Anyone know how to set up a Raspberry Pi to give a double hop VPN?  I've set PiVPN up and can get secure encryption back to my home network, but my traffic leaves the home network without VPN/Unencrypted.
I just can't get my head around how  would set it up.
PS I need it to be easy. I'm an absolute beginner.
I have a Netgear DM200 Modem in router mode connected through an apple time machine, then through a Netgear 8 way unmanaged switch, then to 5 wired connections to Airport Extremes in different rooms.  All of the Apple products are set in Bridge Mode.  My Raspberry Pi 4 is running the full install of Raspberry OS, has Netalk installed and shares a hard drive to my other devices through the USB 3.0 connection.  I currently have piVPN installed with Wireguard, and its configured to work with PiHole.
I have set my DNS on the Netgear DM200 to the local IP address of the Pi.  The Netgear Router is set up as a DHCP Server and it gives a reserved local IP address to the RaspPi.
Any help/advice appreciated!!!!
I don't see you as an absolute beginner if you pulled all that off while using certain expressions normally unknown to beginners to describe it.
Did I understand it right that you want to connect to your home network from the outside so that you can use the internet via AirVPN? Why don't you use AirVPN directly instead?
