sebalpatine
ANSWERED OpenVPN > Warning: route gateway is ambiguous
hello .
i have a little problem :
on my logs , it s written W ........ OpenVPN > Warning: route gateway is ambiguous: 192.......... (2 matches)
(i linked my phone in my vpn account ).
what does that mean?
thx for your answer
bst regrds
Two interfaces within the same IP range, maybe? Ethernet and WLAN connected to the same network?
2 hours ago, sebalpatine said:
hello .
thx for your answer
bst regrds
Just a thought. Did you set them up properly here? https://airvpn.org/devices/
ok
i found the problem : after the last windows update , my old wifi card was reconnected... also i had 2 wifi cards connected
thx very much
