Bilru 0 Posted ... So I am travelling to Egypt soon and they block all OpenVPN connections from what I've read, but stunnel is supposed to be working. How do I set this up through Eddie on Ubuntu? I read the guide and it just saidSelect AirVPN menu -> Preferences -> Protocols. Select one of the SSL Tunnel options. Click Save. I went into protocols and I don't see anything about SSL tunnels. I only see ports I can choose, I know SSL works over port 443. Will simply selecting port 443 work in circumventing the VPN block? Or is there something else I need to do? Quote Share this post Link to post
Tech Jedi Alex 1527 Posted ... In Preferences > Protocols, unselect Automatic, then you can scroll in the list below. 1 Bilru reacted to this Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Staff 10483 Posted ... @Bilru Hello! A month ago a long time customer of us from Egypt told us that protocol TCP to port 443 of entry-IP address three is the quickest way he found to bypass Egypt ISP blocks. Worth a try, probably that connection mode is still effective. It would save you the overhead caused by an additional tunnel. Kind regards Quote Share this post Link to post
y6VXvOOoO0uN 0 Posted ... On 11/6/2020 at 3:37 PM, Staff said: @Bilru Hello! A month ago a long time customer of us from Egypt told us that protocol TCP to port 443 of entry-IP address three is the quickest way he found to bypass Egypt ISP blocks. Worth a try, probably that connection mode is still effective. It would save you the overhead caused by an additional tunnel. Kind regards Is this method still applicable for bypassing the block? I live in Egypt and I used to use other VPN using ovenpn over obfs to bypass the blocks but it made it unusable because of added latency and lost speed. Quote Share this post Link to post
AhmadRehan98 0 Posted ... On 2/2/2022 at 11:01 PM, y6VXvOOoO0uN said: On 11/6/2020 at 3:37 PM, Staff said: @Bilru Hello! A month ago a long time customer of us from Egypt told us that protocol TCP to port 443 of entry-IP address three is the quickest way he found to bypass Egypt ISP blocks. Worth a try, probably that connection mode is still effective. It would save you the overhead caused by an additional tunnel. Kind regards Is this method still applicable for bypassing the block? I live in Egypt and I used to use other VPN using ovenpn over obfs to bypass the blocks but it made it unusable because of added latency and lost speed. It's working but ping is a bit unstable Quote Share this post Link to post
go558a83nk 383 Posted ... Does anybody know if Egypt is like some other countries that have stifled VPN usage in that VPN seems to work on some ISPs but on others they don't? Quote Share this post Link to post
