2020.12.19 12:59:19 - Above log line repeated 1 times more . 2020.12.19 12:59:19 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.19 12:59:19 - OpenVPN > VERIFY KU OK . 2020.12.19 12:59:19 - OpenVPN > Validating certificate extended key usage . 2020.12.19 12:59:19 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.19 12:59:19 - OpenVPN > VERIFY EKU OK . 2020.12.19 12:59:19 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Chalawan, emailAddress=info@airvpn.org . 2020.12.19 12:59:19 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 12:59:19 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 12:59:19 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.19 13:20:17 - Collect information about AirVPN completed . 2020.12.19 13:53:52 - Above log line repeated 1 times more . 2020.12.19 13:53:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.19 13:53:52 - OpenVPN > VERIFY KU OK . 2020.12.19 13:53:52 - OpenVPN > Validating certificate extended key usage . 2020.12.19 13:53:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.19 13:53:52 - OpenVPN > VERIFY EKU OK . 2020.12.19 13:53:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Chalawan, emailAddress=info@airvpn.org . 2020.12.19 13:53:52 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 13:53:52 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 13:53:52 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.19 14:20:33 - Collect information about AirVPN completed . 2020.12.19 14:48:25 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.19 14:48:25 - OpenVPN > VERIFY KU OK . 2020.12.19 14:48:25 - OpenVPN > Validating certificate extended key usage . 2020.12.19 14:48:25 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.19 14:48:25 - OpenVPN > VERIFY EKU OK . 2020.12.19 14:48:25 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Chalawan, emailAddress=info@airvpn.org . 2020.12.19 14:48:25 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 14:48:25 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 14:48:25 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.19 15:01:12 - OpenVPN > [Chalawan] Inactivity timeout (--ping-restart), restarting . 2020.12.19 15:01:12 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting . 2020.12.19 15:01:12 - OpenVPN > Restart pause, 5 second(s) ! 2020.12.19 15:01:12 - Disconnecting . 2020.12.19 15:01:12 - Elevated: Command:route . 2020.12.19 15:01:12 - Routes, removed a route previously added, 193.37.254.19 for gateway 10.29.214.1 . 2020.12.19 15:01:13 - Elevated: Command:route . 2020.12.19 15:01:13 - Routes, removed a route previously added, 2a0d:5600:2:6:f362:ba43:29f3:b8a for gateway fde6:7a:7d20:19d6::1 . 2020.12.19 15:01:13 - Sending soft termination signal . 2020.12.19 15:01:13 - Elevated: Command:kill . 2020.12.19 15:01:17 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 193.37.254.21 MASK 255.255.255.255 192.168.0.1 . 2020.12.19 15:01:17 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2020.12.19 15:01:17 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.29.214.1 . 2020.12.19 15:01:17 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2020.12.19 15:01:17 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.29.214.1 . 2020.12.19 15:01:17 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2020.12.19 15:01:17 - OpenVPN > delete_route_ipv6(::/3) . 2020.12.19 15:01:17 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 interface=4 fe80::8 store=active . 2020.12.19 15:01:17 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.12.19 15:01:17 - OpenVPN > delete_route_ipv6(2000::/4) . 2020.12.19 15:01:17 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=4 fe80::8 store=active . 2020.12.19 15:01:17 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.12.19 15:01:17 - OpenVPN > delete_route_ipv6(3000::/4) . 2020.12.19 15:01:17 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=4 fe80::8 store=active . 2020.12.19 15:01:17 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.12.19 15:01:17 - OpenVPN > delete_route_ipv6(fc00::/7) . 2020.12.19 15:01:17 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=4 fe80::8 store=active . 2020.12.19 15:01:17 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.12.19 15:01:17 - OpenVPN > Closing TUN/TAP interface . 2020.12.19 15:01:17 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:19d6::/64) . 2020.12.19 15:01:17 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:19d6::/64 interface=4 fe80::8 store=active . 2020.12.19 15:01:18 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address Local Area Connection fde6:7a:7d20:19d6::1084 store=active . 2020.12.19 15:01:19 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns Local Area Connection all . 2020.12.19 15:01:19 - OpenVPN > TAP: DHCP address released . 