zvereva
0 DNS (100 errors) + Active Torrent not working
for the past 2 days IPLeak is resolving DNS verrryyy slowly and getting 0 results with 100 errors, while there are 2 DNS IP one each IPv4 and IPv6.
active torrent is not working as the link does not download anything.
I too experience DNS Address - 0 servers, 100 errors on IPLeak. Both IPv4 and IPv6 show addresses for AirVPN server in the Netherlands.
However dnsleaktest will show United Kingdom as 'Country'. This has lead to geographical blocking on a Dutch website I wanted to visit.
I've used both stable Eddie v2.18.9 and experimental Eddie v2.19.4 (Linux Debian/Ubuntu) and both have above described DNS problem!
It seems the fault '0 servers, 100 errors' is also present when connecting to other country AirVPN servers i.e. UK, Belgium, Germany. However those were reporting the correct country in dnsleaktest.
Note: that browsing the Internet could be done as per normal; except for the case where I tried to access the (Dutch) website that used geo-blocking due to wrong DNS server location being reported.
To answer my own post: I think 'DNS Address detection' broke on IPLeak (website) as the '0 servers, 100 errors' fault is also present without VPN.
Also on my mobile [network] IPLeak gives the above mentioned error. It may not be AirVPN related, after all. 🤷‍♂️
Other things I tried:
- rebooted my modem, router and computer
- restarted the DNS service on my computer
EDIT: IPLeak DNS Address detection is working normally, again!
3 hours ago, JasonBourne said:
nvm. I overlooked the pinned post in this forum. 🤦‍♂️ My bad.
And you are supposed to be Jason Bourne? :D
