blackbox0815 3 Posted ... Hello, I have installed a Kubuntu 20.04 here. Now I have included the sources for Eddie as usual and installed Eddie. If I start Eddie now it is no longer usable from the display. How do I get the whole thing under control? Thanks for your help in advance. :-) Quote Share this post Link to post
Tech Jedi Alex 1522 Posted ... This looks like something we've seen in the past. Something along the lines of "update KDE" or "update Mono" was the solution. I think it was the latter. Can't find the two threads anymore, though. Can you post the output of this? $ mono --version . Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
monstrocity 37 Posted ... If it's Mono related, try installing mono-devel or mono-complete. https://www.mono-project.com/download/stable/#download-lin You may have to uninstall / reinstall Eddie. Also, go for the latest beta, 2.19.4. Quote Share this post Link to post
blackbox0815 3 Posted ... OK the Packages mono-devel and mono-complete was no solution. Also after reinstalling Eddie. I've have the folowing mono version: blackbox@workstation-blackbox:~$ mono --version Mono JIT compiler version 6.8.0.105 (Debian 6.8.0.105+dfsg-2 Wed Feb 26 23:23:50 UTC 2020) Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com TLS: __thread SIGSEGV: altstack Notifications: epoll Architecture: amd64 Disabled: none Misc: softdebug Interpreter: yes LLVM: supported, not enabled. Suspend: hybrid GC: sgen (concurrent by default) blackbox@workstation-blackbox:~$ Coud it be the Bindings from Mono to GTK or QT? Quote Share this post Link to post
blackbox0815 3 Posted ... Possibly it is because of the package libnunit2.4-cil, that there was earlier but in the meantime it seems to have been merged into mono-devel. Quote Share this post Link to post
monstrocity 37 Posted ... I'd say it's a GTK or QT compatibility issue. I switched to Hummingbird full time recently, because of Eddie issues. It's nice having the GUI of Eddie (if it works properly), but Hummingbird is faster while consuming far fewer resources. There's a wrapper script for Hummingbird if you need a GUI to connect when you log in to your session. No Mono required either. Quote Share this post Link to post
blackbox0815 3 Posted ... Hm, with other xUbuntu 20.04 distributions it works fine. I have no experience with Hummingbird so far. Quote Share this post Link to post
monstrocity 37 Posted ... I run Linux Mint 20 Cinnamon. Eddie started freezing and sometimes crashing - never the blank ui like you posted though. I updated mono-devel and even tried mono-complete. Did the whole Eddie uninstall / reinstall routine. Anyway, if you want to try Hummingbirdhttps://airvpn.org/forums/topic/46764-hummingbird-110-released/?tab=comments#comment-108744 Hummingbird with wrapperhttps://airvpn.org/forums/topic/46717-interactive-wrapper-for-hummingbird-with-boot-script-and-default-network-lock/?tab=comments#comment-108443 Quote Share this post Link to post