2020.12.19 15:01:19 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting . 2020.12.19 15:01:19 - Connection terminated. . 2020.12.19 15:01:19 - Elevated: Command:wfp . 2020.12.19 15:01:19 - Above log line repeated 5 times more . 2020.12.19 15:01:19 - DNS leak protection with packet filtering disabled. . 2020.12.19 15:01:19 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4 . 2020.12.19 15:01:19 - Elevated: Command:set-interface-metric . 2020.12.19 15:01:19 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv6 . 2020.12.19 15:01:19 - Elevated: Command:set-interface-metric . 2020.12.19 15:01:21 - Collect information about AirVPN completed . 2020.12.19 15:01:22 - Waiting for latency tests (240 to go) . 2020.12.19 15:01:25 - Waiting for latency tests (190 to go) . 2020.12.19 15:01:26 - Waiting for latency tests (172 to go) . 2020.12.19 15:01:29 - Waiting for latency tests (148 to go) . 2020.12.19 15:01:32 - Waiting for latency tests (125 to go) . 2020.12.19 15:01:33 - Waiting for latency tests (124 to go) . 2020.12.19 15:01:35 - Waiting for latency tests (106 to go) . 2020.12.19 15:01:38 - Waiting for latency tests (81 to go) . 2020.12.19 15:01:41 - Waiting for latency tests (72 to go) . 2020.12.19 15:01:42 - Waiting for latency tests (69 to go) . 2020.12.19 15:01:44 - Waiting for latency tests (65 to go) . 2020.12.19 15:01:45 - Waiting for latency tests (57 to go) . 2020.12.19 15:01:47 - Waiting for latency tests (49 to go) . 2020.12.19 15:01:48 - Waiting for latency tests (41 to go) . 2020.12.19 15:01:51 - Waiting for latency tests (33 to go) . 2020.12.19 15:01:52 - Waiting for latency tests (18 to go) . 2020.12.19 15:01:54 - Waiting for latency tests (8 to go) . 2020.12.19 15:01:55 - Waiting for latency tests (3 to go) I 2020.12.19 15:01:57 - Checking authorization ... ! 2020.12.19 15:01:57 - Connecting to Nahn (Canada, Vancouver) . 2020.12.19 15:01:57 - Elevated: Command:process_openvpn . 2020.12.19 15:01:57 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019 . 2020.12.19 15:01:57 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.12.19 15:01:57 - OpenVPN > library versions: OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 . 2020.12.19 15:01:57 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.19 15:01:57 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.19 15:01:57 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.19 15:01:57 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.19 15:01:57 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]192.30.89.69:443 . 2020.12.19 15:01:57 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2020.12.19 15:01:57 - OpenVPN > UDP link local: (not bound) . 2020.12.19 15:01:57 - OpenVPN > UDP link remote: [AF_INET]192.30.89.69:443 . 2020.12.19 15:01:57 - OpenVPN > TLS: Initial packet from [AF_INET]192.30.89.69:443, sid=dd163aee 8b13482c . 2020.12.19 15:01:58 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.19 15:01:58 - OpenVPN > VERIFY KU OK . 2020.12.19 15:01:58 - OpenVPN > Validating certificate extended key usage . 2020.12.19 15:01:58 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.19 15:01:58 - OpenVPN > VERIFY EKU OK . 2020.12.19 15:01:58 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Nahn, emailAddress=info@airvpn.org . 2020.12.19 15:01:58 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.19 15:01:58 - OpenVPN > [Nahn] Peer Connection Initiated with [AF_INET]192.30.89.69:443 . 2020.12.19 15:01:59 - OpenVPN > SENT CONTROL [Nahn]: 'PUSH_REQUEST' (status=1) . 2020.12.19 15:01:59 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.35.70.1,dhcp-option DNS6 fde6:7a:7d20:1f46::1,tun-ipv6,route-gateway 10.35.70.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1f46::1071/64 fde6:7a:7d20:1f46::1,ifconfig 10.35.70.115 255.255.255.0,peer-id 1,cipher AES-256-GCM' . 2020.12.19 15:01:59 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2020.12.19 15:01:59 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2020.12.19 15:01:59 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2020.12.19 15:01:59 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2020.12.19 15:01:59 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2020.12.19 15:01:59 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2020.12.19 15:01:59 - OpenVPN > OPTIONS IMPORT: peer-id set . 2020.12.19 15:01:59 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2020.12.19 15:01:59 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2020.12.19 15:01:59 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2020.12.19 15:01:59 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 15:01:59 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 15:01:59 - OpenVPN > interactive service msg_channel=0 . 2020.12.19 15:01:59 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=10:05:01:46:1d:37 . 