paintballdude11
Prevent Leaks with Linux Iptables modified script
Found some code on here to prevent leaks in linux using iptables and modified it, it's a little more user friendly now. Feedback and or any bug fixes/suggestions would be appreciated.
1) copy and paste the code below into a file, name it anything with the file extension .sh.
i.e.: droppackets.sh
2) open terminal & type: chmod +x droppackets.sh
3) to run type in terminal: sudo ./droppackets.sh eth vega
that's it.
#!/bin/sh
vpnnameinput="$2"
vpnname1="aquarii"
vpnname2="geminorum"
vpnname3="omicron"
vpnname4="tauri"
vpnname5="bootis"
vpnname6="cassiopeia"
vpnname7="herculis"
vpnname8="castor"
vpnname9="leonis"
vpnname10="leporis"
vpnname11="lyra"
vpnname12="orionis"
vpnname13="serpentis"
vpnname14="arietis"
vpnname15="librae"
vpnname16="sirius"
vpnname17="vega"
lannameinput="$1"
lanname1="eth"
lanname2="wlan"
if [ -z "$lannameinput" ] ; then
echo "Please choose a network interface."
echo -e "i.e.: \tsudo $0 eth server\n\tsudo $0 wlan server"
#"wlan or eth?"
exit 1
fi
if [ "${1,,}" == "$lanname1" ]
then
echo "Network interface: ${1,,}"
lanname="eth"
elif [ "${1,,}" == "$lanname2" ]
then
lanname="wlan"
else
exit 1
fi
if [ -z "$vpnnameinput" ] ; then
echo -e "Or: \tsudo $0 $lanname Aquarii\n\tsudo $0 $lanname Geminorum\n\tsudo $0 $lanname Omicron\n\tsudo $0 $lanname Tauri\n\tsudo $0 $lanname Bootis\n\tsudo $0 $lanname Cassiopeia\n\tsudo $0 $lanname Herculis\n\tsudo $0 $lanname Castor\n\tsudo $0 $lanname Leonis\n\tsudo $0 $lanname Leporis\n\tsudo $0 $lanname Lyra\n\tsudo $0 $lanname Orionis\n\tsudo $0 $lanname Serpentis\n\tsudo $0 $lanname Arietis\n\tsudo $0 $lanname Librae\n\tsudo $0 $lanname Sirius\n\tsudo $0 $lanname Vega"
#"wlan or eth?"
exit 1
fi
if [ "${vpnnameinput,,}" == "$vpnname1" ]
then
#aquarii
echo "VPN Server: ${2,,}"
ipAddr=92.42.186.167
elif [ "${vpnnameinput,,}" == "$vpnname2" ]
then
#geminorum
ipAddr=37.235.51.133
elif [ "${vpnnameinput,,}" == "$vpnname3" ]
then
#omicron
ipAddr=89.149.226.185
elif [ "${vpnnameinput,,}" == "$vpnname4" ]
then
#tauri
ipAddr=95.211.98.154
elif [ "${vpnnameinput,,}" == "$vpnname5" ]
then
#bootis
elif [ "${vpnnameinput,,}" == "$vpnname6" ]
then
#Cassiopeia
ipAddr=31.193.12.98
elif [ "${vpnnameinput,,}" == "$vpnname7" ]
then
#Herculis
ipAddr=94.242.205.234
elif [ "${vpnnameinput,,}" == "$vpnname8" ]
then
#Castor
ipAddr=95.211.169.3
elif [ "${vpnnameinput,,}" == "$vpnname9" ]
then
#Leonis
ipAddr=85.17.123.26
elif [ "${vpnnameinput,,}" == "$vpnname10" ]
then
#Leporis
ipAddr=95.211.191.33
elif [ "${vpnnameinput,,}" == "$vpnname11" ]
then
#Lyra
ipAddr=62.212.85.65
elif [ "${vpnnameinput,,}" == "$vpnname12" ]
then
#Orionis
elif [ "${vpnnameinput,,}" == "$vpnname13" ]
then
#Serpentis
ipAddr=178.248.30.131
elif [ "${vpnnameinput,,}" == "$vpnname14" ]
then
#Arietis
ipAddr=198.15.111.162
elif [ "${vpnnameinput,,}" == "$vpnname15" ]
then
#Librae
ipAddr=108.59.11.194
elif [ "${vpnnameinput,,}" == "$vpnname16" ]
then
#Sirius
ipAddr=108.59.8.147
elif [ "${vpnnameinput,,}" == "$vpnname17" ]
then
#Vega
ipAddr=69.163.36.66
else
echo "Please enter a valid server name"
exit 1
fi
### flush old ip tables ###
echo "Now Flushing old iptable rules"
iptables -F
iptables -X
iptables -t nat -F
iptables -t nat -X
iptables -t mangle -F
iptables -t mangle -X
### set new ip table rules, non-vpn drop packets ###
echo "Now Setting up tables for server: ${2,,}"
iptables -A INPUT -i lo -j ACCEPT
iptables -A OUTPUT -o lo -j ACCEPT #allow loopback access
iptables -A OUTPUT -d 255.255.255.255 -j ACCEPT #make sure you can communicate with any DHCP server
iptables -A INPUT -s 255.255.255.255 -j ACCEPT #make sure you can communicate with any DHCP server
iptables -A INPUT -s 192.168.0.0/16 -d 192.168.0.0/16 -j ACCEPT #make sure that you can communicate within your own network
iptables -A OUTPUT -s 192.168.0.0/16 -d 192.168.0.0/16 -j ACCEPT
iptables -A FORWARD -i "$lanname+" -o tun+ -j ACCEPT
iptables -A FORWARD -i tun+ -o "$lanname+" -j ACCEPT # make sure that eth+ and tun+ can communicate
iptables -t nat -A POSTROUTING -o tun+ -j MASQUERADE # in the POSTROUTING chain of the NAT table, map the tun+ interface outgoing packet IP address, cease examining rules and let the header be modified, so that we don't have to worry about ports or any other issue - please check this rule with care if you have already a NAT table in your chain
iptables -A OUTPUT -o "$lanname+" ! -d "$ipAddr" -j DROP # if destination for outgoing packet on eth+ is NOT a.b.c.d, drop the packet, so that nothing leaks if VPN disconnects
echo "Iptables now setup for server: ${2,,}"
echo "Done."
#end
exit 1
done
To flush your ip tables and allow non-vpn packets to flow again, do the same as above, but name the file something different such as maybe 'tableflush.sh'. Put the code below in the tableflush.sh file:
#!/bin/sh
iptables -F
iptables -X
iptables -t nat -F
iptables -t nat -X
Open terminal, type chmod +x tableflush.sh
type in terminal sudo ./tableflush.sh.
this will reset your iptables.
easiercode1.txt
