Not connected, Your IP: 216.73.216.118
ellert
Stunnel + Hummingbird
Not by itself, but you can connect Hummingbird locally after you have established a tunnel by stunnel to our servers. In order to do so please see here:
https://airvpn.org/ssl/
Please test connections in TLS Crypt and TCP first. TLS crypt, combined with TCP; has mainly made OpenVPN over stunnel obsolete: it has the same block circumvention abilities and provides higher performance. Only if TLS Crypt fails test OpenVPN over stunel (if it fails too, test OpenVPN over SSH). https://airvpn.org/ssh
Note: if you are not in a restrictive network do not add a second tunnel, which decreases performance, and work in UDP. which is more efficient for OpenVPN.