2020.12.19 15:01:59 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2020.12.19 15:01:59 - OpenVPN > GetBestInterfaceEx() returned if=15 . 2020.12.19 15:01:59 - OpenVPN > GDG6: II=15 DP=::/0 NH=fe80::3e04:61ff:fee2:c162 . 2020.12.19 15:01:59 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0 . 2020.12.19 15:01:59 - OpenVPN > ROUTE6_GATEWAY fe80::3e04:61ff:fee2:c162 I=15 . 2020.12.19 15:01:59 - OpenVPN > open_tun . 2020.12.19 15:01:59 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{1B7CF9A9-83C9-4156-8020-597EB10B973E}.tap . 2020.12.19 15:01:59 - OpenVPN > TAP-Windows Driver Version 9.24 . 2020.12.19 15:01:59 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.35.70.0/10.35.70.115/255.255.255.0 [SUCCEEDED] . 2020.12.19 15:01:59 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.35.70.115/255.255.255.0 on interface {1B7CF9A9-83C9-4156-8020-597EB10B973E} [DHCP-serv: 10.35.70.254, lease-time: 31536000] . 2020.12.19 15:01:59 - OpenVPN > Successful ARP Flush on interface [4] {1B7CF9A9-83C9-4156-8020-597EB10B973E} . 2020.12.19 15:02:00 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=4 fde6:7a:7d20:1f46::1071 store=active . 2020.12.19 15:02:01 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Local Area Connection static fde6:7a:7d20:1f46::1 validate=no . 2020.12.19 15:02:01 - Shell(11) of 'C:\windows\system32\route.exe', 2 args: '-6';'PRINT'; . 2020.12.19 15:02:01 - Shell(11) done in 31 ms, exit: 0, out: '=========================================================================== . 2020.12.19 15:02:01 - Interface List . 2020.12.19 15:02:01 - 15...10 05 01 46 1d 37 ......Realtek PCIe GBE Family Controller . 2020.12.19 15:02:01 - 4...00 ff 1b 7c f9 a9 ......TAP-Windows Adapter V9 . 2020.12.19 15:02:01 - 5...f4 96 34 d2 71 b2 ......Microsoft Wi-Fi Direct Virtual Adapter . 2020.12.19 15:02:01 - 16...f4 96 34 d2 71 b1 ......Intel(R) Dual Band Wireless-AC 3168 . 2020.12.19 15:02:01 - 14...f4 96 34 d2 71 b5 ......Bluetooth Device (Personal Area Network) . 2020.12.19 15:02:01 - 1...........................Software Loopback Interface 1 . 2020.12.19 15:02:01 - =========================================================================== . 2020.12.19 15:02:01 - IPv6 Route Table . 2020.12.19 15:02:01 - =========================================================================== . 2020.12.19 15:02:01 - Active Routes: . 2020.12.19 15:02:01 - If Metric Network Destination Gateway . 2020.12.19 15:02:01 - 15 281 ::/0 fe80::3e04:61ff:fee2:c162 . 2020.12.19 15:02:01 - 1 331 ::1/128 On-link . 2020.12.19 15:02:01 - 15 281 2600:8801:100:e90::/64 On-link . 2020.12.19 15:02:01 - 15 281 2600:8801:100:e90:383b:b7cd:acaf:48a4/128 . 2020.12.19 15:02:01 - On-link . 2020.12.19 15:02:01 - 15 281 2600:8801:100:e90:3c88:5725:8530:c428/128 . 2020.12.19 15:02:01 - On-link . 2020.12.19 15:02:01 - 4 281 2606:9580:103:a:fda7:1f4c:8c40:8c3e/128 . 2020.12.19 15:02:01 - fde6:7a:7d20:be6::1 . 2020.12.19 15:02:01 - 4 281 fde6:7a:7d20:1f46::/64 fe80::8 . 2020.12.19 15:02:01 - 4 281 fe80::/64 On-link . 2020.12.19 15:02:01 - 15 281 fe80::/64 On-link . 2020.12.19 15:02:01 - 4 281 fe80::1c7c:68c1:fb88:8fb/128 . 2020.12.19 15:02:01 - On-link . 2020.12.19 15:02:01 - 15 281 fe80::383b:b7cd:acaf:48a4/128 . 2020.12.19 15:02:01 - On-link . 2020.12.19 15:02:01 - 1 331 ff00::/8 On-link . 2020.12.19 15:02:01 - 4 281 ff00::/8 On-link . 2020.12.19 15:02:01 - 15 281 ff00::/8 On-link . 2020.12.19 15:02:01 - =========================================================================== . 2020.12.19 15:02:01 - Persistent Routes: . 2020.12.19 15:02:01 - If Metric Network Destination Gateway . 2020.12.19 15:02:01 - 0 4294967295 2606:9580:103:a:fda7:1f4c:8c40:8c3e/128 . 2020.12.19 15:02:01 - fde6:7a:7d20:be6::1 . 2020.12.19 15:02:01 - ===========================================================================' . 2020.12.19 15:02:01 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1f46::/64 -> fde6:7a:7d20:1f46::1071 metric 0) dev Local Area Connection . 2020.12.19 15:02:01 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1f46::/64 interface=4 fe80::8 store=active . 2020.12.19 15:02:01 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.12.19 15:02:06 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2020.12.19 15:02:06 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.30.89.69 MASK 255.255.255.255 192.168.0.1 . 2020.12.19 15:02:06 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.12.19 15:02:06 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.12.19 15:02:06 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.35.70.1 . 2020.12.19 15:02:06 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.12.19 15:02:06 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.12.19 15:02:06 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.35.70.1 . 