itsmefloraluca
Time out problems using eddie or Open Vpn
system_vpn_lock: true
Just a remark: Since you are using Android 10, the VPN lock in Eddie is not needed. Consider setting up Always-On VPN option of Android and select Eddie as the VPN app. You will get a more sophisticated Network Lock this way.
system_pause_vpn_when_screen_is_off: true
This option is also potentially problematic in regard to your problem, but also as a whole. Everytime you turn off your screen, the VPN connection is disconnected, but not closed. This might provoke problems with connectivity.
As for the log output, did I get it right that you changed from WIFI to WIFI, as in, from one network to another and not WIFI to 3G/4G or vice versa?
Thank you giganerd for your input. I will try what you mentioned about Android 10. What you mentioned about if i changed wifi to wifi. When i'm not home i use my mobile 4G network and i put it on wifi when at home. Using wifi at home i can use eddie were as with my mobile phone 4G i have problems cant load pages timeouts. I used eddie on other phones didn't have 4G problem connections. Once again Thanks.