2020.12.19 15:02:06 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.12.19 15:02:06 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.12.19 15:02:06 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1f46::1 metric -1) dev Local Area Connection . 2020.12.19 15:02:06 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=4 fe80::8 store=active . 2020.12.19 15:02:06 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.12.19 15:02:06 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1f46::1 metric -1) dev Local Area Connection . 2020.12.19 15:02:06 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=4 fe80::8 store=active . 2020.12.19 15:02:06 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.12.19 15:02:06 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1f46::1 metric -1) dev Local Area Connection . 2020.12.19 15:02:06 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=4 fe80::8 store=active . 2020.12.19 15:02:06 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.12.19 15:02:06 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1f46::1 metric -1) dev Local Area Connection . 2020.12.19 15:02:06 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=4 fe80::8 store=active . 2020.12.19 15:02:06 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.12.19 15:02:06 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4 . 2020.12.19 15:02:06 - Elevated: Command:set-interface-metric . 2020.12.19 15:02:06 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6 . 2020.12.19 15:02:06 - Elevated: Command:set-interface-metric . 2020.12.19 15:02:06 - Elevated: Command:wfp . 2020.12.19 15:02:06 - Above log line repeated 5 times more . 2020.12.19 15:02:06 - DNS leak protection with packet filtering enabled. . 2020.12.19 15:02:06 - Shell(12) of 'C:\windows\system32\route.exe', 2 args: '-4';'PRINT'; . 2020.12.19 15:02:06 - Shell(12) done in 78 ms, exit: 0, out: '=========================================================================== . 2020.12.19 15:02:06 - Interface List . 2020.12.19 15:02:06 - 4...00 ff 1b 7c f9 a9 ......TAP-Windows Adapter V9 . 2020.12.19 15:02:06 - 15...10 05 01 46 1d 37 ......Realtek PCIe GBE Family Controller . 2020.12.19 15:02:06 - 5...f4 96 34 d2 71 b2 ......Microsoft Wi-Fi Direct Virtual Adapter . 2020.12.19 15:02:06 - 16...f4 96 34 d2 71 b1 ......Intel(R) Dual Band Wireless-AC 3168 . 2020.12.19 15:02:06 - 14...f4 96 34 d2 71 b5 ......Bluetooth Device (Personal Area Network) . 2020.12.19 15:02:06 - 1...........................Software Loopback Interface 1 . 2020.12.19 15:02:06 - =========================================================================== . 2020.12.19 15:02:06 - IPv4 Route Table . 2020.12.19 15:02:06 - =========================================================================== . 2020.12.19 15:02:06 - Active Routes: . 2020.12.19 15:02:06 - Network Destination Netmask Gateway Interface Metric . 2020.12.19 15:02:06 - 0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.2 25 . 2020.12.19 15:02:06 - 0.0.0.0 128.0.0.0 10.35.70.1 10.35.70.115 3 . 2020.12.19 15:02:06 - 10.35.70.0 255.255.255.0 On-link 10.35.70.115 259 . 2020.12.19 15:02:06 - 10.35.70.115 255.255.255.255 On-link 10.35.70.115 259 . 2020.12.19 15:02:06 - 10.35.70.255 255.255.255.255 On-link 10.35.70.115 259 . 2020.12.19 15:02:06 - 127.0.0.0 255.0.0.0 On-link 127.0.0.1 331 . 2020.12.19 15:02:06 - 127.0.0.1 255.255.255.255 On-link 127.0.0.1 331 . 2020.12.19 15:02:06 - 127.255.255.255 255.255.255.255 On-link 127.0.0.1 331 . 2020.12.19 15:02:06 - 128.0.0.0 128.0.0.0 10.35.70.1 10.35.70.115 3 . 2020.12.19 15:02:06 - 192.30.89.69 255.255.255.255 192.168.0.1 192.168.0.2 25 . 2020.12.19 15:02:06 - 192.168.0.0 255.255.255.0 On-link 192.168.0.2 281 . 2020.12.19 15:02:06 - 192.168.0.2 255.255.255.255 On-link 192.168.0.2 281 . 2020.12.19 15:02:06 - 192.168.0.255 255.255.255.255 On-link 192.168.0.2 281 . 2020.12.19 15:02:06 - 224.0.0.0 240.0.0.0 On-link 127.0.0.1 331 . 2020.12.19 15:02:06 - 224.0.0.0 240.0.0.0 On-link 10.35.70.115 259 . 2020.12.19 15:02:06 - 224.0.0.0 240.0.0.0 On-link 192.168.0.2 281 . 2020.12.19 15:02:06 - 255.255.255.255 255.255.255.255 On-link 127.0.0.1 331 . 2020.12.19 15:02:06 - 255.255.255.255 255.255.255.255 On-link 10.35.70.115 259 . 2020.12.19 15:02:06 - 255.255.255.255 255.255.255.255 On-link 192.168.0.2 281 . 2020.12.19 15:02:06 - =========================================================================== . 2020.12.19 15:02:06 - Persistent Routes: . 2020.12.19 15:02:06 - None' . 2020.12.19 15:02:06 - Shell(13) of 'C:\windows\system32\route.exe', 2 args: '-6';'PRINT'; . 2020.12.19 15:02:06 - Shell(13) done in 31 ms, exit: 0, out: '=========================================================================== . 2020.12.19 15:02:06 - Interface List . 2020.12.19 15:02:06 - 4...00 ff 1b 7c f9 a9 ......TAP-Windows Adapter V9 . 2020.12.19 15:02:06 - 15...10 05 01 46 1d 37 ......Realtek PCIe GBE Family Controller . 2020.12.19 15:02:06 - 5...f4 96 34 d2 71 b2 ......Microsoft Wi-Fi Direct Virtual Adapter . 2020.12.19 15:02:06 - 16...f4 96 34 d2 71 b1 ......Intel(R) Dual Band Wireless-AC 3168 . 2020.12.19 15:02:06 - 14...f4 96 34 d2 71 b5 ......Bluetooth Device (Personal Area Network) . 2020.12.19 15:02:06 - 1...........................Software Loopback Interface 1 . 2020.12.19 15:02:06 - =========================================================================== . 2020.12.19 15:02:06 - IPv6 Route Table . 2020.12.19 15:02:06 - =========================================================================== . 2020.12.19 15:02:06 - Active Routes: . 2020.12.19 15:02:06 - If Metric Network Destination Gateway . 2020.12.19 15:02:06 - 15 281 ::/0 fe80::3e04:61ff:fee2:c162 . 2020.12.19 15:02:06 - 4 259 ::/3 fe80::8 . 2020.12.19 15:02:06 - 1 331 ::1/128 On-link . 2020.12.19 15:02:06 - 4 259 2000::/4 fe80::8 . 2020.12.19 15:02:06 - 15 281 2600:8801:100:e90::/64 On-link . 2020.12.19 15:02:06 - 15 281 2600:8801:100:e90:383b:b7cd:acaf:48a4/128 . 2020.12.19 15:02:06 - On-link . 2020.12.19 15:02:06 - 15 281 2600:8801:100:e90:3c88:5725:8530:c428/128 . 2020.12.19 15:02:06 - On-link . 2020.12.19 15:02:06 - 4 259 2606:9580:103:a:fda7:1f4c:8c40:8c3e/128 . 2020.12.19 15:02:06 - fde6:7a:7d20:be6::1 . 2020.12.19 15:02:06 - 4 259 3000::/4 fe80::8 . 2020.12.19 15:02:06 - 4 259 fc00::/7 fe80::8 . 2020.12.19 15:02:06 - 4 259 fde6:7a:7d20:1f46::/64 fe80::8 . 2020.12.19 15:02:06 - 4 259 fde6:7a:7d20:1f46::1071/128 . 2020.12.19 15:02:06 - On-link . 2020.12.19 15:02:06 - 4 259 fe80::/64 On-link . 2020.12.19 15:02:06 - 15 281 fe80::/64 On-link . 2020.12.19 15:02:06 - 4 259 fe80::1c7c:68c1:fb88:8fb/128 . 2020.12.19 15:02:06 - On-link . 2020.12.19 15:02:06 - 15 281 fe80::383b:b7cd:acaf:48a4/128 . 2020.12.19 15:02:06 - On-link . 2020.12.19 15:02:06 - 1 331 ff00::/8 On-link . 2020.12.19 15:02:06 - 4 259 ff00::/8 On-link . 2020.12.19 15:02:06 - 15 281 ff00::/8 On-link . 2020.12.19 15:02:06 - =========================================================================== . 2020.12.19 15:02:06 - Persistent Routes: . 2020.12.19 15:02:06 - If Metric Network Destination Gateway . 2020.12.19 15:02:06 - 0 4294967295 2606:9580:103:a:fda7:1f4c:8c40:8c3e/128 . 2020.12.19 15:02:06 - fde6:7a:7d20:be6::1 . 2020.12.19 15:02:06 - ===========================================================================' . 2020.12.19 15:02:06 - Elevated: Command:route . 2020.12.19 15:02:06 - Routes, added a new route, 192.30.89.67 for gateway 10.35.70.1 . 2020.12.19 15:02:06 - Elevated: Command:route . 2020.12.19 15:02:06 - Routes, added a new route, 2606:9580:100:e:d075:a67e:1f9c:139d for gateway fde6:7a:7d20:1f46::1 . 2020.12.19 15:02:06 - Flushing DNS . 2020.12.19 15:02:06 - Elevated: Command:dns-flush . 2020.12.19 15:02:06 - Shell(14) of 'C:\windows\system32\ipconfig.exe', 1 args: '/flushdns'; . 2020.12.19 15:02:06 - Shell(14) done in 15 ms, exit: 0, out: 'Windows IP Configuration . 2020.12.19 15:02:06 - Successfully flushed the DNS Resolver Cache.' I 2020.12.19 15:02:06 - Checking route IPv4 I 2020.12.19 15:02:07 - Checking route IPv6 I 2020.12.19 15:02:10 - Checking DNS ! 2020.12.19 15:02:11 - Connected. . 2020.12.19 15:02:11 - OpenVPN > Initialization Sequence Completed . 2020.12.19 15:31:11 - Collect information about AirVPN completed . 2020.12.19 15:56:43 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.19 15:56:43 - OpenVPN > VERIFY KU OK . 2020.12.19 15:56:43 - OpenVPN > Validating certificate extended key usage . 2020.12.19 15:56:43 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.19 15:56:43 - OpenVPN > VERIFY EKU OK . 2020.12.19 15:56:43 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Nahn, emailAddress=info@airvpn.org . 2020.12.19 15:56:43 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 15:56:43 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 15:56:43 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.19 16:01:19 - Collect information about AirVPN completed . 2020.12.19 16:51:29 - Above log line repeated 1 times more . 2020.12.19 16:51:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.19 16:51:29 - OpenVPN > VERIFY KU OK . 2020.12.19 16:51:29 - OpenVPN > Validating certificate extended key usage . 2020.12.19 16:51:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.19 16:51:29 - OpenVPN > VERIFY EKU OK . 2020.12.19 16:51:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Nahn, emailAddress=info@airvpn.org . 2020.12.19 16:51:30 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 16:51:30 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 16:51:30 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.19 17:01:30 - Collect information about AirVPN completed . 2020.12.19 17:46:15 - Above log line repeated 1 times more . 2020.12.19 17:46:15 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.19 17:46:15 - OpenVPN > VERIFY KU OK . 2020.12.19 17:46:15 - OpenVPN > Validating certificate extended key usage . 2020.12.19 17:46:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.19 17:46:15 - OpenVPN > VERIFY EKU OK . 2020.12.19 17:46:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Nahn, emailAddress=info@airvpn.org . 2020.12.19 17:46:16 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 17:46:16 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 17:46:16 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.19 18:01:33 - Collect information about AirVPN completed . 2020.12.19 18:41:01 - Above log line repeated 1 times more . 2020.12.19 18:41:01 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.19 18:41:01 - OpenVPN > VERIFY KU OK . 2020.12.19 18:41:01 - OpenVPN > Validating certificate extended key usage . 2020.12.19 18:41:01 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.19 18:41:01 - OpenVPN > VERIFY EKU OK . 2020.12.19 18:41:01 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Nahn, emailAddress=info@airvpn.org . 2020.12.19 18:41:02 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 18:41:02 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 18:41:02 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.19 19:01:51 - Collect information about AirVPN completed . 2020.12.19 19:35:47 - Above log line repeated 1 times more . 2020.12.19 19:35:47 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.19 19:35:47 - OpenVPN > VERIFY KU OK . 2020.12.19 19:35:47 - OpenVPN > Validating certificate extended key usage . 2020.12.19 19:35:47 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.19 19:35:47 - OpenVPN > VERIFY EKU OK . 2020.12.19 19:35:47 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Nahn, emailAddress=info@airvpn.org . 2020.12.19 19:35:47 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 19:35:47 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 19:35:47 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.19 20:02:05 - Collect information about AirVPN completed . 2020.12.19 20:30:32 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.19 20:30:32 - OpenVPN > VERIFY KU OK . 2020.12.19 20:30:32 - OpenVPN > Validating certificate extended key usage . 2020.12.19 20:30:32 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.19 20:30:32 - OpenVPN > VERIFY EKU OK . 2020.12.19 20:30:32 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Nahn, emailAddress=info@airvpn.org . 2020.12.19 20:30:33 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 20:30:33 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 20:30:33 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.19 20:32:11 - Collect information about AirVPN completed . 2020.12.19 21:25:18 - Above log line repeated 1 times more . 2020.12.19 21:25:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.19 21:25:18 - OpenVPN > VERIFY KU OK . 2020.12.19 21:25:18 - OpenVPN > Validating certificate extended key usage . 2020.12.19 21:25:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.19 21:25:18 - OpenVPN > VERIFY EKU OK . 2020.12.19 21:25:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Nahn, emailAddress=info@airvpn.org . 2020.12.19 21:25:18 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 21:25:18 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.19 21:25:18 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2020.12.19 21:32:21 - Collect information about AirVPN completed ---------------------------- Network Interfaces and Routes: { "support_ipv4": true, "support_ipv6": true, "routes": [ { "address": "0.0.0.0\/0", "interface": "{6E519A10-E748-44BE-A266-11D9755D84A8}", "gateway": "192.168.0.1", "metric": "25" }, { "address": "0.0.0.0\/1", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "10.35.70.1", "metric": "3" }, { "address": "10.35.70.0\/24", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "link", "metric": "259" }, { "address": "10.35.70.115", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "link", "metric": "259" }, { "address": "10.35.70.255", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "link", "metric": "259" }, { "address": "127.0.0.0\/8", "interface": "{E7289E53-6ADC-11E9-8064-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.0.0.1", "interface": "{E7289E53-6ADC-11E9-8064-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.255.255.255", "interface": "{E7289E53-6ADC-11E9-8064-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "128.0.0.0\/1", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "10.35.70.1", "metric": "3" }, { "address": "192.30.89.67", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "10.35.70.1", "metric": "4" }, { "address": "192.30.89.69", "interface": "{6E519A10-E748-44BE-A266-11D9755D84A8}", "gateway": "192.168.0.1", "metric": "25" }, { "address": "192.168.0.0\/24", "interface": "{6E519A10-E748-44BE-A266-11D9755D84A8}", "gateway": "link", "metric": "281" }, { "address": "192.168.0.2", "interface": "{6E519A10-E748-44BE-A266-11D9755D84A8}", "gateway": "link", "metric": "281" }, { "address": "192.168.0.255", "interface": "{6E519A10-E748-44BE-A266-11D9755D84A8}", "gateway": "link", "metric": "281" }, { "address": "224.0.0.0\/4", "interface": "{E7289E53-6ADC-11E9-8064-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "224.0.0.0\/4", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "link", "metric": "259" }, { "address": "224.0.0.0\/4", "interface": "{6E519A10-E748-44BE-A266-11D9755D84A8}", "gateway": "link", "metric": "281" }, { "address": "255.255.255.255", "interface": "{E7289E53-6ADC-11E9-8064-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "255.255.255.255", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "link", "metric": "259" }, { "address": "255.255.255.255", "interface": "{6E519A10-E748-44BE-A266-11D9755D84A8}", "gateway": "link", "metric": "281" }, { "address": "::\/0", "interface": "{6E519A10-E748-44BE-A266-11D9755D84A8}", "gateway": "fe80::3e04:61ff:fee2:c162", "metric": "281" }, { "address": "::\/3", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "fe80::8", "metric": "259" }, { "address": "::1", "interface": "{E7289E53-6ADC-11E9-8064-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "2000::\/4", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "fe80::8", "metric": "259" }, { "address": "2600:8801:100:e90::\/64", "interface": "{6E519A10-E748-44BE-A266-11D9755D84A8}", "gateway": "link", "metric": "281" }, { "address": "2600:8801:100:e90:383b:b7cd:acaf:48a4", "interface": "{6E519A10-E748-44BE-A266-11D9755D84A8}", "gateway": "link", "metric": "281" }, { "address": "2600:8801:100:e90:3c88:5725:8530:c428", "interface": "{6E519A10-E748-44BE-A266-11D9755D84A8}", "gateway": "link", "metric": "281" }, { "address": "2606:9580:100:e:d075:a67e:1f9c:139d", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "fde6:7a:7d20:1f46::1", "metric": "259" }, { "address": "2606:9580:103:a:fda7:1f4c:8c40:8c3e", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "fde6:7a:7d20:be6::1", "metric": "259" }, { "address": "3000::\/4", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "fe80::8", "metric": "259" }, { "address": "fc00::\/7", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "fe80::8", "metric": "259" }, { "address": "fde6:7a:7d20:1f46::\/64", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "fe80::8", "metric": "259" }, { "address": "fde6:7a:7d20:1f46::1071", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "link", "metric": "259" }, { "address": "fe80::\/64", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "link", "metric": "259" }, { "address": "fe80::\/64", "interface": "{6E519A10-E748-44BE-A266-11D9755D84A8}", "gateway": "link", "metric": "281" }, { "address": "fe80::1c7c:68c1:fb88:8fb", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "link", "metric": "259" }, { "address": "fe80::383b:b7cd:acaf:48a4", "interface": "{6E519A10-E748-44BE-A266-11D9755D84A8}", "gateway": "link", "metric": "281" }, { "address": "ff00::\/8", "interface": "{E7289E53-6ADC-11E9-8064-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "ff00::\/8", "interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "gateway": "link", "metric": "259" }, { "address": "ff00::\/8", "interface": "{6E519A10-E748-44BE-A266-11D9755D84A8}", "gateway": "link", "metric": "281" }, { "address": "2606:9580:103:a:fda7:1f4c:8c40:8c3e", "gateway": "fde6:7a:7d20:be6::1", "metric": "4294967295" }, { "address": "2606:9580:100:e:d075:a67e:1f9c:139d", "gateway": "fde6:7a:7d20:1f46::1", "metric": "4294967295" } ], "interfaces": [ { "friendly": "Local Area Connection", "id": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "name": "Local Area Connection", "description": "TAP-Windows Adapter V9", "type": "53", "status": "Up", "bytes_received": "3649266239", "bytes_sent": "183486188", "support_ipv4": true, "support_ipv6": true, "ips": [ "fde6:7a:7d20:1f46::1071", "fe80::1c7c:68c1:fb88:8fb", "10.35.70.115" ], "gateways": [ "10.35.70.1", "fe80::8", "fde6:7a:7d20:1f46::1", "fde6:7a:7d20:be6::1" ], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Ethernet", "id": "{6E519A10-E748-44BE-A266-11D9755D84A8}", "name": "Ethernet", "description": "Realtek PCIe GBE Family Controller", "type": "Ethernet", "status": "Up", "bytes_received": "3836910338", "bytes_sent": "290924306", "support_ipv4": true, "support_ipv6": true, "ips": [ "2600:8801:100:e90:383b:b7cd:acaf:48a4", "2600:8801:100:e90:3c88:5725:8530:c428", "fe80::383b:b7cd:acaf:48a4", "192.168.0.2" ], "gateways": [ "192.168.0.1", "fe80::3e04:61ff:fee2:c162" ], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Local Area Connection* 1", "id": "{2A521883-1792-4639-92A4-C1E00277A627}", "name": "Local Area Connection* 1", "description": "Microsoft Wi-Fi Direct Virtual Adapter", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::ddc5:4e18:7dfe:c017", "169.254.192.23" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Wi-Fi", "id": "{76C0C723-52CD-4538-A0B7-E52C7A7A9B48}", "name": "Wi-Fi", "description": "Intel(R) Dual Band Wireless-AC 3168", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::7c41:9506:9a32:ed34", "169.254.237.52" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Bluetooth Network Connection", "id": "{6D6D5ED0-37CB-4017-AAD1-3C9E5959019B}", "name": "Bluetooth Network Connection", "description": "Bluetooth Device (Personal Area Network)", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::e191:abc8:73b3:7be8", "169.254.123.232" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Loopback Pseudo-Interface 1", "id": "{E7289E53-6ADC-11E9-8064-806E6F6E6963}", "name": "Loopback Pseudo-Interface 1", "description": "Software Loopback Interface 1", "type": "Loopback", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "::1", "127.0.0.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null } ], "ipv4-default-gateway": "10.35.70.1", "ipv4-default-interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}", "ipv6-default-gateway": "fe80::8", "ipv6-default-interface": "{1B7CF9A9-83C9-4156-8020-597EB10B973E}" } ---------------------------- ipconfig /all: Windows IP Configuration Host Name . . . . . . . . . . . . : DESKTOP-6E170PF Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No Unknown adapter Local Area Connection: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : TAP-Windows Adapter V9 Physical Address. . . . . . . . . : 00-FF-1B-7C-F9-A9 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv6 Address. . . . . . . . . . . : fde6:7a:7d20:1f46::1071(Preferred) Link-local IPv6 Address . . . . . : fe80::1c7c:68c1:fb88:8fb%4(Preferred) IPv4 Address. . . . . . . . . . . : 10.35.70.115(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Saturday, December 19, 2020 3:01:59 PM Lease Expires . . . . . . . . . . : Sunday, December 19, 2021 3:01:59 PM Default Gateway . . . . . . . . . : DHCP Server . . . . . . . . . . . : 10.35.70.254 DHCPv6 IAID . . . . . . . . . . . : 620822299 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-24-59-52-25-10-05-01-46-1D-37 DNS Servers . . . . . . . . . . . : fde6:7a:7d20:1f46::1 10.35.70.1 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Ethernet: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller Physical Address. . . . . . . . . : 10-05-01-46-1D-37 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv6 Address. . . . . . . . . . . : 2600:8801:100:e90:383b:b7cd:acaf:48a4(Preferred) Temporary IPv6 Address. . . . . . : 2600:8801:100:e90:3c88:5725:8530:c428(Preferred) Link-local IPv6 Address . . . . . : fe80::383b:b7cd:acaf:48a4%15(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.0.2(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Saturday, December 19, 2020 9:15:15 AM Lease Expires . . . . . . . . . . : Saturday, December 19, 2020 10:31:13 PM Default Gateway . . . . . . . . . : fe80::3e04:61ff:fee2:c162%15 192.168.0.1 DHCP Server . . . . . . . . . . . : 192.168.0.1 DHCPv6 IAID . . . . . . . . . . . : 152044801 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-24-59-52-25-10-05-01-46-1D-37 DNS Servers . . . . . . . . . . . : 2001:578:3f::30 2001:578:3f:1::30 68.105.28.11 68.105.29.11 68.105.28.12 NetBIOS over Tcpip. . . . . . . . : Enabled Wireless LAN adapter Local Area Connection* 1: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter Physical Address. . . . . . . . . : F4-96-34-D2-71-B2 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Wi-Fi: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 3168 Physical Address. . . . . . . . . : F4-96-34-D2-71-B1 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Ethernet adapter Bluetooth Network Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) Physical Address. . . . . . . . . : F4-96-34-D2-71-B5 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Edited ... by OpenSourcerer Apply LOG format to system report Quote Share this post Link to post
stok 0 Posted ... Also, maybe being closer to my actual server would help rather than connecting to USEast? (I'll try to select Phoenix next time and see if this changes anything.) Quote Share this post Link to post
stok 0 Posted ... (edited) All good now, I think I just have to upgrade my modem and get an new router. Thanks! 👍 (Our Internet Provider said the connections are stable, so I just believe its the modem.) Edited ... by stok Quote Share this post Link to post
